  4. Test Adapter homeconnect (BSH Home-Connect) v0.0.x
    6.3k
bshbsh home connecthome connecthomeconnect adapter
1.4k Beiträge 202 Kommentatoren 688.6k Aufrufe 153 Beobachtet
  • T tombox
    @totti1171 Was ist genau das Problem du musst nur den states
    homeconnect.0.SIEMENS-XXXXX.status.BSH_Common_Status_OperationState
    mit den Möglichkeiten vergleichen
    BSH.Common.EnumType.OperationState.Inactive
    BSH.Common.EnumType.OperationState.Ready
    BSH.Common.EnumType.OperationState.Run
    BSH.Common.EnumType.OperationState.Finished
    totti1171
    schrieb am zuletzt editiert von totti1171
    #550
    @tombox Danke. inzwischen funktionieren diese Abfragen gut. Ich habe inzwischen 6 Homeconnect-Geräte (2 Geschirrspüler, Herd, Waschmaschine, Trockner, Kaffeeautomat) im Haus und trotz eingelegter 24h Pause nach kurzer Zeit wieder diese Meldung:
    homeconnect.0	2021-07-15 06:04:05.429	error	(19432) Error (401010522127001422)
    homeconnect.0	2021-07-15 06:04:05.429	error	(19432) 429 Too Many Requests
    homeconnect.0	2021-07-15 06:04:05.429	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
    homeconnect.0	2021-07-15 06:04:05.380	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
    homeconnect.0	2021-07-15 06:04:05.380	error	(19432) Error (BOSCH-HNG6764S6-68A40E565336)
    homeconnect.0	2021-07-15 06:04:05.380	error	(19432) 429 Too Many Requests
    homeconnect.0	2021-07-15 06:04:05.380	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
    homeconnect.0	2021-07-15 06:04:05.372	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
    homeconnect.0	2021-07-15 06:04:05.372	error	(19432) Error (SIEMENS-WT7YH701-68A40E02A511)
    homeconnect.0	2021-07-15 06:04:05.372	error	(19432) 429 Too Many Requests
    homeconnect.0	2021-07-15 06:04:05.372	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
    homeconnect.0	2021-07-15 06:04:05.363	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
    homeconnect.0	2021-07-15 06:04:05.363	error	(19432) Error (SIEMENS-TI9555X1DE-68A40E2399A9)
    homeconnect.0	2021-07-15 06:04:05.363	error	(19432) 429 Too Many Requests
    homeconnect.0	2021-07-15 06:04:05.363	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
    homeconnect.0	2021-07-15 06:04:05.355	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
    homeconnect.0	2021-07-15 06:04:05.355	error	(19432) Error (BOSCH-SMI88TS36E-68A40E029D20)
    homeconnect.0	2021-07-15 06:04:05.354	error	(19432) 429 Too Many Requests
    homeconnect.0	2021-07-15 06:04:05.354	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
    homeconnect.0	2021-07-15 06:04:05.343	warn	(19432) Too many requests. Adapter sends too many requests per minute. Please wait 1min before restart the instance.
    homeconnect.0	2021-07-15 06:04:05.343	error	(19432) Error (SIEMENS-WM4YH741-68A40E02AF0A)
    homeconnect.0	2021-07-15 06:04:05.343	error	(19432) 429 Too Many Requests
    homeconnect.0	2021-07-15 06:04:05.343	error	(19432) EventSource error: {"type":"error","status":429,"message":"Too Many Requests"}
    Mein Smarthome:
    iobroker (Dokker Synology), HomeKit,
    raspi4 (Redmatic,CuxD), Phillips Hue, HomeConnect, Xiaomi, Sonos, Alexa (Show 5/8/10, Dot1-3, Spot, Echo flex)
    • T totti1171
      tombox
      #551
      @totti1171 dann wurde der Adapter zu oft neugestartet oder er läuft doppelt
      T D 2 Antworten Letzte Antwort
      • T tombox
        totti1171
        #552
        @tombox Hab bei diesem Adapter keine Neustarts eingerichtet und es läuft auch nur eine Instanz 😠
        hatte ihn >24h vorgestern aus, da lief er dann wieder für ein paar Stunden - heute morgen dann wieder die Meldungen
        Mein Smarthome:
        • T totti1171
          tombox
          #553
          @totti1171 Dann muss irgend ein fehler oder neu verbinden statt finden. Schick mal das komplette log file nach dem 24h warten per pn an mich
          • T tombox
            totti1171
            #554
            @tombox würde ich ja gern - habe aber keinen "PN-Button" 😠
            Mein Smarthome:
            • T tombox
              bob der 1.
              #555
              @tombox sagte in Test Adapter homeconnect (BSH Home-Connect) v0.0.x:
              Und wie müsste ein Blockly aussehen zn für die Tür ?
              Wenn offen dann Lampe an oder wie binde ich sowas ein mit den Operatonns States.Finished.
              Das komme ich nicht klar.
              Kann.mit da einer mal nur zeigen wie ich den Finished dazu bekomme irgendwas zu schalten
              • B bob der 1.
                tombox
                #556
                @bob-der-1
                Tür ist dann der Zustand:
                homeconnect.0.SIEMENS-XXXXXXX.status.BSH_Common_Status_DoorState
                die beiden Zustände
                BSH.Common.EnumType.DoorState.Closed
                BSH.Common.EnumType.DoorState.Open
                • T tombox
                  @bob-der-1
                  die beiden Zustände
                  bob der 1.
                  #557
                  @tombox
                  Ich muss das morgen mal testen,ich sehe da noch nicht meinen Weg....
                  • J Offline
                    JohnnyBahama
                    #558
                    Hi, ich bekomme in meinen Log folgende Errors. Weiß einer was das bedeutet und wie man diese beseitigt.
                    homeconnect.0	2021-07-24 15:01:20.042	error	(23410) {"data":{"programs":[]}}
                    homeconnect.0	2021-07-24 15:01:20.042	error	(23410) /programs
                    homeconnect.0	2021-07-24 15:01:20.041	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
                    homeconnect.0	2021-07-24 15:01:20.041	error	at runMicrotasks (<anonymous>)
                    homeconnect.0	2021-07-24 15:01:20.041	error	at /opt/iobroker/node_modules/iobroker.homeconnect/main.js:1032:39
                    homeconnect.0	2021-07-24 15:01:20.041	error	at Array.forEach (<anonymous>)
                    homeconnect.0	2021-07-24 15:01:20.041	error	at /opt/iobroker/node_modules/iobroker.homeconnect/main.js:1041:57
                    homeconnect.0	2021-07-24 15:01:20.041	error	(23410) TypeError: Cannot read property 'forEach' of undefined
                    homeconnect.0	2021-07-24 15:01:20.039	error	(23410) TypeError: Cannot read property 'forEach' of undefined
                    • J JohnnyBahama
                      tombox
                      #559
                      @johnnybahama installier mal über GitHub ob es dann weg ist
                      • T tombox
                        JohnnyBahama
                        #560
                        @tombox Selbes Ergebniss
                        • J JohnnyBahama
                          tombox
                          #561
                          @johnnybahama Eigentlich müsste es gefixt sein wenn du via github installierst und neustartest welchen fehler bekommst du dann genau
                          • T tombox
                            JohnnyBahama
                            #562
                            @tombox Also ich habe jetzt folgendes probiert:
                            Adapter deinstalliert, über Adapter Page neu installiert v0.0.36
                            Adapter wieder deinstalliert, über GitHub installiert v0.0.30 wird angezeigt.
                            Adapter upgedated über Adapterpage auf v0.0.36
                            Alle drei Schritte werfen den oben genannten Error aus.
                            Am Ende kann ich auch damit leben, wenn es keine Auswirkungen hat.
                            • J JohnnyBahama
                              tombox
                              #563
                              @johnnybahama Hat keine Auswirkung github sollte eigentlich kein Update anbieten ich werde mal eine neue version hochladen
                                tombox
                                #564
                                @johnnybahama Du hast das falsche github installiert
                                https://github.com/iobroker-community-adapters/ioBroker.homeconnect
                                • T tombox
                                  JohnnyBahama
                                  #565
                                  @tombox Ah ok. Ist natürlich blöd, wenn der nicht korrekte Adapter in der Liste erscheint. Danke. Momentan keine Meldungen.
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #566
                                    hab da noch was gefunden (ps.. ich komm zu nix)
                                    gerade das system neu gestartet.. der adapter läuft auf dem master.. nicht irritieren lassen von dem slave LOg...
                                    aber.. da ich den gerade neu gestartet habe wie kommt der zu der Meldung
                                    ich würde vermuten ohne in den source zu schauen dass der refresh token da mist macht
                                    wie gesagt vor dem systemneu start lief der adapter durch
                                    • arteckA arteck
                                      tombox
                                      #567
                                      @arteck Wäre interessant zu wissen was passiert ist bevor der erste 429 aufgetaucht ist
                                      • T tombox
                                        arteckA Offline
                                        arteckA Offline
                                        arteck
                                        #568
                                        @tombox ja...
                                        um 3 uhr wurder der adapter neu gestartet
                                        und ab da gings los
                                        weiter um 6 hab ich die GIT Version gezogen
                                        • arteckA arteck
                                          @tombox ja...
                                          und ab da gings los
                                          tombox
                                          #569
                                          @arteck Es sieht so aus als wäre er 1Uhr auch neugestartet. Je nach anzahl an devices sind nur begrenzte Neustarts möglich durch die hohe anzahl von requests
                                          Das ist doch normales Verhalten. Ist es denn trotzdem der einzige Neustart in den letzten 24h gewesen?
