  4. ZigBee neue Version 1.5.x
    6.5k
579 Beiträge 72 Kommentatoren 188.4k Aufrufe 74 Beobachtet
  • DK43D DK43
    @asgothian
    Node.js v12.22.1
    NPM 6.14.12
    zigbee.0	2021-06-27 20:43:00.426	error	(1159) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
    host.iobroker-pi	2021-06-27 20:38:49.770	info	Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
    zigbee.0	2021-06-27 20:23:31.547	error	(1159) Error herdsman start
    zigbee.0	2021-06-27 20:23:31.546	error	(1159) Failed to start Zigbee
    zigbee.0	2021-06-27 20:23:31.545	error	(1159) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0	2021-06-27 20:23:31.261	info	(1159) Installed Version: iobroker.zigbee@1.5.6
    zigbee.0	2021-06-27 20:23:31.220	info	(1159) Starting Zigbee npm ...
    zigbee.0	2021-06-27 20:23:31.217	info	(1159) Try to reconnect. 1 attempts left
    zigbee.0	2021-06-27 20:23:21.213	error	(1159) Error herdsman start
    zigbee.0	2021-06-27 20:23:21.212	error	(1159) Failed to start Zigbee
    zigbee.0	2021-06-27 20:23:21.208	error	(1159) Starting zigbee-herdsman problem : "network commissioning timed out - most likely network with the same panId or extendedPanId already exists nearby"
    zigbee.0	2021-06-27 20:22:15.123	info	(1159) Installed Version: iobroker.zigbee@1.5.6
    zigbee.0	2021-06-27 20:22:14.275	info	(1159) Starting Zigbee npm ...
    zigbee.0	2021-06-27 20:22:14.072	info	(1159) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
    host.iobroker-pi	2021-06-27 20:22:09.484	info	instance system.adapter.zigbee.0 started with pid 1159
    info.0	2021-06-27 20:22:06.677	info	(764) starting. Version 1.7.14 in /opt/iobroker/node_modules/iobroker.info, node: v12.22.1, js-controller: 3.2.16
    host.iobroker-pi	2021-06-27 20:22:02.133	info	instance system.adapter.info.0 started with pid 764
    discovery.0	2021-06-27 20:21:59.537	info	(745) starting. Version 2.6.1 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.1, js-controller: 3.2.16
    admin.0	2021-06-27 20:21:58.067	info	(734) Use link "http://localhost:8081" to configure.
    admin.0	2021-06-27 20:21:58.066	info	(734) http server listening on port 8081
    admin.0	2021-06-27 20:21:57.821	info	(734) received all objects
    admin.0	2021-06-27 20:21:57.213	info	(734) requesting all objects
    admin.0	2021-06-27 20:21:57.212	info	(734) requesting all states
    admin.0	2021-06-27 20:21:57.123	info	(734) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.1, js-controller: 3.2.16
    host.iobroker-pi	2021-06-27 20:21:56.537	info	instance system.adapter.discovery.0 started with pid 745
    host.iobroker-pi	2021-06-27 20:21:53.696	info	instance system.adapter.admin.0 started with pid 734
    host.iobroker-pi	2021-06-27 20:21:39.463	info	Restart adapter system.adapter.zigbee.0 because enabled
    host.iobroker-pi	2021-06-27 20:21:39.462	error	instance system.adapter.zigbee.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    zigbee.0	2021-06-27 20:21:38.878	warn	(623) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    zigbee.0	2021-06-27 20:21:38.874	error	(623) zigbee.0 already running
    so sieht der Log aus nach einem Neustart des Raspberrys
    Ich danke euch für eure Hilfe :)
    arteckA Offline
    arteckA Offline
    arteck
    #501
    @davut-karabulut der Adapter merkt wenn die panid schon vergeben ist.. da die Router diese aussenden..
    entweder du vegibst eine neue oder du nimmst alle Router vom Netz (strom aus) startest den adapter neu und dann kannst die router wieder einschalten. danach sollte sich das Netz wieder heilen
    DK43D 1 Antwort Letzte Antwort
    • K klassisch
      @hg6806 sagte in ZigBee neue Version 1.5.x:
      Ich habe mit dem CC2652P massive Probleme, da nach fast jedem Mal Reboot des Raspberry Pi4 der ComPort wegfliegt:
      Wenn Du löten kannst und willst, kannst Du prüfen, ob die Anbindung über TCP und LAN auch bei Dir erfolgreich ist und Abhilfe schafft.
      Bei mir schnurrt die Sache, zusammen mit einem CC2652P, diesem Adapter in der Version 1.5.5. Der CC2652P und wahrscheinlich auch das TI Launch kit lassen sich recht einfach modifizieren und so "aufrüsten", weil die Kommunikation über die Serielle Schnittstelle zugänglich ist. Wenn man auf die Möglichkeit des Nachflashens verzichtet, wird der Umbau noch etwas einfacher.
      crunchipC Offline
      crunchipC Offline
      #502
      @klassisch hab das auch mal versucht, mit dem CC1352P-2 ( muss nichts gelötet werden), komm aber gar nicht erst auf die Startseite zum einrichten. IP wird im Netzwerk angezeigt, jedoch Seite nicht erreichbar (Unifi Netzwerk), hatte das an nem US-8-60W probiert.
      Vllt hat ja irgendwer nen Tipp ob man da etwas spezielles im Netzwerk einstellen muss?
        klassisch
        #503
        @crunchip sagte in ZigBee neue Version 1.5.x:
        CC1352P-2
        Bei den TI Launchboards kann man TxD und RxD über Jumper erreichen und spart sich das Löten.
        Welchen Serial <-> Eth Wandler hast Du verwendet? Die USRIOT werden leider mit fixed IP (192.168.0.7, wenn ich mich recht erinnere) ausgeliefert. Die muß man zuerst auf DHCP umstellen.
        Dann sind die in einem Fritten-Netzwerk ansprechbar und konfogurierbar.
        Hatte allerdings auch mal einen Nachbau bekommen, der anders aussah und anscheinend keinen Webserver drin hatte.
        • K klassisch
          CC1352P-2
          crunchipC Offline
          crunchipC Offline
          #504
          @klassisch sagte in ZigBee neue Version 1.5.x:
          USRIOT USR-TCP232-T 2 Tiny Seriell-Ethernet-Konverter von Amazon bestellt
          richtig, habs mit 192.168.0.7 und auch mit 192.168.1.7 probiert, so wie in GITHUB beschrieben
          muss ich mir extra nochmal ein Netzwerk mit dem Ip Adressenbereich einrichten, damit ich drauf komme? Meine Netzwerke laufen im 10.1.x.x Bereich
            klassisch
            #505
            @crunchip Interessant, wußte nicht, daß man die auch bei amazon bekommt. Um den Fluß hier nicht zu stören schlage ich vor in den dedizierten Thread umzuziehen
            Muß mir mal Deinen Github Link anschauen und suche auch die passende USR Anleitung raus.
            • arteckA arteck
              DK43D Offline
              DK43D Offline
              DK43
              #506
              @arteck
              Gestern Abend habe ich in den Einstellungen "Zigbee herdsmann debug info" aktiviert und den adapter neu gestartet. Daraufhin hat es plötzlich funktioniert. Der Adapter war grün.
              Testweise habe ich einen SmartPlug gepairt und konnte diesen auch wie gewohnt schalten.
              Über nacht war der Raspberry dann stromlos. Hab ihn vorhin wieder an seinen Ursprünglichen Platz gebracht und wollte anfangen alle Geräte wieder zu pairen.
              Der Adapter war wieder gelb hinterlegt und "Verbunden mit Zigbee" stand auf falsch.
              Durch Deaktivieren und wieder aktivieren der Einstellung "Zigbee Herdsmann Debug Info" hat leider keinen Erfolg gebracht.
              Hier der Aktuelle Log
              zigbee.0	2021-06-28 18:02:50.698	error	(1290) Error herdsman start
              zigbee.0	2021-06-28 18:02:50.697	error	(1290) Failed to start Zigbee
              zigbee.0	2021-06-28 18:02:50.695	error	(1290) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              zigbee.0	2021-06-28 18:02:50.260	info	(1290) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 18:02:50.211	info	(1290) Starting Zigbee npm ...
              zigbee.0	2021-06-28 18:02:50.207	info	(1290) Try to reconnect. 1 attempts left
              zigbee.0	2021-06-28 18:02:40.204	error	(1290) Error herdsman start
              zigbee.0	2021-06-28 18:02:40.202	error	(1290) Failed to start Zigbee
              zigbee.0	2021-06-28 18:02:40.200	error	(1290) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              zigbee.0	2021-06-28 18:02:20.669	info	(1290) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 18:02:19.179	info	(1290) Starting Zigbee npm ...
              zigbee.0	2021-06-28 18:02:18.950	info	(1290) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
              zigbee.0	2021-06-28 18:02:05.581	error	(1253) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:02:05.580	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
              zigbee.0	2021-06-28 18:02:05.580	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
              zigbee.0	2021-06-28 18:02:05.580	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
              zigbee.0	2021-06-28 18:02:05.580	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
              zigbee.0	2021-06-28 18:02:05.580	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
              zigbee.0	2021-06-28 18:02:05.580	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
              zigbee.0	2021-06-28 18:02:05.580	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
              zigbee.0	2021-06-28 18:02:05.580	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
              zigbee.0	2021-06-28 18:02:05.580	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
              zigbee.0	2021-06-28 18:02:05.580	error	(1253) TypeError: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:02:05.577	error	(1253) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:02:05.576	error	(1253) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-28 18:02:05.573	info	(1253) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              zigbee.0	2021-06-28 18:02:05.571	info	(1253) terminating
              zigbee.0	2021-06-28 18:02:05.569	warn	(1253) Failed to stop zigbee during startup
              zigbee.0	2021-06-28 18:02:05.566	info	(1253) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-28 18:02:05.557	info	(1253) cleaned everything up...
              zigbee.0	2021-06-28 18:02:05.554	info	(1253) Got terminate signal TERMINATE_YOURSELF
              zigbee.0	2021-06-28 18:01:54.851	info	(1253) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 18:01:53.612	info	(1253) Starting Zigbee npm ...
              zigbee.0	2021-06-28 18:01:53.343	info	(1253) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
              zigbee.0	2021-06-28 18:01:42.289	error	(1235) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:01:42.287	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
              zigbee.0	2021-06-28 18:01:42.287	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
              zigbee.0	2021-06-28 18:01:42.287	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
              zigbee.0	2021-06-28 18:01:42.287	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
              zigbee.0	2021-06-28 18:01:42.287	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
              zigbee.0	2021-06-28 18:01:42.287	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
              zigbee.0	2021-06-28 18:01:42.287	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
              zigbee.0	2021-06-28 18:01:42.287	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
              zigbee.0	2021-06-28 18:01:42.287	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
              zigbee.0	2021-06-28 18:01:42.287	error	(1235) TypeError: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:01:42.282	error	(1235) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:01:42.280	error	(1235) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-28 18:01:42.276	info	(1235) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              zigbee.0	2021-06-28 18:01:42.273	info	(1235) terminating
              zigbee.0	2021-06-28 18:01:42.270	warn	(1235) Failed to stop zigbee during startup
              zigbee.0	2021-06-28 18:01:42.265	info	(1235) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-28 18:01:42.254	info	(1235) cleaned everything up...
              zigbee.0	2021-06-28 18:01:42.248	info	(1235) Got terminate signal TERMINATE_YOURSELF
              zigbee.0	2021-06-28 18:01:38.588	error	(1235) Error herdsman start
              zigbee.0	2021-06-28 18:01:38.586	error	(1235) Failed to start Zigbee
              zigbee.0	2021-06-28 18:01:38.584	error	(1235) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              zigbee.0	2021-06-28 18:01:19.083	info	(1235) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 18:01:17.787	info	(1235) Starting Zigbee npm ...
              zigbee.0	2021-06-28 18:01:17.517	info	(1235) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
              zigbee.0	2021-06-28 18:01:07.809	error	(1212) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:01:07.807	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
              zigbee.0	2021-06-28 18:01:07.807	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
              zigbee.0	2021-06-28 18:01:07.807	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
              zigbee.0	2021-06-28 18:01:07.807	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
              zigbee.0	2021-06-28 18:01:07.807	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
              zigbee.0	2021-06-28 18:01:07.807	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
              zigbee.0	2021-06-28 18:01:07.807	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
              zigbee.0	2021-06-28 18:01:07.807	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
              zigbee.0	2021-06-28 18:01:07.807	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
              zigbee.0	2021-06-28 18:01:07.807	error	(1212) TypeError: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:01:07.802	error	(1212) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:01:07.800	error	(1212) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-28 18:01:07.796	info	(1212) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              zigbee.0	2021-06-28 18:01:07.793	info	(1212) terminating
              zigbee.0	2021-06-28 18:01:07.791	warn	(1212) Failed to stop zigbee during startup
              zigbee.0	2021-06-28 18:01:07.786	info	(1212) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-28 18:01:07.775	info	(1212) cleaned everything up...
              zigbee.0	2021-06-28 18:01:07.771	info	(1212) Got terminate signal TERMINATE_YOURSELF
              zigbee.0	2021-06-28 18:01:00.233	error	(1212) Error herdsman start
              zigbee.0	2021-06-28 18:01:00.232	error	(1212) Failed to start Zigbee
              zigbee.0	2021-06-28 18:01:00.230	error	(1212) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              zigbee.0	2021-06-28 18:01:00.040	info	(1212) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 18:01:00.001	info	(1212) Starting Zigbee npm ...
              zigbee.0	2021-06-28 18:00:59.997	info	(1212) Try to reconnect. 1 attempts left
              zigbee.0	2021-06-28 18:00:56.667	error	(1212) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
              zigbee.0	2021-06-28 18:00:49.994	error	(1212) Error herdsman start
              zigbee.0	2021-06-28 18:00:49.992	error	(1212) Failed to start Zigbee
              zigbee.0	2021-06-28 18:00:49.990	error	(1212) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              zigbee.0	2021-06-28 18:00:42.850	error	(1212) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
              zigbee.0	2021-06-28 18:00:30.466	info	(1212) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 18:00:29.279	info	(1212) Starting Zigbee npm ...
              zigbee.0	2021-06-28 18:00:28.998	info	(1212) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
              zigbee.0	2021-06-28 18:00:18.849	error	(954) Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:00:18.848	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
              zigbee.0	2021-06-28 18:00:18.848	error	at runMicrotasks (<anonymous>)
              zigbee.0	2021-06-28 18:00:18.848	error	at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:696:41)
              zigbee.0	2021-06-28 18:00:18.848	error	at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:385:20)
              zigbee.0	2021-06-28 18:00:18.848	error	at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:214:42)
              zigbee.0	2021-06-28 18:00:18.848	error	at DeviceAvailability.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceAvailability.js:222:43)
              zigbee.0	2021-06-28 18:00:18.848	error	at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:228:49)
              zigbee.0	2021-06-28 18:00:18.848	error	at Controller.getDevices (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:303:31)
              zigbee.0	2021-06-28 18:00:18.848	error	at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:240:16)
              zigbee.0	2021-06-28 18:00:18.848	error	at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/device.js:220:55)
              zigbee.0	2021-06-28 18:00:18.848	error	(954) TypeError: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:00:18.846	error	(954) unhandled promise rejection: Cannot read property 'getEntries' of null
              zigbee.0	2021-06-28 18:00:18.845	error	(954) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
              zigbee.0	2021-06-28 18:00:18.843	info	(954) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              zigbee.0	2021-06-28 18:00:18.841	info	(954) terminating
              zigbee.0	2021-06-28 18:00:18.840	warn	(954) Failed to stop zigbee during startup
              zigbee.0	2021-06-28 18:00:18.837	info	(954) Zigbee: disabling joining new devices.
              zigbee.0	2021-06-28 18:00:18.832	info	(954) cleaned everything up...
              zigbee.0	2021-06-28 18:00:18.828	info	(954) Got terminate signal TERMINATE_YOURSELF
              zigbee.0	2021-06-28 18:00:05.275	error	(954) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
              zigbee.0	2021-06-28 17:59:17.964	error	(954) getGroups: caught error: TypeError: Cannot read property 'getGroups' of undefined
              zigbee.0	2021-06-28 17:41:37.006	error	(954) Error herdsman start
              zigbee.0	2021-06-28 17:41:37.005	error	(954) Failed to start Zigbee
              zigbee.0	2021-06-28 17:41:37.003	error	(954) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              zigbee.0	2021-06-28 17:41:36.732	info	(954) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 17:41:36.692	info	(954) Starting Zigbee npm ...
              zigbee.0	2021-06-28 17:41:36.688	info	(954) Try to reconnect. 1 attempts left
              zigbee.0	2021-06-28 17:41:26.685	error	(954) Error herdsman start
              zigbee.0	2021-06-28 17:41:26.683	error	(954) Failed to start Zigbee
              zigbee.0	2021-06-28 17:41:26.681	error	(954) Starting zigbee-herdsman problem : "Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)"
              zigbee.0	2021-06-28 17:41:07.188	info	(954) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-28 17:41:05.983	info	(954) Starting Zigbee npm ...
              zigbee.0	2021-06-28 17:41:05.651	info	(954) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
              zigbee.0	2021-06-28 17:40:26.796	warn	(654) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
              zigbee.0	2021-06-28 17:40:26.789	error	(654) zigbee.0 already running
              und so sah der Log aus nachdem ich gestern Abend Zigbee Herdsmann Debug info aktiviert habe.
              zigbee.0	2021-06-27 21:11:50.334	info	(1237) Zigbee started
              zigbee.0	2021-06-27 21:11:50.332	info	(1237) Currently no devices.
              zigbee.0	2021-06-27 21:11:50.318	info	(1237) --> transmitPower : normal
              zigbee.0	2021-06-27 21:11:50.317	info	(1237) Unable to disable LED, unsupported function.
              zigbee.0	2021-06-27 21:11:50.305	info	(1237) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210218}}
              zigbee.0	2021-06-27 21:11:26.925	info	(1237) Installed Version: iobroker.zigbee@1.5.6
              zigbee.0	2021-06-27 21:11:26.218	info	(1237) Starting Zigbee npm ...
              zigbee.0	2021-06-27 21:11:26.059	info	(1237) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.22.1, js-controller: 3.2.16
              host.iobroker-pi	2021-06-27 21:11:21.486	info	instance system.adapter.zigbee.0 started with pid 1237
              host.iobroker-pi	2021-06-27 21:11:19.548	info	instance system.adapter.zigbee.0 terminated with code null ()
              host.iobroker-pi	2021-06-27 21:11:19.547	warn	instance system.adapter.zigbee.0 terminated due to SIGTERM
              host.iobroker-pi	2021-06-27 21:11:19.499	info	stopInstance system.adapter.zigbee.0 killing pid 1230
              host.iobroker-pi	2021-06-27 21:11:18.444	info	stopInstance system.adapter.zigbee.0 send kill signal
              host.iobroker-pi	2021-06-27 21:11:18.436	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
              host.iobroker-pi	2021-06-27 21:11:17.402	info	instance system.adapter.zigbee.0 started with pid 1230
              host.iobroker-pi	2021-06-27 21:11:14.925	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              An der Panid hatte ich nichts geändert.
              • DK43D DK43
                @arteck
                B Online
                B Online
                BigMike71
                schrieb am zuletzt editiert von BigMike71
                #507
                @davut-karabulut
                mal was anderes, wie hast du deinen Raspi in Betrieb?
                SSD an USB 3.0 Anschluss über SATA2USB3.0 Adapter vieleicht?
                wenn ja dann benutze den USB 2.0 Anschluss vom Raspi (nicht die Blauen)
                • F Offline
                  fabwal
                  #508
                  Hallo ich habe auch den Fehler mit:
                  "startup failed - configuration-adapter mismatch - see logs above for more information"
                  Please update configuration to prevent further issues.
                  zigbee.0	2021-06-29 09:09:07.348	error	(9127) - Channel List: configured=11, adapter=11
                  zigbee.0	2021-06-29 09:09:07.347	error	(9127) - Network Key: configured=01030507090b0d0f00020406080a0cff, adapter=01030507090b0d0f00020406080a0cff
                  zigbee.0	2021-06-29 09:09:07.347	error	(9127) - Extended PAN ID: configured=ffdddddddddddddd, adapter=00124b00194af258
                  zigbee.0	2021-06-29 09:09:07.346	error	(9127) - PAN ID: configured=6666, adapter=6666
                  Bei mir ist allerdings nur die EPANID unterschiedlich.
                  Habe dazu ein Issue auf Github aufgemacht und ein Antwort bekommen:
                  castorw commented 2 days ago
                  @fabwal You will only be updating configuration to match the adapter state. Not changing the actual EPID - just the other way around. Making your configuration to conform to reality.
                  Leider habe ich keine Idee, wie ich das durchführen soll.
                  Habt ihr Ideen?
                  Danke und Gruß
                  • F fabwal
                    Habt ihr Ideen?
                    Danke und Gruß
                    arteckA Offline
                    arteckA Offline
                    arteck
                    #509
                    @fabwal was steht in der datei
                    /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json
                    drin
                    F 1 Antwort Letzte Antwort
                    • arteckA arteck
                      drin
                      fabwal
                      schrieb am zuletzt editiert von fabwal
                      #510
                      @arteck
                       "ZCD_NV_EXTENDED_PAN_ID": {
                            "id": 45,
                            "offset": 0,
                            "osal": true,
                            "product": -1,
                            "value": [
                              255,
                              221,
                              221,
                              221,
                              221,
                              221,
                              221,
                              221
                            "len": 8
                      Darf ich da ändern oder ist dann die Config hin und ich muss 56 Geräte neu anlernen?
                      arteckA AsgothianA 2 Antworten Letzte Antwort
                      • F fabwal
                        @arteck
                              "id": 45,
                              "offset": 0,
                              "osal": true,
                              "product": -1,
                              "value": [
                                255,
                                221,
                                221,
                                221,
                                221,
                                221,
                                221,
                                221
                              "len": 8
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #511
                        @fabwal wenn du weisst was du tuest
                        • F fabwal
                          @arteck
                                "id": 45,
                                "offset": 0,
                                "osal": true,
                                "product": -1,
                                "value": [
                                  255,
                                  221,
                                  221,
                                  221,
                                  221,
                                  221,
                                  221,
                                  221
                                "len": 8
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          #512
                          @fabwal Da willst du nicht ändern. Das ganze sieht danach aus als ob du in deiner adapter config
                          dddddddddddddddd
                          als ext-pan ID stehen hast. Der Herdsman erwartet aber wohl
                          ddddddddddddddff
                          A.
                          F AsgothianA 2 Antworten Letzte Antwort
                          • AsgothianA Asgothian
                            dddddddddddddddd
                            ddddddddddddddff
                            A.
                            fabwal
                            #513
                            @asgothian @arteck
                            castorw aus dem Github Issue (https://github.com/ioBroker/ioBroker.zigbee/issues/1127#issuecomment-869662400)
                            sagt:
                            @fabwal I think your problem is much simpler. It's standard EPID collision, so entering the Extended PAN ID reported as adapter= into configuration should fix your issue.
                            Leider hat er dann auf meine Nachfrage nicht mehr reagiert :(
                            Daher hier die Frage, wie ich das umsetzen kann.
                              dddddddddddddddd
                              ddddddddddddddff
                              A.
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #514
                              @asgothian sagte in ZigBee neue Version 1.5.x:
                              dddddddddddddddd
                              ddddddddddddddff
                              A.
                              Das ist die einzige Lösung die mir bekannt ist bei der du NICHT alles neu anlernen musst. Jede manuelle Anpassung der nvbackup.json wird dazu führen das das Netzwerk welches der Koordinator aufbaut nicht zu dem passt was die Geräte erwarten.
                              A.
                                dddddddddddddddd
                                ddddddddddddddff
                                A.
                                A.
                                fabwal
                                #515
                                @asgothian
                                Ah ok, dann blick ich es noch nicht.
                                Wo finde ich die Adapter Config?
                                • F fabwal
                                  @asgothian
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #516
                                  @fabwal sagte in ZigBee neue Version 1.5.x:
                                  Die findest Du an der stelle wo du auch die anderen Adapter Parameter konfigurierst.
                                    fabwal
                                    #517
                                    @asgothian
                                    Ich sag ja ich blick es nicht :D
                                    Auch auf die Gefahr hin von dir erschlagen zu werden noch zwei Nachfragen:
                                    1. In der Zigbee Config steht für die EPID dieser Satz:
                                      Diese ID darf sich für vorhandene Netzwerke niemals ändern, da du sonst deine Geräte zurücksetzen und neu koppeln musst.
                                    2. Die neue EPID müsste doch dann:
                                      00124b00194af258 sein, also das was der Adapter erwartet
                                    • F fabwal
                                      @asgothian
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      #518
                                      @fabwal
                                      Was steht aktuell bei Dir als EPID in der Konfiguration drin ?
                                        @fabwal
                                        fabwal
                                        #519
                                        @asgothian ddddddddddddddff
                                        • F fabwal
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #520
                                          @fabwal dann passt die nvbackup.json die du gepostet hast nicht zu der die der adapter geladen hat, da in der das gleiche drin steht.
                                          Oder stand da etwas anderes drin und du hast das was du gepostet hast schon editiert ?
                                          Nachtrag: Ich bin auf Discord. ggf. ist das dann einfacher zu lösen, an statt hier posts hin und her zu werfen.
