<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[OK] InfluxDB - Fehler bei Backup &amp; Connection failed ...]]></title><description><![CDATA[<p dir="auto">Hallo zusammen,</p>
<p dir="auto">bekomme seit gestern bei der Sicherung im Backitup-Adapter bei influx (Grafana geht ohne Probleme) folgende Meldung:</p>
<pre><code>[DEBUG] [influxDB] - Start InfluxDB Backup ...
[DEBUG] [influxDB] - InfluxDB Backup tmp directory created
[DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
[DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
[ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_08_15-10_39_47_backupiobroker"
2021/08/15 10:39:51 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:58784-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (0)...
2021/08/15 10:40:02 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59018-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (1)...
2021/08/15 10:40:13 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59310-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (2)...
2021/08/15 10:40:24 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59614-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (3)...
2021/08/15 10:40:35 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:59928-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (4)...
2021/08/15 10:40:46 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:60256-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2s and retrying (5)...
2021/08/15 10:40:58 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:60552-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 3.01s and retrying (6)...
2021/08/15 10:41:09 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:60886-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 11.441s and retrying (7)...
2021/08/15 10:41:31 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:33238-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 43.477s and retrying (8)...
2021/08/15 10:42:15 Download shard 0 failed copy backup to file: err=read tcp 127.0.0.1:34670-&gt;127.0.0.1:8088: read: connection reset by peer, n=0.  Waiting 2m45.216s and retrying (9)...
backup: copy backup to file: err=read tcp 127.0.0.1:34670-&gt;127.0.0.1:8088: read: connection reset by peer, n=0
</code></pre>
<p dir="auto"><strong>Update:</strong> Im Influx-Adapter ist unter Protokomlle zu sehen, das er sich nicht verbinden kann:</p>
<pre><code>influxdb.0
2021-08-15 12:25:04.649	info	Connecting http://localhost:8086 ...
influxdb.0
2021-08-15 12:24:54.649	error	Error: connect ECONNREFUSED 127.0.0.1:8086
influxdb.0
2021-08-15 12:24:54.645	info	Connecting http://localhost:8086 ...
influxdb.0
2021-08-15 12:24:44.644	error	Error: connect ECONNREFUSED 127.0.0.1:8086
influxdb.0
2021-08-15 12:24:44.639	info	Connecting http://localhost:8086 ...
influxdb.0
2021-08-15 12:24:34.638	error	Error: connect ECONNREFUSED 127.0.0.1:8086
influxdb.0
2021-08-15 12:24:34.635	info	Connecting http://localhost:8086 ...
</code></pre>
<p dir="auto">Als Info:</p>
<pre><code>pi@ioBroker:~ $ sudo iobroker info
Platform       : linux
os             : linux
Architecture   : arm
CPUs           : 4
Speed          : 1500 MHz
Model          : ARMv7 Processor rev 3 (v7l)
RAM            : 3.7 GB
System uptime  : 01:33:27
Node.js        : v12.22.5
Disk size      : 457.2 GiB
Disk free      : 449.9 GiB
adapters count : 339
NPM            : v6.14.14
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/47049/ok-influxdb-fehler-bei-backup-connection-failed</link><generator>RSS for Node</generator><lastBuildDate>Wed, 27 May 2026 04:54:57 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/47049.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Aug 2021 08:56:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Tue, 17 Aug 2021 07:26:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqolli" aria-label="Profile: qqolli">@<bdi>qqolli</bdi></a> sagte in <a href="/post/665367">[OK] InfluxDB - Fehler bei Backup &amp; Connection failed ...</a>:</p>
<blockquote>
<p dir="auto">und der Adapter wurde grün</p>
</blockquote>
<p dir="auto">hattest du ja auch gar nicht angegeben, nur das dein backup nicht funktioniert<img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=":wink:" alt="😉" /></p>
]]></description><link>https://forum.iobroker.net/post/665369</link><guid isPermaLink="true">https://forum.iobroker.net/post/665369</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 17 Aug 2021 07:26:02 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Tue, 17 Aug 2021 07:19:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<p dir="auto">Dank Deines Hinweises auf den anderen Thread habe ich mit</p>
<pre><code>nano /usr/lib/influxdb/scripts/influxd-systemd-start.sh
</code></pre>
<p dir="auto">das Delay von 1s auf 10s eingestellt und der Adapter wurde grün, hat sich verbunden und keine Fehlermeldung mehr. Backup mit BackitUp geht auch wieder :-)</p>
]]></description><link>https://forum.iobroker.net/post/665367</link><guid isPermaLink="true">https://forum.iobroker.net/post/665367</guid><dc:creator><![CDATA[qqolli]]></dc:creator><pubDate>Tue, 17 Aug 2021 07:19:43 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Tue, 17 Aug 2021 07:18:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqolli" aria-label="Profile: qqolli">@<bdi>qqolli</bdi></a> ok, 1.8.9, Probleme wie in dem gezeigten Link hast/hattest du nicht?<br />
Zwecks Backup Problem kann ich dir leider nicht weiterhelfen, nutze ich nicht und bin auch noch auf einer älteren Version. da muss <a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a> mal schauen</p>
]]></description><link>https://forum.iobroker.net/post/665366</link><guid isPermaLink="true">https://forum.iobroker.net/post/665366</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 17 Aug 2021 07:18:27 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Tue, 17 Aug 2021 07:03:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<p dir="auto">Scheint zu laufen:</p>
<pre><code>pi@ioBroker:~ $ apt policy influxdb
influxdb:
  Installiert:           1.8.9-1
  Installationskandidat: 1.8.9-1
  Versionstabelle:
 *** 1.8.9-1 500
        500 https://repos.influxdata.com/debian buster/stable armhf Packages
        100 /var/lib/dpkg/status
     1.6.4-1+deb10u1 500
        500 https://archive.raspbian.org/raspbian buster/main armhf Packages
</code></pre>
<p dir="auto">und auch</p>
<pre><code>pi@ioBroker:~ $ ls -la /usr/lib/influxdb/scripts
insgesamt 24
drwxr-xr-x 2 root root 4096 Aug 14 10:37 .
drwxr-xr-x 3 root root 4096 Okt 10  2020 ..
-rw-r--r-- 1 root root  533 Aug  5 00:50 influxdb.service
-rwxr-xr-x 1 root root 1116 Aug  5 00:50 influxd-systemd-start.sh
-rw-r--r-- 1 root root 5702 Aug  5 00:50 init.sh
</code></pre>
<p dir="auto">scheint ok zu sein.</p>
]]></description><link>https://forum.iobroker.net/post/665360</link><guid isPermaLink="true">https://forum.iobroker.net/post/665360</guid><dc:creator><![CDATA[qqolli]]></dc:creator><pubDate>Tue, 17 Aug 2021 07:03:01 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Tue, 17 Aug 2021 06:42:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqolli" aria-label="Profile: qqolli">@<bdi>qqolli</bdi></a> schau mal <a href="https://forum.iobroker.net/post/662050">hier</a></p>
]]></description><link>https://forum.iobroker.net/post/665354</link><guid isPermaLink="true">https://forum.iobroker.net/post/665354</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Tue, 17 Aug 2021 06:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Tue, 17 Aug 2021 06:35:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/feuersturm" aria-label="Profile: feuersturm">@<bdi>feuersturm</bdi></a></p>
<p dir="auto">Hallo,</p>
<p dir="auto">wie genau kann ich das nochmal prüfen? :-)</p>
]]></description><link>https://forum.iobroker.net/post/665351</link><guid isPermaLink="true">https://forum.iobroker.net/post/665351</guid><dc:creator><![CDATA[qqolli]]></dc:creator><pubDate>Tue, 17 Aug 2021 06:35:53 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Tue, 17 Aug 2021 06:35:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/simatec" aria-label="Profile: simatec">@<bdi>simatec</bdi></a></p>
<p dir="auto">ich habe ein Raspi 4 mit SSD laufen unter Raspberrymatic. Ja, ein Systemupgrade (sudo apt update &amp;&amp; sudo apt dist-upgrade) hatte ich gemacht.</p>
<p dir="auto">Die influx-Version ist die 1.9.5.</p>
]]></description><link>https://forum.iobroker.net/post/665350</link><guid isPermaLink="true">https://forum.iobroker.net/post/665350</guid><dc:creator><![CDATA[qqolli]]></dc:creator><pubDate>Tue, 17 Aug 2021 06:35:21 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Mon, 16 Aug 2021 11:02:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqolli" aria-label="Profile: qqolli">@<bdi>qqolli</bdi></a><br />
Was für ein System hast du laufen und welche Version von influx läuft bei dir?<br />
Hast du eventuell ein Systemupgrade in den letzten Tagen gemacht?</p>
<p dir="auto">Dort gab es massive Probleme mit einer neuen influx Version.</p>
]]></description><link>https://forum.iobroker.net/post/664832</link><guid isPermaLink="true">https://forum.iobroker.net/post/664832</guid><dc:creator><![CDATA[simatec]]></dc:creator><pubDate>Mon, 16 Aug 2021 11:02:28 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Sun, 15 Aug 2021 21:52:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqolli" aria-label="Profile: qqolli">@<bdi>qqolli</bdi></a> Nein, spontan nicht. Meine erste Idee / Hoffnung war, dass du den Influx Adapter aus dem Beta Repository installiert hast und die Neueingabe des Passwortes helfen würde. Aber da du auf 1.9.5 bist kann es daran nicht liegen.</p>
<p dir="auto">Hast du schon geprüft, dass deine Influx Datenbank auch läuft?</p>
]]></description><link>https://forum.iobroker.net/post/664656</link><guid isPermaLink="true">https://forum.iobroker.net/post/664656</guid><dc:creator><![CDATA[Feuersturm]]></dc:creator><pubDate>Sun, 15 Aug 2021 21:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Sun, 15 Aug 2021 10:47:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/feuersturm" aria-label="Profile: feuersturm">@<bdi>feuersturm</bdi></a></p>
<p dir="auto">Wie gesagt, ist es Version 1.9.5. Hast Du eine Idee dazu, was es sein könnte?</p>
]]></description><link>https://forum.iobroker.net/post/664328</link><guid isPermaLink="true">https://forum.iobroker.net/post/664328</guid><dc:creator><![CDATA[qqolli]]></dc:creator><pubDate>Sun, 15 Aug 2021 10:47:00 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Sun, 15 Aug 2021 09:35:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/feuersturm" aria-label="Profile: feuersturm">@<bdi>feuersturm</bdi></a></p>
<p dir="auto">Hi,</p>
<p dir="auto">hatte ich ganz vergessen, sorry. Es ist die Version 1.9.5.</p>
]]></description><link>https://forum.iobroker.net/post/664289</link><guid isPermaLink="true">https://forum.iobroker.net/post/664289</guid><dc:creator><![CDATA[qqolli]]></dc:creator><pubDate>Sun, 15 Aug 2021 09:35:56 GMT</pubDate></item><item><title><![CDATA[Reply to [OK] InfluxDB - Fehler bei Backup &amp; Connection failed ... on Sun, 15 Aug 2021 09:33:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/qqolli" aria-label="Profile: qqolli">@<bdi>qqolli</bdi></a> welche Version vom influx Adapter hast du installiert?</p>
]]></description><link>https://forum.iobroker.net/post/664287</link><guid isPermaLink="true">https://forum.iobroker.net/post/664287</guid><dc:creator><![CDATA[Feuersturm]]></dc:creator><pubDate>Sun, 15 Aug 2021 09:33:39 GMT</pubDate></item></channel></rss>
