  4. [gelöst] Backupit - keine iobroker Backups möglich
    1.0k
    6.1k
97 Beiträge 4 Kommentatoren 12.6k Aufrufe 4 Beobachtet
    @heisenberg0709 Das sieht schon mal gut aus.
    free -ht
    iobroker fix
    @heisenberg0709 sagte in Backupit - keine iobroker Backups möglich:
    pi@iobrokerSSD062021master:~ $ iobroker start
    vorher noch ein iobroker stop
      free -ht
      iobroker fix
      Heisenberg0709
      iobroker stop kam vorher
      pi@iobrokerSSD062021master:~ $ iobroker status
      iobroker is not running on this host.
      Objects type: file
      States  type: file
      pi@iobrokerSSD062021master:~ $ iobroker fix
      library: loaded
      Library version=2021-04-07
          Welcome to the ioBroker installation fixer!
          Script version: 2021-04-07
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      OK:3 https://deb.nodesource.com/node_12.x buster InRelease
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      nachdem dann alle Instanzen im iobroker wieder liefen dann:
      pi@iobrokerSSD062021master:~ $ free -ht
      Mem:          3,7Gi       1,3Gi       1,7Gi       8,0Mi       759Mi       2,6Gi
      Swap:          99Mi          0B        99Mi
      Total:        3,8Gi       1,3Gi       1,8Gi
      • H Heisenberg0709
        Objects type: file
        States  type: file
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        Swap:          99Mi          0B        99Mi
        @heisenberg0709
        Und wenn du jetzt das Backup nochmal manuell antrittst?
        H 1 Antwort Letzte Antwort
          @heisenberg0709
          Heisenberg0709
          backup wird leider auch nicht angelegt...
          pi@iobrokerSSD062021master:~ $ iobroker stop
          pi@iobrokerSSD062021master:~ $ cd /opt/iobroker
          pi@iobrokerSSD062021master:/opt/iobroker $ iobroker backup
          host.iobrokerSSD062021master 6281 states saved
          host.iobrokerSSD062021master 7631 objects saved
          internal/buffer.js:950
          class FastBuffer extends Uint8Array {}
          RangeError: Array buffer allocation failed
              at new ArrayBuffer (<anonymous>)
              at new Uint8Array (<anonymous>)
              at new FastBuffer (internal/buffer.js:950:1)
              at createUnsafeBuffer (buffer.js:149:12)
              at allocate (buffer.js:419:10)
              at Function.allocUnsafe (buffer.js:384:10)
              at Function.encodeBufBulk (/opt/iobroker/node_modules/respjs/index.js:46:27)
              at RedisHandler.sendBufBulk (/opt/iobroker/node_modules/@iobroker/db-base/lib/redisHandler.js:259:44)
              at RedisHandler.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-file/lib/objects/objectsInMemServerRedis.js:452:29)
              at RedisHandler.emit (events.js:314:20)
          • H Heisenberg0709
            @heisenberg0709
            Keine Ahnung warum es dir da den Speicher fetzt.
            • H Offline
              Heisenberg0709
              ok ok, trotzdem euch einen Riesen Dank schon einmal bis hier her für euren Support.
              Kennt ihr eine Alternative zum neu aufsetzen. Wenn ich hier jetzt ohne Backup komplett bei 0 anfange sitze ich hier wieder wochenlang dran bis wieder alles so ist, wie es mal war…
              Was mir dann irgendwie auch nicht nach der Lösung scheint 😧
              • H Heisenberg0709
                @heisenberg0709
                Du kannst probieren den js-controller nochmal reinzubügeln:
                iobroker stop
                cd /opt/iobroker
                sudo -H -u iobroker npm install iobroker.js-controller
                iobroker restart
                Nutzt dir aber auch nur was wenn es keine Fehlkonfiguration in irgendeinem Adapter ist.
                Standardfrage:
                NodeJS ist aber sauber installiert?
                • H Heisenberg0709
                  hast du denn mal ein einfaches iobroker backup über die Konsole abgesetzt?
                    Heisenberg0709
                    inwiefern? ich habe es sowohl in der konsole via mac als auch via backupit probiert
                    • H Heisenberg0709
                      nicht dass dir der mac in die Suppe spuckt und das tar. entpackt
                      inwiefern?
                      • ob dann auch alles zusammenbricht
                      • ob dann ein Backup unter /opt/iobroker/backups liegt
                      hast du per Konsole vorher iobroker stop gemacht?
                        @heisenberg0709
                        iobroker stop
                        cd /opt/iobroker
                        iobroker restart
                        Standardfrage:
                        Heisenberg0709
                        ich habe die Schritte eben nochmal durchgeführt, es bleibt bei der aktuellen Situation.
                        Ich gehe mal davon aus, das das NodeJS sauber installiert ist. Kann man das ggf. irgendwie abprüfen?
                        • H Heisenberg0709
                          @heisenberg0709
                          Ja, das steht in meiner Signatur.
                          Kann man mit
                          which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                          checken.
                            @heisenberg0709
                            Kann man mit
                            checken.
                            Heisenberg0709
                            habe gerade deine Top Anleitung kurz durchgelesen ;-)
                            hier das Ergebnis:
                            pi@iobrokerSSD062021master:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v12.22.4
                            v12.22.4
                            6.14.14
                            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                            OK:2 http://archive.raspberrypi.org/debian buster InRelease
                            Alle Pakete sind aktuell.
                            nodejs:
                              Installiert:           12.22.4-1nodesource1
                              Installationskandidat: 12.22.4-1nodesource1
                              Versionstabelle:
                             *** 12.22.4-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                 10.24.0~dfsg-1~deb10u1 500
                            Thomas BraunT simatecS 2 Antworten Letzte Antwort
                            • H Heisenberg0709
                              hier das Ergebnis:
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v12.22.4
                              v12.22.4
                              6.14.14
                              nodejs:
                                Versionstabelle:
                              @heisenberg0709 Dann fällt mir nix mehr ein.
                              • H Heisenberg0709
                                hier das Ergebnis:
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v12.22.4
                                v12.22.4
                                6.14.14
                                nodejs:
                                  Versionstabelle:
                                simatecS Offline
                                simatecS Offline
                                simatec
                                @heisenberg0709
                                Welche js-controller Version hast du laufen?
                                • Besuche meine Github Seite
                                • HowTo Restore ioBroker
                                • simatecS simatec
                                  @heisenberg0709
                                  Heisenberg0709
                                  schrieb am zuletzt editiert von Heisenberg0709
                                  @simatec
                                  aktuell:
                                  (Node.js v12.22.4 // NPM 6.14.14)
                                  simatecS Thomas BraunT 2 Antworten Letzte Antwort
                                  • H Heisenberg0709
                                    @simatec
                                    aktuell:
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    @heisenberg0709 Nein js-controller meine ich
                                    • H Heisenberg0709
                                      @simatec
                                      aktuell:
                                      @heisenberg0709
                                      iobroker -v
                                        @heisenberg0709
                                        iobroker -v
                                        Heisenberg0709
                                        @thomas-braun sagte in Backupit - keine iobroker Backups möglich:
                                        iobroker -v
                                        3.2.16
                                        • H Heisenberg0709
                                          iobroker -v
                                          3.2.16
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          @heisenberg0709 Mach mal ein Update auf die neuste Version.
                                          iobroker stop
                                          iobroker update
                                          iobroker upgrade self
                                          iobroker fix
                                          iobroker start
