  4. Zigbee Adpterproblem - CC2538
    6.5k
41 Beiträge 5 Kommentatoren 6.2k Aufrufe 5 Beobachtet
  • E Elkja
    @thomas-braun ``````wie bringe ich den log rein? ohne screenshot?
    @elkja
    Steht im Werkzeugkasten drin.
    E 1 Antwort Letzte Antwort
      @elkja
      Elkja
      @thomas-braun ....aahhh.....danke
      code_text
      ```021-09-02 21:02:24.506  - warn: modbus.0 (2238) Poll error count: 1 code: {"errorCode":131,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
      2021-09-02 21:02:33.833  - info: host.raspberrypi "system.adapter.zigbee.0" enabled
      2021-09-02 21:02:33.998  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 3127
      2021-09-02 21:02:37.814  - info: zigbee.0 (3127) starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
      2021-09-02 21:02:37.900  - warn: fullybrowser.0 (2392) updateDeviceERROR 192.168.188.95
      2021-09-02 21:02:37.922  - info: zigbee.0 (3127) Starting Zigbee  npm ...
      2021-09-02 21:02:38.330  - info: zigbee.0 (3127) Installed Version: ioBroker/ioBroker.zigbee#master
      2021-09-02 21:02:39.961  - error: zigbee.0 (3127) Configuration is not consistent with adapter state/backup!
      2021-09-02 21:02:39.962  - error: zigbee.0 (3127) - PAN ID: configured=65534, adapter=65534
      2021-09-02 21:02:39.963  - error: zigbee.0 (3127) - Extended PAN ID: configured=ddddddddddaddddc, adapter=00124b001940bcbe
      2021-09-02 21:02:39.963  - error: zigbee.0 (3127) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
      2021-09-02 21:02:39.964  - error: zigbee.0 (3127) - Channel List: configured=11, adapter=
      2021-09-02 21:02:39.964  - error: zigbee.0 (3127) Please update configuration to prevent further issues.
      2021-09-02 21:02:39.964  - error: zigbee.0 (3127) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
      2021-09-02 21:02:39.965  - error: zigbee.0 (3127) Re-commissioning your network will require re-pairing of all devices!
      2021-09-02 21:02:40.140  - error: zigbee.0 (3127) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
      2021-09-02 21:02:40.141  - error: zigbee.0 (3127) Failed to start Zigbee
      2021-09-02 21:02:40.141  - error: zigbee.0 (3127) Error herdsman start
      2021-09-02 21:02:47.111  - warn: fronius.0 (2376) TypeError: Cannot read property 'Value' of undefined
      2021-09-02 21:02:50.144  - info: zigbee.0 (3127) Try to reconnect. 1 attempts left
      2021-09-02 21:02:50.146  - info: zigbee.0 (3127) Starting Zigbee  npm ...
      2021-09-02 21:02:50.177  - info: zigbee.0 (3127) Installed Version: ioBroker/ioBroker.zigbee#master
      2021-09-02 21:02:50.413  - error: zigbee.0 (3127) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
      2021-09-02 21:02:50.414  - error: zigbee.0 (3127) Failed to start Zigbee
      2021-09-02 21:02:50.414  - error: zigbee.0 (3127) Error herdsman start
      2021-09-02 21:02:53.684  - warn: modbus.0 (2238) Poll error count: 1 code: {"errorCode":131,"exceptionCode":10,"message":"GATEWAY PATH UNAVAILABLE"}
      • Thomas BraunT Online
        @elkja
        Die muss schonmal übereinstimmen.
          @elkja
          Elkja
          @thomas-braun ```
          code_text
          2021-09-02 21:08:41.171  - info: zigbee.0 (3166) Starting Zigbee  npm ...
          2021-09-02 21:08:41.563  - info: zigbee.0 (3166) Installed Version: ioBroker/ioBroker.zigbee#master
          2021-09-02 21:08:43.194  - error: zigbee.0 (3166) Configuration is not consistent with adapter state/backup!
          2021-09-02 21:08:43.195  - error: zigbee.0 (3166) - PAN ID: configured=65534, adapter=65534
          2021-09-02 21:08:43.196  - error: zigbee.0 (3166) - Extended PAN ID: configured=bebc4019004b1200, adapter=00124b001940bcbe
          2021-09-02 21:08:43.197  - error: zigbee.0 (3166) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=010305070                       90b0d0f00020406080a0c0d
          2021-09-02 21:08:43.198  - error: zigbee.0 (3166) - Channel List: configured=11, adapter=
          2021-09-02 21:08:43.198  - error: zigbee.0 (3166) Please update configuration to prevent further issues.
          2021-09-02 21:08:43.199  - error: zigbee.0 (3166) If you wish to re-commission your network, please remove coordinator backup a                       t /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
          2021-09-02 21:08:43.200  - error: zigbee.0 (3166) Re-commissioning your network will require re-pairing of all devices!
          2021-09-02 21:08:43.364  - error: zigbee.0 (3166) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mi                       smatch - see logs above for more information"
          2021-09-02 21:08:43.365  - error: zigbee.0 (3166) Failed to start Zigbee
          2021-09-02 21:08:43.365  - error: zigbee.0 (3166) Error herdsman start
          2021-09-02 21:08:47.012  - warn: fronius.0 (2376) TypeError: Cannot read property 'Value' of undefined
          2021-09-02 21:08:53.368  - info: zigbee.0 (3166) Try to reconnect. 1 attempts left
          2021-09-02 21:08:53.369  - info: zigbee.0 (3166) Starting Zigbee  npm ...
          2021-09-02 21:08:53.391  - info: zigbee.0 (3166) Installed Version: ioBroker/ioBroker.zigbee#master
          2021-09-02 21:08:53.652  - error: zigbee.0 (3166) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Er                       ror Resource temporarily unavailable Cannot lock port'"
          2021-09-02 21:08:53.653  - error: zigbee.0 (3166) Failed to start Zigbee
          2021-09-02 21:08:53.653  - error: zigbee.0 (3166) Error herdsman start
          • E Elkja
            @thomas-braun ```
            code_text
            @elkja
            Fast.
            Jetzt noch einmal die Reihenfolge ändern.
            E 4 Antworten Letzte Antwort
              @elkja
              Fast.
              Elkja
              @thomas-braun ``` ...jetzt hab ich beim der instanz die Pan ID rausgelöscht.....jetzt ist adapter und id gleich
              2021-09-02 21:17:23.493 - info: zigbee.0 (3277) cleaned everything up...
              2021-09-02 21:17:23.501 - info: zigbee.0 (3277) Zigbee: disabling joining new devices.
              2021-09-02 21:17:23.671 - warn: zigbee.0 (3277) Failed to stop zigbee during startup
              2021-09-02 21:17:23.671 - info: zigbee.0 (3277) terminating
              2021-09-02 21:17:23.673 - info: zigbee.0 (3277) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2021-09-02 21:17:23.689 - warn: zigbee.0 (3277) Got terminate signal. Checking desired PID: 3306 vs own PID 3277
              2021-09-02 21:17:24.412 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be resta rted, before user restarts it.
              2021-09-02 21:17:24.413 - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because desired by instance
              2021-09-02 21:17:27.825 - info: zigbee.0 (3306) starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
              2021-09-02 21:17:27.953 - info: zigbee.0 (3306) Starting Zigbee npm ...
              2021-09-02 21:17:28.575 - info: zigbee.0 (3306) Installed Version: ioBroker/ioBroker.zigbee#master
              2021-09-02 21:17:30.101 - error: zigbee.0 (3306) Configuration is not consistent with adapter state/backup!
              2021-09-02 21:17:30.101 - error: zigbee.0 (3306) - PAN ID: configured=65534, adapter=65534
              2021-09-02 21:17:30.102 - error: zigbee.0 (3306) - Extended PAN ID: configured=00124b001940bcbe, adapter=00124b001940bcbe
              2021-09-02 21:17:30.103 - error: zigbee.0 (3306) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
              2021-09-02 21:17:30.104 - error: zigbee.0 (3306) - Channel List: configured=11, adapter=
              2021-09-02 21:17:30.105 - error: zigbee.0 (3306) Please update configuration to prevent further issues.
              2021-09-02 21:17:30.105 - error: zigbee.0 (3306) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroke r-data/zigbee_0/nvbackup.json.
              2021-09-02 21:17:30.106 - error: zigbee.0 (3306) Re-commissioning your network will require re-pairing of all devices!
              2021-09-02 21:17:30.284 - error: zigbee.0 (3306) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
              2021-09-02 21:17:30.285 - error: zigbee.0 (3306) Failed to start Zigbee
              2021-09-02 21:17:30.285 - error: zigbee.0 (3306) Error herdsman start
              2021-09-02 21:17:40.288 - info: zigbee.0 (3306) Try to reconnect. 1 attempts left
              2021-09-02 21:17:40.289 - info: zigbee.0 (3306) Starting Zigbee npm ...
              2021-09-02 21:17:40.309 - info: zigbee.0 (3306) Installed Version: ioBroker/ioBroker.zigbee#master
              2021-09-02 21:17:40.555 - error: zigbee.0 (3306) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2021-09-02 21:17:40.558 - error: zigbee.0 (3306) Failed to start Zigbee
              2021-09-02 21:17:40.560 - error: zigbee.0 (3306) Error herdsman start
              • E Elkja
                Elkja
                code_text
                  @elkja
                  Fast.
                  Elkja
                  code_text
                  `2021-09-02 21:17:23.493  - info: zigbee.0 (3277) cleaned everything up...
                    @elkja
                    Fast.
                    Elkja
                    @thomas-braun ....leider ändert sich der status des adapters nicht.....pan-id und adapter sind jetzt gleich.
                    hast du ev. noch einen tip was da noch sein kann?
                      @elkja
                      Fast.
                      Elkja
                      2021-09-02 21:50:20.128  - info: zigbee.0 (3477) starting. Version 1.6.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.6, js-controller: 3.3.15
                      2021-09-02 21:50:20.248  - info: zigbee.0 (3477) Starting Zigbee  npm ...
                      2021-09-02 21:50:20.751  - info: zigbee.0 (3477) Installed Version: ioBroker/ioBroker.zigbee#master
                      2021-09-02 21:50:22.273  - error: zigbee.0 (3477) Configuration is not consistent with adapter state/backup!
                      2021-09-02 21:50:22.274  - error: zigbee.0 (3477) - PAN ID: configured=65534, adapter=65534
                      2021-09-02 21:50:22.274  - error: zigbee.0 (3477) - Extended PAN ID: configured=00124b001940bcbe, adapter=00124b001940bcbe
                      2021-09-02 21:50:22.275  - error: zigbee.0 (3477) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
                      2021-09-02 21:50:22.275  - error: zigbee.0 (3477) - Channel List: configured=11, adapter=
                      2021-09-02 21:50:22.276  - error: zigbee.0 (3477) Please update configuration to prevent further issues.
                      2021-09-02 21:50:22.276  - error: zigbee.0 (3477) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvba                  ckup.json.
                      2021-09-02 21:50:22.276  - error: zigbee.0 (3477) Re-commissioning your network will require re-pairing of all devices!
                      2021-09-02 21:50:22.437  - error: zigbee.0 (3477) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more informatio                  n"
                      2021-09-02 21:50:22.438  - error: zigbee.0 (3477) Failed to start Zigbee
                      2021-09-02 21:50:22.438  - error: zigbee.0 (3477) Error herdsman start
                      2021-09-02 21:50:32.441  - info: zigbee.0 (3477) Try to reconnect. 1 attempts left
                      2021-09-02 21:50:32.443  - info: zigbee.0 (3477) Starting Zigbee  npm ...
                      2021-09-02 21:50:32.491  - info: zigbee.0 (3477) Installed Version: ioBroker/ioBroker.zigbee#master
                      2021-09-02 21:50:32.797  - error: zigbee.0 (3477) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot                   lock port'"
                      2021-09-02 21:50:32.798  - error: zigbee.0 (3477) Failed to start Zigbee
                      2021-09-02 21:50:32.799  - error: zigbee.0 (3477) Error herdsman start
                      Thomas BraunT JLegJ 2 Antworten Letzte Antwort
                      • E Elkja
                        @elkja
                        die nvbackup.json hast du da mal weg manövriert?
                        E 2 Antworten Letzte Antwort
                          @elkja
                          Elkja
                          @thomas-braun ....ja stimmt leider.
                          • E Elkja
                            @elkja
                            Was ist das eigentlich für eine merkwürdige Versionsnummer?
                              @elkja
                              Elkja
                              @thomas-braun hab ich über git installiert
                              • E Elkja
                                @elkja Solltest du nicht tun.
                                  Elkja
                                  @thomas-braun hab ich auch schon gemerkt,dass das nicht immer gut ist.....bin schon verzweifelt.....weiss nicht mehr was ich noch machen soll.
                                  meine Frau ist schon sauer weil kinder frieren....und ich bekommst nicht mehr hin :-(
                                  • E Elkja
                                    @elkja Installier halt eine stabile. In git liegt Code in allen möglichen Zuständen.
                                      Elkja
                                      @thomas-braun welche soll ich denn nehmen ?
                                      • E Elkja
                                        @elkja
                                        Was aus stable?
                                        github:	1.6.1
                                        latest:	1.6.0 for 24 days
                                        stable:	1.5.6 for 96 days
                                          @elkja
                                          Was aus stable?
                                          github:	1.6.1
                                          Elkja
                                          @thomas-braun hab wo gelesen, wenn man mal auf 1.6 ist gibts kein zurück mehr. stimmt das?
                                          Thomas BraunT arteckA 2 Antworten Letzte Antwort
