  4. Zigbee Adpterproblem - CC2538
    6.5k
41 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
    @elkja
    Fast.
    Jetzt noch einmal die Reihenfolge ändern.
    Elkja
    @thomas-braun ....leider ändert sich der status des adapters nicht.....pan-id und adapter sind jetzt gleich.
    hast du ev. noch einen tip was da noch sein kann?
      @elkja
      Fast.
      Elkja
      2021-09-02 21:50:20.128  - info: zigbee.0 (3477) starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
      2021-09-02 21:50:20.248  - info: zigbee.0 (3477) Starting Zigbee  npm ...
      2021-09-02 21:50:20.751  - info: zigbee.0 (3477) Installed Version: ioBroker/ioBroker.zigbee#master
      2021-09-02 21:50:22.273  - error: zigbee.0 (3477) Configuration is not consistent with adapter state/backup!
      2021-09-02 21:50:22.274  - error: zigbee.0 (3477) - PAN ID: configured=65534, adapter=65534
      2021-09-02 21:50:22.274  - error: zigbee.0 (3477) - Extended PAN ID: configured=00124b001940bcbe, adapter=00124b001940bcbe
      2021-09-02 21:50:22.275  - error: zigbee.0 (3477) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      2021-09-02 21:50:22.275  - error: zigbee.0 (3477) - Channel List: configured=11, adapter=
      2021-09-02 21:50:22.276  - error: zigbee.0 (3477) Please update configuration to prevent further issues.
      2021-09-02 21:50:22.276  - error: zigbee.0 (3477) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvba                  ckup.json.
      2021-09-02 21:50:22.276  - error: zigbee.0 (3477) Re-commissioning your network will require re-pairing of all devices!
      2021-09-02 21:50:22.437  - error: zigbee.0 (3477) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more informatio                  n"
      2021-09-02 21:50:22.438  - error: zigbee.0 (3477) Failed to start Zigbee
      2021-09-02 21:50:22.438  - error: zigbee.0 (3477) Error herdsman start
      2021-09-02 21:50:32.441  - info: zigbee.0 (3477) Try to reconnect. 1 attempts left
      2021-09-02 21:50:32.443  - info: zigbee.0 (3477) Starting Zigbee  npm ...
      2021-09-02 21:50:32.491  - info: zigbee.0 (3477) Installed Version: ioBroker/ioBroker.zigbee#master
      2021-09-02 21:50:32.797  - error: zigbee.0 (3477) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot                   lock port'"
      2021-09-02 21:50:32.798  - error: zigbee.0 (3477) Failed to start Zigbee
      2021-09-02 21:50:32.799  - error: zigbee.0 (3477) Error herdsman start
      Thomas BraunT JLegJ 2 Antworten Letzte Antwort
      • E Elkja
        @elkja
        die nvbackup.json hast du da mal weg manövriert?
        E 2 Antworten Letzte Antwort
          @elkja
          Elkja
          @thomas-braun ....ja stimmt leider.
          • E Elkja
            @elkja
            Was ist das eigentlich für eine merkwürdige Versionsnummer?
            E 1 Antwort Letzte Antwort
              @elkja
              Elkja
              @thomas-braun hab ich über git installiert
              • E Elkja
                @elkja Solltest du nicht tun.
                  Elkja
                  @thomas-braun hab ich auch schon gemerkt,dass das nicht immer gut ist.....bin schon verzweifelt.....weiss nicht mehr was ich noch machen soll.
                  meine Frau ist schon sauer weil kinder frieren....und ich bekommst nicht mehr hin :-(
                  • E Elkja
                    @elkja Installier halt eine stabile. In git liegt Code in allen möglichen Zuständen.
                      Elkja
                      @thomas-braun welche soll ich denn nehmen ?
                      • E Elkja
                        @elkja
                        Was aus stable?
                        github:	1.6.1
                        latest:	1.6.0 for 24 days
                        stable:	1.5.6 for 96 days
                          @elkja
                          Was aus stable?
                          github:	1.6.1
                          Elkja
                          @thomas-braun hab wo gelesen, wenn man mal auf 1.6 ist gibts kein zurück mehr. stimmt das?
                          Thomas BraunT arteckA 2 Antworten Letzte Antwort
                          • E Elkja
                            @elkja
                            Keine Ahnung. Eigentlich aber nicht.
                            Aber probier's einfach aus. Weniger laufen kann der Adapter ja nicht.
                              @elkja
                              Elkja
                              @thomas-braun hab den 1.6.1 nur installiert weil der 1.5.6er auch nicht ging.
                              ich probiers jetzt nochmal .......
                                @elkja
                                Elkja
                                @thomas-braun sagte in Zigbee Adpterproblem - CC2538:
                                @elkja
                                zum thema weg manövieren.....es sollte sich ja dann wieder einer erstellen,oder?
                                bei mir kam dann keine mehr.......
                                • E Elkja
                                  JLegJ Offline
                                  JLegJ Offline
                                  JLeg
                                  @elkja sagte in Zigbee Adpterproblem - CC2538:
                                  das dürfte ein Problem sein….
                                  • JLegJ JLeg
                                    Elkja
                                    @jleg wie bekomm ich da was rein?
                                    • JLegJ JLeg
                                      Elkja
                                      @jleg sagte in Zigbee Adpterproblem - CC2538:
                                      du meinst weill bei adapter= ....nix steht oder?
                                      • E Elkja
                                        Elkja
                                        @elkja
                                        so.......jetzt hab ich den adaper komplett neu installiert.
                                        hier die fehlermeldungen vielleich gibts noch Tips wie ich den zum Laufen bring
                                        2021-09-02 23:05:21.722  - error: zigbee.0 (2989) Starting zigbee-herdsman problem : "network commissioning                                   failed - timed out waiting for nib to settle"
                                        2021-09-02 23:05:21.723  - error: zigbee.0 (2989) Failed to start Zigbee
                                        2021-09-02 23:05:21.724  - error: zigbee.0 (2989) Error herdsman start
                                        2021-09-02 23:05:26.029  - warn: fronius.0 (2232) TypeError: Cannot read property 'Value' of undefined
                                        2021-09-02 23:05:31.727  - info: zigbee.0 (2989) Try to reconnect. 1 attempts left
                                        2021-09-02 23:05:31.728  - info: zigbee.0 (2989) Starting Zigbee  npm ...
                                        2021-09-02 23:05:31.751  - info: zigbee.0 (2989) Installed Version: ioBroker/ioBroker.zigbee#master
                                        2021-09-02 23:05:32.055  - error: zigbee.0 (2989) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                        2021-09-02 23:05:32.057  - error: zigbee.0 (2989) Failed to start Zigbee
                                        2021-09-02 23:05:32.058  - error: zigbee.0 (2989) Error herdsman start
                                        • E Elkja
                                          @elkja
                                          Elkja
                                          @elkja da er über iobroker nicht installierbar was habich es so gemacht
                                          pi@raspberrypi:/opt/iobroker $ npm install iobroker.zigbee@1.5.6
                                          weiss nur nicht warum er hier
                                          zigbee'master heißt
