  4. Admin funktioniert seit update auf 5.1.10 nicht mehr
    6.7k
60 Beiträge 6 Kommentatoren 3.0k Aufrufe 6 Beobachtet
  • M myssv
    cd /opt/iobroker
    npm cache clear --force
    Hatte ich ausgeführt. Kann es an der Version bei github liegen?
    @myssv
    npm cache verify
      @myssv
      npm cache verify
      myssv
      @thomas-braun sagte in Admin funktioniert seit update auf 5.1.10 nicht mehr:
      npm cache verify
      root@iobroker:/opt/iobroker# npm cache verify
      Cache verified and compressed (~/.npm/_cacache):
      Content verified: 30 (40281332 bytes)
      Index entries: 37
      Finished in 0.69s
      • M myssv
        npm cache verify
        Index entries: 37
        Finished in 0.69s
        myssv
        root@iobroker:/opt/iobroker# iobroker upgrade
        This upgrade of "admin" will introduce the following changes:
        -> 5.1.10:
        Corrected some GUI errors
        Would you like to upgrade admin from @5.1.9 to @5.1.10 now? [(y)es, (n)o]: y
        Update admin from @5.1.9 to @5.1.10
        host.iobroker Adapter "system.adapter.admin.0" is stopped.
        NPM version: 6.14.13
        npm install iobroker.admin@5.1.10 --loglevel error --prefix "/opt/iobroker" (System call)
        npm ERR! code EINTEGRITY
        npm ERR! Verification failed while extracting iobroker.openligadb@https://github.com/oweitman/ioBroker.openligadb/tarball/master:
        npm ERR! sha512-pB22Fvp08/amIRWYLQfhozpKkRAiM2LUDrNZrEnHDhERBwidYFYWOFFJ80N54pVh9yz6Y3gbJ3VWK4/VmPl77A== integrity checksum failed when using sha512: wanted sha512-pB22Fvp08/amIRWYLQfhozpKkRAiM2LUDrNZrEnHDhERBwidYFYWOFFJ80N54pVh9yz6Y3gbJ3VWK4/VmPl77A== but got sha512-WLFcOaoHfNIu5uGyi6Q/iQ/UB+ITNjsAYShVYAUsWoefc/3RrqZzWl7odAxoQaRDmnkYP9+/s2/sE2mrAJPakQ==. (252178 bytes)
        npm ERR!     /opt/iobroker/.npm/_logs/2021-07-10T10_12_55_252Z-debug.log
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        Adapter "admin" updated
        host.iobroker Adapter "system.adapter.admin.0" is started
        • M myssv
          Moin zusammen,
          ich habe gerade das Update vom Admin Adapter auf die 5.1.10 gestartet. Dabei hat er sich irgendwie aufgehängt. Es lief der Kreis in Dauerschleife.
          Danach habe ich den Server neu gestartet und nun komme ich nicht mehr auf die Admin Oberfläche. Die VIS an sich läuft, aber der Admin nicht.
          Was kann ich tun?
          PS: Das ganze läuft bei mir in einer Docker-Umgebung auf einer Synology. Mit dem Portainer komme ich auf die Oberfläche und in die Logs. Die zeigen aber nichts ungewöhnliches:
          -----       Welcome to your ioBroker-container!        -----
          -----          Startupscript is now running.           -----
          -----                Please be patient!                -----
          -----              Debugging information               -----
          -----                      System                      -----
          -----               arch:      x86_64                  -----
          -----                     Versions                     -----
          -----               image:     v5.1.0                  -----
          -----               node:      v14.17.3                -----
          -----               npm:       7.19.1                  -----
          -----                       ENV                        -----
          -----               AVAHI:     false                   -----
          -----               PACKAGES:  nano                    -----
          -----               SETGID:    1000                    -----
          -----               SETUID:    1000                    -----
          -----               USBDEVICES: none                    -----
          -----               ZWAVE:     false                   -----
          -----         Step 1 of 5: Preparing container         -----
          Installing additional packages is set by ENV.
          The following packages will be installed: nano...
          Done.
          -----   Step 2 of 5: Detecting ioBroker installation   -----
          Existing installation of ioBroker detected in /opt/iobroker.
          -----   Step 3 of 5: Checking ioBroker installation    -----
          (Re)Setting folder permissions (This might take a while! Please be patient!)...
          Done.
          Fixing "sudo-bug" by replacing sudo in iobroker with gosu...
          Done.
          -----      Step 4 of 5: Applying special settings      -----
          Some adapters have special requirements/ settings which can be activated by the use of environment variables.
          For more information take a look at readme.md on Github!
          -----          Step 5 of 5: ioBroker startup           -----
          Starting ioBroker...
          host.iobroker check instance "system.adapter.admin.0" for host "iobroker"
          host.iobroker check instance "system.adapter.email.0" for host "iobroker"
          host.iobroker check instance "system.adapter.javascript.0" for host "iobroker"
          host.iobroker check instance "system.adapter.weatherunderground.0" for host "iobroker"
          host.iobroker check instance "system.adapter.web.0" for host "iobroker"
          host.iobroker check instance "system.adapter.history.0" for host "iobroker"
          host.iobroker check instance "system.adapter.vis.0" for host "iobroker"
          host.iobroker check instance "system.adapter.info.0" for host "iobroker"
          host.iobroker check instance "system.adapter.vis-hqwidgets.0" for host "iobroker"
          host.iobroker check instance "system.adapter.vis-timeandweather.0" for host "iobroker"
          host.iobroker check instance "system.adapter.trashschedule.0" for host "iobroker"
          host.iobroker check instance "system.adapter.ical.0" for host "iobroker"
          host.iobroker check instance "system.adapter.dwd.0" for host "iobroker"
          host.iobroker check instance "system.adapter.rainbird.0" for host "iobroker"
          host.iobroker check instance "system.adapter.tankerkoenig.0" for host "iobroker"
          host.iobroker check instance "system.adapter.vis-rgraph.0" for host "iobroker"
          host.iobroker check instance "system.adapter.vis-materialdesign.0" for host "iobroker"
          host.iobroker check instance "system.adapter.web-speedy.0" for host "iobroker"
          host.iobroker check instance "system.adapter.vis-canvas-gauges.0" for host "iobroker"
          host.iobroker check instance "system.adapter.openligadb.0" for host "iobroker"
          host.iobroker check instance "system.adapter.pollenflug.0" for host "iobroker"
          host.iobroker check instance "system.adapter.ping.0" for host "iobroker"
          host.iobroker check instance "system.adapter.backitup.0" for host "iobroker"
          host.iobroker check instance "system.adapter.vis-google-fonts.0" for host "iobroker"
          host.iobroker check instance "system.adapter.fritzdect.0" for host "iobroker"
          host.iobroker check instance "system.adapter.fb-checkpresence.0" for host "iobroker"
          host.iobroker check instance "system.adapter.tr-064.0" for host "iobroker"
          host.iobroker check instance "system.adapter.fitbit-api.0" for host "iobroker"
          host.iobroker check instance "system.adapter.fitbit-api.1" for host "iobroker"
          host.iobroker check instance "system.adapter.tvprogram.0" for host "iobroker"
          host.iobroker check instance "system.adapter.telegram.0" for host "iobroker"
          host.iobroker check instance "system.adapter.govee.0" for host "iobroker"
          ls: Zugriff auf '/dev/disk/by-id/' nicht möglich: Datei oder Verzeichnis nicht gefunden
          GlasfaserG Offline
          GlasfaserG Offline
          @myssv
          @Thomas-Braun
          ... das ist nur ein gebastel .. er hantiert im Docker mit root ( Standart Login ) man weiß ja nicht was vorher noch war , besonders da er im BETA Status ist
          das gibt kein Ende ....Docker neu .... Backup rein fertig !
          M 2 Antworten Letzte Antwort
          • GlasfaserG Glasfaser
            @myssv
            @Thomas-Braun
            myssv
            @glasfaser sagte in Admin funktioniert seit update auf 5.1.10 nicht mehr:
            Das habe ich ja vorhin gemacht!
            • M myssv
              GlasfaserG Offline
              GlasfaserG Offline
              @myssv sagte in Admin funktioniert seit update auf 5.1.10 nicht mehr:
              Ab welchen Beitrag ,ich sehe davon nichts ?
                myssv
                • M myssv
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @myssv
                  Hast du den Adapter openligadb mal deinstalliert ?
                    @myssv
                    myssv
                    @glasfaser jetzt ja
                    Jetzt lief das Update durch ...
                    -> 5.1.10:
                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                    Update "system.adapter.admin.0"
                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                    Vielen Dank für Eure Hilfe!!!
                      @myssv
                      @Thomas-Braun
                      myssv
                      @myssv
                      @Thomas-Braun
                      Nun ja, wäre ich nicht im Beta Status, könnte ich z.B. die Neue Vis-Offline Lizenz nicht nutzen.
                      Zitat: Zur Nutzung dieser Offline Lizenz ist der Vis Adapter in Version v1.4.3 nötig.
                      Im Stable ist noch 1.3.10
                      • M myssv
                        @myssv
                        @Thomas-Braun
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @myssv
                        Es war eine Anmerkung , das du komplett im Beta-Status bist.
                        Du kannst auch die VIS 1.4.3 einzeln nutzen ohne alles im Beta zu haben !
                          @myssv
                          myssv
                          schrieb am zuletzt editiert von myssv
                          @glasfaser
                          ok, verstehe.
                          Aber das macht die Sache gerade für unerfahrene Anwender wie mich nicht gerade einfacher. Da ich mir dann die Adapter selber suchen muss, wo neue Updates Sinn machen.
                          Dazu kommen dann ja evtl. noch irgendwelche Abhängigkeiten. Die aktuelle VIS setzt dies oder jenes vorraus, wo ich dann auch wieder manuell suchen muss ...
                          Im Beta Status wurden mir bisher immer gleich die neuen Versionen vorgeschlagen und ich hatte noch nicht ein Problem damit. Außer wenn ich selber was ver(schlimm)bessern wollte ...
                          • M myssv
                            @glasfaser
                            ok, verstehe.
                            @myssv
                            Und gerade dann sollte man nicht komplett im Beta-Zweig herumhüpfen.
                            • M myssv
                              @glasfaser
                              ok, verstehe.
                              was verstehst du darunter?
                              neue gerade halbwegs implementierte Features, die nach ausgiebigem Testen etwas später auch im "stable" sind, wenn weitestgehend gesichert ist, dass sie stabil laufen?
                              es gibt nur ganz wenige Fälle, in denen man kurzfristig das Repo zur Installation umstellen müsste, dann aber nur diese eine Aktualisierung durchführt und danach sofort das Repo wieder auf stable stellt.
                              Wo ist dabei das Problem.
                              wenn du immer im stable bist erfährst du gar nichts von anderen Versionen.
                              SezerS 1 Antwort Letzte Antwort
                                SezerS Offline
                                SezerS Offline
                                Sezer
                                @homoran kann ich mich hir in das thrad anschliessen?ich erreiche mein iobroker auch nicht mehr.
                                • SezerS Sezer
                                  @sezer Bitte eigenen Thread mit den eigenen Informationen zum System und dessen Rückmeldungen starten.
