  4. IoBroker-Pro Fernzugriff auf Scripte geht nicht
    6.4k
fernzugriff iot cloudscript adapter
48 Beiträge 9 Kommentatoren 5.8k Aufrufe 6 Beobachtet
  • E ente34
    mit chrome dasselbe
    Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
    instrument.ts:129 Help us to create open source project with reactJS!
    instrument.ts:129 See you :)
    contentScript.js:49 dispatching the event: emc.ctf.addonInited
    sentry.iobroker.net/api/56/envelope/?sentry_key=504499a725eb4898930d3b9e9da95740&sentry_version=7:1 Failed to load resource: the server responded with a status of 403 (Forbidden)
    tab.html:1 Uncaught (in promise) unknown command
    confirmid_content.js:240 onCompleted for  https://iobroker.pro/adapter/javascript/tab.html Event
    sentry.iobroker.net/api/56/store/?sentry_key=504499a725eb4898930d3b9e9da95740&sentry_version=7:1 Failed to load resource: the server responded with a status of 403 (Forbidden)
    content.js:682 mutationObserverCallback
    content.js:662 Process DOM-mutation event  Attributes:  2 Nodes:  7
    DevTools failed to load source map: Could not load content for https://iobroker.pro/adapter/min-maps/vs/loader.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for https://iobroker.pro/adapter/min-maps/vs/editor/editor.main.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    DevTools failed to load source map: Could not load content for https://iobroker.pro/adapter/min-maps/vs/editor/editor.main.nls.de.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
    contentScript.js:165 Stopping Trials as application is not D2, WebTop, xCP or eRoom
    GlasfaserG Offline
    GlasfaserG Offline
    @ente34
    Zumindest ist dort mehr im Protokoll ,eventuell kann ein anderer damit mehr anfangen
    • GlasfaserG Glasfaser
      @cash sagte in IoBroker-Pro Fernzugriff auf Scripte geht nicht:
      Funktioniert bei Dir über der Cloud der Zugriff
      Habe kein Cloud , wollte nur hier helfen !
      cashC Offline
      cashC Offline
      cash
      @glasfaser sorry das verstehe ich nicht. Woher willst Du wissen wo das Problem ist wenn Du selber nicht testen kannst? Ich würde mal sagen es liegt nicht am User sondern an der Cloud. Somit kann @ente34 bei Vollmond ums Feuer tanzen oder andere Brwoser testen es wird nichts nutzen…
      Also können wir nichts machen bis jemand antwortet der entweder nicht das Problem hat oder jemand der Zugriff auf den Server hat um dort zu gucken ob etwas nicht stimmt.
      • cashC cash
        GlasfaserG Offline
        GlasfaserG Offline
        Ist alles richtig was du schreibts ,
        aber wenn im Vorfeld wichtige Informationen Fehler , so kann derjenige der hier im Thread reinschaut schon eine Lösung mit den vorliegenden Informationen haben .
        Oder ist es besser wenn einer schreibt "mein ioBroker startet nicht " ohne Info´s zu geben , dort muß man alles mühlsehlich erfragen !?
        • cashC cash
          GlasfaserG Offline
          GlasfaserG Offline
          Hier wurde ein Issues eröffnet !
          https://github.com/ioBroker/ioBroker.cloud/issues/213
          E cashC 2 Antworten Letzte Antwort
            ente34
            @glasfaser
            @all Vielen Dank!
            • E ente34
              Systemdata Bitte Ausfüllen
              Hardwaresystem: Pi4
              Arbeitsspeicher: 4GB
              Festplattenart: SSD
              Betriebssystem: Raspian
              Node-Version: 12.22.1
              Nodejs-Version: 12.22.1
              NPM-Version: 6.x.x
              Installationsart: Skript
              Image genutzt: Nein
              Ort/Name der Imagedatei: Link
              Hallo Forum,
              beim Fernzugriff funktionieren alle Tabs, nur bei Scripten erscheint ein drehendes IoBroker Symbol.
              Alle Adapter im latestest, js-controller 3.3.12
              sigi234S Online
              sigi234S Online
              @ente34
              Kann ich bestätigen.
              {"detail":"failed to read request body","causes":["failed to decode zlib payload","corrupt deflate stream"]}
              Plattform: Windows
              RAM: 16 GB
              Node.js: 12.22.1
              NPM: 6.14.12
              JS Controller: 3.3.14
              Admin: 5.1.11
              Web: 3.4.3
              Socket.io: 3.1.4
              Script Engine: 5.2.3
              IOT: 1.8.22
              VIS: 1.4.2
              HM-Rega: 3.0.29
              HM-RPC: 1.14.43
              Jarvis: 3.0.0
              Backitup: 2.1.12
              Cloud: 4.0.11
              ICal: 1.9.3
              iQontrol: 1.8.0
              fb-checkpresence: 1.1.5
              Hue: 3.5.19
              Alexa2: 3.9.3
                cashC Offline
                cashC Offline
                cash
                @glasfaser Issue habe ich eröffnet.
                Vielen Dank @sigi234.
                Abwarten was @Bluefox oder @apollon77 sagen. Ich vermute Server Update??
                • cashC cash
                  sigi234S Online
                  sigi234S Online
                  Jupp, denke ich auch.
                  cashC 1 Antwort Letzte Antwort
                  • sigi234S sigi234
                    cashC Offline
                    cashC Offline
                    cash
                    Gibt es hier evtl Neuigkeiten? Bei mir geht es immer noch nicht. Wobei ich nicht weiß ob Adapter-Versionen der eigenen Installation überhaupt relevant sind, da ja z. B. selbst wenn man selber Admi V5.x nutzt man über cloud immer noch die alte 4er sieht. Wird vermutlich also bei vielen Adaptern so sein…
                    Auf das Issue hat sich bisher auch niemand gemeldet. Ich fände es schon nett wenn man zumindest mal ein Status-Update kriegt wie „Sind dran, größeres Problem, wird ca. x Tage dauern“ oder so….
                    • cashC cash
                      das ist ja nicht einmal 24h alt - also etwas Geduld.
                        cashC Offline
                        cashC Offline
                        cash
                        @homoran da muss ich Dich enttäuschen. Es ist schon älter als 24 Stunden und das deutlich. Ich würde es auf etwa 36 Stunden schätzen :-)
                        Ich könnte jetzt auch noch erwähnen das die cloud-Lösung eine Bezahllösung ist und man dort evtl etwas andere Reaktionszeiten erwarten kann als wenn man einen Beta-Adapter installiert und der Adapter dann nicht funktioniert. Wie schon erwähnt, würde ja ein kurzes „wir sind dran, Dauer x Tage“ reichen. Aber das mache ich natürlich nicht, zumal das ganze eigentlich ziemlich zuverlässig und schon sehr lange sauber läuft. Man könnte auch erwähnen, dass die User die dafür zahlen nicht mal eine Info bekommen haben, das es Abends vorher ggf. ein Update gab. Auch das würde ich nicht tun zumal ich nichtmal weiß ob es stimmt, da es nur eine Vermutung ist.
                        Ist nicht so negativ gemeint, wie man es aufnehmen könnte, bin insgesamt sehr zufrieden nur bei manchen sachen fehlt mir einfach etwas die Kommunikation. Ja ich weiß das kostet Zeit und in der Zeit kann man teils viele Zeilen code schreiben aber je größer eine Community ist je wichtiger ist so etwas. Zumindest für mein empfinden.
                        • cashC cash
                          @cash da bist du massiv auf dem Holzweg!
                          läuft die cloud, oder nicht?
                          • apollon77A Offline
                            Mal so ne ganz freche Frage: JavaScript Adapter >5.1.9? Ihr habt gesehen das der Admin 5.1.x braucht (https://github.com/ioBroker/ioBroker.javascript/blob/master/README.md#520-2021-07-04)? Welche Admin-version ist doch gleich auf Cloud verfügbar? Mir wäre neu das das schon ein Admin5 ist was per Cloud Server verfügbar ist ...
                            Das bringt mich geschlussfolgert zu einer Vermutung ... ... ... versuch doch mal JavaScript Downgrade auf 5.1.x ... Ich würde vermuten das das durchaus das Problem lösen könnte. (Und ja ist nur eine Annahme)
                            Bitte bedenkt das der Cloud Server bestimmt Versionen der Adapter hat die eher Stable entsprechen als Latest und ggf nichts mit Euren lokalen Versionen zu tun haben, sondern nur auf diese "Datentechnisch" zugreifen.
                            Das bedeutet: Wer lokal im Latest unterwegs ist kann mit Cloud durchaus solche inkompatibilitäten haben und das ist dann auch so.
                            Sobald der controller 3.3 und Admin5 und der ganze Rest dann ins Stable geht bekommt auch der Cloud-Server die Updates.
                              cashC Offline
                              cashC Offline
                              cash
                              @homoran nein sie läuft selbstverständlich nicht. Präziser: Der Funktionsumfang ist je nach User sehr eingeschränkt. Für mich sind nur 3 Sachen interessant Logs, Instanzen und der Scriptbereich. Alles andere nutze ich nicht, denn sonst würde ich anmerken das je nach gebastelten VIS dies auch nicht bedienbar ist. Mache ich aber nicht, weil ich es nicht nutze.
                              Das Problem besteht aber wohl schon länger…Wobei es dafür eine plausible „Ausrede“ geben wird.
                              Auch hier ist Ausrede nicht negativ gemeint.
                              • apollon77A apollon77
                                cashC Offline
                                cashC Offline
                                cash
                                @apollon77 Javascript nutze ich 5.1.3.
                                Den Tag davor ging es noch und ich habe an dem Tag nicht einen Adapter aktualisiert…
                                  seit gestern Mittag ist das Issue gefixt. Man muss allerdings Cloud 4.1.0 nutzen. Bitte checken
                                    cashC Offline
                                    cashC Offline
                                    cash
                                    @apollon77 ich habe den Adapter gestern installiert und das Issue geschlossen. Was mich interessieren würde wo das Problem lag? Da der Adapter ja vorher lief kann ja eigentlich nur der Server ein Update erhalten haben womit wiederum der Adapter nicht zurecht kam.
                                    Was mich generell interessieren würde. Welche Adapter spielen eigentlich eine wesentlich Rolle das es funktioniert? Mit anderen Worten bei welchen Adaptern sollte man Beta meiden damit es sicher läuft und welche kann man installieren?
                                    Meine Vermutung wäre stable: Admi, jascript, cloud, iot, echarts, web, socket io und vis. Alle anderen spielen keine große Rolle?
                                      In dem Fall hat Bluefix JavaScript auf dem Cloud Server aktualisiert und übersehen das Admin noch auf 4 war ... Damit "kaputt" ... :-( Wir arbeiten hart das wir endlich Admin5 und so ins Stable bekommen das solche komischen Dependencies uns nicht nochmal ärgern
