  4. Smartmeter Adapter Probleme mit Hirche IR-Lesekopf
    6.5k
34 Beiträge 6 Kommentatoren 2.4k Aufrufe 5 Beobachtet
  • GlasfaserG Glasfaser
    @janni01 sagte in Smartmeter Adapter Probleme mit Hirche IR-Lesekopf:
    die admin Konsole ist jetzt nicht aufrufbar.
    ?? was machst du
    was sagt
    iobroker list adapters
    iobroker list instances
    janni01
    @glasfaser
    pi@pi:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v5.1.23
    system.adapter.discovery               : discovery      - v2.7.0
    system.adapter.net-tools               : net-tools      - v0.1.7
    system.adapter.ping                    : ping           - v1.5.0
    system.adapter.tr-064                  : tr-064         - v4.2.14
    system.adapter.web                     : web            - v3.4.7
    system.adapter.history                 : history        - v1.9.13
    system.adapter.javascript              : javascript     - v5.2.8
    system.adapter.info                    : info           - v1.9.8
    system.adapter.smartmeter              : smartmeter     - v3.2.1
    system.adapter.iot                     : iot            - v1.8.22
    system.adapter.rflink                  : rflink         - v2.1.6
    system.adapter.cul                     : cul            - v1.3.5
    system.adapter.deconz                  : deconz         - v1.3.19
    pi@pi:~ $ iobroker list instances
      system.adapter.admin.0                 : admin       -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0              : backitup    -  enabled
      system.adapter.discovery.0             : discovery   -  enabled
      system.adapter.history.0               : history     -  enabled
      system.adapter.smartmeter.0            : smartmeter  -  enabled
    + instance is alive
    pi@pi:~ $
    • J janni01
      @glasfaser
      + instance is alive
      pi@pi:~ $
      GlasfaserG Offline
      GlasfaserG Offline
      @janni01
      iobroker add admin.0
      iobroker upload all
      • J janni01
        pi@pi:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
        library: loaded
        Library version=2021-08-05
            Welcome to the ioBroker installation fixer!
            Script version: 2021-04-07
            You might need to enter your password a couple of times.
            Installing prerequisites (1/3)
        Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
        Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
        Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
        Hit:4 https://dl.yarnpkg.com/debian stable InRelease
        Get:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [380 kB]
        Err:4 https://dl.yarnpkg.com/debian stable InRelease
          The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23E7166788B63E1E
        Fetched 428 kB in 13s (33.6 kB/s)
        Reading package lists... Done
        W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.yarnpkg.com/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23E7166788B63E1E
        W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 23E7166788B63E1E
        W: Some index files failed to download. They have been ignored, or old ones used instead.
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/3)
            Checking autostart (3/3)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        pi@pi:~ $ iobroker start
        pi@pi:~ $ npm install --production
        npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
        npm WARN pi No description
        npm WARN pi No repository field.
        npm WARN pi No README data
        npm WARN pi No license field.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        audited 481 packages in 23.268s
        11 packages are looking for funding
          run `npm fund` for details
        found 3 high severity vulnerabilities
          run `npm audit fix` to fix them, or `npm audit` for details
        pi@pi:~ $
        Wo kommt das Repo her? Das hat da imho auch nix zu suchen.
        • J janni01
          Hallo ich habe auf de raspberry ppi 2 IR-Leseköpfe von Hirche, wenn ich den Smartmeter im Iobroker installiere erkennt er nicht die Leseköpfe. erzeugt nicht die Dropdown Liste und bringt nur Fehler im Protokoll.
          9f99c3ad-faa5-4cac-a658-b86731a69f42-image.png b1627947-9bb1-45f9-9f72-093a927aae4f-image.png
          Danke vorab für die Hilfe..
          c1olli
          @janni01
          Ich habe auch diesen Sensor in der USB Version und das schaut bei mir so aus:
          So läuft das schon seit einiger Zeit einwandfrei.
          Olli
          • C c1olli
            @janni01
            janni01
            @c1olli ich verstehe nicht warum die Schnittstelle nicht dargestellt wird bei mir?
            Hast du die Leseköpfe auch auf eine raspi3 mit SD card?
            C 1 Antwort Letzte Antwort
            • J janni01
              c1olli
              @janni01
              USB Lesekopf von Hitchi, RPi 4 und SD Card.
              Den USB Anschluß konnte ich im entsprechendem Menü (Serielles Gerät: Name) per dropdown auswählen - er wurde nicht gleich automatisch angezeigt.
              Olli
              • C c1olli
                @janni01
                janni01
                @c1olli eben er baut bei mir nicht mal die Liste auf. Da steht es wird gesucht und dann kommt nichts.
                K GlasfaserG 2 Antworten Letzte Antwort
                • J janni01
                  klassisch
                  @janni01 hilft es nach dem Anschließen den Adapter zu stoppen und neu zu starten?
                  • J janni01
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Funktioniert jetzt admin wieder ?
                    @glasfaser sagte in Smartmeter Adapter Probleme mit Hirche IR-Lesekopf:
                    @janni01
                    was erscheint im Log , wieder die gleichen Fehlermeldungen !?
                    Damit meinte ich das Log beim smartmeteradapter
                    Nochmals , was kommt jetzt im Log
                      @janni01
                      janni01
                      @glasfaser Hallo zusammen nach einer Neunstallation des Raspbian und komplettaufsetzen des Systems folgendes:
                      Wenn man den Raspberry aufsetzt sollt man alle Optionen im Raspberry aktivieren wie Serial /I2C / und so weiter...
                      Hierdurch funktionieren die Schnittstellen und die Leseköpfe werden erkannt.
                      Das steht nicht in der Doku.
                      • J janni01
                        HomoranH Offline
                        HomoranH Offline
                        in welcher Doku?
                        RaspBian Install?
                          in welcher Doku?
                          RaspBian Install?
                          janni01
                          @homoran eher in den prerequisites von dem iobroker
                          • J janni01
                            HomoranH Offline
                            HomoranH Offline
                            Das sehe ich nicht unbedingt so.
                            ioBroker geht von einem komplett eingerichteten Betriebssystem aus.
                            Die Möglichkeiten solcher "Fehler" sind zum einen unendlich, zum anderen von dem eingestezten Hardware und OS abhängig, ganz zu schweigen von Containern oder anderen Pitfalls.
                            Dieses bei jedem der >400 Adapter für alle Kombinationen Hardware und OS (und ggf. deren verschiedenen Versionen) zu nennen ist unmöglich
                              janni01
                              @homoran danke trotzdem das es geklappt hat
                              • J janni01
                                HomoranH Offline
                                HomoranH Offline
                                ich habe jetzt die ganze Zeit darüber nachgedacht.
                                @c1olli sagte in Smartmeter Adapter Probleme mit Hirche IR-Lesekopf:
                                USB ist davon eigentlich nicht betroffen!
                                Ist bei mir auch alles nicht aktiviert
                                Da muss es woanders gehangen haben und zufällig, vielleicht durch den folgenden reboot, wieder funktioniert haben
                                  @homoran sagte in Smartmeter Adapter Probleme mit Hirche IR-Lesekopf:
                                  Schon, hier wird aber offenbar serial über USB abgewickelt. Da muss dann auch in raspi-config der serial Port aktiv sein.
                                    HomoranH Offline
                                    HomoranH Offline
                                    @thomas-braun sagte in Smartmeter Adapter Probleme mit Hirche IR-Lesekopf:
                                    klingt komisch, ist es anscheinend auch.
                                    Mein Smartmeter-RasPi mit USB-Lesekopf hat nix wegen i2c o.ä. aktiv
                                      HomoranH Offline
                                      HomoranH Offline
                                      @thomas-braun ich bin sogar jetzt noch einen Schritt weiter gegangen und habe den Punk serial noch einmal auf "nein" gesetzt und die Daten kommen immer noch.
                                      Interessant ist, die Beschreibung für den Punkt serial
                                      anscheinend geht es hier um die serielle Konsole 😂
                                      Man wird gefragt ob diesr Zugang zur Konsole freigeschaltet werden soll
