  4. Zigbee Adpterproblem - CC2538
    6.5k
41 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • E Elkja
    @elkja
    so.......jetzt hab ich den adaper komplett neu installiert.
    hier die fehlermeldungen vielleich gibts noch Tips wie ich den zum Laufen bring
    2021-09-02 23:05:21.722  - error: zigbee.0 (2989) Starting zigbee-herdsman problem : "network commissioning                                   failed - timed out waiting for nib to settle"
    2021-09-02 23:05:21.723  - error: zigbee.0 (2989) Failed to start Zigbee
    2021-09-02 23:05:21.724  - error: zigbee.0 (2989) Error herdsman start
    2021-09-02 23:05:26.029  - warn: fronius.0 (2232) TypeError: Cannot read property 'Value' of undefined
    2021-09-02 23:05:31.727  - info: zigbee.0 (2989) Try to reconnect. 1 attempts left
    2021-09-02 23:05:31.728  - info: zigbee.0 (2989) Starting Zigbee  npm ...
    2021-09-02 23:05:31.751  - info: zigbee.0 (2989) Installed Version: ioBroker/ioBroker.zigbee#master
    2021-09-02 23:05:32.055  - error: zigbee.0 (2989) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    2021-09-02 23:05:32.057  - error: zigbee.0 (2989) Failed to start Zigbee
    2021-09-02 23:05:32.058  - error: zigbee.0 (2989) Error herdsman start
    Elkja
    @elkja da er über iobroker nicht installierbar was habich es so gemacht
    pi@raspberrypi:/opt/iobroker $ npm install iobroker.zigbee@1.5.6
    weiss nur nicht warum er hier
    zigbee'master heißt
    • E Elkja
      zigbee'master heißt
      Thomas BraunT Offline
      @elkja
      iobroker upgrade zigbee@1.5.6
      E 1 Antwort Letzte Antwort
        @elkja
        Elkja
        @thomas-braun sagte in Zigbee Adpterproblem - CC2538:
        2021-09-02 23:16:11.191  - error: zigbee.0 (3133) Unhandled promise rejection. This error originated either                                                               by throwing inside of an async function without a catch block, or by rejecting a promise which was not han                                                              dled with .catch().
        2021-09-02 23:16:11.192  - error: zigbee.0 (3133) unhandled promise rejection: Cannot read property 'getEnt                                                              ries' of null
        2021-09-02 23:16:11.195  - error: zigbee.0 (3133) TypeError: Cannot read property 'getEntries' of null
            at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/mod                                                              el/device.js:220:55)
            at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
            at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:                                                              31)
            at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:                                                              49)
            at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:                                                              43)
            at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontrolle                                                              r.js:214:42)
            at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
            at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
            at processTicksAndRejections (internal/process/task_queues.js:97:5)
        2021-09-02 23:16:11.195  - error: zigbee.0 (3133) Cannot read property 'getEntries' of null
        • E Elkja
          Elkja
          @elkja
          2021-09-02 23:17:05.281  - error: zigbee.0 (3150) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
          • E Elkja
            @elkja
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @elkja
            Das hier ist das zu Grunde liegende Problem:
            Ich gehe aktuell davon aus das die Firmware deines CC2538 zu alt ist um mit der aktuellen Version des zigbee-herdsman-converters stabil betrieben zu werden (siehe auch hier)
            A.
            • E Elkja
              @thomas-braun hab wo gelesen, wenn man mal auf 1.6 ist gibts kein zurück mehr. stimmt das?
              arteckA Offline
              arteckA Offline
              arteck
              @elkja das ist quatsch... man kommt aus jeder Version zurück.. sogar mit den board mitteln..
              aber wie schon geschrieben worden ist.. interessant währe zu wissen welche Version auf dem Stick drauf ist ?
              und ist das ein Multihost System ?
              E 2 Antworten Letzte Antwort
              • arteckA arteck
                Elkja
                @arteck hi, wie kann ich die Version vom Stick auslesen?
                • arteckA arteck
                  Elkja
                  @arteck ...nein, ist kein multihost system
                  • E Elkja
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @elkja du musst doch wissen was du gekauft hast ?
                    • arteckA arteck
                      Elkja
                      @arteck der liegt, denke ich schon seit 9 Monaten rum. Wollte ich im Zuge der Neuinstallation verwenden. Keine Ahnung welche Version der hat.
                      • E Elkja
                        arteckA Offline
                        arteckA Offline
                        arteck
                        @elkja dann neuflashen und gut ist
