  3. Entwicklung
  4. Adapter: Worx Landroid v2.x.x
1.2k Beiträge 121 Kommentatoren 579.1k Aufrufe 64 Beobachtet
    Semmy
    #430
    @hsteinme Der Ordner rawmqtt fehlt bei mir aber
    hsteinmeH 1 Antwort Letzte Antwort
    • S Semmy
      hsteinmeH Offline
      hsteinmeH Offline
      hsteinme
      #431
      @semmy Dann aktivier mal "add raw data" in den Adapter-Einstellungen.
      • hg6806H Offline
        hg6806H Offline
        hg6806
        #432
        Wo finde ich denn eigentlich eine Liste für "sendCommand"?
        • hg6806H hg6806
          hsteinmeH Offline
          hsteinmeH Offline
          hsteinme
          #433
          @hg6806 Markiere die sendCommand-Zeile im Objektbaum des Adapters, klicke ganz rechts auf das Bleistift-Symbol, aktiviere den Reiter RAW (EXPERTS ONLY) und schaue, was unter "states" steht:
              "states": {
                "1": "Start",
                "2": "Stop",
                "3": "Home",
                "4": "Start Zone Taining",
                "5": "Lock",
                "6": "Unlock",
                "7": "Restart Robot",
                "8": "pause when follow wire",
                "9": "safe homing"
          hg6806H Jens MeyerJ H 3 Antworten Letzte Antwort
          • hsteinmeH hsteinme
                "states": {
                  "1": "Start",
                  "2": "Stop",
                  "3": "Home",
                  "5": "Lock",
                  "6": "Unlock",
                  "9": "safe homing"
            hg6806H Offline
            hg6806H Offline
            hg6806
            #434
            @hsteinme
            Ah - ok, bei mir geht es nur bis 7
              "type": "state",
              "common": {
                "name": "send Command",
                "type": "number",
                "role": "value",
                "min": 1,
                "max": 7,
                "read": true,
                "write": true,
                "desc": "send Command to Landroid",
                "states": {
                  "1": "Start",
                  "2": "Stop",
                  "3": "Home",
                  "5": "Lock",
                  "6": "Unlock",
            Habe die 1.4.3 instaliert
            • hg6806H hg6806
              @hsteinme
                "type": "state",
                "common": {
                  "type": "number",
                  "role": "value",
                  "min": 1,
                  "max": 7,
                  "read": true,
                  "write": true,
                  "states": {
                    "1": "Start",
                    "2": "Stop",
                    "3": "Home",
                    "5": "Lock",
                    "6": "Unlock",
              hsteinmeH Offline
              hsteinmeH Offline
              hsteinme
              #435
              @hg6806 Beachte https://github.com/iobroker-community-adapters/ioBroker.worx/issues/284#issuecomment-874628679
                    "states": {
                      "1": "Start",
                      "2": "Stop",
                      "3": "Home",
                      "5": "Lock",
                      "6": "Unlock",
                      "9": "safe homing"
                Jens MeyerJ Offline
                Jens MeyerJ Offline
                Jens Meyer
                schrieb am zuletzt editiert von Jens Meyer
                #436
                @hsteinme
                Hallo, da hab ich gleich mal ne Frage… wie löse ich so ein Befehl aus? Unter send command die Zahl eingeben? Von 1-7 ?
                Also 3 für Home … oder kann ich auch Home schreiben
                • Jens MeyerJ Jens Meyer
                  @hsteinme
                  hsteinmeH Offline
                  hsteinmeH Offline
                  hsteinme
                  #437
                  @jens-meyer Oh Mann! Warum probierst Du es nicht einfach aus? Dein Mäher wird Dir dabei schon nicht um die Ohren fliegen 😊
                  • Test im Objektbaum
                    • auf Bleistift rechts neben Eingabefeld klicken und Kommandotext eingeben und SET-Taste drücken:
                      • nichts passiert
                    • auf Bleistift rechts neben Eingabefeld klicken und Kommandonummer eingeben und SET-Taste drücken:
                      • das Gewünschte passiert
                    • in Eingabefeld klicken, eine geschlossene Combobox wird angezeigt, Combobox öffnen, gewünschtes Kommando und anschließend Haken rechts daneben anklicken:
                  • Test in einem Javascript mit setState('worx.0.9999.mower.sendCommand', XXXX);
                    • XXXX ist ein String und enthält einen Kommandotext:
                      • im Log erscheint eine Warnung wegen der Verwendung eines falschen Datentyps, ansonsten passiert aber nichts
                    • XXXX ist ein numerisches Feld und enthält eine Kommandonummer:
                  Jens MeyerJ 1 Antwort Letzte Antwort
                        • nichts passiert
                    Jens MeyerJ Offline
                    Jens MeyerJ Offline
                    Jens Meyer
                    #438
                    @hsteinme
                    nik82N 1 Antwort Letzte Antwort
                      @hsteinme
                      nik82N Offline
                      nik82N Offline
                      nik82
                      schrieb am zuletzt editiert von nik82
                      #439
                      kann man eigentlich über den Iobroker den Punkt "totalTime" resetten oder geht das nur via App?
                      --- EDIT ----
                      Bitte vergessen, war quatsch, die Time lässt sich ja auch nicht in der App resetten...
                      • hg6806H Offline
                        hg6806H Offline
                        hg6806
                        #440
                        Den Landroid würde ich gerne manuell laden lassen, sprich, wenn die Photovoltaik Anlage gerade ins Netz einspeist, wie z.B. morgens, wenn der Rasen noch feucht ist.
                        Ich habe versucht über einen Sonoff Schalter die Ladestation komplett abzuschalten, das Problem ist, dass dann auch der Landroid sich ganz abschaltet.
                        Geht das evtl. über einen Befehl? Wenn nicht werde ich das mal bei Worx anfragen.
                        Jede Ladung ist zwar nur ca. 0,1kWh, das summiert sich aber auch auf.
                        M hsteinmeH 3 Antworten Letzte Antwort
                        • hg6806H hg6806
                          MartyBr
                          #441
                          @hg6806
                          Das habe ich auch noch nicht geschafft. Bin an der Antwort von Worx interessiert.
                          Martin
                          Homematic und Homematic IP
                          • hg6806H Offline
                            hg6806H Offline
                            hg6806
                            #442
                            ...habe es mal angefragt und werde berichten.
                            • hg6806H hg6806
                              hsteinmeH Offline
                              hsteinmeH Offline
                              hsteinme
                              #443
                              @hg6806 sagte in Adapter: Worx Landroid:
                              Das Ladeverhalten des Mähers lässt sich weder über ein Web-Kommando noch über einen Dialog am Gerät beeinflussen.
                                    "states": {
                                      "1": "Start",
                                      "2": "Stop",
                                      "3": "Home",
                                      "5": "Lock",
                                      "6": "Unlock",
                                      "9": "safe homing"
                                Habedere
                                #444
                                @hsteinme sagte in Adapter: Worx Landroid:
                                    "states": {
                                      "1": "Start",
                                      "2": "Stop",
                                      "3": "Home",
                                      "5": "Lock",
                                      "6": "Unlock",
                                      "9": "safe homing"
                                Frage eines Noobs - kann ich den Robi aus einem "festgefahren Error" zurücksetzen?
                                Der M500 verirrt sich öfter im neuem Klettergerüst - wenn ich jetzt dann zwei Wochen im Urlaub bin möchte ich den da gerne resetten...
                                Mfg
                                • H Habedere
                                      "states": {
                                        "1": "Start",
                                        "2": "Stop",
                                        "3": "Home",
                                        "5": "Lock",
                                        "6": "Unlock",
                                        "9": "safe homing"
                                  Mfg
                                  hsteinmeH Offline
                                  hsteinmeH Offline
                                  hsteinme
                                  #445
                                  @habedere sagte in Adapter: Worx Landroid:
                                  Da hast Du keine Chance. In einem Fehlerfall musst Du am Mäher selbst zunächst mit der START-Taste den Fehler quittieren und dann mit START und OK bzw. mit HOME und OK den Mäher wieder in Bewegung setzen.
                                  Behördliche Sicherheitsvorschriften werden als Grund für diese Vorgehensweise genannt.
                                  • S Semmy
                                    Diese Logik kannst Du in einem kleinen Skript realisieren
                                    So zum Beispiel:
                                    'use strict';
                                    const startSequenceKey = "worx.0.999...999.areas.startSequence";
                                    var Arr = JSON.parse(getState(startSequenceKey).val);
                                    Arr.unshift(Arr.pop());
                                    setState(startSequenceKey, JSON.stringify(Arr));
                                    • In Zeile 3 wird der startSequence-String ausgelesen und in eine eindimensionale Tabelle konvertiert.
                                    • Zeile 4: Arr.pop() liefert den rechten Wert der Tabelle und entfernt ihn dort, unshift stellt ihn an den Anfang der Tabelle.
                                    • Zeile 5 konvertiert die Tabelle zurück in einen String der Art [x, ...,x] und stellt diesen wieder in startSequence ab.
                                    Hallo und vielen Dank, funktioniert tadellos.
                                    Viele Grüße
                                    Semmy
                                    Semmy
                                    #446
                                    @semmy sagte in Adapter: Worx Landroid:
                                    'use strict'; const startSequenceKey = "worx.0.999...999.areas.startSequence"; var Arr = JSON.parse(getState(startSequenceKey).val); Arr.unshift(Arr.pop()); setState(startSequenceKey, JSON.stringify(Arr));
                                    Hallo
                                    Ich habe Firmware 3.25 installiert und jetzt funktioniert das Script nicht mehr, kommt immer folgende Fehlermeldung:
                                    javascript.0 (9961) script.js.Mähroboter.Sequenz_verschieben: SyntaxError: Unexpected token , in JSON at position 1
                                    Was kann das jetzt wieder sein?
                                    Viele Grüße
                                    Semmy
                                      So zum Beispiel:
                                      'use strict';
                                      Semmy
                                      #447
                                      So zum Beispiel:
                                      'use strict';
                                      Hallo
                                      Viele Grüße
                                      Semmy
                                      • S Semmy
                                        So zum Beispiel:
                                        'use strict';
                                        Hallo
                                        Viele Grüße
                                        Semmy
                                        hsteinmeH Offline
                                        hsteinmeH Offline
                                        hsteinme
                                        #448
                                        @semmy : Welcher Wert steht denn vor dem Skriptlauf bei Dir in worx.0.999...999.areas.startSequence?
                                          Semmy
                                          #449
                                          Das steht davor:
