  4. Test Adapter influxdb 2.0
293 Beiträge 43 Kommentatoren 96.7k Aufrufe 43 Beobachtet
  • FeuersturmF Feuersturm
    @apollon77 @Excodibur
    Ich hab vor dem Update "Alle Daten in Datenbank löschen" ausgeführt.
    Nach dem Update und beim Start des Adapters waren folgende Errors im Log
    10 Aug 2021 00:52:44.990
    host.ioBrokerTestsystem Restart adapter system.adapter.influxdb.0 because enabled
    10 Aug 2021 00:52:44.988
    host.ioBrokerTestsystem instance system.adapter.influxdb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.ioBrokerTestsystem Caught by controller[0]: at /opt/iobroker/node_modules/@influxdata/influxdb-client/src/impl/node/NodeHttpTransport.ts:111:14
    10 Aug 2021 00:52:44.987
    host.ioBrokerTestsystem Caught by controller[0]: at at._request (/opt/iobroker/node_modules/@influxdata/influxdb-client/src/impl/node/NodeHttpTransport.ts:242:22)
    10 Aug 2021 00:52:44.986
    host.ioBrokerTestsystem Caught by controller[0]: at at.requestApi (/opt/iobroker/node_modules/@sentry/node/src/integrations/http.ts:126:10)
    host.ioBrokerTestsystem Caught by controller[0]: at at.request (http.js:46:10)
    10 Aug 2021 00:52:44.985
    host.ioBrokerTestsystem Caught by controller[0]: at new ClientRequest (_http_client.js:242:14)
    10 Aug 2021 00:52:44.984
    host.ioBrokerTestsystem Caught by controller[0]: at ClientRequest.setHeader (_http_outgoing.js:533:3)
    10 Aug 2021 00:52:44.983
    host.ioBrokerTestsystem Caught by controller[0]: TypeError [ERR_INVALID_CHAR]: Invalid character in header content ["authorization"]
    10 Aug 2021 00:52:44.982
    host.ioBrokerTestsystem Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    10 Aug 2021 00:53:18.449
    influxdb.0 (1959) Terminated (UNCAUGHT_EXCEPTION): Without reason
    10 Aug 2021 00:53:18.443
    influxdb.0 (1959) terminating
    10 Aug 2021 00:53:18.417
    influxdb.0 (1959) Exception-Code: ERR_INVALID_CHAR: Invalid character in header content ["authorization"]
    10 Aug 2021 00:53:18.416
    influxdb.0 (1959) TypeError [ERR_INVALID_CHAR]: Invalid character in header content ["authorization"] at ClientRequest.setHeader (_http_outgoing.js:533:3) at new ClientRequest (_http_client.js:242:14) at at.request (http.js:46:10) at at.requestApi (/opt/iobroker/node_modules/@sentry/node/src/integrations/http.ts:126:10) at at._request (/opt/iobroker/node_modules/@influxdata/influxdb-client/src/impl/node/NodeHttpTransport.ts:242:22) at /opt/iobroker/node_modules/@influxdata/influxdb-client/src/impl/node/NodeHttpTransport.ts:111:14
    10 Aug 2021 00:53:18.414
    influxdb.0 (1959) unhandled promise rejection: Invalid character in header content ["authorization"]
    10 Aug 2021 00:53:18.412
    influxdb.0 (1959) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    10 Aug 2021 00:53:18.241
    influxdb.0 (1959) Connecting to InfluxDB 2
    10 Aug 2021 00:53:18.239
    influxdb.0 (1959) Influx DB Version used: 2.x
    10 Aug 2021 00:53:18.238
    influxdb.0 (1959) Connecting http://192.168.178.101:8086 ...
    10 Aug 2021 00:53:18.235
    influxdb.0 (1959) No stored data from last exit found
    10 Aug 2021 00:53:18.179
    influxdb.0 (1959) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.influxdb, node: v12.22.2, js-controller: 3.3.15
    Nach dem Update ist der Token in den Einstellungen "kaputt", bzw. enthält irgendwelche Steuerzeichen.
    Nachdem ich den Token aus der Influx GUI (welcher sich geändert hat) neu in der Instanz eingetragen hat, ist die Instanz erfolgreich gestartet.
    #79
    @feuersturm Achja ... das hatten wir vergesen zu erwähnen ;-)) Passwort bzw Token wird jetzt verschlüsselt gespeichert und muss dahger einmalig neu eingegeben werden
    • apollon77A apollon77
      FeuersturmF Offline
      FeuersturmF Offline
      Feuersturm
      #80
      @apollon77 Ah :-)
      Irgendwas scheint noch nicht ganz sauber zu funktionieren. Ich lasse den Datenpunkt proxmox.0.node_pve.cpu in die Datenbank speichern. In Influx wird hier folgendes angezeigt:
      In ioBroker wird mir der Wert vom Datenpunkt korrekt angezeigt:
      Das sind die Einstellungen vom Datenpunkt
      Influx Version
      proxmox@DatenbankenTest:~$ influx version
      Influx CLI 2.0.7 (git: 2a45f0c037) build_date: 2021-06-04T19:17:40Z
      Welche weiteren Infos helfen euch weiter?
      Edit:
      proxmox@DatenbankenTest:~$ influx query 'from(bucket:"iobroker") |> range(start:-10m) |> filter(fn: (r) => r._measurement == "proxmox.0.node_pve.cpu")'
      Result: _result
      Table: keys: [_start, _stop, _field, _measurement]
                         _start:time                      _stop:time           _field:string     _measurement:string                      _time:time   _value:bool
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:42:01.093000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:43:01.075000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:44:01.155000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:45:01.086000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:46:01.129000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:47:01.082000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:48:01.104000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:49:01.089000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:50:01.119000000Z          true
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                     ack  proxmox.0.node_pve.cpu  2021-08-09T23:51:01.088000000Z          true
                         _start:time                      _stop:time           _field:string     _measurement:string                      _time:time             _value:string
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:42:01.093000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:43:01.075000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:44:01.155000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:45:01.086000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:46:01.129000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:47:01.082000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:48:01.104000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:49:01.089000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:50:01.119000000Z  system.adapter.proxmox.0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                    from  proxmox.0.node_pve.cpu  2021-08-09T23:51:01.088000000Z  system.adapter.proxmox.0
                         _start:time                      _stop:time           _field:string     _measurement:string                      _time:time                  _value:float
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:42:01.093000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:43:01.075000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:44:01.155000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:45:01.086000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:46:01.129000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:47:01.082000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:48:01.104000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:49:01.089000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:50:01.119000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                       q  proxmox.0.node_pve.cpu  2021-08-09T23:51:01.088000000Z                             0
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:42:01.093000000Z                         18.98
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:43:01.075000000Z                         18.47
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:44:01.155000000Z                         18.68
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:45:01.086000000Z                         16.12
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:46:01.129000000Z                         17.03
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:47:01.082000000Z                         16.98
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:48:01.104000000Z                         16.77
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:49:01.089000000Z                         18.57
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:50:01.119000000Z                          20.2
      2021-08-09T23:41:06.058022993Z  2021-08-09T23:51:06.058022993Z                   value  proxmox.0.node_pve.cpu  2021-08-09T23:51:01.088000000Z                         21.49
      ExcodiburE apollon77A 2 Antworten Letzte Antwort
        @apollon77 Ah :-)
        Influx Version
        Edit:
        Result: _result
        ExcodiburE Offline
        ExcodiburE Offline
        Excodibur
        schrieb am zuletzt editiert von Excodibur
        #81
        @feuersturm Ich kenne dein Query-Tool nicht, aber kannst du dort die mean-Funktion auf das value-Feld beschränken? ack ist Boolean und from String, darauf wird die mean-Funktion sehr wahrscheinlich solche Fehler werfen. Im Adapter-Code wird die Funktion immer nur auf das value-Feld ausgeführt und dort z.B. bei boolean Werten ausgelassen, um solche Fehler nicht zu produzieren.
        Die letzte Query kannst du übersichtlicher gestalten, indem du noch |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value") anhängst.
          @apollon77 Ah :-)
          Influx Version
          Edit:
          Result: _result
          #82
          @feuersturm WIe Excodibur sagt, Influxdb 1 hatscheinbar ein "Mean auf boolean" mit nem "percentile 50" oder soweas intern gleichgesetzt. FluxQL macht das scheinbar nicht. Und ja bei Boolean gibt es kein "vielleicht" was im Zweifel das Ergebnis von mean ist wenn die Daten nicht 100% treu oder false sind :-)
          Kleiner Randtip (auch wenn offtopic) : mean/avg ist alles blödsinn :-))) https://www.elastic.co/de/blog/averages-can-dangerous-use-percentile
          K S 2 Antworten Letzte Antwort
            Kueppert
            #83
            @apollon77 direkt mal in der Influx1DB auf percentile(50) umgestellt für nen Bool-Wert. Mal sehen, ob ich das Englisch da korrekt verstanden hab ^^
            • K Kueppert
              S Nicht stören
              S Nicht stören
              stenmic
              #84
              kurze Frage, wird jetzt die eingestellte Vorhaltezeit der einzelnen Datenpunkte beachtet?
              Ich kann das aus den Beiträgen nicht wirklich rauslesen.
              • S stenmic
                #85
                @stenmic hat noch nie geklappt und die Einstellung ist daher auch in der 2.0 ganz weg. Geht nur noch pro DB - aber da geht es jetzt auch wirklich.
                  S Nicht stören
                  S Nicht stören
                  stenmic
                  #86
                  @apollon77 ok… kann ich mehrere Datenbanken anlegen?
                  Geht das über Instanzen?
                    S Nicht stören
                    S Nicht stören
                    stenmic
                    #87
                    @apollon77 weißt du vielleicht wie das der sql-Adapter mit ner MariaDB regelt? Funktionieren da die Vorgaben oder ist das auch nur eine “Attrappe“
                    • ExcodiburE Excodibur
                      FeuersturmF Offline
                      FeuersturmF Offline
                      Feuersturm
                      #88
                      @excodibur
                      Die influxdb UI wurde bei mir standardmäßig mit installiert und ist über den port 8086 erreichbar.
                      Wenn ich "value" auswähle, dann werden mir die Werte wieder dargestellt.
                      Das ist die Ausgabe mit der optimierten Query:
                      proxmox@DatenbankenTest:~$ influx query 'from(bucket:"iobroker") |> range(start:-15m) |> filter(fn: (r) => r._measurement == "proxmox.0.node_pve.cpu")|> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")'
                      Result: _result
                      Table: keys: [_start, _stop, _measurement]
                      _start:time                      _stop:time     _measurement:string                      _time:time      ack:bool               from:string                       q:float                   value:float
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:31:20.467000000Z          true  system.adapter.proxmox.0                             0                         20.61
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:32:20.476000000Z          true  system.adapter.proxmox.0                             0                         26.39
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:33:20.478000000Z          true  system.adapter.proxmox.0                             0                         21.75
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:34:20.487000000Z          true  system.adapter.proxmox.0                             0                         22.67
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:35:20.475000000Z          true  system.adapter.proxmox.0                             0                         19.91
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:36:20.472000000Z          true  system.adapter.proxmox.0                             0                         20.58
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:37:20.490000000Z          true  system.adapter.proxmox.0                             0                         18.83
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:38:20.483000000Z          true  system.adapter.proxmox.0                             0                         22.74
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:39:20.483000000Z          true  system.adapter.proxmox.0                             0                         18.35
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:40:20.479000000Z          true  system.adapter.proxmox.0                             0                         18.97
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:41:20.481000000Z          true  system.adapter.proxmox.0                             0                         18.96
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:42:20.481000000Z          true  system.adapter.proxmox.0                             0                         25.59
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:43:20.480000000Z          true  system.adapter.proxmox.0                             0                         17.72
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:44:20.483000000Z          true  system.adapter.proxmox.0                             0                         15.64
                      2021-08-10T18:31:15.028415368Z  2021-08-10T18:46:15.028415368Z  proxmox.0.node_pve.cpu  2021-08-10T18:45:20.476000000Z          true  system.adapter.proxmox.0                             0                         19.26
                      Sieht somit doch gut aus :)
                      • S stenmic
                        #89
                        @stenmic Exakt. Jede instanz eine DB, damit kannst Du auch genau konfigurieren welche Datenpunkte wo hin laufen sollen
                        • S stenmic
                          #90
                          @stenmic Was meinst Du? MariaDB ist MySQL und so einfach MySQL einricjten, IP und Port, fertig. Oder was war die Frage (auch wenn das hier nicht reingehört)
                            @excodibur
                            Result: _result
                            #91
                            @feuersturm Es wurde nich gemedlet das der Adapter craht bei Timeouts bzw Connection Lost ... das schaut sich @Excodibur gerade noch an ...
                              S Nicht stören
                              S Nicht stören
                              stenmic
                              #92
                              @apollon77 sagte in Test Adapter influxdb 2.0:
                              Geht das nur mit Influx 2.0 oder dann auch mit der 1.8er Version.
                              • S stenmic
                                #93
                                @stenmic dann auch mit 1.8
                                  S Nicht stören
                                  S Nicht stören
                                  stenmic
                                  #94
                                  @apollon77 super… ich setzte gerade meinen iobroker neu auf.
                                  Soll ich schon den neuen Adapter nehmen bzw. könnt ihr schon abschätzen wann er stable wird?
                                  Bei influxdb bin ich unentschlossen 1.8 oder 2.0
                                  • S stenmic
                                    #95
                                    @stenmic sagte in Test Adapter influxdb 2.0:
                                    Naja wir sind hier gerade im Alpha Test ... Wenn alles klappt gehen wir diese Woche noch ins Beta/Latest. Dann hngt es vom User-Feedback ab wie schnell wir Stable gehen. Aber frühestens 14 tage nach Beta
                                    • apollon77A Offline
                                      #96
                                      AUf GitHub ist eine neue Version - immer noch v2.1.0 ... also bitte nach Update manuell Adapter neustarten.
                                      passt bei euch alles?
                                        ChaotC Offline
                                        ChaotC Offline
                                        Chaot
                                        #97
                                        @apollon77
                                        Mal eine Frage.
                                        Ich arbeite scheinbar mit InfluxDB Version 1.6.4 in einem Proxmox Container.
                                        Ist es sinnvoll ein Update zu machen?
                                        Welche Version wäre sinnvoll?
                                        Gibt es irgendwo eine verständliche Anleitung dafür?
                                        Mir sind die vorhandenen Daten nicht unbedingt wichtig falls die verloren gehen. Wäre zwar schön die zu übernehemn, aber wenn es sich nicht vermeiden lässt dann muss ich eben damit leben.
                                        Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                                        • ChaotC Chaot
                                          @apollon77
                                          Mal eine Frage.
                                          #98
                                          @chaot
                                          Dann arbeitest du offenbar mit den distributionsseitig gelieferten Paket/Softwarestand.
                                          apt policy influxdb
                                          zeigt das Repository.
                                          Wenn du nichts vermisst (und das scheint ja der Fall zu sein), dann würde ich die Version und das Repository auch beibehalten
