  4. Zigbee Adpterproblem - CC2538
    6.5k
41 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • E Elkja
    @elkja da er über iobroker nicht installierbar was habich es so gemacht
    pi@raspberrypi:/opt/iobroker $ npm install iobroker.zigbee@1.5.6
    weiss nur nicht warum er hier
    info: zigbee.0 (2989) Installed Version: ioBroker/ioBroker.zigbee#master
    zigbee'master heißt
    Thomas BraunT Offline
    @elkja
    iobroker upgrade zigbee@1.5.6
    E 1 Antwort Letzte Antwort
      @elkja
      Elkja
      @thomas-braun sagte in Zigbee Adpterproblem - CC2538:
      2021-09-02 23:16:11.191  - error: zigbee.0 (3133) Unhandled promise rejection. This error originated either                                                               by throwing inside of an async function without a catch block, or by rejecting a promise which was not han                                                              dled with .catch().
      2021-09-02 23:16:11.192  - error: zigbee.0 (3133) unhandled promise rejection: Cannot read property 'getEnt                                                              ries' of null
      2021-09-02 23:16:11.195  - error: zigbee.0 (3133) TypeError: Cannot read property 'getEntries' of null
          at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/mod                                                              el/device.js:220:55)
          at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
          at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:                                                              31)
          at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:                                                              49)
          at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:                                                              43)
          at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontrolle                                                              r.js:214:42)
          at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
          at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
          at processTicksAndRejections (internal/process/task_queues.js:97:5)
      2021-09-02 23:16:11.195  - error: zigbee.0 (3133) Cannot read property 'getEntries' of null
      • E Elkja
        Elkja
        @elkja
        2021-09-02 23:17:05.281  - error: zigbee.0 (3150) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        • E Elkja
          @elkja
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @elkja
          Das hier ist das zu Grunde liegende Problem:
          021-09-02 23:05:21.722  - error: zigbee.0 (2989) Starting zigbee-herdsman problem : "network commissioning failed - timed out waiting for nib to settle"
          Ich gehe aktuell davon aus das die Firmware deines CC2538 zu alt ist um mit der aktuellen Version des zigbee-herdsman-converters stabil betrieben zu werden (siehe auch hier)
          A.
          • E Elkja
            @thomas-braun hab wo gelesen, wenn man mal auf 1.6 ist gibts kein zurück mehr. stimmt das?
            arteckA Offline
            arteckA Offline
            arteck
            @elkja das ist quatsch... man kommt aus jeder Version zurück.. sogar mit den board mitteln..
            aber wie schon geschrieben worden ist.. interessant währe zu wissen welche Version auf dem Stick drauf ist ?
            und ist das ein Multihost System ?
            E 2 Antworten Letzte Antwort
            • arteckA arteck
              Elkja
              @arteck hi, wie kann ich die Version vom Stick auslesen?
              • arteckA arteck
                Elkja
                @arteck ...nein, ist kein multihost system
                • E Elkja
                  arteckA Offline
                  arteckA Offline
                  arteck
                  @elkja du musst doch wissen was du gekauft hast ?
                  • arteckA arteck
                    Elkja
                    @arteck der liegt, denke ich schon seit 9 Monaten rum. Wollte ich im Zuge der Neuinstallation verwenden. Keine Ahnung welche Version der hat.
                    • E Elkja
                      arteckA Offline
                      arteckA Offline
                      arteck
                      @elkja dann neuflashen und gut ist
