  4. Test Adapter Shelly v4.0.6 (latest)
    6.7k
shelly
360 Beiträge 34 Kommentatoren 87.8k Aufrufe 36 Beobachtet
  • NegaleinN Negalein
    Hallo
    Ich hab den Adapter auf 4.0.8 laufen.
    Derzeit ist nur ein Plug-S angemeldet.
    Grundsätzlich funktioniert alles. Nur ist der Adapter komischerweise gelb!
    Hab nicht wirklich was zu diesem Phänomen gefunden.
    2021-07-07 19:24:48.660  - info: host.ioBroker instance system.adapter.shelly.0 started with pid 15350
    2021-07-07 19:24:49.056  - debug: shelly.0 (15350) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2021-07-07 19:24:49.069  - debug: shelly.0 (15350) Objects client ready ... initialize now
    2021-07-07 19:24:49.069  - debug: shelly.0 (15350) Objects create System PubSub Client
    2021-07-07 19:24:49.070  - debug: shelly.0 (15350) Objects create User PubSub Client
    2021-07-07 19:24:49.070  - debug: shelly.0 (15350) Objects client initialize lua scripts
    2021-07-07 19:24:49.082  - debug: shelly.0 (15350) Objects connected to redis: 0.0.0.0:9001
    2021-07-07 19:24:49.085  - debug: shelly.0 (15350) objectDB connected
    2021-07-07 19:24:49.086  - debug: shelly.0 (15350) Redis States: Use Redis connection: 0.0.0.0:9000
    2021-07-07 19:24:49.093  - debug: shelly.0 (15350) States create System PubSub Client
    2021-07-07 19:24:49.093  - debug: shelly.0 (15350) States create User PubSub Client
    2021-07-07 19:24:49.103  - debug: shelly.0 (15350) States connected to redis: 0.0.0.0:9000
    2021-07-07 19:24:49.104  - debug: shelly.0 (15350) statesDB connected
    2021-07-07 19:24:49.378  - debug: shelly.0 (15350) Plugin sentry Initialize Plugin (enabled=true)
    2021-07-07 19:24:49.516  - info: shelly.0 (15350) starting. Version 4.0.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.17.1, js-controller: 3.3.14
    2021-07-07 19:24:49.526  - info: shelly.0 (15350) Starting Adapter shelly.0 in version 4.0.8
    2021-07-07 19:24:49.608  - info: shelly.0 (15350) Starting Shelly adapter in CoAP modus.
    2021-07-07 19:24:49.625  - info: shelly.0 (15350) Listening for Shelly packets in the network
    2021-07-07 19:24:51.306  - debug: shelly.0 (15350) CoAP status package received: {"3332":"SHPLG-S#DE2ACB#2","3412":38400,"3420":30208,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]}
    2021-07-07 19:24:51.306  - debug: shelly.0 (15350) Status update received for SHPLG-S#DE2ACB#2: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]}
    2021-07-07 19:24:51.307  - debug: shelly.0 (15350) CoAP device description request for SHPLG-S#DE2ACB#2 to 10.0.1.190(0)
    2021-07-07 19:24:51.321  - debug: shelly.0 (15350) CoAP response: {"3332":"SHPLG-S#DE2ACB#2"}
    2021-07-07 19:24:51.321  - debug: shelly.0 (15350) Device description received: {"3332":"SHPLG-S#DE2ACB#2"} / {"blk":[{"I":1,"D":"relay_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":1101,"T":"S","D":"output","R":"0/1","L":1},{"I":4101,"T":"P","D":"power","U":"W","R":["0/2500","-1"],"L":1},{"I":4103,"T":"E","D":"energy","U":"Wmin","R":["U32","-1"],"L":1},{"I":6102,"T":"A","D":"overpower","R":["0/1","-1"],"L":1},{"I":6109,"T":"P","D":"overpowerValue","U":"W","R":["U32","-1"],"L":1},{"I":3104,"T":"T","D":"deviceTemp","U":"C","R":["-40/300","999"],"L":2},{"I":3105,"T":"T","D":"deviceTemp","U":"F","R":["-40/572","999"],"L":2},{"I":6101,"T":"A","D":"overtemp","R":["0/1","-1"],"L":2}]}
    2021-07-07 19:24:51.322  - info: shelly.0 (15350) Shelly device 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1) with CoAP connected! Polltime set to 5 sec.
    2021-07-07 19:24:51.322  - debug: shelly.0 (15350) 1. Shelly device Info: SHPLG-S#DE2ACB#1 : {"blk":[{"I":1,"D":"relay_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":1101,"T":"S","D":"output","R":"0/1","L":1},{"I":4101,"T":"P","D":"power","U":"W","R":["0/2500","-1"],"L":1},{"I":4103,"T":"E","D":"energy","U":"Wmin","R":["U32","-1"],"L":1},{"I":6102,"T":"A","D":"overpower","R":["0/1","-1"],"L":1},{"I":6109,"T":"P","D":"overpowerValue","U":"W","R":["U32","-1"],"L":1},{"I":3104,"T":"T","D":"deviceTemp","U":"C","R":["-40/300","999"],"L":2},{"I":3105,"T":"T","D":"deviceTemp","U":"F","R":["-40/572","999"],"L":2},{"I":6101,"T":"A","D":"overtemp","R":["0/1","-1"],"L":2}]}
    2021-07-07 19:24:51.322  - debug: shelly.0 (15350) 2. Shelly device Info: SHPLG-S#DE2ACB#1 : {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]}
    2021-07-07 19:24:51.324  - debug: shelly.0 (15350) CoAP Message for SHPLG-S#DE2ACB#1 : {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]}
    2021-07-07 19:24:51.325  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Switch, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.325  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Switch, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.325  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.Relay0.Switch, Value: true for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.325  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Power, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.325  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Power, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.Relay0.Power, Value: 97 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Energy, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Energy, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.Relay0.Energy, Value: 71.23 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.overpowerValue, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.overpowerValue, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.Relay0.overpowerValue, Value: 0 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.326  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureC, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureC, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.temperatureC, Value: 40.68 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureF, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureF, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.temperatureF, Value: 105.23 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.overtemperature, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,97],[0,4103,4274],[0,6102,0],[0,6109,0],[0,3104,40.68],[0,3105,105.23],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.overtemperature, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:24:51.327  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.overtemperature, Value: false for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.333  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings/relay/0","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.357  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.Relay0.ChannelName, Value: null for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.360  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.396  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.Relay0.AutoTimerOff, Value: 0 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.397  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.Relay0.AutoTimerOn, Value: 0 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.413  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.Relay0.Timer, Value: 0 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.414  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.led_wifi_disable, Value: false for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.414  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.led_power_disable, Value: false for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.414  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.version, Value: "20210429-101611/v1.10.4-g3f94cd7" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.423  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.name, Value: null for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.423  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/status","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.450  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.firmware, Value: false for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.450  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.uptime, Value: "00:49:12" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.450  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.hostname, Value: "10.0.1.190" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.450  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.id, Value: "shellyplug-s" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.450  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.type, Value: "SHPLG-S" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:51.451  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.rssi, Value: -56 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:56.454  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings/relay/0","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:56.628  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:56.695  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/status","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:24:56.718  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.uptime, Value: "00:49:17" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:01.722  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings/relay/0","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:02.043  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:02.134  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/status","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:02.160  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.uptime, Value: "00:49:22" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:06.303  - debug: shelly.0 (15350) CoAP status package received: {"3332":"SHPLG-S#DE2ACB#2","3412":38400,"3420":30208,"Uri-Path":"cit/s"} / {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]}
    2021-07-07 19:25:06.303  - debug: shelly.0 (15350) Status update received for SHPLG-S#DE2ACB#2: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]}
    2021-07-07 19:25:06.303  - debug: shelly.0 (15350) CoAP device description request for SHPLG-S#DE2ACB#2 to 10.0.1.190(0)
    2021-07-07 19:25:06.304  - debug: shelly.0 (15350) CoAP Message for SHPLG-S#DE2ACB#1 : {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]}
    2021-07-07 19:25:06.304  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Switch, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.304  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Switch, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.304  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Power, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.304  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Power, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.Relay0.Power, Value: 95.91 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Energy, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.Energy, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.Relay0.Energy, Value: 72.85 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.overpowerValue, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.Relay0.overpowerValue, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureC, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureC, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.305  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.temperatureC, Value: 40.76 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:06.306  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureF, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.306  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.temperatureF, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.306  - debug: shelly.0 (15350) State change : SHPLG-S#DE2ACB#1.temperatureF, Value: 105.37 for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:06.306  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.overtemperature, Payload: {"G":[[0,9103,0],[0,1101,1],[0,4101,95.91],[0,4103,4371],[0,6102,0],[0,6109,0],[0,3104,40.76],[0,3105,105.37],[0,6101,0]]} for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.306  - debug: shelly.0 (15350) Create State : SHPLG-S#DE2ACB#1.overtemperature, Payload: [object Object] for SHPLG-S#DE2ACB#1
    2021-07-07 19:25:06.322  - debug: shelly.0 (15350) CoAP response: {"3332":"SHPLG-S#DE2ACB#2"}
    2021-07-07 19:25:06.322  - debug: shelly.0 (15350) Device description received: {"3332":"SHPLG-S#DE2ACB#2"} / {"blk":[{"I":1,"D":"relay_0"},{"I":2,"D":"device"}],"sen":[{"I":9103,"T":"EVC","D":"cfgChanged","R":"U16","L":2},{"I":1101,"T":"S","D":"output","R":"0/1","L":1},{"I":4101,"T":"P","D":"power","U":"W","R":["0/2500","-1"],"L":1},{"I":4103,"T":"E","D":"energy","U":"Wmin","R":["U32","-1"],"L":1},{"I":6102,"T":"A","D":"overpower","R":["0/1","-1"],"L":1},{"I":6109,"T":"P","D":"overpowerValue","U":"W","R":["U32","-1"],"L":1},{"I":3104,"T":"T","D":"deviceTemp","U":"C","R":["-40/300","999"],"L":2},{"I":3105,"T":"T","D":"deviceTemp","U":"F","R":["-40/572","999"],"L":2},{"I":6101,"T":"A","D":"overtemp","R":["0/1","-1"],"L":2}]}
    2021-07-07 19:25:07.164  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings/relay/0","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:07.183  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:07.216  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/status","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:07.240  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.uptime, Value: "00:49:27" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:12.244  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings/relay/0","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:12.262  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/settings","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:12.293  - debug: shelly.0 (15350) http request{"url":"http://10.0.1.190/status","timeout":5000,"headers":{"Authorization":"Basic Y2hyaXN0aWFuQG5lZ2EuYXQ6eWludXR1MjY="}} for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:12.318  - debug: shelly.0 (15350) Set http state SHPLG-S#DE2ACB#1.uptime, Value: "00:49:32" for 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1)
    2021-07-07 19:25:15.431  - info: host.ioBroker stopInstance system.adapter.shelly.0 (force=false, process=true)
    2021-07-07 19:25:15.433  - info: shelly.0 (15350) Got terminate signal TERMINATE_YOURSELF
    2021-07-07 19:25:15.433  - info: shelly.0 (15350) Closing Adapter
    2021-07-07 19:25:15.434  - info: shelly.0 (15350) terminating
    2021-07-07 19:25:15.434  - debug: shelly.0 (15350) Plugin sentry destroyed
    2021-07-07 19:25:15.434  - info: shelly.0 (15350) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-07-07 19:25:15.437  - info: host.ioBroker stopInstance system.adapter.shelly.0 send kill signal
    2021-07-07 19:25:15.997  - info: host.ioBroker instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-07-07 19:25:18.529  - info: host.ioBroker instance system.adapter.shelly.0 started with pid 16038
    2021-07-07 19:25:19.451  - info: shelly.0 (16038) starting. Version 4.0.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.17.1, js-controller: 3.3.14
    2021-07-07 19:25:19.462  - info: shelly.0 (16038) Starting Adapter shelly.0 in version 4.0.8
    2021-07-07 19:25:19.548  - info: shelly.0 (16038) Starting Shelly adapter in CoAP modus.
    2021-07-07 19:25:19.565  - info: shelly.0 (16038) Listening for Shelly packets in the network
    2021-07-07 19:25:21.323  - info: shelly.0 (16038) Shelly device 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1) with CoAP connected! Polltime set to 5 sec.
    da_WoodyD Offline
    da_WoodyD Offline
    #297
    @negalein was macht da benutzername und passwort? hast du den shelly restricted?
    • C Cino
      Kann man es ändern das bei dem Namen vom Shelly keine Raute angegeben wird? In der Vis gibt das Probleme wenn man mit den Werten rechnen will.
      da_WoodyD Offline
      da_WoodyD Offline
      #298
      @cino versteh ich nicht, was hat die # mit dem wert zu tun mit dem du rechnest?
      abgesehn davon, schon überlegt mit Alias zu arbeiten? alias-manager
      C 1 Antwort Letzte Antwort
      • da_WoodyD da_Woody
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #299
        @da_woody sagte in Test Adapter Shelly v4.0.6 (latest):
        Hmmm, hab gedacht hier gehören die Anmeldedaten rein?
        Restricted?? Was ist das?
        ° Fixer ---> iob fix
          da_WoodyD Offline
          da_WoodyD Offline
          #300
          @negalein bis auf die polltime gehört da gar nix rein.
          du kannst ja jedem shelly die weboberfläche sperren.
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #301
            Thx
            bleibt trotzdem Gelb. Aber volle Funktionalität.
            wie geil ist das denn? Die haben eine eigene Weboberfläche?
            Mag wer meine TP-Link? 😂 😂
              Thx
              da_WoodyD Offline
              da_WoodyD Offline
              #302
              @negalein sagte in Test Adapter Shelly v4.0.6 (latest):
              öhmm, wie hast du CoIOT eingestellt? das geht nur auf der GUI...
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #303
                hab da nichts gemacht.
                Web erst gerade mal geöffnet.
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #304
                  dann wirst du auch keine werte in den objekten bekommen... mcast tut nicht mehr. unicast ist programm.
                  IP von ioBroker, save. port wird automatisch angehängt...
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #305
                    Doch. Das ist ja das merkwürdige (siehe GIF)!
                    Also, da wo in meinem obigen Screenshot mcast steht, kommt die ioBroker IP rein?
                      da_WoodyD Offline
                      da_WoodyD Offline
                      #306
                      @negalein normalerweise wird nur rssi und uptime aktualisiert, der rest nicht. funktionieren tun sie trotzdem.
                      jup, statt mcast gehört die IP vom ioB rein.
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #307
                        Ok, am Verhalten hat sich nichts geändert.
                        Bleibt gelb.
                        shelly.0	2021-07-07 22:42:13.833	info	(6261) Shelly device 10.0.1.190 (shellyplug-s / shellyplug-s-DE2ACB / SHPLG-S#DE2ACB#1) with CoAP connected! Polltime set to 5 sec.
                        shelly.0	2021-07-07 22:41:59.030	info	(6261) Listening for Shelly packets in the network
                        shelly.0	2021-07-07 22:41:59.012	info	(6261) Starting Shelly adapter in CoAP modus.
                        shelly.0	2021-07-07 22:41:58.918	info	(6261) Starting Adapter shelly.0 in version 4.0.8
                        shelly.0	2021-07-07 22:41:58.905	info	(6261) starting. Version 4.0.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.17.1, js-controller: 3.3.14
                          Bleibt gelb.
                          da_WoodyD Offline
                          da_WoodyD Offline
                          #308
                          @negalein hmm, du bist da nicht der einzige... keine ahnung was da bei euch los ist.
                            Cino
                            #309
                            @da_woody said in Test Adapter Shelly v4.0.6 (latest):
                            https://forum.iobroker.net/topic/46245/werte-im-vis-addieren/6
                            IOB@RPI4
                            Shelly, Zigbee, ebus
                            • C Cino
                              da_WoodyD Offline
                              da_WoodyD Offline
                              #310
                              @cino auch dort wird dir empfohlen mir alias zu arbeiten... ;)
                              dann hast du die probleme nicht und nebenbei eine schöne struktur.
                              • ? Offline
                                #311
                                Es funktioniert alles aber der Adapter 4.0.8 wird nicht mehr grün. Was kann man als Information liefern damit er wieder grün wird.
                                  da_WoodyD Offline
                                  da_WoodyD Offline
                                  #312
                                  @brainbug das problem hab ich jetzt schon oft gelesen, lösung hab ich bis jetzt keine... sorry
                                  bei mir ist das ding grün.
                                  möglich, daß es mit COAP und cloud zusammenhängt. bei mir ist beides aktiv.
                                  bin aber auch mit der FW aktuell.
                                  • ? Offline
                                    #313
                                    System läuft bei mir auf latest und wird trotz produktiv immer auf den neusten Stand gebracht.
                                    E 1 Antwort Letzte Antwort
                                      e-s
                                      #314
                                      @brainbug
                                      Was sagt denn das log?
                                        #315
                                        Der Adapter bleibt bei mir auch grün und hatte nur einmal kurz Probleme, wo ich sehr viel mit der Firmware der Shellys und MCAST/Unicast probiert und gewechselt habe. Nachdem sich mein Zielzustand (Neuste Firmware mit Unicast) als funktional erwiesen hat, hat es dann auch funktioniert. Werden sicher einige Shelly Neustarts, ggf. Neustarts von Netzwerktechnik wie Router und dem Adapter auch gemacht worden sein.
                                        Darf ich daraus schließen, dass die aktuelle Firmware 1.11.2 bei Dir funktioniert? Bin noch komplett auf 1.10.4 und auch froh nicht sofort die ersten 11er Versionen probiert zu haben :) Aber die 1.11.2 schein ja nun wieder funktional zu sein und ein Upgrade wäre denkbar.
                                          da_WoodyD Offline
                                          da_WoodyD Offline
                                          #316
                                          @pete0815 bei ir siehts gut aus. die fixes waren ja schnell da. teilweise schneller, als ich das update gemacht hab... :)
