Adapter "smartmeter"
So,
bin jetzt mit diesem Tastkopf:
http://www.emh-metering.de/media//emh-m … d-1.40.pdf
Und diesen Einstellungen:
Soweit das im iobroker log das steht:
smartmeter.0 2017-02-04 17:16:23.444 debug smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000 smartmeter.0 2017-02-04 17:16:23.443 debug smartmeter.0 CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE smartmeter.0 2017-02-04 17:16:23.443 debug smartmeter.0 CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE smartmeter.0 2017-02-04 17:16:23.443 debug smartmeter.0 INITIAL MESSAGES TO SEND: 2 smartmeter.0 2017-02-04 17:16:23.443 debug smartmeter.0 SERIALPORT RESET BAUDRATE TO 300 smartmeter.0 2017-02-04 17:16:23.443 debug smartmeter.0 SERIALPORT OPEN smartmeter.0 2017-02-04 17:16:23.443 debug smartmeter.0 CREATE SERIALPORT: 300 7 1 even smartmeter.0 2017-02-04 17:16:23.443 debug smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":300,"transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate T30 2017-02-04 17:15:50.689 info host.T30 Restart adapter system.adapter.smartmeter.0 because enabled T30 2017-02-04 17:15:50.688 error host.T30 instance system.adapter.smartmeter.0 terminated with code 0 (OK) smartmeter.0 2017-02-04 17:15:50.168 debug smartmeter.0 SERIALPORT CLOSE smartmeter.0 2017-02-04 17:15:50.168 warn smartmeter.0 Exception: Error: No answer from Serial Device after last request. smartmeter.0 2017-02-04 17:15:50.167 error smartmeter.0 Error: No answer from Serial Device after last request. at SerialRequestResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-o smartmeter.0 2017-02-04 17:15:50.167 error smartmeter.0 uncaught exception: No answer from Serial Device after last request. smartmeter.0 2017-02-04 17:15:50.165 debug smartmeter.0 MESSAGE TIMEOUT TRIGGEREDWährend der Adapter läuft kann ich über die Konsole````
cat /dev/ttyUSB04/ITR5EM214
F.F(00000000)
0.0.0(1240007670003202)
0.2.0(V01.69#EEA3546C)
0.2.1(00017245)
1.7.0(04.82kW)
2.7.0(00.00kW)
1.8.1(021872.0kWh)
1.8.2(000000.0kWh)
2.8.1(010442.9kWh)
2.8.2(000000.0kWh)
31.7.0(+013.9A)
51.7.0(+005.5A)
71.7.0(+006.2A)
C.1(53965555)
C.5.0(L1-L2-L3)
C.6.3(03.77V)
C.8.1(024455.78h)
C.8.2(000000.00h)
C.13.21(00000001*secs)
C.13.22(00000001)
C.90(00000100)
!Nach dem letzten Wert "C90" kommt immer das "!" Zeichen, dann macht der Adapter einen restart und das ganze beginnt von vorne. iobroker Objekte sind nicht angelegt worden. Habe ich da jetzt noch einen Einstellungsfehler? Danke und Gruß Mirko -
Was muss ich den tun um den Lesekopf ans laufenb zu bekommen ?
Habe einen Pi 3 als 2. Host an meine iobroker Installation angebunden.
Jessie light installiert und dann iobroker drauf und als Host eingerichtet.
Das funktioniert auch.
Dann habe ich den IR-Lesekopf an einen USB-Anschluss angesteckt und den smartmeter Adapter installiert.
Bekomme aber immer Fehlermeldungen:
obroker2 2017-02-04 17:18:19.889 info host.iobroker2 Restart adapter system.adapter.smartmeter.0 because enabled iobroker2 2017-02-04 17:18:19.888 error host.iobroker2 instance system.adapter.smartmeter.0 terminated with code 0 (OK) smartmeter.0 2017-02-04 17:18:19.359 warn smartmeter.0 Exception: Error: Serial port data bits invalid, check your configuration! smartmeter.0 2017-02-04 17:18:19.359 error smartmeter.0 Error: Serial port data bits invalid, check your configuration! at Error (native) at main (/opt/iobroker/node_modules/iobroker.smartmeter/smartmeter.js:88:23) at Adapter. smartmeter.0 2017-02-04 17:18:19.358 error smartmeter.0 uncaught exception: Serial port data bits invalid, check your configuration! smartmeter.0 2017-02-04 17:18:19.357 info smartmeter.0 starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.3In den Einstellungen habe ich bei Data-Bits schon alles durch.
Jedes mal wenn ich gespeichert habe und dann in die Einstellungen gehe ist Data-Bits wieder leer ?
(Wie kann ich sehen, evtl. ohne den Adapter, ob der Lesekopf überhaupt erkannt wird und Daten gelesen werden ?)
Zum Testen kannst du mal hier schauen:
http://forum.iobroker.net/viewtopic.php … =40#p51107
und hier:
http://wiki.volkszaehler.org/hardware/c ... nter_linux
Welchen Tastkopf hast du denn und welchen Zähler?
Ich kann meinen mit 300 7 N 1 ansprechen... und bekomme wenigstens etwas aus dem Zähler... bis sich der Adapter wieder restartet :|
cat /dev/ttyUSB0sehen das einige Daten kommen: `Ist das auch so wenn du parallel zum Adapter NICHTS per cat selbst ausliesst? Die Daten scheinen korrekt zu sein. Es kann nur sein das dein cat bedeutet das der Adapter (der ja auch da lesen will) nicht lesen darf bzw nichts bekommt.
Jedes mal wenn ich gespeichert habe und dann in die Einstellungen gehe ist Data-Bits wieder leer ? `
lass mich heute Abend mal schauen. Die Sache mit Databits in den einstellungen ist erst gestern Abend reingekommen und muss ich noch testen … Sorry. Checke ich heute abend!
cat /dev/ttyUSB0sehen das einige Daten kommen: `Ist das auch so wenn du parallel zum Adapter NICHTS per cat selbst ausliesst? Die Daten scheinen korrekt zu sein. Es kann nur sein das dein cat bedeutet das der Adapter (der ja auch da lesen will) nicht lesen darf bzw nichts bekommt. `
Wenn ich "cat" beende, sieht es im iobroker log so aus:
! 017-02-04 17:45:21.060 - [31merror[39m: smartmeter.0 uncaught exception: No answer from Serial Device after last request.
! 2017-02-04 17:45:21.067 - [31merror[39m: smartmeter.0 Error: No answer from Serial Device after last request.
! at SerialRequestResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:148:11)
! at null. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:60:26)
! at Timer.listOnTimeout (timers.js:92:15)
! 2017-02-04 17:45:21.071 - [33mwarn[39m: smartmeter.0 Exception: Error: No answer from Serial Device after last request.
! 2017-02-04 17:45:21.075 - [34mdebug[39m: smartmeter.0 SERIALPORT CLOSE
! 2017-02-04 17:45:21.576 - [32minfo[39m: smartmeter.0 terminating
! 2017-02-04 17:45:21.594 - [31merror[39m: host.T30 instance system.adapter.smartmeter.0 terminated with code 0 (OK)
! 2017-02-04 17:45:21.597 - [32minfo[39m: host.T30 Restart adapter system.adapter.smartmeter.0 because enabled
! 2017-02-04 17:45:51.618 - [32minfo[39m: host.T30 instance system.adapter.smartmeter.0 started with pid 6422
! 2017-02-04 17:45:56.521 - [34mdebug[39m: smartmeter.0 objectDB connected
! 2017-02-04 17:45:56.677 - [34mdebug[39m: smartmeter.0 statesDB connected
! 2017-02-04 17:45:56.767 - [32minfo[39m: smartmeter.0 starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.3
! 2017-02-04 17:45:56.785 - [34mdebug[39m: smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"600","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"protocolD0WakeupCharacters":null,"obisFallbackMedium":1}
! 2017-02-04 17:45:56.809 - [34mdebug[39m: smartmeter.0 CREATE SERIALPORT: 300 7 1 even
! 2017-02-04 17:45:56.849 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
! 2017-02-04 17:45:56.850 - [34mdebug[39m: smartmeter.0 SERIALPORT RESET BAUDRATE TO 300
! 2017-02-04 17:45:56.870 - [34mdebug[39m: smartmeter.0 INITIAL MESSAGES TO SEND: 2
! 2017-02-04 17:45:56.875 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
! 2017-02-04 17:45:56.883 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
! 2017-02-04 17:45:56.887 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000
! 2017-02-04 17:45:57.114 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.119 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/" -> null
! 2017-02-04 17:45:57.142 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.143 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/I" -> null
! 2017-02-04 17:45:57.176 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.177 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/IT" -> null
! 2017-02-04 17:45:57.213 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.214 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR" -> null
! 2017-02-04 17:45:57.246 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.247 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5" -> null
! 2017-02-04 17:45:57.283 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.284 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5E" -> null
! 2017-02-04 17:45:57.316 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.318 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM" -> null
! 2017-02-04 17:45:57.351 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.352 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM2" -> null
! 2017-02-04 17:45:57.387 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.389 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM21" -> null
! 2017-02-04 17:45:57.421 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.423 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214" -> null
! 2017-02-04 17:45:57.456 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.457 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214\r" -> null
! 2017-02-04 17:45:57.491 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 17:45:57.492 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214\r\n" -> ["/ITR5EM214\r\n","/ITR5EM214"]
! 2017-02-04 17:45:57.494 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
! 2017-02-04 17:45:57.496 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
! 2017-02-04 17:45:57.497 - [34mdebug[39m: smartmeter.0 MESSAGES TO SEND: 2
! 2017-02-04 17:45:57.497 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN GETNEXTMESSAGE
! 2017-02-04 17:45:57.504 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN GETNEXTMESSAGE
! 2017-02-04 17:45:57.505 - [34mdebug[39m: smartmeter.0 BAUD CHANGEOVER TO 9600 baud
! 2017-02-04 17:45:57.508 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000
! 2017-02-04 17:45:57.510 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
! 2017-02-04 17:45:57.512 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING:
! 2017-02-04 17:46:03.042 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.045 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000" -> null
! 2017-02-04 17:46:03.062 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.063 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000" -> null
! 2017-02-04 17:46:03.083 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.084 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.098 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.100 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.116 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.120 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.139 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.141 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.144 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.145 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.175 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.178 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.184 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.192 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.233 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.236 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.250 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.260 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.261 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.262 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.291 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.294 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.322 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.323 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.327 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.328 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.354 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.356 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.364 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.365 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.387 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.389 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.409 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.411 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.418 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.418 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.439 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.442 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.462 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.463 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.492 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.493 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.497 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.499 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.515 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.523 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.526 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.527 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.549 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.554 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.556 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.556 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.580 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.582 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.586 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.586 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.617 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.618 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.639 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.642 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.660 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.666 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.670 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.670 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.675 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.675 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.705 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.707 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.712 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.713 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.736 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.739 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.750 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.752 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.770 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.775 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.818 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.830 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.832 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.833 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.846 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.850 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.856 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.865 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.879 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.883 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.889 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.889 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.952 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.954 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.960 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.961 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:03.975 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:03.976 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.002 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.004 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.018 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.019 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.035 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.036 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.042 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.042 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.047 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.048 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.078 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.079 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.081 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.082 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.093 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.094 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.115 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.119 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.131 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.132 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.135 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.136 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.161 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.168 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.171 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.172 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.188 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.191 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.200 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.203 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.231 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.234 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.247 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.254 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.267 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.270 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.278 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.279 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.300 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.301 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.306 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.306 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.327 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.332 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.343 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.346 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.352 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.352 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.398 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.400 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.403 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.404 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.406 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.407 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.484 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.487 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.499 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.500 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 17:46:04.511 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 17:46:04.512 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u[/spoiler]</anonymous>Habe das log nicht komplett gepostet da es noch etliche Zeilen so weitergeht.
Aber immer noch Adapter restart und keine objekte.
Mirko
@ralalla: Bitte neu von Github laden. War ein Bug im Adapter-Admin Seite … gefixt.
@wendy2702: hm ... komisch ...er bekommt die Wilkommensnachricht, wechselt die Baudrate an sich wie verlangt und dann kommen nur nullen rein.
Was ist das genau für ein Gerät was Du ausliesst? Es ist Protokollode C, das konnte ich bisher noch nicht testen ... :-) Ich bau mehr Logging ein ... bist jetzt das Versuchskanienchen? ;-))
Bitte auch Update machen und dann nochmal posten. Jetzt sollten die Messages die er sendet auch ausgegeben werden
Bitte auch Update machen und dann nochmal posten. Jetzt sollten die Messages die er sendet auch ausgegeben werden `
hier die logs nach Update (verkürzt):
! 2017-02-04 19:15:55.237 - [32minfo[39m: host.T30 object change system.adapter.admin.1
! 2017-02-04 19:15:55.238 - [32minfo[39m: host.T30 "system.adapter.admin.1" enabled
! 2017-02-04 19:15:55.269 - [32minfo[39m: host.T30 instance system.adapter.admin.1 started with pid 6680
! 2017-02-04 19:16:03.126 - [32minfo[39m: admin.1 starting. Version 1.6.11 in /opt/iobroker/node_modules/iobroker.admin, node: v4.7.3
! 2017-02-04 19:16:03.258 - [32minfo[39m: admin.1 requesting all states
! 2017-02-04 19:16:03.261 - [32minfo[39m: admin.1 requesting all objects
! 2017-02-04 19:16:03.262 - [32minfo[39m: admin.1 Request actual repository…
! 2017-02-04 19:16:03.266 - [32minfo[39m: admin.1 http server listening on port 8081
! 2017-02-04 19:16:03.267 - [32minfo[39m: admin.1 Use link "http://localhost:8081" to configure.
! 2017-02-04 19:16:04.778 - [32minfo[39m: admin.1 received all states
! 2017-02-04 19:16:05.647 - [32minfo[39m: admin.1 received all objects
! 2017-02-04 19:16:05.899 - [32minfo[39m: host.T30 Update repository "default" under "conf/sources-dist.json"
! 2017-02-04 19:16:20.518 - [32minfo[39m: admin.1 Change log subscriber state: true
! 2017-02-04 19:16:20.663 - [32minfo[39m: admin.1 system.adapter.admin.1: logging true
! 2017-02-04 19:16:29.715 - [32minfo[39m: admin.1 Repository received successfully.
! 2017-02-04 19:16:44.605 - [32minfo[39m: iobroker url "https://github.com/Apollon77/ioBroker.smartmeter"
! 2017-02-04 19:16:47.850 - [32minfo[39m: iobroker install https://github.com/Apollon77/ioBroker.s ... all/master
! 2017-02-04 19:16:48.331 - [32minfo[39m: iobroker npm install https://github.com/Apollon77/ioBroker.s ... all/master --production --prefix "/opt/iobroker" (System call)
! 2017-02-04 19:17:48.444 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.smartmeter/admin
! 2017-02-04 19:17:48.477 - [32minfo[39m: iobroker upload [4] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/tooltip.css tooltip.css text/css
! 2017-02-04 19:17:48.570 - [32minfo[39m: iobroker upload [3] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.png smartmeter.png image/png
! 2017-02-04 19:17:48.665 - [32minfo[39m: iobroker upload [2] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/smartmeter.jpg smartmeter.jpg image/jpeg
! 2017-02-04 19:17:48.793 - [32minfo[39m: iobroker upload [1] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/questionmark.png questionmark.png image/png
! 2017-02-04 19:17:48.869 - [32minfo[39m: iobroker upload [0] smartmeter.admin /opt/iobroker/node_modules/iobroker.smartmeter/admin/index.html index.html text/html
! 2017-02-04 19:17:48.978 - [32minfo[39m: iobroker exit 0
! 2017-02-04 19:17:49.502 - [32minfo[39m: host.T30 Update repository "default" under "conf/sources-dist.json"
! 2017-02-04 19:18:57.326 - [32minfo[39m: host.T30 object change system.adapter.smartmeter.0
! 2017-02-04 19:18:57.327 - [32minfo[39m: host.T30 "system.adapter.smartmeter.0" enabled
! 2017-02-04 19:18:57.355 - [32minfo[39m: host.T30 instance system.adapter.smartmeter.0 started with pid 6733
! 2017-02-04 19:19:00.118 - [34mdebug[39m: smartmeter.0 objectDB connected
! 2017-02-04 19:19:00.189 - [34mdebug[39m: smartmeter.0 statesDB connected
! 2017-02-04 19:19:00.231 - [32minfo[39m: smartmeter.0 starting. Version 0.2.2 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.3
! 2017-02-04 19:19:00.241 - [34mdebug[39m: smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"600","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"protocolD0WakeupCharacters":null,"obisFallbackMedium":1}
! 2017-02-04 19:19:00.249 - [34mdebug[39m: smartmeter.0 CREATE SERIALPORT: 300 7 1 even
! 2017-02-04 19:19:00.276 - [34mdebug[39m: smartmeter.0 SERIALPORT OPEN
! 2017-02-04 19:19:00.278 - [34mdebug[39m: smartmeter.0 SERIALPORT RESET BAUDRATE TO 300
! 2017-02-04 19:19:00.288 - [34mdebug[39m: smartmeter.0 INITIAL MESSAGES TO SEND: 2
! 2017-02-04 19:19:00.289 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
! 2017-02-04 19:19:00.292 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
! 2017-02-04 19:19:00.293 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000
! 2017-02-04 19:19:00.510 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.511 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/" -> null
! 2017-02-04 19:19:00.542 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.543 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/I" -> null
! 2017-02-04 19:19:00.576 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.576 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/IT" -> null
! 2017-02-04 19:19:00.611 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.611 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR" -> null
! 2017-02-04 19:19:00.646 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.646 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5" -> null
! 2017-02-04 19:19:00.681 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.681 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5E" -> null
! 2017-02-04 19:19:00.716 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.716 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM" -> null
! 2017-02-04 19:19:00.751 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.751 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM2" -> null
! 2017-02-04 19:19:00.786 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.786 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM21" -> null
! 2017-02-04 19:19:00.821 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.821 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214" -> null
! 2017-02-04 19:19:00.856 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.856 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214\r" -> null
! 2017-02-04 19:19:00.891 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 19:19:00.891 - [34mdebug[39m: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214\r\n" -> ["/ITR5EM214\r\n","/ITR5EM214"]
! 2017-02-04 19:19:00.893 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
! 2017-02-04 19:19:00.895 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
! 2017-02-04 19:19:00.895 - [34mdebug[39m: smartmeter.0 MESSAGES TO SEND: 2
! 2017-02-04 19:19:00.896 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 3 IN GETNEXTMESSAGE
! 2017-02-04 19:19:00.897 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN GETNEXTMESSAGE
! 2017-02-04 19:19:00.898 - [34mdebug[39m: smartmeter.0 BAUD CHANGEOVER TO 9600 baud
! 2017-02-04 19:19:00.899 - [34mdebug[39m: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000
! 2017-02-04 19:19:00.900 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
! 2017-02-04 19:19:00.901 - [34mdebug[39m: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING:
! 2017-02-04 19:19:06.438 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.439 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000" -> null
! 2017-02-04 19:19:06.451 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.452 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000" -> null
! 2017-02-04 19:19:06.473 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.474 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.486 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.486 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.508 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.508 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.525 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.526 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.536 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.537 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.552 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.553 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.564 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.574 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.604 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.605 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.608 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.612 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.613 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.614 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.636 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.637 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.648 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.649 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.671 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.672 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.683 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.684 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.706 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.707 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.724 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.728 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.741 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.742 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.759 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.760 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.776 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.777 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.788 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.789 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.811 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.812 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.823 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 19:19:06.824 - [34mdebug[39m: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 19:19:06.846 - [34mdebug[39m: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE[/spoiler]Und komplett als ZIP
Das ganze ist ein Stromzähler.
http://www.ewh.de/fileadmin/user_upload … _EM214.pdf
Und hier noch das was rauskommt wenn ich ein "cat" auf das Device mache:
! root@T30:~# cat /dev/ttyUSB0
! /ITR5EM214
! F.F(00000000)
! 0.0.0(1240007670003202)
! 0.2.0(V01.69#EEA3546C)
! 0.2.1(00017245)
! 1.7.0(02.88kW)
! 2.7.0(00.00kW)
! 1.8.1(021879.4kWh)
! 1.8.2(000000.0kWh)
! 2.8.1(010442.9kWh)
! 2.8.2(000000.0kWh)
! 31.7.0(+006.2A)
! 51.7.0(+005.5A)
! 71.7.0(+006.2A)
! C.1(53965555)
! C.5.0(L1-L2-L3)
! C.6.3(03.77V)
! C.8.1(024458.11h)
! C.8.2(000000.00h)
! C.13.21(00000001*secs)
! C.13.22(00000001)
! C.90(00000100)
! 5^C
! root@T30:~# cat /dev/ttyUSB0 | od -tx1
! 0000000 2f 49 54 52 35 45 4d 32 31 34 0d 0a 02 46 2e 46
! 0000020 28 30 30 30 30 30 30 30 30 29 0d 0a 30 2e 30 2e
! 0000040 30 28 31 32 34 30 30 30 37 36 37 30 30 30 33 32
! 0000060 30 32 29 0d 0a 30 2e 32 2e 30 28 56 30 31 2e 36
! 0000100 39 23 45 45 41 33 35 34 36 43 29 0d 0a 30 2e 32
! 0000120 2e 31 28 30 30 30 31 37 32 34 35 29 0d 0a 31 2e
! 0000140 37 2e 30 28 30 33 2e 30 30 2a 6b 57 29 0d 0a 32
! 0000160 2e 37 2e 30 28 30 30 2e 30 30 2a 6b 57 29 0d 0a
! 0000200 31 2e 38 2e 31 28 30 32 31 38 37 39 2e 34 2a 6b
! 0000220 57 68 29 0d 0a 31 2e 38 2e 32 28 30 30 30 30 30
! 0000240 30 2e 30 2a 6b 57 68 29 0d 0a 32 2e 38 2e 31 28
! 0000260 30 31 30 34 34 32 2e 39 2a 6b 57 68 29 0d 0a 32
! 0000300 2e 38 2e 32 28 30 30 30 30 30 30 2e 30 2a 6b 57
! 0000320 68 29 0d 0a 33 31 2e 37 2e 30 28 2b 30 30 36 2e
! 0000340 34 2a 41 29 0d 0a 35 31 2e 37 2e 30 28 2b 30 30
! 0000360 35 2e 36 2a 41 29 0d 0a 37 31 2e 37 2e 30 28 2b
! 0000400 30 30 36 2e 33 2a 41 29 0d 0a 43 2e 31 28 35 33
! 0000420 39 36 35 35 35 35 29 0d 0a 43 2e 35 2e 30 28 4c
! 0000440 31 2d 4c 32 2d 4c 33 29 0d 0a 43 2e 36 2e 33 28
! 0000460 30 33 2e 37 37 2a 56 29 0d 0a 43 2e 38 2e 31 28
! 0000500 30 32 34 34 35 38 2e 31 32 2a 68 29 0d 0a 43 2e
! 0000520 38 2e 32 28 30 30 30 30 30 30 2e 30 30 2a 68 29
! 0000540 0d 0a 43 2e 31 33 2e 32 31 28 30 30 30 30 30 30
! 0000560 30 31 2a 73 65 63 73 29 0d 0a 43 2e 31 33 2e 32
! 0000600 32 28 30 30 30 30 30 30 30 31 29 0d 0a 43 2e 39
! 0000620 30 28 30 30 30 30 30 31 30 30 29 0d 0a 21 0d 0a -
! /ITR5EM214
! F.F(00000000)
! 0.2.1(00017245)
! 1.7.0(02.88kW)
! 2.7.0(00.00kW)
! 31.7.0(+006.2A)
! 51.7.0(+005.5A)
! 71.7.0(+006.2A)
! C.1(53965555)
! C.5.0(L1-L2-L3)
! C.6.3(03.77V)
! C.8.1(024458.11h)
! C.8.2(000000.00h)
! C.13.22(00000001)
! C.90(00000100)
! 5^COk, sehr interessant. Das neue Logging fehlt … ggrr :-) Kommt nachher noch ein Update
Ansonsten: Wenn Du ein cat auf das Device direct machst und laufen lässt, kommt das dann regelmäßig von alleine? Wenn ja versuch mal "Seriell Device reading data only" anstelle von der Bidirektionalen Kommunikation zu wählen und dann mal 9600 8N1 oder 9600 7E1 ... `
Also wenn der Adapter nicht läuft, kommt auch nichts beim "cat".
Scheint also nicht nur "lesend" zu sein.
Habe den Kopf von Udo (Volkszähler).
Zählertyp muss ich noch mal schauen, ist ein eHz…... ?
Habe eben den Adapter noch mal deinstalliert und neu installiert. :shock:
Siehe da:
Läuft, mit 9600 8E1 und einem momentanen Intervall von 60 Sekunden.
Habe meinen Zähler auch mit einer PIN freigeschaltet um Tages-, Wochen- Monatswerte ….... sehen zu können.
Diese werden aber, so wie es aussieht nicht mit ausgegeben.
So, updaten bitte vom Github … jetzt ist in jedem Fall mal das Logging dabei ..
Und bei mir läuft es jetzt schon 1h ohne SIGABRT :-) ... heisst nix, aber vllt hab ichs ja :-)
@ralalla: ja das die Werte fehlen ist schon aufgefallen, aber was nicht da ist kann nicht angezeigt werden :-(
@ralalla: ja das die Werte fehlen ist schon aufgefallen, aber was nicht da ist kann nicht angezeigt werden :-( `
So,
jetzt Version 0.23 installiert.
Hier mal ein log Auszug von einem Adapter neustart. Habe den Adapter dann gestoppt. Hier kommen immer noch die "nullen" zurück.
! 0\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:18.796 - debug: smartmeter.0 MESSAGE TIMEOUT TRIGGERED
! 2017-02-04 23:02:18.817 - error: smartmeter.0 uncaught exception: No answer from Serial Device after last request.
! 2017-02-04 23:02:18.824 - error: smartmeter.0 Error: No answer from Serial Device after last request.
! at SerialRequestResponseTransport.handleSerialTimeout (/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:154:11)
! at null. <anonymous>(/opt/iobroker/node_modules/iobroker.smartmeter/node_modules/smartmeter-obis/lib/transports/SerialRequestResponseTransport.js:61:26)
! at Timer.listOnTimeout (timers.js:92:15)
! 2017-02-04 23:02:18.828 - warn: smartmeter.0 Exception: Error: No answer from Serial Device after last request.
! 2017-02-04 23:02:18.832 - debug: smartmeter.0 SERIALPORT CLOSE
! 2017-02-04 23:02:19.334 - info: smartmeter.0 terminating
! 2017-02-04 23:02:19.354 - error: host.T30 instance system.adapter.smartmeter.0 terminated with code 0 (OK)
! 2017-02-04 23:02:19.356 - info: host.T30 Restart adapter system.adapter.smartmeter.0 because enabled
! 2017-02-04 23:02:49.368 - info: host.T30 instance system.adapter.smartmeter.0 started with pid 3544
! 2017-02-04 23:02:51.633 - debug: smartmeter.0 objectDB connected
! 2017-02-04 23:02:51.705 - debug: smartmeter.0 statesDB connected
! 2017-02-04 23:02:51.750 - info: smartmeter.0 starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.3
! 2017-02-04 23:02:51.759 - debug: smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"300","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"protocolD0WakeupCharacters":0,"obisFallbackMedium":1}
! 2017-02-04 23:02:51.768 - debug: smartmeter.0 CREATE SERIALPORT: 300 7 1 even
! 2017-02-04 23:02:51.794 - debug: smartmeter.0 SERIALPORT OPEN
! 2017-02-04 23:02:51.807 - debug: smartmeter.0 SERIALPORT RESET BAUDRATE TO 300
! 2017-02-04 23:02:51.812 - debug: smartmeter.0 INITIAL MESSAGES TO SEND: 2
! 2017-02-04 23:02:51.814 - debug: smartmeter.0 CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
! 2017-02-04 23:02:51.817 - debug: smartmeter.0 CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
! 2017-02-04 23:02:51.818 - debug: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000
! 2017-02-04 23:02:52.037 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.038 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/" -> null
! 2017-02-04 23:02:52.068 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.069 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/I" -> null
! 2017-02-04 23:02:52.102 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.103 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/IT" -> null
! 2017-02-04 23:02:52.137 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.138 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR" -> null
! 2017-02-04 23:02:52.172 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.173 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5" -> null
! 2017-02-04 23:02:52.207 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.208 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5E" -> null
! 2017-02-04 23:02:52.242 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.243 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM" -> null
! 2017-02-04 23:02:52.277 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.278 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM2" -> null
! 2017-02-04 23:02:52.312 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.313 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM21" -> null
! 2017-02-04 23:02:52.347 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.348 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214" -> null
! 2017-02-04 23:02:52.382 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.383 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214\r" -> null
! 2017-02-04 23:02:52.417 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN CHECKMESSAGE
! 2017-02-04 23:02:52.418 - debug: smartmeter.0 MATCH-RESULT SIGNON: "/ITR5EM214\r\n" -> ["/ITR5EM214\r\n","/ITR5EM214"]
! 2017-02-04 23:02:52.419 - debug: smartmeter.0 CURRENT PROCESS STEP 2 IN HANDLEMESSAGE
! 2017-02-04 23:02:52.421 - debug: smartmeter.0 CURRENT PROCESS STEP 3 IN ISPROCESSCOMPLETE: false
! 2017-02-04 23:02:52.422 - debug: smartmeter.0 MESSAGES TO SEND: 2
! 2017-02-04 23:02:52.427 - debug: smartmeter.0 CURRENT PROCESS STEP 3 IN GETNEXTMESSAGE
! 2017-02-04 23:02:52.428 - debug: smartmeter.0 TO SEND 0: 050
! 2017-02-04 23:02:52.435 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN GETNEXTMESSAGE
! 2017-02-04 23:02:52.435 - debug: smartmeter.0 BAUD CHANGEOVER TO 9600 baud
! 2017-02-04 23:02:52.436 - debug: smartmeter.0 TO SEND 1:
! 2017-02-04 23:02:52.437 - debug: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000
! 2017-02-04 23:02:52.452 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN ISPROCESSCOMPLETE: false
! 2017-02-04 23:02:52.453 - debug: smartmeter.0 REMAINING DATA AFTER MESSAGE HANDLING:
! 2017-02-04 23:02:52.455 - debug: smartmeter.0 BAUD CHANGEOVER DONE
! 2017-02-04 23:02:57.969 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:57.971 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000" -> null
! 2017-02-04 23:02:57.981 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:57.985 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000" -> null
! 2017-02-04 23:02:58.004 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.006 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.018 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.019 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.039 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.041 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.056 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.057 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.073 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.074 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.079 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.080 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.114 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.118 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.131 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.136 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.138 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.138 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.165 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.166 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.171 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.172 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.178 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.180 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.201 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.202 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.214 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.219 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.236 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.238 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.248 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.253 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.271 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.273 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.283 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.285 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.306 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.308 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.328 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.329 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.348 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.349 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.362 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.363 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.376 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.378 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.391 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.393 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.411 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.413 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.423 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.425 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.439 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.443 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.444 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.445 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.450 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.450 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.474 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.476 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.484 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.484 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.504 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.505 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.507 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.508 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.523 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.524 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.536 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.538 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.552 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.553 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.563 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.565 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.595 - info: host.T30 object change system.adapter.smartmeter.0
! 2017-02-04 23:02:58.614 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.619 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.598 - info: host.T30 "system.adapter.smartmeter.0" disabled
! 2017-02-04 23:02:58.620 - info: host.T30 stopInstance system.adapter.smartmeter.0
! 2017-02-04 23:02:58.625 - info: host.T30 stopInstance system.adapter.smartmeter.0 killing pid 3544
! 2017-02-04 23:02:58.632 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.642 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.647 - debug: smartmeter.0 CURRENT PROCESS STEP 4 IN CHECKMESSAGE
! 2017-02-04 23:02:58.657 - debug: smartmeter.0 MATCH-RESULT DATA: "\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000" -> null
! 2017-02-04 23:02:58.688 - debug: smartmeter.0 SERIALPORT CLOSE
! 2017-02-04 23:02:59.184 - info: smartmeter.0 terminating
! 2017-02-04 23:02:59.203 - info: host.T30 instance system.adapter.smartmeter.0 terminated with code 0 (OK)</anonymous>Was mir auffällt, wenn ich das mit dem "cat" mache, findet die Umschaltung der Baudrate nicht statt. Könnte das das Problem bei der Ausgabe ohne "cat" sein?
So sieht das log bei "cat" aus wenn die Daten aus dem Device "richtig" kommen.
! 2017-02-04 23:09:09.965 - info: host.T30 instance system.adapter.smartmeter.0 started with pid 3697
! 2017-02-04 23:09:12.481 - debug: smartmeter.0 objectDB connected
! 2017-02-04 23:09:12.559 - debug: smartmeter.0 statesDB connected
! 2017-02-04 23:09:12.606 - info: smartmeter.0 starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v4.7.3
! 2017-02-04 23:09:12.617 - debug: smartmeter.0 SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialRequestResponseTransport","requestInterval":"300","transportSerialPort":"/dev/ttyUSB0","transportSerialBaudrate":null,"protocolD0WakeupCharacters":0,"obisFallbackMedium":1}
! 2017-02-04 23:09:12.626 - debug: smartmeter.0 CREATE SERIALPORT: 300 7 1 even
! 2017-02-04 23:09:12.656 - debug: smartmeter.0 SERIALPORT OPEN
! 2017-02-04 23:09:12.662 - debug: smartmeter.0 SERIALPORT RESET BAUDRATE TO 300
! 2017-02-04 23:09:12.667 - debug: smartmeter.0 INITIAL MESSAGES TO SEND: 2
! 2017-02-04 23:09:12.669 - debug: smartmeter.0 CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
! 2017-02-04 23:09:12.672 - debug: smartmeter.0 CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
! 2017-02-04 23:09:12.673 - debug: smartmeter.0 SET MESSAGE TIMEOUT TIMER: 60000Bei einem anderen Zähler des Herstellers steht im Volkszähler Wiki folgendes:
Für die Kommunikation mittels d0-Protokoll muss zuerst eine Initialisierungs-Sequenz “/?!” mit 300bd, 7E1 und “LF+CR” geschickt werden, um ihn zum Antworten zu bewegen. Die Baudrate kann bei dem Zähler nicht geändert werden und bleibt bei 300bd.Vielleicht darf die Baudrate bei meinem auch nicht umgeschaltet werden?
> @ralalla: ja das die Werte fehlen ist schon aufgefallen, aber was nicht da ist kann nicht angezeigt werden :-(Ja wollte nur noch einmal drauf hinweisen weil gefragt wurde ob die Werte auch angezeigt werden können.
(für mich als Adapter-Noob, wie installiere ich das Update von git ?)
Dann würde sich das Device nicht D0-Protokollkonform verhalten ;-)
Ok, dann versuche Du mal folgendes (um das zu verifizieren):
Suche mal das Verzeichnis der node-Library "smartmeter-obis" entweder in /opt/iobroker/node_modules oder in /opt/iobroker/node_modules/iobroker.smartmeter/node_modules/
Dort ist das File lib/protocols/D0Protocol.js in Zeile 86-91 so:
commObj.update({baudrate: this.commBaudrateChangeover}, function (error) { if (self.options.debug === 2) self.options.logger('BAUD CHANGEOVER DONE'); if (error) { self.options.logger('EROR ON BAUD CHANGEOVER!'); } });lösche das mal oder kommentiere das aus. Dann wird der Baudrate changeover nicht gemacht. Und dann neu starten und sagen was passiert :-)
Und ich hatte nach 2h doch wieder ein SIGABRT … keine Ahnung warum :-(
Und ich hatte nach 2h doch wieder ein SIGABRT … keine Ahnung warum :-( `
Ich habe testweise den Anfrageinterval auf 5 Sekunden gestellt, und habe seitdem keine Fehlermeldung erhalten, vielleicht können die vielen Daten nicht so schnell verarbeitet werden wenn es auf 0 Sekunden steht!?
Adrian
Ich habe testweise den Anfrageinterval auf 5 Sekunden gestellt, und habe seitdem keine Fehlermeldung erhalten, vielleicht können die vielen Daten nicht so schnell verarbeitet werden wenn es auf 0 Sekunden steht!? `
War auch meine Idee. Ich hab auf 60 Sekunden bei mir :-) In der 0.2.3 ist eingebaut das der Puffer nach dem verarbeiten einer Nachricht immer verworfen wird … damit sollte sich nicht so viel ansammeln ... mal beobachten.
