  4. JavaScript
  5. IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol
javascripttemplate
493 Beiträge 26 Kommentatoren 205.0k Aufrufe 41 Beobachtet
  • L
    L
    luft-post
    #328
    Ok habe jetzt das Aktuelle Script in Betrieb.
    //@liv-in-sky Januar 2020 9.3-20:15
    auch hier ist die Fehlermeldung ähnlich
    18:42:34.945	info	javascript.0 (27161) Start javascript script.js.14_Tabelle_Netzwerk
    18:42:35.049	info	javascript.0 (27161) script.js.14_Tabelle_Netzwerk: registered 1 subscription and 1 schedule
    18:42:49.403	warn	javascript.0 (27161) at script.js.14_Tabelle_Netzwerk:379:22
    18:42:49.404	warn	javascript.0 (27161) at writeHTML (script.js.14_Tabelle_Netzwerk:262:1)
    18:42:49.418	error	javascript.0 (27161) script.js.14_Tabelle_Netzwerk: TypeError: Cannot read property 'replace' of undefined
    18:42:49.419	error	javascript.0 (27161) at script.js.14_Tabelle_Netzwerk:390:21
    18:42:49.419	error	javascript.0 (27161) at writeHTML (script.js.14_Tabelle_Netzwerk:262:1)
    hier Zeilen aus den Skript
    if (mysortiereClient==2){
               myObj.sort(function (alpha, beta) {
                //   if (parseFloat(beta[1].replace(/.+\.(.+)$/,"$1")) > parseFloat(alpha[1].replace(/.+\.(.+)$/,"$1")))
                 if ((parseFloat(beta[1].replace(/.+\.(.+)$/,"$1")))+(parseFloat(beta[1].replace(/.+\.(.+)\..+$/,"$1"))*1000) > (parseFloat(alpha[1].replace(/.+\.(.+)$/,"$1")))+(parseFloat(alpha[1].replace(/.+\.(.+)\..+$/,"$1"))*1000))
                       return -1;
                   if ((parseFloat(alpha[1].replace(/.+\.(.+)$/,"$1")))+(parseFloat(alpha[1].replace(/.+\.(.+)\..+$/,"$1"))*1000) > (parseFloat(beta[1].replace(/.+\.(.+)$/,"$1")))+(parseFloat(beta[1].replace(/.+\.(.+)\..+$/,"$1"))*1000))
                       return 1;
                return 0;
        var1="scanned in" //nur scanned seconds
       var3="true"
       var2=myTimeScanArr[0].replace(/.+ (\d+\.\d+.+$)/,"$1");//log(var2)
       let help=[var1,var2,var3]
      if (mysortiereClient==1) help=["xxxx"+var1,var2,var3]
      myObj.push(help)
    /*if (!rootcount)*/  setState(dpPrefix+"Tabellen.IPDevices.Device_Collection", myObjOld)
    ///////////////////////////log("myObject ------- "+myObj.length.toString()+"---- ")
     // setState("0_userdata.0.Tabellen.IPDeviceERROR", myObj.toString())   // zur fehlersuche
            for(var i=0;i<myObj.length;i++) {            // hier eigene schleife definieren und den wert counter++ nicht vergessen  !!!
              counter++;                                       // SEHR WICHTIG - MUSS IN JEDER SCHLEIFE INTEGRIERT SEIN
            //  log(myObj[i][0].toString())
              val0=myObj[i][0].replace("for","").trim()
              val0=val0.replace("."+domainName,"")
              val0=val0.replace(/[(,)]/g,"")
              val1=myObj[i][1]
              val1=val1.replace(/[(,)]/g,"")
          //  log(val0+" --- "myDeviceNamesNew[].ip)
    for (var index in myDeviceNames) {                   //ersetze mit aliasnamen
                                  //log(index)
                                   if ((val1.trim()).match(index.trim()) && val1.trim().length == index.trim().length) {val0=myDeviceNames[index];
                                   //log(val0+" - "+index)
    let helperIP=""
    let helperlink=""
    L liv-in-skyL 2 Antworten Letzte Antwort
    • L luft-post
                         return -1;
                         return 1;
                  return 0;
         var3="true"
        myObj.push(help)
                val1=myObj[i][1]
                                    //log(index)
      let helperIP=""
      let helperlink=""
      L
      L
      luft-post
      #329
      Zeile 390 ist hier die 29
      Meine IP Setting:
      let mySchedule=" */15 * * * * ";                       //jede minute  -  nicht unter eine minute gehen -besser 3 oder 5 minuten nutzen !!!
      const domainName="fritz.box";                  // domainname in der fritzbox definiert
      const ipbereich="192.168.2.0/24";           //  gilt nicht für windows
      const dnsServer="192.168.2.1"               // gilt nicht für windows
      let mysortiereClient=1;
      Verwenden tu ich ein PI4 mit Buster.
      Und hier die Ausgabe von nmap:
      • L luft-post
                           return -1;
                           return 1;
                    return 0;
           var3="true"
          myObj.push(help)
                  val1=myObj[i][1]
                                      //log(index)
        let helperIP=""
        let helperlink=""
        liv-in-skyL
        liv-in-skyL
        #330
        @luft-post das ist wieder eine seltsame version - die ist von 2020 - aber ich denke , es gibt da eh ein anderes thema
        ist es möglich mit anydesk bei dir drauf zu gehen - wäre einfacher und wahrscheinlich schneller
        L 1 Antwort Letzte Antwort
        • liv-in-skyL liv-in-sky
          L
          L
          luft-post
          #331
          @liv-in-sky
          Anydesk bekomme ich hier gerade nicht installiert, hätte Skype im Angebot bittet aber keine Übernahme der Steuerung :-|
          Mit der Version hast du recht würde gerade versuchen die aktuellste zu übernehmen (Hätte gedacht, dass ich es gemacht habe...)
          Anydesk könnten wir heute Abend oder Morgen versuchen wenn ich wieder einen Freien Rechner zur Verfügung habe.
          dank und gruß
          Matthias
          • L luft-post
            @liv-in-sky
            dank und gruß
            Matthias
            liv-in-skyL
            liv-in-skyL
            #332
            @luft-post anydesk wäre schon gut
            was ist den heute abend - bei mir ist schon abend :-)
            • L
              L
              luft-post
              #333
              so ab 22Uhr, wenn ich Feierabend habe...
              • L luft-post
                liv-in-skyL
                liv-in-skyL
                #334
                @luft-post sorry - das ist zu spät
                gibt es eine andere möglichkeit - oder evtl. wochenende
                  L
                  L
                  luft-post
                  #335
                  @liv-in-sky
                  hier jetzt die Fehlermeldung von der Januar 2021 13.3-19:00 version
                  9:08:45.211	info	javascript.0 (27161) Stop script script.js.15-Tabelle_Netzwerk
                  19:08:52.189	info	javascript.0 (27161) Start javascript script.js.15-Tabelle_Netzwerk
                  19:08:52.263	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: registered 1 subscription and 1 schedule
                  19:09:04.480	warn	javascript.0 (27161) at script.js.15-Tabelle_Netzwerk:378:22
                  19:09:04.480	warn	javascript.0 (27161) at writeHTML (script.js.15-Tabelle_Netzwerk:261:1)
                  19:09:04.494	error	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: TypeError: Cannot read property 'replace' of undefined
                  19:09:04.495	error	javascript.0 (27161) at script.js.15-Tabelle_Netzwerk:389:21
                  19:09:04.495	error	javascript.0 (27161) at writeHTML (script.js.15-Tabelle_Netzwerk:261:1)
                  • L luft-post
                    @liv-in-sky
                    L
                    L
                    luft-post
                    #336
                    @luft-post
                    wieder die selbe stelle.
                    19:14:08.262	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: for Google-Home.fritz.box
                    19:14:08.262	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: for D797424.fritz.box
                    19:14:08.262	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: for Chromecast-Ultra.fritz.box
                    19:14:08.263	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: for Galaxy-S9Plus.fritz.box
                    19:14:08.263	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: 192.168.2.251
                    19:14:08.263	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: for iobroker.fritz.box
                    19:14:08.264	info	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: f
                    19:14:08.267	error	javascript.0 (27161) script.js.15-Tabelle_Netzwerk: TypeError: Cannot read property 'replace' of undefined
                    19:14:08.267	error	javascript.0 (27161) at script.js.15-Tabelle_Netzwerk:389:21
                    19:14:08.267	error	javascript.0 (27161) at writeHTML (script.js.15-Tabelle_Netzwerk:261:1)
                    mit log
                    • L luft-post
                      @luft-post
                      mit log
                      liv-in-skyL
                      liv-in-skyL
                      #337
                      @luft-post
                      da verennt sich der regex, der die daten aufbereitet - die ip und das f sehen seltsam aus - du kannst ja mal den consolen befehl nochmal machen und die ausgabe nach dem galaxys9 zeigen - was da ankommt
                        @luft-post
                        L
                        L
                        luft-post
                        #338
                        @liv-in-sky
                        • L luft-post
                          @liv-in-sky
                          liv-in-skyL
                          liv-in-skyL
                          #339
                          @luft-post wenn du zuhause bist, ist es möglich die 2.251 mal vom netz zu nehmen und das script dann laufen zu lassen
                            L
                            L
                            luft-post
                            #340
                            @liv-in-sky
                            ich bin gerade auf der suche nach der 2.251
                            Habe gerade keine Idee was es ist, meine Fritzbox zeigt mir das gerät nicht an
                            • L luft-post
                              @liv-in-sky
                              L
                              L
                              luft-post
                              #341
                              Antworten auf ein ping tut es auch nicht
                              • L luft-post
                                @liv-in-sky
                                liv-in-skyL
                                liv-in-skyL
                                #342
                                @luft-post irgendwas "chinesisches" - evtl mit fester ip, wenn du es nicht in fritzbox siehst
                                shenzen - evtl etwas "billiges"
                                Z 1 Antwort Letzte Antwort
                                  Z
                                  Z
                                  zahnheinrich
                                  #343
                                  @liv-in-sky
                                  Gibt es da schon eine Lösung für den "no Array" Fehler?
                                  15:15:00.119	warn	javascript.0 (812) script.js.common.Tabellen.IpDevices: no Array
                                  Mit dem kämpfe ich auch zur Zeit.
                                  Verwende dieses script
                                  //@liv-in-sky Januar 2021 13.3-19:00
                                  Die Konsole sagt
                                  root@ServerRubensstr:/opt/iobroker# nmap -sPR --dns-servers 192.168.3.1 192.168.3.0/24
                                  WARNING: -sR is now an alias for -sV and activates version detection as well as RPC scan.
                                  Starting Nmap 7.70 ( https://nmap.org ) at 2021-09-13 15:24 CEST
                                  Nmap scan report for fritz.box (192.168.3.1)
                                  Host is up (0.0016s latency).
                                  MAC Address: 3C:A6:2F:76:D1:25 (AVM Audiovisuelles Marketing und Computersysteme GmbH)
                                  Nmap scan report for Repeater-OG.fritz.box (192.168.3.3)
                                  Host is up (0.00095s latency).
                                  MAC Address: 32:3A:FD:86:FF:CC (Unknown)
                                  Nmap scan report for Repeater-EG.fritz.box (192.168.3.5)
                                  Host is up (0.0012s latency).
                                  MAC Address: 22:A6:2F:75:C0:BF (Unknown)
                                  Nmap scan report for DoorBird.fritz.box (192.168.3.6)
                                  Host is up (0.00089s latency).
                                  MAC Address: 1C:CA:E3:71:D6:3E (Ieee Registration Authority)
                                  Nmap scan report for 192.168.3.12
                                  Host is up (0.00061s latency).
                                  MAC Address: 54:53:ED:B5:AE:77 (Sony)
                                  Nmap scan report for PhoneSchlafziOG1.fritz.box (192.168.3.21)
                                  Host is up (0.010s latency).
                                  MAC Address: C8:38:70:D0:AB:F5 (Samsung Electronics)
                                  Nmap scan report for TabletEGKueche.fritz.box (192.168.3.25)
                                  Host is up (0.042s latency).
                                  MAC Address: D4:AE:05:3F:34:3D (Samsung Electronics)
                                  Nmap scan report for Tablet-Halle.fritz.box (192.168.3.26)
                                  Host is up (0.077s latency).
                                  MAC Address: 08:78:08:7E:1F:14 (Samsung Electronics)
                                  Nmap scan report for MusikStreamKueche.fritz.box (192.168.3.32)
                                  Host is up (0.096s latency).
                                  MAC Address: 74:DA:38:88:4D:BB (Edimax Technology)
                                  Nmap scan report for MusikStreamBadOG1.fritz.box (192.168.3.33)
                                  Host is up (0.098s latency).
                                  MAC Address: 74:DA:38:88:4D:B1 (Edimax Technology)
                                  Nmap scan report for CCU.fritz.box (192.168.3.44)
                                  Host is up (-0.12s latency).
                                  MAC Address: B8:27:EB:A4:B9:06 (Raspberry Pi Foundation)
                                  Nmap scan report for HM-Gateway-CCU2.fritz.box (192.168.3.45)
                                  MAC Address: 00:1A:22:06:08:9C (eQ-3 Entwicklung GmbH)
                                  Nmap scan report for HM-LANGateway.fritz.box (192.168.3.47)
                                  MAC Address: 00:1A:22:04:2A:39 (eQ-3 Entwicklung GmbH)
                                  Nmap scan report for SonoffSchlafMusik.fritz.box (192.168.3.51)
                                  Host is up (0.058s latency).
                                  MAC Address: BC:DD:C2:0F:95:1B (Espressif)
                                  Nmap scan report for shellyswitch25-RollSchlafziOG1.fritz.box (192.168.3.60)
                                  MAC Address: 24:62:AB:00:83:6C (Espressif)
                                  Nmap scan report for shellyswitch25-RollDachfenster.fritz.box (192.168.3.61)
                                  Host is up (-0.057s latency).
                                  MAC Address: 80:7D:3A:74:58:9F (Espressif)
                                  Nmap scan report for shellyswitch25-RollMoniUnten.fritz.box (192.168.3.62)
                                  Host is up (0.030s latency).
                                  MAC Address: 80:7D:3A:74:4E:6A (Espressif)
                                  Nmap scan report for shellyswitch25-RollFlurOG1Klein.fritz.box (192.168.3.63)
                                  MAC Address: 84:F3:EB:E6:6D:FF (Espressif)
                                  Nmap scan report for shellyswitch25-RollBadOG1.fritz.box (192.168.3.64)
                                  Host is up (0.015s latency).
                                  MAC Address: 80:7D:3A:74:4F:B0 (Espressif)
                                  Nmap scan report for shellyswitch25-E663F3.fritz.box (192.168.3.65)
                                  Host is up (0.018s latency).
                                  MAC Address: 84:F3:EB:E6:63:F3 (Espressif)
                                  Nmap scan report for shelly1-LichtBueroGross.fritz.box (192.168.3.66)
                                  Host is up (0.023s latency).
                                  MAC Address: 3C:71:BF:22:BE:7B (Espressif)
                                  Nmap scan report for shellyswitch25-RollTerry.fritz.box (192.168.3.67)
                                  Host is up (0.0057s latency).
                                  MAC Address: 24:62:AB:00:7C:00 (Espressif)
                                  Nmap scan report for shellyswitch25-RollBuero.fritz.box (192.168.3.68)
                                  MAC Address: DC:4F:22:5D:B6:52 (Espressif)
                                  Nmap scan report for shelly1-BueroMusik.fritz.box (192.168.3.69)
                                  Host is up (0.036s latency).
                                  MAC Address: 98:F4:AB:B8:B5:D1 (Espressif)
                                  Nmap scan report for shelly1-Kellertreppe.fritz.box (192.168.3.70)
                                  Host is up (0.075s latency).
                                  MAC Address: CC:50:E3:1D:98:39 (Espressif)
                                  Nmap scan report for shelly1-RaeumchenEG.fritz.box (192.168.3.71)
                                  Host is up (0.024s latency).
                                  MAC Address: CC:50:E3:1D:9C:EE (Espressif)
                                  Nmap scan report for shelly1-SchlafzimmerOG1Flur.fritz.box (192.168.3.72)
                                  Host is up (0.083s latency).
                                  MAC Address: CC:50:E3:1D:9F:99 (Espressif)
                                  Nmap scan report for shellyswitch-BadOG1.fritz.box (192.168.3.73)
                                  Host is up (0.072s latency).
                                  MAC Address: CC:50:E3:13:51:18 (Espressif)
                                  Nmap scan report for shelly1-22F653.fritz.box (192.168.3.74)
                                  Host is up (0.094s latency).
                                  MAC Address: 3C:71:BF:22:F6:53 (Espressif)
                                  Nmap scan report for shelly1-227C1F.fritz.box (192.168.3.75)
                                  Host is up (0.11s latency).
                                  MAC Address: 3C:71:BF:22:7C:1F (Espressif)
                                  Nmap scan report for shelly1-944C06.fritz.box (192.168.3.77)
                                  Host is up (0.091s latency).
                                  MAC Address: BC:DD:C2:94:4C:06 (Espressif)
                                  Nmap scan report for shelly1-55EBDA.fritz.box (192.168.3.78)
                                  Host is up (0.12s latency).
                                  MAC Address: B4:E6:2D:55:EB:DA (Espressif)
                                  Nmap scan report for shellyswitch-5A3EB3.fritz.box (192.168.3.79)
                                  MAC Address: B4:E6:2D:5A:3E:B3 (Espressif)
                                  Nmap scan report for shelly1-55EE37.fritz.box (192.168.3.80)
                                  MAC Address: B4:E6:2D:55:EE:37 (Espressif)
                                  Nmap scan report for shellyswitch-55BE4F.fritz.box (192.168.3.81)
                                  MAC Address: B4:E6:2D:55:BE:4F (Espressif)
                                  Nmap scan report for shelly1-55E049.fritz.box (192.168.3.82)
                                  Host is up (-0.17s latency).
                                  MAC Address: B4:E6:2D:55:E0:49 (Espressif)
                                  Nmap scan report for shelly1-2C0B82.fritz.box (192.168.3.83)
                                  Host is up (-0.054s latency).
                                  MAC Address: 3C:71:BF:2C:0B:82 (Espressif)
                                  Nmap scan report for shellyswitch-55A389.fritz.box (192.168.3.84)
                                  MAC Address: CC:50:E3:55:A3:89 (Espressif)
                                  Nmap scan report for shelly1-GastWC.fritz.box (192.168.3.85)
                                  MAC Address: BC:DD:C2:94:4B:FC (Espressif)
                                  Nmap scan report for shelly1-StudioLichtDecke.fritz.box (192.168.3.86)
                                  Host is up (-0.10s latency).
                                  MAC Address: E8:DB:84:D7:1F:E9 (Espressif)
                                  Nmap scan report for shelly1-246831.fritz.box (192.168.3.87)
                                  MAC Address: EC:FA:BC:24:68:31 (Espressif)
                                  Nmap scan report for shelly1-59DB1E.fritz.box (192.168.3.88)
                                  Host is up (-0.055s latency).
                                  MAC Address: B4:E6:2D:59:DB:1E (Espressif)
                                  Nmap scan report for shelly1-LichtNachtFlurOG2.fritz.box (192.168.3.89)
                                  Host is up (-0.098s latency).
                                  MAC Address: 3C:71:BF:2C:8B:36 (Espressif)
                                  Nmap scan report for shelly1-22F8DB.fritz.box (192.168.3.90)
                                  Host is up (-0.053s latency).
                                  MAC Address: 3C:71:BF:22:F8:DB (Espressif)
                                  Nmap scan report for shellyswitch25-RollEssziKlein.fritz.box (192.168.3.91)
                                  MAC Address: E0:98:06:8C:F7:71 (Espressif)
                                  Nmap scan report for shellyswitch25-RollKuecheWigaRe.fritz.box (192.168.3.92)
                                  MAC Address: DC:4F:22:5D:BE:F7 (Espressif)
                                  Nmap scan report for shelly1-TasterLichtKuecheTradfriTuer.fritz.box (192.168.3.93)
                                  MAC Address: 98:F4:AB:B8:B5:96 (Espressif)
                                  Nmap scan report for shellyix3-TasterStudioTuer.fritz.box (192.168.3.94)
                                  Host is up (-0.086s latency).
                                  MAC Address: 10:52:1C:F1:D4:1E (Espressif)
                                  Nmap scan report for shelly1-LaderreglerHalle.fritz.box (192.168.3.95)
                                  MAC Address: 98:F4:AB:B9:5A:24 (Espressif)
                                  Nmap scan report for shellyswitch25-RollWigaMitte.fritz.box (192.168.3.96)
                                  MAC Address: 80:7D:3A:74:4B:6F (Espressif)
                                  Nmap scan report for shellyswitch25-RollWigaMitteLi.fritz.box (192.168.3.97)
                                  MAC Address: 80:7D:3A:74:4B:D6 (Espressif)
                                  Nmap scan report for shellyswitch25-RolladenHalle.fritz.box (192.168.3.98)
                                  MAC Address: 84:F3:EB:E5:E4:BB (Espressif)
                                  Nmap scan report for shellyswitch25-RollWigaLi.fritz.box (192.168.3.99)
                                  MAC Address: 80:7D:3A:74:4F:B4 (Espressif)
                                  Nmap scan report for shellyswitch25-RollEingang.fritz.box (192.168.3.100)
                                  Host is up (-0.059s latency).
                                  MAC Address: 80:7D:3A:74:50:D2 (Espressif)
                                  Nmap scan report for shelly1-LichtKuecheDecke.fritz.box (192.168.3.102)
                                  Host is up (0.10s latency).
                                  MAC Address: 3C:71:BF:2C:83:A9 (Espressif)
                                  Nmap scan report for shelly1-LichtKuecheEssenDecke.fritz.box (192.168.3.103)
                                  MAC Address: B4:E6:2D:59:DA:7E (Espressif)
                                  Nmap scan report for shelly1-LichtKuecheEssenWand.fritz.box (192.168.3.104)
                                  MAC Address: B4:E6:2D:59:DF:CD (Espressif)
                                  Nmap scan report for shelly1-LichtKuecheFenster.fritz.box (192.168.3.105)
                                  MAC Address: BC:DD:C2:94:22:E5 (Espressif)
                                  Nmap scan report for shelly1-59D729.fritz.box (192.168.3.106)
                                  MAC Address: B4:E6:2D:59:D7:29 (Espressif)
                                  Nmap scan report for shellyswitch25-RollEssZiGross.fritz.box (192.168.3.107)
                                  MAC Address: 80:7D:3A:74:57:41 (Espressif)
                                  Nmap scan report for shelly1-LichtGartenHinten.fritz.box (192.168.3.108)
                                  MAC Address: 98:F4:AB:B8:B5:68 (Espressif)
                                  Nmap scan report for shelly1-LichtGartenRechts.fritz.box (192.168.3.109)
                                  MAC Address: 98:F4:AB:B9:62:32 (Espressif)
                                  Nmap scan report for CamKueche.fritz.box (192.168.3.110)
                                  Host is up (0.0011s latency).
                                  MAC Address: E0:62:90:61:43:1E (Jinan Jovision Science & Technology)
                                  Nmap scan report for Cam-Garten.fritz.box (192.168.3.111)
                                  MAC Address: EC:71:DB:80:E1:3D (Shenzhen Baichuan Digital Technology)
                                  Nmap scan report for CamOG2.fritz.box (192.168.3.112)
                                  Host is up (0.00047s latency).
                                  MAC Address: E0:62:90:56:29:11 (Jinan Jovision Science & Technology)
                                  Nmap scan report for CamFront.fritz.box (192.168.3.113)
                                  MAC Address: 18:68:CB:76:39:96 (Hangzhou Hikvision Digital Technology)
                                  Nmap scan report for CamHalle.fritz.box (192.168.3.118)
                                  Host is up (0.00048s latency).
                                  MAC Address: E0:62:90:F5:FC:DB (Jinan Jovision Science & Technology)
                                  Nmap scan report for shelly1-SteckdoseGarten.fritz.box (192.168.3.121)
                                  Host is up (-0.076s latency).
                                  MAC Address: EC:FA:BC:24:63:E6 (Espressif)
                                  Nmap scan report for shelly1-SteckdoseTerasseEG.fritz.box (192.168.3.122)
                                  MAC Address: 98:F4:AB:B8:B5:76 (Espressif)
                                  Nmap scan report for shelly1-55EBE5.fritz.box (192.168.3.123)
                                  MAC Address: B4:E6:2D:55:EB:E5 (Espressif)
                                  Nmap scan report for shellyswitch25-RolladenTerryTuer.fritz.box (192.168.3.124)
                                  MAC Address: EC:FA:BC:C4:BD:F6 (Espressif)
                                  Nmap scan report for shellyswitch25-RollFlurOG1Gross.fritz.box (192.168.3.125)
                                  MAC Address: DC:4F:22:76:FA:32 (Espressif)
                                  Nmap scan report for shellyix3-TasterLichtKuecheEssplatz.fritz.box (192.168.3.126)
                                  MAC Address: A4:CF:12:F4:73:72 (Espressif)
                                  Nmap scan report for shellyix3-TasterLichtKuecheArbeitsplatte.fritz.box (192.168.3.127)
                                  MAC Address: A4:CF:12:F4:75:46 (Espressif)
                                  Nmap scan report for shellyix3-TasterLichtKuecheTuer.fritz.box (192.168.3.128)
                                  MAC Address: A4:CF:12:F4:6D:C2 (Espressif)
                                  Nmap scan report for shellyix3-TasterKellerVerteilung.fritz.box (192.168.3.129)
                                  Host is up (0.19s latency).
                                  MAC Address: 10:52:1C:F2:CB:22 (Espressif)
                                  Nmap scan report for shelly1-LichtStudioSchrank.fritz.box (192.168.3.130)
                                  Host is up (-0.071s latency).
                                  MAC Address: E8:DB:84:D7:21:32 (Espressif)
                                  Nmap scan report for shelly1-LichtGastNacht.fritz.box (192.168.3.132)
                                  MAC Address: E8:DB:84:D7:22:30 (Espressif)
                                  Nmap scan report for shelly1-LichtNachtFlurEG.fritz.box (192.168.3.133)
                                  MAC Address: E8:DB:84:D7:1A:46 (Espressif)
                                  Nmap scan report for shellyix3-8CAAB5439505.fritz.box (192.168.3.134)
                                  MAC Address: 8C:AA:B5:43:95:05 (Espressif)
                                  Nmap scan report for shellyswitch25-LichtBadOG2.fritz.box (192.168.3.135)
                                  MAC Address: EC:FA:BC:C4:7F:29 (Espressif)
                                  Nmap scan report for shellyix3-TasterBadOG1Waschtisch.fritz.box (192.168.3.136)
                                  MAC Address: 8C:AA:B5:43:23:DE (Espressif)
                                  Nmap scan report for shelly1-KuecheFloaltMitte.fritz.box (192.168.3.137)
                                  MAC Address: E8:DB:84:D7:1F:97 (Espressif)
                                  Nmap scan report for shellyswitch25-RollKuecheRechts.fritz.box (192.168.3.138)
                                  MAC Address: 3C:61:05:E5:4B:8E (Unknown)
                                  Nmap scan report for shelly1-LichtGarage.fritz.box (192.168.3.139)
                                  MAC Address: E8:DB:84:A1:B8:79 (Espressif)
                                  Nmap scan report for 192.168.3.149
                                  Host is up (0.00079s latency).
                                  MAC Address: E0:62:90:50:7A:29 (Jinan Jovision Science & Technology)
                                  Nmap scan report for 192.168.3.199
                                  Host is up (0.21s latency).
                                  MAC Address: E0:D0:83:12:35:37 (Samsung Electronics)
                                  Nmap scan report for 192.168.3.200
                                  Host is up (0.00042s latency).
                                  MAC Address: 02:11:32:2A:D0:8C (Unknown)
                                  Nmap scan report for 192.168.3.201
                                  Host is up (0.00032s latency).
                                  Nmap scan report for shelly1-E8DB84D71429.fritz.box (192.168.3.204)
                                  MAC Address: E8:DB:84:D7:14:29 (Espressif)
                                  Nmap scan report for SonMusikEssZi.fritz.box (192.168.3.205)
                                  Host is up (-0.080s latency).
                                  MAC Address: EC:FA:BC:06:45:DF (Espressif)
                                  Nmap scan report for Netgear-8PortPOE.fritz.box (192.168.3.206)
                                  Host is up (0.0028s latency).
                                  MAC Address: B0:B9:8A:68:33:DF (Netgear)
                                  Nmap scan report for 192.168.3.207
                                  Host is up (0.00015s latency).
                                  Nmap scan report for 192.168.3.208
                                  Host is up (0.00037s latency).
                                  Nmap scan report for Netgear-16Port.fritz.box (192.168.3.209)
                                  Host is up (0.011s latency).
                                  MAC Address: C0:FF:D4:C5:C0:69 (Netgear)
                                  Nmap scan report for shellyix3-TasterWohziTuer.fritz.box (192.168.3.210)
                                  Host is up (0.00039s latency).
                                  Nmap scan report for 192.168.3.211
                                  Nmap scan report for shellyswitch25-RollKuecheLinks.fritz.box (192.168.3.212)
                                  Host is up (0.13s latency).
                                  MAC Address: E8:DB:84:D7:1F:4D (Espressif)
                                  Nmap scan report for Netgear-5Port.fritz.box (192.168.3.213)
                                  Host is up (0.00063s latency).
                                  Nmap scan report for 192.168.3.214
                                  Host is up (-0.14s latency).
                                  Nmap scan report for 192.168.3.215
                                  Nmap scan report for SonoffBadOG1.fritz.box (192.168.3.216)
                                  MAC Address: 60:01:94:8E:50:98 (Espressif)
                                  Nmap scan report for SonKueMusik.fritz.box (192.168.3.217)
                                  Host is up (-0.082s latency).
                                  MAC Address: 2C:3A:E8:44:64:DF (Espressif)
                                  Nmap scan report for 192.168.3.218
                                  Nmap scan report for shelly1-E098069529BF.fritz.box (192.168.3.220)
                                  MAC Address: E0:98:06:95:29:BF (Espressif)
                                  Nmap scan report for Cam-Kiosk.fritz.box (192.168.3.221)
                                  Host is up (0.00070s latency).
                                  MAC Address: E0:62:90:D4:E2:EE (Jinan Jovision Science & Technology)
                                  Nmap scan report for 192.168.3.222
                                  Host is up (0.00049s latency).
                                  Nmap scan report for esp32-arduino.fritz.box (192.168.3.224)
                                  MAC Address: F0:08:D1:D2:CF:C4 (Espressif)
                                  Nmap scan report for 192.168.3.228
                                  Host is up (0.51s latency).
                                  Nmap scan report for 192.168.3.229
                                  Host is up (0.28s latency).
                                  Nmap scan report for 192.168.3.230
                                  Host is up (0.35s latency).
                                  Nmap scan report for Synology.fritz.box (192.168.3.23)
                                  Host is up.
                                  Nmap done: 256 IP addresses (112 hosts up) scanned in 6.35 seconds
                                  System: Synology, ioB im Docker, Admin 4.2.2, Adapter aktuell
                                  Platform: linux
                                  os: linux
                                  RAM: 7.7 GB
                                  System uptime: 3 T. 18:45:36
                                  Node.js: v12.20.0
                                  NPM: 6.14.8
                                  adapters count: 359
                                  Uptime: 01:40:55
                                  Active instances: 33
                                  Danke im Voraus für einen Hinweis
                                  MfG Ulrich
                                  • Z zahnheinrich
                                    @liv-in-sky
                                    Die Konsole sagt
                                    Host is up.
                                    Platform: linux
                                    os: linux
                                    RAM: 7.7 GB
                                    Node.js: v12.20.0
                                    NPM: 6.14.8
                                    adapters count: 359
                                    Uptime: 01:40:55
                                    liv-in-skyL
                                    liv-in-skyL
                                    #344
                                    @zahnheinrich
                                    der "fehler" sollte eingentlich nur ab und zu kommen - aus irgendeinem grund kommt dann von nmap nix zurück
                                    kommt der bei dir immer ?
                                    war eigentlich nur, wenn das schedule zu "schnell" war - standard ist 15 min
                                      @zahnheinrich
                                      Z
                                      Z
                                      zahnheinrich
                                      #345
                                      @liv-in-sky
                                      der schedule steht auf 15 Min.
                                      Die Meldungen kommen öfter, ok, jedesmal, wenn ich das skript neu starte...
                                      javascript.0	2021-09-13 15:45:00.518	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 15:39:56.570	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 15:30:00.569	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 15:21:40.638	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 15:15:00.119	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 15:13:08.645	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 15:12:22.717	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 15:11:19.795	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      javascript.0	2021-09-13 14:52:26.738	warn	(812) script.js.common.Tabellen.IpDevices: no Array
                                      Was mir ausserdem auffält:
                                      In der Tabelle sind Geräte aufgelistet, die schon länger ausser Betrieb sind und auch nicht mehr in der FB auftauchen.
                                      Wo kommen die her?
                                      Kann ich das irgendwie abfangen?
                                      MfG Ulrich
                                      • Z zahnheinrich
                                        @liv-in-sky
                                        Wo kommen die her?
                                        liv-in-skyL
                                        liv-in-skyL
                                        #346
                                        @zahnheinrich sagte in IP Devices im Netzwerk - HTML Tabelle vis, Iqontrol:
                                        • da ist es normal !
                                        die sind in einer eigenen datenbank - die kannst du löschen - das script muss sich ja merken, welches gerät da war - um es bei nicht erreichen als "offline" zu kennzeichnen - wenn das gerät dann für immer verschwindet, kann das script das nicht herausfinden und läßt es für immer auf "offline"
                                        suche die javascript instanz (meistens 0) und lösche den ganzen datenpunkt (im beispiel bei mir javascript.2 - da ich 3 instanzen habe)
                                        DANN SCRIPT NEUSTARTEN !!
                                          Z
                                          Z
                                          zahnheinrich
                                          #347
                                          @liv-in-sky
                                          Ja ok, die DeviceCollection hatte ich nicht mehr auf dem Schirm.
                                          Hatte dein skript vor längerer Zeit mal angeschaut, aber nicht fehlerfrei zum Laufen bekommen. Daher die alte Liste.
                                          Hatte mich echt gewundert...
                                          Der Fehler kommt regelmässig alle 15Min., die Tabelle wird nicht geschrieben...
                                          MfG Ulrich
                                          33.2k
                                          84.4k
