  4. Shelly Adapter: Warnung "Verbunden mit Gerät oder Dienst"
33 Beiträge 13 Kommentatoren 7.2k Aufrufe 8 Beobachtet
    @daniel-driessen
    Erstmal auf info lassen. Der Adapter-Neustart wird nämlich vom host geloggt, deswegen nicht auf Adapter-Ebene filtern.
    daniel.driessenD Offline
    daniel.driessen
    OK. Hier ist der Log:
    2021-05-29 17:54:09.364 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:09.425 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:12.351 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:12.383 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:15.084 - info: host.ioBrokerServer stopInstance system.adapter.shelly.0 (force=false, process=true)
    2021-05-29 17:54:15.087 - info: host.ioBrokerServer stopInstance system.adapter.shelly.0 send kill signal
    2021-05-29 17:54:15.088 - info: shelly.0 (166891) Got terminate signal TERMINATE_YOURSELF
    2021-05-29 17:54:15.090 - info: shelly.0 (166891) Closing Adapter
    2021-05-29 17:54:15.090 - info: shelly.0 (166891) terminating
    2021-05-29 17:54:15.091 - info: shelly.0 (166891) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-05-29 17:54:15.354 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:15.429 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:15.645 - info: host.ioBrokerServer instance system.adapter.shelly.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-05-29 17:54:18.134 - info: host.ioBrokerServer instance system.adapter.shelly.0 started with pid 823184
    2021-05-29 17:54:18.353 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:18.391 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:19.036 - info: shelly.0 (823184) starting. Version 4.0.8 in /opt/iobroker/node_modules/iobroker.shelly, node: v12.22.1, js-controller: 3.3.11
    2021-05-29 17:54:19.047 - info: shelly.0 (823184) Starting Adapter shelly.0 in version 4.0.8
    2021-05-29 17:54:19.160 - info: shelly.0 (823184) Starting Shelly adapter in CoAP modus.
    2021-05-29 17:54:19.186 - info: shelly.0 (823184) Listening for Shelly packets in the network
    2021-05-29 17:54:20.371 - info: shelly.0 (823184) Shelly device 192.168.2.102 (shelly1pm / shelly1pm-68C63AFB6573 / SHSW-PM#68C63AFB6573#1) with CoAP connected! Polltime set to 5 sec.
    2021-05-29 17:54:20.414 - info: shelly.0 (823184) Shelly device 192.168.2.105 (shelly1pm / shelly1pm-A4CF12F3CF0C / SHSW-PM#A4CF12F3CF0C#1) with CoAP connected! Polltime set to 5 sec.
    2021-05-29 17:54:21.368 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:21.437 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:24.354 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:24.392 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:24.471 - info: shelly.0 (823184) Shelly device 192.168.2.100 (shelly1pm / shelly1pm-68C63AFB35AE / SHSW-PM#68C63AFB35AE#1) with CoAP connected! Polltime set to 5 sec.
    2021-05-29 17:54:25.339 - info: shelly.0 (823184) Shelly device 192.168.2.101 (shellyswitch25 / shellyswitch25-BA8EC3 / SHSW-25#BA8EC3#1) with CoAP connected! Polltime set to 5 sec.
    2021-05-29 17:54:25.531 - info: shelly.0 (823184) Shelly device 192.168.2.104 (shelly1pm / shelly1pm-40F5200142BA / SHSW-PM#40F5200142BA#1) with CoAP connected! Polltime set to 5 sec.
    2021-05-29 17:54:26.982 - info: shelly.0 (823184) Shelly device 192.168.2.106 (shellyswitch25 / shellyswitch25-40F520050002 / SHSW-25#40F520050002#1) with CoAP connected! Polltime set to 5 sec.
    2021-05-29 17:54:27.336 - info: shelly.0 (823184) Shelly device 192.168.2.103 (shellyswitch25 / shellyswitch25-40F5200499F7 / SHSW-25#40F5200499F7#1) with CoAP connected! Polltime set to 5 sec.
    2021-05-29 17:54:27.361 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:27.402 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:30.358 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:30.433 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:33.358 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:33.392 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:36.358 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:36.433 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:39.358 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:39.433 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:42.358 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:42.390 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:45.368 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:45.449 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:48.362 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:48.395 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:51.362 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:51.395 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:53.493 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Wohnzimmer.Temperature.DewPoint" has to be type "number" but received type "string"
    2021-05-29 17:54:53.493 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Wohnzimmer.Humidity.AbsoluteHumidity" has to be type "number" but received type "string"
    2021-05-29 17:54:53.493 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Wohnzimmer.LastUpdate" has to be type "datetime" but received type "string"
    2021-05-29 17:54:53.511 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Außen.Temperature.DewPoint" has to be type "number" but received type "string"
    2021-05-29 17:54:53.511 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Außen.Humidity.AbsoluteHumidity" has to be type "number" but received type "string"
    2021-05-29 17:54:53.512 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Außen.LastUpdate" has to be type "datetime" but received type "string"
    2021-05-29 17:54:53.512 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Badezimmer.Temperature.DewPoint" has to be type "number" but received type "string"
    2021-05-29 17:54:53.512 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Badezimmer.Humidity.AbsoluteHumidity" has to be type "number" but received type "string"
    2021-05-29 17:54:53.512 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Badezimmer.LastUpdate" has to be type "datetime" but received type "string"
    2021-05-29 17:54:53.553 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Garage.Temperature.DewPoint" has to be type "number" but received type "string"
    2021-05-29 17:54:53.553 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Garage.Humidity.AbsoluteHumidity" has to be type "number" but received type "string"
    2021-05-29 17:54:53.554 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Garage.LastUpdate" has to be type "datetime" but received type "string"
    2021-05-29 17:54:53.555 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Schlafzimmer.Temperature.DewPoint" has to be type "number" but received type "string"
    2021-05-29 17:54:53.555 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Schlafzimmer.Humidity.AbsoluteHumidity" has to be type "number" but received type "string"
    2021-05-29 17:54:53.555 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Schlafzimmer.LastUpdate" has to be type "datetime" but received type "string"
    2021-05-29 17:54:53.555 - info: netatmo.0 (3882) State value to set for "netatmo.0.Home-(Wohnzimmer).Regen.LastUpdate" has to be type "datetime" but received type "string"
    2021-05-29 17:54:54.362 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:54.393 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:54:57.363 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:54:57.437 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:55:00.366 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:55:00.395 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:55:03.366 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:55:03.395 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:55:06.366 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:55:06.437 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:55:09.371 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:55:09.457 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:55:12.366 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:55:12.401 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:55:15.370 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:55:15.441 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    2021-05-29 17:55:18.370 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.currentspeed.coresSpeed" has to be stringified but received type "object"
    2021-05-29 17:55:18.445 - info: info.0 (2841) State value to set for "info.0.sysinfo.cpu.temperature.cores" has to be stringified but received type "object"
    Denke das sollte reichen. Jedenfalls kommt keine Info mehr vom Shelly Adapter.
    Wie gesagt. Ich sehe nichts Auffälliges. Aber vielleicht übersehe ich ja etwas.
    • daniel.driessenD daniel.driessen
      da_WoodyD Offline
      da_WoodyD Offline
      @daniel-driessen welche FW version haben deine shelly? hast du objekte im ioBroker? CoIoT eingestellt?
      daniel.driessenD 1 Antwort Letzte Antwort
      • da_WoodyD da_Woody
        daniel.driessen
        @da_woody Hallo Woody,
        Hier ist ein Screenshot von einer der Shellys. Sie haben alle die aktuellste Firmware:
        Ja, es sind Geräte in den Objekten drin. Es fehlt auch keins. Und alle sind "live":
        Und ja, ColoT ist eingestellt wie in der Beschreibung vom Shelly-Adapter vermerkt:
          da_WoodyD Offline
          da_WoodyD Offline
          @daniel-driessen soweit sollte alles ok sein, warum der adapter nicht grün wird...
          eventuell bei der install verschluckt? du kannst versuchen den adapter nochmal zu löschen und neu zu insten.
          die 4.0.8 ist eigentlich absolut ok.
            daniel.driessen
            @da_woody OK. Habe ich eigentlich auch schon gemacht.
            Wie gesagt, bisher war er eigentlich immer "grün". Warum auf einmal nicht mehr ist mir ein Rätsel.
            Ich werde ihn aber nochmals neu installieren. Mal sehen, vielleicht hilft das ja. Trotzdem schonmal vielen Dank für die Hilfe!
              daniel.driessen
              schrieb am zuletzt editiert von daniel.driessen
              Neuinstallation des Adapters hat leider auch nichts gebracht. Ich bin leider mit meinem Latein am Ende.
              Trotzdem danke für die Hilfe!
                @da_Woody
                ich habe keine shellies.
                der Screenshot sieht nach der alpha admin v5 aus.
                hast du auch v5?
                haselchenH da_WoodyD 2 Antworten Letzte Antwort
                  @da_Woody
                  hast du auch v5?
                  haselchenH Offline
                  haselchenH Offline
                  haselchen
                  @daniel-driessen
                  Stable ist 4.0.7, also warum Beta Tester spielen?
                  Das es Probleme geben kann steht sogar im Changelog
                    @da_Woody
                    hast du auch v5?
                    da_WoodyD Offline
                    da_WoodyD Offline
                    @homoran ich fahre admin5 und shelly 4.0.8 ohne probleme... ja, ok, der #370er. der ist mir egal. und soweit ich mir erinnern zu können, war die 4.0.7 wo der online rausgenommen wurde. weils mir keine ruhe gelassen hat, gerade mit einem shelly plug-s getestet, online funktioniert.
                    da fällt mir ein @daniel-driessen hast du vllt in deinem netzwerk updates gemacht? ich hatte ja was ähnliches. da war wie durch geisterhand, ohne änderung in 2 managed switches IGMP snooping aktiv. das mögen die shellys nicht.
                    irgendwie glaub ich da an ein netzwerk problem...
                      Systemdata Bitte Ausfüllen
                      Hardwaresystem: Lenovo ThinkCentre M92p
                      Arbeitsspeicher: 7.58 GB
                      Festplattenart: 240GB SSD
                      Betriebssystem: Ubuntu
                      Node-Version: v12.22.1
                      Nodejs-Version: /
                      NPM-Version: 6.14.12
                      Installationsart: Skript
                      Image genutzt: Nein
                      Ort/Name der Imagedatei: /
                      Hallo
                      Das ist mein 1. Post. Leider konnte ich im Forum nichts dazu finden.
                      Seit einiger Zeit steht mein Shelly Adapter auf Warnung. Es scheint aber trotzdem alles soweit zu funktionieren. Jedoch war die Warnung vorher nie da und jetzt leider immer. Er zeigt an das er angeblich nicht Verbunden mit Geräten oder Diensten ist (siehe Bild).
                      Hat jemand eine Ahnung woran das liegen kann? Ich habe schon alles mögliche ausprobiert. Leider ohne Erfolg. Wie gesagt, vorher gab es diese Meldung nie und der Adapter war grün. Umgestellt habe ich nichts. Nur den Adapter geupdatet.
                      Leider finde ich diese Meldung nicht so richtig aussagekräftig. Daher fehlt mir leider der richtige Ansatz worin das Problem genau liegen soll.
                      Vielen Dank für Eure Hilfe.
                      BigMike71
                      @daniel-driessen
                      ich habe ebenfalls diesen Fehler!
                      Da ich am Testen bin habe ich ein komplettes raspi4 system mit iobroker hochgezogen.
                      aber der Adapter gibt bei mir ebenfalls diesen fehler aus, die shellys laufen aber..
                        Nodejs-Version: /
                        Image genutzt: Nein
                        Hallo
                        Pat_
                        schrieb am zuletzt editiert von Pat_
                        @daniel-driessen
                        Hab das gleiche Problem. Hast du was rausgefunden?
                        Sorry.. Habs zu spät gesehen. Bin auf 4.07 zurück. Da läufts.
                        RoddiEFR 1 Antwort Letzte Antwort
                        • P Pat_
                          @daniel-driessen
                          RoddiEFR Offline
                          RoddiEFR Offline
                          RoddiEF
                          @pat_ said in Shelly Adapter: Warnung "Verbunden mit Gerät oder Dienst": Bin auf 4.07 zurück. Da läufts.
                          Ist zwar schon länger her mit der letzten Antwort aber auch Ich hab ewig Experimentiert aber weder Neuinstallation (3x) noch der Beta-Adapter (4.0.9) hat das Problem gelöst. Erst mit Version 4.0.7 wird der Adapter wieder komplett Grün.
                          Ich bin wie ich bin, was anderes bekommt man nicht !!
                          • RoddiEFR RoddiEF
                            S Online
                            S Online
                            Schimi
                            schrieb am zuletzt editiert von Schimi
                            Das gleiche problem habe ich nach dem Update auf 4.10 auch....
                            Nach einen Downgrade hat es sich auch nicht geändert.... den Adapter zu lösche und neu zu installieren habe ich auch versucht....
                            Bis auf das "nicht verbunden" funktioniert aber alles ohne probleme....
                            Edit
                            alle shellys sind mit MQTT eingebunden
                            • crunchipC Offline
                              crunchipC Offline
                              @roddief sagte in Shelly Adapter: Warnung "Verbunden mit Gerät oder Dienst":
                              nützt ja nichts die Adapterversion hin und her zu wechseln, wenn ab einer bestimmten Version CoIot benutzt werden muss, diesbezüglich muss man das auch bei jedem shelly einzeln anpassen und die Geräte neu starten.
                              @schimi sagte in Shelly Adapter: Warnung "Verbunden mit Gerät oder Dienst":
                              Das gleiche problem
                              welches?
                                Das gleiche problem
                                welches?
                                S Online
                                S Online
                                Schimi
                                @crunchip
                                Das meine ich....
                                wie geschrieben, es funktioniert alles einwandfrei...
                                • S Schimi
                                  @crunchip
                                  Das meine ich....
                                  crunchipC Offline
                                  crunchipC Offline
                                  @schimi und was genau hast du wo und wie eingestellt, welche Firmeware, Netzwerk...etc?
                                    S Online
                                    S Online
                                    Schimi
                                    @crunchip
                                    • Bei mir haben die Shellys die aktuellste Firmware (1.11.7) (bis auf einen, der hat die 1.10.4)
                                    • Bis auf einen, sind alle über MQTT eingebunden
                                    • Nach dem Update des shelly-Adapters wurde auch nichts verändert
                                    • Haben bislang alle einwandfrei funktioniert (und tu es immer noch) nur der Shelly Adapter zeigt den oberen Fehler (MQTT und CoAP Instanz).. funktioniert aber einwandfrei
                                    • Habe den Adapter deinstalliert, VM neu gestartet und den 4.0.8 versucht, da blieb es auch bei dem Roten "Verbunden mit......."
                                    • S Online
                                      S Online
                                      Schimi
                                      Update:
                                      mit der 4.0.7 ist alles wieder "Grün"
                                      • S Schimi
                                        Update:
                                        crunchipC Offline
                                        crunchipC Offline
                                        @schimi und nun gehst wieder hoch auf die aktuellste😉
                                          S Online
                                          S Online
                                          Schimi
                                          @crunchip
                                          alles Grün.... faszinierend....
