  4. [OK] InfluxDB - Fehler bei Backup & Connection failed ...
    6.6k
backitupinfluxdb
13 Beiträge 4 Kommentatoren 765 Aufrufe 4 Beobachtet
  • qqolliQ Offline
    qqolliQ Offline
    qqolli
    schrieb am zuletzt editiert von qqolli
    bekomme seit gestern bei der Sicherung im Backitup-Adapter bei influx (Grafana geht ohne Probleme) folgende Meldung:
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_08_15-10_39_47_backupiobroker"
    2021/08/15 10:39:51 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:58784->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (0)...
    2021/08/15 10:40:02 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59018->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (1)...
    2021/08/15 10:40:13 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59310->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (2)...
    2021/08/15 10:40:24 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59614->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (3)...
    2021/08/15 10:40:35 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59928->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (4)...
    2021/08/15 10:40:46 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:60256->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (5)...
    2021/08/15 10:40:58 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:60552->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 3.01s and retrying (6)...
    2021/08/15 10:41:09 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:60886->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 11.441s and retrying (7)...
    2021/08/15 10:41:31 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:33238->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 43.477s and retrying (8)...
    2021/08/15 10:42:15 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:34670->127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2m45.216s and retrying (9)...
    backup: copy backup to file: err=read tcp 127.0.0.1:34670->127.0.0.1:8088: read: connection reset by peer, n=0
    Update: Im Influx-Adapter ist unter Protokomlle zu sehen, das er sich nicht verbinden kann:
    influxdb.0
    2021-08-15 12:25:04.649	info	Connecting http://localhost:8086 ...
    influxdb.0
    2021-08-15 12:24:54.649	error	Error: connect ECONNREFUSED 127.0.0.1:8086
    influxdb.0
    2021-08-15 12:24:54.645	info	Connecting http://localhost:8086 ...
    influxdb.0
    2021-08-15 12:24:44.644	error	Error: connect ECONNREFUSED 127.0.0.1:8086
    influxdb.0
    2021-08-15 12:24:44.639	info	Connecting http://localhost:8086 ...
    influxdb.0
    2021-08-15 12:24:34.638	error	Error: connect ECONNREFUSED 127.0.0.1:8086
    influxdb.0
    2021-08-15 12:24:34.635	info	Connecting http://localhost:8086 ...
    Als Info:
    pi@ioBroker:~ $ sudo iobroker info
    Platform       : linux
    os             : linux
    Architecture   : arm
    CPUs           : 4
    Speed          : 1500 MHz
    Model          : ARMv7 Processor rev 3 (v7l)
    RAM            : 3.7 GB
    System uptime  : 01:33:27
    Node.js        : v12.22.5
    Disk size      : 457.2 GiB
    Disk free      : 449.9 GiB
    adapters count : 339
    NPM            : v6.14.14
    • qqolliQ qqolli
      influxdb.0
      influxdb.0
      influxdb.0
      influxdb.0
      influxdb.0
      influxdb.0
      influxdb.0
      Als Info:
      Platform       : linux
      os             : linux
      Architecture   : arm
      CPUs           : 4
      Speed          : 1500 MHz
      RAM            : 3.7 GB
      Node.js        : v12.22.5
      NPM            : v6.14.14
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      @qqolli welche Version vom influx Adapter hast du installiert?
      qqolliQ 2 Antworten Letzte Antwort
      • FeuersturmF Feuersturm
        qqolliQ Offline
        qqolliQ Offline
        qqolli
        @feuersturm
        hatte ich ganz vergessen, sorry. Es ist die Version 1.9.5.
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          @feuersturm
          Wie gesagt, ist es Version 1.9.5. Hast Du eine Idee dazu, was es sein könnte?
          FeuersturmF simatecS 2 Antworten Letzte Antwort
          • qqolliQ qqolli
            @feuersturm
            FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            @qqolli Nein, spontan nicht. Meine erste Idee / Hoffnung war, dass du den Influx Adapter aus dem Beta Repository installiert hast und die Neueingabe des Passwortes helfen würde. Aber da du auf 1.9.5 bist kann es daran nicht liegen.
            Hast du schon geprüft, dass deine Influx Datenbank auch läuft?
            qqolliQ 1 Antwort Letzte Antwort
            • qqolliQ qqolli
              @feuersturm
              simatecS Offline
              simatecS Offline
              simatec
              @qqolli
              Was für ein System hast du laufen und welche Version von influx läuft bei dir?
              Hast du eventuell ein Systemupgrade in den letzten Tagen gemacht?
              Dort gab es massive Probleme mit einer neuen influx Version.
              • Besuche meine Github Seite
              • HowTo Restore ioBroker
              • simatecS simatec
                @qqolli
                qqolliQ Offline
                qqolliQ Offline
                qqolli
                @simatec
                ich habe ein Raspi 4 mit SSD laufen unter Raspberrymatic. Ja, ein Systemupgrade (sudo apt update && sudo apt dist-upgrade) hatte ich gemacht.
                Die influx-Version ist die 1.9.5.
                  qqolliQ Offline
                  qqolliQ Offline
                  qqolli
                  @feuersturm
                  wie genau kann ich das nochmal prüfen? :-)
                  • qqolliQ qqolli
                    @feuersturm
                    crunchipC Offline
                    crunchipC Offline
                    @qqolli schau mal hier
                      qqolliQ Offline
                      qqolliQ Offline
                      qqolli
                      @crunchip
                      Scheint zu laufen:
                      pi@ioBroker:~ $ apt policy influxdb
                      influxdb:
                        Installiert:           1.8.9-1
                        Installationskandidat: 1.8.9-1
                        Versionstabelle:
                       *** 1.8.9-1 500
                              500 https://repos.influxdata.com/debian buster/stable armhf Packages
                           1.6.4-1+deb10u1 500
                              500 https://archive.raspbian.org/raspbian buster/main armhf Packages
                      und auch
                      pi@ioBroker:~ $ ls -la /usr/lib/influxdb/scripts
                      insgesamt 24
                      drwxr-xr-x 2 root root 4096 Aug 14 10:37 .
                      drwxr-xr-x 3 root root 4096 Okt 10  2020 ..
                      -rw-r--r-- 1 root root  533 Aug  5 00:50 influxdb.service
                      -rwxr-xr-x 1 root root 1116 Aug  5 00:50 influxd-systemd-start.sh
                      -rw-r--r-- 1 root root 5702 Aug  5 00:50 init.sh
                      scheint ok zu sein.
                      • qqolliQ qqolli
                        @crunchip
                        Scheint zu laufen:
                        influxdb:
                          Versionstabelle:
                         *** 1.8.9-1 500
                             1.6.4-1+deb10u1 500
                        und auch
                        insgesamt 24
                        scheint ok zu sein.
                        crunchipC Offline
                        crunchipC Offline
                        @qqolli ok, 1.8.9, Probleme wie in dem gezeigten Link hast/hattest du nicht?
                        Zwecks Backup Problem kann ich dir leider nicht weiterhelfen, nutze ich nicht und bin auch noch auf einer älteren Version. da muss @simatec mal schauen
                          qqolliQ Offline
                          qqolliQ Offline
                          qqolli
                          @crunchip
                          Dank Deines Hinweises auf den anderen Thread habe ich mit
                          nano /usr/lib/influxdb/scripts/influxd-systemd-start.sh
                          das Delay von 1s auf 10s eingestellt und der Adapter wurde grün, hat sich verbunden und keine Fehlermeldung mehr. Backup mit BackitUp geht auch wieder :-)
                          • qqolliQ qqolli
                            @crunchip
                            crunchipC Offline
                            crunchipC Offline
                            @qqolli sagte in [OK] InfluxDB - Fehler bei Backup & Connection failed ...:
                            hattest du ja auch gar nicht angegeben, nur das dein backup nicht funktioniert😉
