  4. Weboberfläche nicht mehr erreichbar.
    6.5k
16 Beiträge 5 Kommentatoren 1.8k Aufrufe 5 Beobachtet
  • A AlphaII
    @crunchip ok danke
    pi@raspberrypi-IOB:~ $ iobroker adapters
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start                                               Starts the js-controller
      iobroker stop                                                stops the js-controller
      iobroker restart                                             Restarts js-controller
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter
      iobroker install <adapter>                                   Installs a specified adapter
      iobroker rebuild <adapter>|self                              Rebuilds a specified adapter
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter from system
      iobroker del <adapter>.<instance>                            Remove adapter instance
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload                                              Upload management
      iobroker object                                              Object management
      iobroker state                                               State management
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter
    Options:
          --help     Show help  [boolean]
      -v, --version  Show version  [boolean]
    MOD-Edit: Code in code-tags gesetzt!
    AlphaII
    pi@raspberrypi-IOB:~ $ iobroker status
    Objects type: file
    States  type: file
    pi@raspberrypi-IOB:~ $ iobroker list adapters
    pi@raspberrypi-IOB:~ $ iobroker list instances
    + instance is alive
    • A AlphaII
      Objects type: file
      States  type: file
      + instance is alive
      AlphaII
      @alphaii Ich bitte nochmal um Entschuldigung. Weil jetzt nicht mehr angezeigt wurde, habe ich jetzt auch den fix mal laufen lassen:
      pi@raspberrypi-IOB:~ $ iobroker fix
      library: loaded
      Library version=2021-04-07
          Welcome to the ioBroker installation fixer!
          Script version: 2021-04-07
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:2 http://archive.raspberrypi.org/debian buster InRelease
      OK:3 https://deb.nodesource.com/node_12.x buster InRelease
      OK:4 https://phoscon.de/apt/deconz buster InRelease
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
      chown: der Eigentümer von '/opt/iobroker/iobroker-data/backup-objects/2021-07-01_11-30_states.json.gz' wird geändert: Die Struktur muss bereinigt werden
      This system does not support setting default permissions.
      Do not use npm to manually install adapters unless you know what you are doing!
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      Aber das Ergebnis ist das gleiche:
      pi@raspberrypi-IOB:~ $ iobroker start
      Objects type: file
      States  type: file
      + instance is alive
      • A AlphaII
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        Objects type: file
        States  type: file
        + instance is alive
        crunchipC Offline
        crunchipC Offline
        @alphaii irgendwas ist bei dir faul, da scheint nichts zu laufen, "leerer" iobroker ohne admin, ohne alles
          AlphaII
          @crunchip Wie funktioniert das?
          • A AlphaII
            crunchipC Offline
            crunchipC Offline
            @alphaii keine Ahnung
            • A AlphaII
              @thomas-braun ich bin leider nicht so fit und weiß daher nicht wie ich das Putty Bild kopiert bekomme.
              So ist es sicher nicht richtig. Bitte gib mir hierfür auch nochmal einen Tipp
              Objects type: file
              States  type: file
              Jan1
              @alphaii sagte in Weboberfläche nicht mehr erreichbar.:
              Objects type: file
              States type: file
              Trägt zwar nichts zur Problemlösung bei, aber mal ein bisschen Wissen erweitern kann auch nicht schaden ;)
              Putty ist ein Tool mit dem man ne Konsole öffnet, somit ist das schon mal kein Bild von Putty, sonder von der Konsole und dort gibts Text keine Bilder. Eine Konsole kannst auch ganz ohne Putty öffnen da das ja nur ein Werkzeug ist um etwas zu vereinfachen.
              Dann zum Problem, wenn so was sehr seltsames passiert, einfach Backup restoren und das nächste mal keine unüberlegten Dinge tun :)
              • J Jan1
                Objects type: file
                States type: file
                AlphaII
                @jan1 Danke
                  AlphaII
                  Ok ich werde dann mal einen Bachup machen.
                  • A AlphaII
                    Jan1
                    @alphaii
                    Dafür ist es jetzt zu spät, es sollte schon ein Backup vorhanden sein. Oder meinst ein Backup restoren?
                    Wenn ja, hier empfiehlt sich dann ein Vollrestor bei dem man vorher den IOBroker Ordner komplett löscht und mit nacktem IOBroker und dem Backitup Adapter das Backup restort.
                      einfach mit der Maus markieren (linke Taste gedrückt halten), danach mit rechter Taste einfügen
                      GOETSCHHOFER
                      @crunchip
                      Ich möchte wieder auf meinen alten RSP Pi3+ zugreifen, kann diesen aber über die Weboberfläche über die IP:8081 nicht mehr aufrufen. Zugriff funktioniert über die shell einwandfrei.
                      Hätte gestern schon update u. upgrade gemacht, ebenso iobroker fix.
                      Bei Abfrage mit instances, status und adapters bekomme ich folgende Info:
                      Danke für die Hilfe.
                      login as: pi
                      pi@192.168.1.160's password:
                      permitted by applicable law.
                      Last login: Sat Sep 11 09:51:41 2021 from pc-home-desktop-q6er4kb.fritz.box
                      pi@raspberrypi:~ $ iobroker status
                       Cannot read system.config: null (OK when migrating or restoring)
                       Cannot find view "system" for search "host"
                      Objects type: file
                      States  type: file
                      pi@raspberrypi:~ $ iobroker lsit adapters
                      iobroker [command]
                      Commands:
                        iobroker start                                               Starts the js-con        troller
                        iobroker stop                                                stops the js-cont        roller
                        iobroker restart                                             Restarts js-contr        oller
                        iobroker info                                                Shows the host in        fo
                        iobroker add <adapter> [desiredNumber]                       Add instance of a        dapter
                        iobroker install <adapter>                                   Installs a specif        ied adapter
                        iobroker rebuild <adapter>|self                              Rebuilds a specif        ied adapter
                        iobroker url <url> [<name>]                                  Install adapter f        rom specified url, e.g. GitHub
                        iobroker del <adapter>                                       Remove adapter fr        om system
                        iobroker del <adapter>.<instance>                            Remove adapter in        stance
                        iobroker upgrade                                             Upgrade managemen        t
                        iobroker message <adapter>[.instance] <command> [<message>]  Send message to a        dapter instance/s
                        iobroker chmod <mode> <file>                                 Change file right        s
                        iobroker chown <user> <group> <file>                         Change file owner        ship
                        iobroker set <adapter>.<instance>                            Change settings o        f adapter config
                        iobroker cert                                                Certificate manag        ement
                        iobroker clean <yes>                                         Clears all object        s and states
                        iobroker restore <backup name or path>                       Restore a specifi        ed backup
                        iobroker validate <backup name or path>                      Validate a specif        ied backup
                        iobroker status [all|<adapter>.<instance>]                   Status of ioBroke        r or adapter instance
                        iobroker repo [<name>]                                       Show repo informa        tion
                        iobroker unsetup                                             Reset license, in        stallation secret and language
                        iobroker fix                                                 Execute the insta        llation fixer script, this updates your ioBroker installation
                        iobroker multihost                                           Multihost managem        ent
                        iobroker compact                                             compact group man        agement
                        iobroker version [<adapter>]                                 Show version of j        s-controller or specified adapter
                      Options:
                      pi@raspberrypi:~ $ iobroker list instances
                      + instance is alive
                      Objects type: file
                      States  type: file
                      pi@raspberrypi:~ $
                      • G GOETSCHHOFER
                        @crunchip
                        login as: pi
                        Objects type: file
                        States  type: file
                        iobroker [command]
                        Commands:
                        Options:
                        + instance is alive
                        Objects type: file
                        States  type: file
                        pi@raspberrypi:~ $
                        crunchipC Offline
                        crunchipC Offline
                        @goetschhofer sagte in Weboberfläche nicht mehr erreichbar.:
                        hast dich verschrieben
                        da ist wohl was kaputt gegangen, gibt hier im Forum unzählige Threads dazu
