  4. Zigbee Adpterproblem - CC2538
    6.5k
41 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • E Elkja
    2021-09-02 21:50:20.128  - info: zigbee.0 (3477) starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
    2021-09-02 21:50:20.248  - info: zigbee.0 (3477) Starting Zigbee  npm ...
    2021-09-02 21:50:20.751  - info: zigbee.0 (3477) Installed Version: ioBroker/ioBroker.zigbee#master
    2021-09-02 21:50:22.273  - error: zigbee.0 (3477) Configuration is not consistent with adapter state/backup!
    2021-09-02 21:50:22.274  - error: zigbee.0 (3477) - PAN ID: configured=65534, adapter=65534
    2021-09-02 21:50:22.274  - error: zigbee.0 (3477) - Extended PAN ID: configured=00124b001940bcbe, adapter=00124b001940bcbe
    2021-09-02 21:50:22.275  - error: zigbee.0 (3477) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    2021-09-02 21:50:22.275  - error: zigbee.0 (3477) - Channel List: configured=11, adapter=
    2021-09-02 21:50:22.276  - error: zigbee.0 (3477) Please update configuration to prevent further issues.
    2021-09-02 21:50:22.276  - error: zigbee.0 (3477) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvba                  ckup.json.
    2021-09-02 21:50:22.276  - error: zigbee.0 (3477) Re-commissioning your network will require re-pairing of all devices!
    2021-09-02 21:50:22.437  - error: zigbee.0 (3477) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more informatio                  n"
    2021-09-02 21:50:22.438  - error: zigbee.0 (3477) Failed to start Zigbee
    2021-09-02 21:50:22.438  - error: zigbee.0 (3477) Error herdsman start
    2021-09-02 21:50:32.441  - info: zigbee.0 (3477) Try to reconnect. 1 attempts left
    2021-09-02 21:50:32.443  - info: zigbee.0 (3477) Starting Zigbee  npm ...
    2021-09-02 21:50:32.491  - info: zigbee.0 (3477) Installed Version: ioBroker/ioBroker.zigbee#master
    2021-09-02 21:50:32.797  - error: zigbee.0 (3477) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot                   lock port'"
    2021-09-02 21:50:32.798  - error: zigbee.0 (3477) Failed to start Zigbee
    2021-09-02 21:50:32.799  - error: zigbee.0 (3477) Error herdsman start
    @elkja
    die nvbackup.json hast du da mal weg manövriert?
    E 2 Antworten Letzte Antwort
      @elkja
      Elkja
      @thomas-braun ....ja stimmt leider.
      • E Elkja
        @elkja
        Was ist das eigentlich für eine merkwürdige Versionsnummer?
        E 1 Antwort Letzte Antwort
          @elkja
          Elkja
          @thomas-braun hab ich über git installiert
          • E Elkja
            @elkja Solltest du nicht tun.
              Elkja
              @thomas-braun hab ich auch schon gemerkt,dass das nicht immer gut ist.....bin schon verzweifelt.....weiss nicht mehr was ich noch machen soll.
              meine Frau ist schon sauer weil kinder frieren....und ich bekommst nicht mehr hin :-(
              • E Elkja
                @elkja Installier halt eine stabile. In git liegt Code in allen möglichen Zuständen.
                  Elkja
                  @thomas-braun welche soll ich denn nehmen ?
                  • E Elkja
                    @elkja
                    Was aus stable?
                    github:	1.6.1
                    latest:	1.6.0 for 24 days
                    stable:	1.5.6 for 96 days
                      @elkja
                      Was aus stable?
                      github:	1.6.1
                      Elkja
                      @thomas-braun hab wo gelesen, wenn man mal auf 1.6 ist gibts kein zurück mehr. stimmt das?
                      Thomas BraunT arteckA 2 Antworten Letzte Antwort
                      • E Elkja
                        @elkja
                        Keine Ahnung. Eigentlich aber nicht.
                        Aber probier's einfach aus. Weniger laufen kann der Adapter ja nicht.
                          @elkja
                          Elkja
                          @thomas-braun hab den 1.6.1 nur installiert weil der 1.5.6er auch nicht ging.
                          ich probiers jetzt nochmal .......
                            @elkja
                            Elkja
                            @thomas-braun sagte in Zigbee Adpterproblem - CC2538:
                            @elkja
                            zum thema weg manövieren.....es sollte sich ja dann wieder einer erstellen,oder?
                            bei mir kam dann keine mehr.......
                            • E Elkja
                              JLegJ Offline
                              JLegJ Offline
                              JLeg
                              @elkja sagte in Zigbee Adpterproblem - CC2538:
                              das dürfte ein Problem sein….
                              • JLegJ JLeg
                                Elkja
                                @jleg wie bekomm ich da was rein?
                                • JLegJ JLeg
                                  Elkja
                                  @jleg sagte in Zigbee Adpterproblem - CC2538:
                                  du meinst weill bei adapter= ....nix steht oder?
                                  • E Elkja
                                    Elkja
                                    @elkja
                                    so.......jetzt hab ich den adaper komplett neu installiert.
                                    hier die fehlermeldungen vielleich gibts noch Tips wie ich den zum Laufen bring
                                    2021-09-02 23:05:21.722  - error: zigbee.0 (2989) Starting zigbee-herdsman problem : "network commissioning                                   failed - timed out waiting for nib to settle"
                                    2021-09-02 23:05:21.723  - error: zigbee.0 (2989) Failed to start Zigbee
                                    2021-09-02 23:05:21.724  - error: zigbee.0 (2989) Error herdsman start
                                    2021-09-02 23:05:26.029  - warn: fronius.0 (2232) TypeError: Cannot read property 'Value' of undefined
                                    2021-09-02 23:05:31.727  - info: zigbee.0 (2989) Try to reconnect. 1 attempts left
                                    2021-09-02 23:05:31.728  - info: zigbee.0 (2989) Starting Zigbee  npm ...
                                    2021-09-02 23:05:31.751  - info: zigbee.0 (2989) Installed Version: ioBroker/ioBroker.zigbee#master
                                    2021-09-02 23:05:32.055  - error: zigbee.0 (2989) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    2021-09-02 23:05:32.057  - error: zigbee.0 (2989) Failed to start Zigbee
                                    2021-09-02 23:05:32.058  - error: zigbee.0 (2989) Error herdsman start
                                    • E Elkja
                                      @elkja
                                      Elkja
                                      @elkja da er über iobroker nicht installierbar was habich es so gemacht
                                      pi@raspberrypi:/opt/iobroker $ npm install iobroker.zigbee@1.5.6
                                      weiss nur nicht warum er hier
                                      zigbee'master heißt
                                      • E Elkja
                                        zigbee'master heißt
                                        @elkja
                                        iobroker upgrade zigbee@1.5.6
                                          @elkja
                                          Elkja
                                          2021-09-02 23:16:11.191  - error: zigbee.0 (3133) Unhandled promise rejection. This error originated either                                                               by throwing inside of an async function without a catch block, or by rejecting a promise which was not han                                                              dled with .catch().
                                          2021-09-02 23:16:11.192  - error: zigbee.0 (3133) unhandled promise rejection: Cannot read property 'getEnt                                                              ries' of null
                                          2021-09-02 23:16:11.195  - error: zigbee.0 (3133) TypeError: Cannot read property 'getEntries' of null
                                              at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/mod                                                              el/device.js:220:55)
                                              at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
                                              at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:                                                              31)
                                              at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:                                                              49)
                                              at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:                                                              43)
                                              at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontrolle                                                              r.js:214:42)
                                              at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
                                              at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
                                              at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                          2021-09-02 23:16:11.195  - error: zigbee.0 (3133) Cannot read property 'getEntries' of null
