  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.9m Aufrufe 231 Beobachtet
  • Rene_HMR Rene_HM
    Nachdem das System nun vier Wochen ohne Probleme durchlief, habe ich seit gestern eine Dauer-reboot-Schleife:
    [MQTT]
    abort() was called at PC 0x40153923 on core 0
    ELF file SHA256: d625d782fdb447c4
    Backtrace: 0x4008cd78:0x3fff9560 0x4008d1a9:0x3fff9580 0x40153923:0x3fff95a0 0x4015396a:0x3fff95c0 0x40153a77:0x3fff95e0 0x40162cc7:0x3fff9600 0x4018f162:0x3fff9620 0x40191ca6:0x3fff9660 0x4019297d:0x3fff9c50 0x4018b21e:0x3fff9d00 0x400f0d4a:0x3fffa180 0x400f0f9f:0x3fffa1c0
    Rebooting...
    ets Jun  8 2016 00:22:57
    rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    mode:DIO, clock div:2
    load:0x3fff0030,len:4
    load:0x3fff0034,len:7248
    ho 0 tail 12 room 4
    load:0x40078000,len:13856
    load:0x40080400,len:4052
    entry 0x40080688
    I (31) boot: ESP-IDF 3.40100.200827 2nd stage bootloader
    I (31) boot: compile time 10:16:06
    I (31) boot: chip revision: 1
    I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0
    I (41) boot.esp32: SPI Speed      : 40MHz
    I (46) boot.esp32: SPI Mode       : DIO
    I (51) boot.esp32: SPI Flash Size : 4MB
    I (55) boot: Enabling RNG early entropy source...
    I (61) boot: Partition Table:
    I (64) boot: ## Label            Usage          Type ST Offset   Length
    I (71) boot:  0 nvs              WiFi data        01 02 00009000 00004000
    I (79) boot:  1 otadata          OTA data         01 00 0000d000 00002000
    I (86) boot:  2 phy_init         RF data          01 01 0000f000 00001000
    I (94) boot:  3 ota_0            OTA app          00 10 00010000 001db000
    I (101) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
    I (109) boot: End of partition table
    I (113) boot_comm: chip revision: 1, min. application chip revision: 0
    I (120) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x507c0 (329664) map
    I (272) esp_image: segment 1: paddr=0x000607e8 vaddr=0x3ffb0000 size=0x05038 ( 20536) load
    I (282) esp_image: segment 2: paddr=0x00065828 vaddr=0x40080000 size=0x00404 (  1028) load
    I (283) esp_image: segment 3: paddr=0x00065c34 vaddr=0x40080404 size=0x0a3e4 ( 41956) load
    I (310) esp_image: segment 4: paddr=0x00070020 vaddr=0x400d0020 size=0x14f8a8 (1374376) map
    I (905) esp_image: segment 5: paddr=0x001bf8d0 vaddr=0x4008a7e8 size=0x12194 ( 74132) load
    I (958) boot: Loaded app from partition at offset 0x10000
    I (958) boot: Disabling RNG early entropy source...
    I (959) psram: This chip is ESP32-D0WD
    I (963) spiram: Found 64MBit SPI RAM device
    I (968) spiram: SPI RAM mode: flash 40m sram 40m
    I (973) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
    I (980) cpu_start: Pro cpu up.
    I (984) cpu_start: Application information:
    I (989) cpu_start: Project name:     esp32cam-server-only
    I (995) cpu_start: App version:      0.0.9.3
    I (1000) cpu_start: Compile time:     Jul 25 2021 18:09:35
    I (1006) cpu_start: ELF file SHA256:  d625d782fdb447c4...
    I (1012) cpu_start: ESP-IDF:          3.40100.200827
    I (1018) cpu_start: Starting app cpu, entry point is 0x40081ad8
    I (1009) cpu_start: App cpu up.
    I (1916) spiram: SPI SRAM memory test OK
    I (1916) heap_init: Initializing. RAM available for dynamic allocation:
    I (1916) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
    I (1922) heap_init: At 3FFC29D0 len 0001D630 (117 KiB): DRAM
    I (1929) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
    I (1935) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
    I (1942) heap_init: At 4009C97C len 00003684 (13 KiB): IRAM
    I (1948) cpu_start: Pro cpu start user code
    I (1953) spiram: Adding pool of 4096K of external SPI memory to heap allocator
    I (1978) spi_flash: detected chip: generic
    I (1979) spi_flash: flash io: dio
    I (1979) cpu_start: Starting scheduler on PRO CPU.
    I (0) cpu_start: Starting scheduler on APP CPU.
    I (1987) spiram: Reserving pool of 32K of internal memory for DMA/internal allocations
    Do Reset Camera
    I (1997) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
    Init Camera
    I (4007) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4007) gpio: GPIO[18]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4007) gpio: GPIO[19]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4017) gpio: GPIO[21]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4027) gpio: GPIO[22]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4037) gpio: GPIO[23]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4047) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4057) gpio: GPIO[34]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4067) gpio: GPIO[35]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4077) gpio: GPIO[36]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4087) gpio: GPIO[39]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
    I (4097) sccb: pin_sda 26 pin_scl 27
    I (4097) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
    I (4247) camera: Detected OV2640 camera
    I (4257) camera: Allocating 1 frame buffers (150 KB total)
    I (4267) camera: Allocating 150 KB frame buffer in OnBoard RAM
    I (4867) main: Using SDMMC peripheral
    Type: SDHC/SDXC
    Speed: 20 MHz
    I (4907) server_ota: Start CheckOTAUpdateCheck ...
    I (4917) server_ota: SHA-256 for the partition table: : 9d4a2809ae90fb20709a8ca3dd3ac3462e1e73286bcd31b689060c91de06fa3a
    I (4977) server_ota: SHA-256 for bootloader: : 8677ca5aab674ba732c280f0c34b595fce09e670bf8282c4147250de215bf674
    I (5677) server_ota: SHA-256 for current firmware: : 96b6dc9fddcfb5775935a1c42d8adbe2938758f34a84a784278d4a09f4052572
    CheckOTAUpdate Partition: ESP_OK
    open config file /sdcard/wlan.ini in mode r
    file loaded
    WLan: FRITZ!Box Fon WLAN 7390,
    Hostename: watermeter
    I (5737) wifi:wifi driver task: 3ffd9cb0, prio:23, stack:6656, core=0
    I (5737) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
    I (5767) wifi:wifi firmware version: 3ea4c76
    I (5767) wifi:config NVS flash: enabled
    I (5767) wifi:config nano formating: disabled
    I (5767) wifi:Init dynamic tx buffer num: 32
    I (5777) wifi:Init data frame dynamic rx buffer num: 32
    I (5777) wifi:Init management frame dynamic rx buffer num: 32
    I (5787) wifi:Init management short buffer num: 32
    I (5787) wifi:Init static tx buffer num: 16
    I (5797) wifi:Init static rx buffer size: 1600
    I (5797) wifi:Init static rx buffer num: 10
    I (5797) wifi:Init dynamic rx buffer num: 32
    I (5897) phy: phy_version: 4180, cb3948e, Sep 12 2019, 16:39:13, 0, 0
    I (5897) wifi:mode : sta (24:6f:28:af:18:a8)
    I (5897) BLINK: Blinken - start
    I (5907) wifi station: wifi_init_sta finished.
    I (6027) wifi:new:<1,1>, old:<1,0>, ap:<255,255>, sta:<1,1>, prof:6
    I (6027) wifi:state: init -> auth (b0)
    I (6037) wifi:state: auth -> assoc (0)
    I (6047) wifi:state: assoc -> run (10)
    I (6057) wifi:connected with FRITZ!Box Fon WLAN 7390, aid = 4, channel 1, 40U, bssid = 9c:c7:a6:fa:3a:04
    I (6057) wifi:security: WPA2-PSK, phy: bgn, rssi: -27
    I (6067) wifi:pm start, type: 1
    I (6107) BLINK: Blinken - done
    I (6117) wifi:AP's beacon interval = 102400 us, DTIM period = 1
    I (6717) esp_netif_handlers: sta ip: 192.168.3.14, mask: 255.255.255.0, gw: 192.168.3.1
    I (6717) wifi station: got ip:192.168.3.14
    I (6717) BLINK: Blinken - start
    I (6727) wifi station: connected to ap SSID:FRITZ!Box Fon WLAN 7390 password:
    main: sleep for : 200ms
    I (8737) sntp: Time is not set yet. Connecting to WiFi and getting time over NTP.
    I (8737) sntp: Initializing SNTP
    I (8737) sntp: Waiting for system time to be set... (1/10)
    TimeZone set to CET-1CEST,M3.5.0,M10.5.0/3
    Logfile opened: /sdcard/log/message/log_2021-08-18.txt
    I (10747) sntp: The current date/time in Berlin is: Wed Aug 18 18:49:09 2021
    I (10747) sntp: The current date/time in Berlin is: 2021-08-18_18:49
    timeist 20210818-184909
    time 20210818-184909
    I (12787) server-main: Starting server on port: '80'
    I (12787) server-main: Registering URI handlers
    I (12787) server_tflite: server_part_camera - Registering URI handlers
    I (12787) server_ota: server_ota - Registering URI handlers
    I (12797) server_GPIO: start GpioHandler
    I (12797) server_GPIO: register GPIO Uri
    I (12807) server_GPIO: server_GPIO - Registering URI handlers
    vor reg server main
    vor dotautostart
    task_autodoFlow: start
    open config file /sdcard/config/config.ini in mode r
    [MakeImage]
    Start ReadParameter
    ;LogImageLocation = /log/source
    WaitBeforeTakingPicture = 5
    ;LogfileRetentionInDays = 15
    ;Brightness = -2
    ;Contrast = 0
    ;Saturation = 0
    ImageQuality = 5
    ImageSize = VGA
    FixedExposure = true
    [Alignment]
    I (16727) BLINK: Blinken - done
    Start ReadParameter
    InitialRotate = 170
    InitialMirror = false
    SearchFieldX = 20
    SearchFieldY = 20
    ;AlignmentAlgo = default
    ;FlipImageSize = false
    /config/ref0.jpg 269 20
    /config/ref1.jpg 462 370
    [Digits]
    2021-08-14T10:50:09
    Start ReadParameter
    aktparamgraph: [Digits]
    Name Digit:
    Model = /config/dig0820s2q.tflite
    ;LogImageLocation = /log/digit
    ;LogfileRetentionInDays = 3
    ModelInputSize = 20 32
    main.dig1 244 80 33 60
    GetDIGIT - digit main - roi dig1
    main.dig2 282 82 33 60
    GetDIGIT - digit main - roi dig2
    main.dig3 320 82 34 60
    GetDIGIT - digit main - roi dig3
    [Analog]
    Start ReadParameter
    Model = /config/ana0700s1lq.tflite
    ;LogImageLocation = /log/analog
    ModelInputSize = 32 32
    ExtendedResolution = false
    main.ana1 387 145 123 123
    GetANALOG - ANALOG main - roi ana1
    main.ana3 346 255 115 115
    GetANALOG - ANALOG main - roi ana3
    main.ana4 244 300 112 112
    GetANALOG - ANALOG main - roi ana4
    main.ana2 127 252 118 118
    GetANALOG - ANALOG main - roi ana2
    [PostProcessing]
    Start ReadParameter
    Anzahl NUMBERS: 1 - DIGITS: 1, ANALOG: 1
    Number main, Anz DIG: 3, Anz ANA 4
    main.DecimalShift = 0
    PreValueUse = true
    PreValueAgeStartup = 720
    AllowNegativeRates = true
    main.MaxRateValue = 0.1
    ErrorMessage = true
    CheckDigitIncreaseConsistency = false
    [MQTT]
    Rebooting...
    ho 0 tail 12 room 4
    entry 0x40080688
    F
    F
    Feinfinger
    schrieb am zuletzt editiert von Feinfinger
    #1600
    Also bei mir läuft das System stabil.
    Allerdings muss ich nach jedem Durchlauf eines m³ (von 305,... auf 306,... usw) die Pre-Value neu setzen.
    Letzter Stand des Zählers waren 306,9969 m³, beim nächsten Durchlauf waren es 307,0008 m³ und die Software hängt im "rate too high" Error, obwohl maxRateValue auf 0,3 steht.
    Das kann ich mir nicht erklären.
    Hatte das jetzt bei drei Durchläufen eines vollen m³.
    iob als LXC im Proxmox
    Node.js: v22.19.0
    NPM: 10.9.3
    js-controller 7.0.7
    Rene_HMR 1 Antwort Letzte Antwort
    • Rene_HMR Rene_HM
      [MQTT]
      Rebooting...
      ho 0 tail 12 room 4
      entry 0x40080688
      Do Reset Camera
      Init Camera
      Type: SDHC/SDXC
      Speed: 20 MHz
      file loaded
      vor reg server main
      vor dotautostart
      [MakeImage]
      Start ReadParameter
      ;Brightness = -2
      ;Contrast = 0
      ;Saturation = 0
      ImageQuality = 5
      ImageSize = VGA
      [Alignment]
      Start ReadParameter
      InitialRotate = 170
      SearchFieldX = 20
      SearchFieldY = 20
      [Digits]
      2021-08-14T10:50:09
      Start ReadParameter
      Name Digit:
      [Analog]
      Start ReadParameter
      [PostProcessing]
      Start ReadParameter
      PreValueUse = true
      ErrorMessage = true
      [MQTT]
      Rebooting...
      ho 0 tail 12 room 4
      entry 0x40080688
      Rene_HMR
      Rene_HMR
      Rene_HM
      #1601
      @rene_hm sagte in Wasserzähler - Version 2 - all-in-device:
      Ursache war wohl die SD-Karte. Es gab zwar keinen Fehler, sie konnte normal gelesen und geschrieben werde. Ich habe alle Daten kopiert, Karte neu formatiert und Daten wieder zurück kopiert. Seitdem läuft das System wieder... seltsam...
      • F Feinfinger
        Rene_HMR
        Rene_HMR
        Rene_HM
        #1602
        @feinfinger sagte in Wasserzähler - Version 2 - all-in-device:
        Das habe ich auch manchmal. Bei mir ist das Problem, dass sich die letzte Stelle nicht sprunghaft ändert, sondern langsam. Das führt dazu, dass diese Stelle dann ein NaN liefert, weil sie nicht erkannt wird und das führt dann bei mir zu dem "rate too high" Fehler. Ich ignoriere das, weil sich das nach kurzer Zeit automatisch wieder korrigiert (wenn die letzte Stelle wieder erkannt wird)
        C 1 Antwort Letzte Antwort
        • Rene_HMR Rene_HM
          C
          C
          ChrisXY
          schrieb am zuletzt editiert von ChrisXY
          #1603
          Kann man hier auch Improvisieren ? Habe aktuell keine 3D Druck Möglichkeit. Oder verschickt jemand ? Ich benötige 3 Stück.
          • C ChrisXY
            D
            D
            Dan.Master
            schrieb am zuletzt editiert von Dan.Master
            #1604
            @chrisxy
            Meine erste Version war eine -P/r/i/n/g/e/l/s- Dose entsprechen bearbeitet zusammen mit einem Pflanztopfring zum anbringen an den Wasserzähler. Funktionierte perfekt.
            Die P***box hatte sogar den Vorteil der reflektierenden Wände was mit dem abkleben der LED-Leuchte zu einem nahezu Reflextionsfreien Uhrglas führte.
            DerDani
            • D Dan.Master
              @chrisxy
              DerDani
              C
              C
              ChrisXY
              #1605
              @dan-master Danke für den Tipp.
              Problem 2.. Luftfeuchte ca. 99% Ich glaube das der ESP so nicht lange Überlebt ..
              • C ChrisXY
                D
                D
                Dan.Master
                #1606
                @chrisxy
                Das
                oberfraggerO 1 Antwort Letzte Antwort
                • D Dan.Master
                  @chrisxy
                  Das
                  oberfraggerO
                  oberfraggerO
                  oberfragger
                  schrieb am zuletzt editiert von oberfragger
                  #1607
                  @jomjol Moin und vielen Dank für die tolle Arbeit!
                  Ich habe mir mal erlaubt dein Design auf Thingiverse zu remixen und einen [Adapter für den Sensus620](link url) (Wasserwerke Hamburg) zur Verfügung zu stellen. Ich hoffe das ist okay. Hält bombenfest und sicher das Ding. Passgenau. Als 3D Druck Anfänger bin ich auch recht stolz :)
                  Aber das eigentliche- aus Doku-Zwecken - für alle die auch so ein Gerät haben. Die Erkennung scheint mittlerweile recht gut. Folgende Einstellung habe ich getroffen:
                  Damit hatte jemand anderes hier einige Erkennungsprobleme, da die Zahl recht knapp unten ist. Leider noch einige Reflexionen auf den Zahlen. Habe ich da irgendeine Möglichkeit das dem neuronalen Netzwerk beizubringen bzw. "per Hand" anzulernen?
                  J L 2 Antworten Letzte Antwort
                  • J jomjol
                    ich möchte in diesem Thread den Wasserzähler in der Version 2 vorstellen und diskutieren. In Version 1 waren 2 Komponeten notwendig (Hardware mit Kameraaufnahme, Docker-Server zur Auswertung). Das Zusammenspiel und die Konfiguration waren nicht immer ganz einfach.
                    Daher habe ich eine Nachfolgegeneration entwickelt, bei der alles in einem all-included Device umgesetzt ist und es noch um eine Web-basierte graphische Oberfläche zur einfachen Konfiguration ergänzt.
                    Das Grundprinzip basiert unverändert auf einem ESP32-Modul mit Kamera, welches regelmäßig ein Bild aufnimmt und durch Bilderkennung (Neuronale Netze, CNN) auswertet und den Zählerstand digitalisiert zur Verfügung stellt:
                    Hier ein Eindruck der graphischen Benutzeroberfläche:
                    Die Hardware ist wieder auf Thingiverse veröffentlicht, die Software könnt ihr als Firmware oder zum selber kompilieren auf GitHub finden. Dort gibt es auch ein Wiki mit Installations- und Konfigurationsanleitung.
                    • Hardware: https://www.thingiverse.com/thing:4573481
                    • Software/Wiki: https://github.com/jomjol/AI-on-the-edge-device/wiki
                    Ich stehe hier gerne wieder für Feedback, Fragen oder einfach zur Hilfe zur Verfügung und freue mich, wenn dieser Thread genauso intensiv genutzt wird, wie bei der Version 1 (>1k Beiträge und >22k Aufrufe).
                    Beste Grüße und viel Spass beim Nachbauen,
                    Jomjol
                    P.S.: die neue Software ist sehr flexibel aufgebaut und kann grundsätzlich auch Bildererkennung / Neuronale Netze für andere Zwecke eingesetzt werden. Wer eine gute Idee oder Anregung hat oder bei eine Modifikation Unterstützung braucht - bitte auch gerne einfach hier posten.
                    M
                    M
                    martinz01
                    #1608
                    @jomjol Bei mir läuft die Version 2 mit dem Sensus 620 sehr gut außer dass eine 6 oft als 0 erkannt wird. In welcher Form/Ausschnitt kann ich dir Bilder zum Lernen schicken?
                    • M martinz01
                      J
                      J
                      jomjol
                      #1609
                      @martinz01 sagte in Wasserzähler - Version 2 - all-in-device:
                      Du kannst das Logging in der Config.ini einschalten und mir dann von jeder Ziffer ca. 2-3 Bilder (nicht mehr!) schicken. Die nehme ich dann in mein nächstes Training mit auf.
                      • oberfraggerO oberfragger
                        J
                        J
                        jomjol
                        #1610
                        @oberfragger Um die "Randziffern" zu berücksichtigen bräuchtest du einen eigenen Trainingsatz. Ist etwas Aufwenidig :-(
                        • J jomjol
                          oberfraggerO
                          oberfraggerO
                          oberfragger
                          #1611
                          @jomjol Danke für die Rückmeldung.
                          Jetzt gerade macht er alles was "man" braucht. Selbst die komische 5 hat er erkannt.
                          Hatte mir einen Diffusor mit weissem PLA gebaut, aber den mal rausgenommen und rumprobiert. Dadurch die Refexionen reduziert und selbt die "0"en erkennt er zuverlässig. Fieserweise haben die nämlich irgendso eine Plastikwurst unterhalb der Zahlen verbaut. Vermutlich kommen die Reflexionen dadurch.
                          Mal sehen ob er morgen die "6" erkennt.
                            oberfraggerO
                            oberfraggerO
                            oberfragger
                            #1612
                            @jomjol
                            Sehe ich dass richtig, dass man leider GIO26 und 27 nicht ansprechen kann. Zumindest geht das in den GPIO-Settings nicht.
                            https://randomnerdtutorials.com/esp32-cam-ai-thinker-pinout/
                            Am liebsten würde ich da noch 1nen BME680 anschliessen und Temperatur, Luftfeuchtigkeit und vor allem VOC via MQTT empfangen. Wenn es da eine Möglichkeit gibt, dann spare ich mir den NodeMCU, der direkt neben der Wasseruhr hängt. Ein 1-wire Termometer wie ein AM2301 könnte ich dran hängen...? Vermutlich nicht, da nicht die richtigen Bibiotheken drin sind. Oder?
                            Und sehe ich das richtig, dass man prinzipiell an die GPIOs weitere Leuchtdioden anschliessen könnte? Wenn ich also eine indirekte Beleuchtung ohne interne LED (wegen der Reflexionen) erreichen möchte. GPIO4 ausstellen und dann einfach an einen anderen GPIO klemmen? So würde ich die Zerstörung der LED vermeiden.
                              @jomjol
                              J
                              J
                              jomjol
                              #1613
                              @oberfragger Alle GPIOs bis auf GPIO 12 und 13 sind belegt. Du kannst noch den GPIO1 und 3 verwenden, wenn du auf die serielle Ausgabe zum Debuggen verzichtest und dies nur zum Flashen verwendest. Dito für GPIO4, der hängt aber auch mit der SD-Karte zusammen.
                              • J jomjol
                                M
                                M
                                martinz01
                                #1614
                                @jomjol
                                Ich hoffe, die sind so in Ordnung:
                                digits_sensus620.zip
                                Vielen Dank!
                                • M martinz01
                                  @jomjol
                                  Vielen Dank!
                                  J
                                  J
                                  jomjol
                                  #1615
                                  @martinz01 Daten sind gut - Timing ist etwas ungünstig, da ich gerade erst ein neues Training gemacht habe (siehe Rolling). Aber die Bilder sind schon kopiert und fließen automatisch in die nächste Version ein.
                                  • M
                                    M
                                    MischMaster
                                    #1616
                                    ich bastel auch grad an dem Wasserzähler rum. Hab ihn trotz Beginner-Kenntnisse zum Laufen gebracht. Flashen hat funktioniert, ins Wlan einbinden auch und ich war gestern schon mal auf der Start Website.
                                    Heute hab ich den ESP-32 auf den Deckel der Röhre geklebt und wollte jetzt mal am Focus rumspielen, aber plötzlich komme ich nicht mehr auf die Website.
                                    Ich sehe "watermeter" immer noch in der Fritzbox, aber wenn ich daraufklicke, öffnet sich die Website nicht mehr.
                                    Er versucht http://192.168.178.1/secure_link.lua?sid= aufzurufen. Ist das korrekt?
                                    Die IP wäre eigentlich die .46 am Schluss und ich bekomme den Fehler ERR_CONNECTION_REFUSED.
                                    Hat wer ne Idee?
                                    Danke,
                                    Michi
                                    • M MischMaster
                                      Hat wer ne Idee?
                                      Danke,
                                      Michi
                                      J
                                      J
                                      jomjol
                                      #1617
                                      @mischmaster Das ist ein Thema von deinem Netz und deiner FritzBox. Du kannst den ESP32 direkt über seine IP-Adresse ansteuern. Das geht mit Sicherheit. Die findest du auch in der FritzBox.
                                      • J jomjol
                                        M
                                        M
                                        MischMaster
                                        schrieb am zuletzt editiert von MischMaster
                                        #1618
                                        @jomjol Ja, so mach ich es auch. Ich klicke in der Fritzbox auf Watermeter und bekomme dann die Fehlermeldung.
                                        Auch wenn ich die IP direkt im Browser eingebe funktioniert es nicht.
                                        SD Karte formatieren und den Inhalt neu draufkopieren hat nichts gebracht.
                                        Vielleich sollte ich die Firmware nochmal flashen..
                                        Michi
                                        • M MischMaster
                                          Michi
                                          J
                                          J
                                          jomjol
                                          #1619
                                          @mischmaster Wenn alles nicht hilft, dann schau mal das Log der seriellen Schnittstelle an oder poste es hier. Meistens findet man dann den Fehler recht gut.
                                          33.2k
                                          84.3k
