  4. iobroker startet nicht mehr
54 Beiträge 5 Kommentatoren 6.5k Aufrufe 3 Beobachtet
    BFM
    Ich Idiot habe es mit Rechtsklick aus Putty probiert. Ok, neuer Versuch
    technikkram@tinkerboard:/opt/iobroker$ node node_modules/iobroker.js-controller/        controller.je --logs
    node:internal/modules/cjs/loader:944
      throw err;
    Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/con        troller.je'
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:941:15        )
        at Function.Module._load (node:internal/modules/cjs/loader:774:27)
        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_ma        in:76:12)
        at node:internal/main/run_main_module:17:47 {
      code: 'MODULE_NOT_FOUND',
      requireStack: []
    technikkram@tinkerboard:/opt/iobroker$ iobroker stop
    technikkram@tinkerboard:/opt/iobroker$ npm install iobroker.js-controller
    [sudo] password for technikkram:
    npm ERR! code ENOTEMPTY
    npm ERR! syscall rename
    npm ERR! path /opt/iobroker/node_modules/abort-controller
    npm ERR! dest /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
    npm ERR! errno -39
    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/abor        t-controller' -> '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa'
    npm ERR!     /home/iobroker/.npm/_logs/2021-06-06T08_36_40_161Z-debug.log
    technikkram@tinkerboard:/opt/iobroker$ pm ERR! code ENOTEMPTY
    technikkram@tinkerboard:/opt/iobrCould not find the database of available applic        ations, run update-command-not-found as root to fix this
    pm: command not found
    technikkram@tinkerboard:/opt/iobroker$ npm ERR! syscall rename
    Unknown command: "ERR!"
    Habe jetzt im Anschluss auch mal probiert den js-controller neu zu installieren. Funktioniert leider auch nicht.
    • B BFM
        throw err;
        requireStack: []
      npm ERR! errno -39
      @bfm sagte in iobroker startet nicht mehr:
      rename '/opt/iobroker/node_modules/abort-controller' -> '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa'
        BFM
        technikkram@tinkerboard:/opt/iobroker$  rename '/opt/iobroker/node_modules/abort-        controller' -> '/opt/iobroker/node_modules/.abort-controller-x3pdLVqa'
        -bash: /opt/iobroker/node_modules/.abort-controller-x3pdLVqa: Is a directory
        technikkram@tinkerboard:/opt/iobroker$ -bash: /opt/iobroker/node_modules/.abort-controller-x3pdLVqa: Is a directory
        Could not find the database of available applications, run update-command-not-found as root to fix this
        -bash:: command not found
        • B BFM
          @bfm
          sudo -u iobroker mv /opt/iobroker/node_modules/abort-controller /opt/iobroker/node_modules/.abort-controller-x3pdLVqa
            BFM
            @thomas-braun said in iobroker startet nicht mehr:
            Ok, hab ich gemacht. Hat keine Meldung gegeben
            • B BFM
              @bfm
              Keine Rückmeldung heißt das es funktioniert hat.
                @bfm
                BFM
                Das hört sich gut an. Und du denkst, ioBroker startet jetzt wieder? Trau mich fast nicht...
                • B BFM
                  ich hoffe, du bringst mich jetzt nicht um. Aber rauskopieren aus Putty geht leider nicht 😢 . Was nutzt ihr denn?
                  LG
                  BFM
                  Jan1
                  Richtig, weil Putty nur ein Tool ist das ne Konsole öffnet und aus der Konsole kann man alles kopieren.
                  Putty brauchst somit eigentlich überhaupt nicht, hat nur den Vorteil, dass wenn man viele verschiedene Geräte hat auf die man per Terminal zugreift, dort eben alle hinterlegen kann und somit nicht immer alles tippen muss ;)
                  • B BFM
                    @bfm
                    Der Befehl den js-controller sauber zu installieren ist:
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                      @bfm
                      cd /opt/iobroker
                      BFM
                      npm ERR! path /opt/iobroker/node_modules/acme-http-01-standalone
                      npm ERR! dest /opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK
                      npm ERR! errno -39
                      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acme-http-01-standalone' -> '/opt/iobroker/node_modules/.acme-http-01-standalone-sG2kCsLK'
                      npm ERR!     /home/iobroker/.npm/_logs/2021-06-06T10_43_39_320Z-debug.log
                      Ich glaube, da ist ganz schön viel im argen...
                      • B BFM
                        npm ERR! errno -39
                        Glaube ich auch. Die ganzen versteckten Odner mit Punkt am Anfang habe ich bei mir in der Installation auch gar nicht.
                          BFM
                          Kann ich denn einfach drüberbügeln?
                          • B BFM
                            @bfm
                            Versuch halt mal.
                            Backup hast du ja in der Hinterhand.
                              BFM
                              Habe das Backup gerade probiert. Leider ohne Erfolg
                              technikkram@tinkerboard:/opt/iobroker$ sudo iobroker restore 0
                                throw err;
                              Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                  at Function.Module._resolveFilename (node:internal/modules/cjs/loader:941:15)
                                  at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:76:12)
                                requireStack: []
                              Das wird langsam echt komisch
                              • B BFM
                                  throw err;
                                  requireStack: []
                                Jan1
                                @bfm
                                Das macht man auch mit dem Backup Adapter, weils einfach einfacher ist ;)
                                Und wenn der JS wie bei Dir nicht mehr will, dann löscht man den IOBroker Ordner, installiert IOBroker samt Backitup Adapter neu und restort dann, weil das auf alle Fälle wieder alles gerade zieht.
                                  BFM
                                  Auch auf die Gefahr hin dass ich gelyncht werde... Gibts ne Erklärung für Dummies?😖
                                  • B BFM
                                    Jan1
                                    @bfm
                                    Das war schon die Erklärung, weil mehr is das nicht ;)
                                    Bevor Du natürlich den IOBroker Ordner löschst, sollten die Backups dort raus kopiert werden, wenn das nicht es schon auf ein NAS oder sonst wo automatisch hingelegt wird.
                                      BFM
                                      Das mit den Backups rauskopieren macht Sinn!
                                      Leider habe ich ioBroker noch nicht installiert. War bei mir fertig mit im Image drin. Aber ich denke, da wird mit Tante Google sicher helfen
                                      Thomas BraunT J 2 Antworten Letzte Antwort
                                      • B BFM
                                        @bfm
                                        Und man packt iobroker nicht mit sudo an.
                                        • B BFM
                                          Jan1
                                          @bfm
                                          Ein Blick oben in die Doku und den einen Befehl, dazu brauchst nicht mal Tante Google ;)
                                          https://www.iobroker.net/#de/documentation/install/windows.md
                                          Das mit Node kannst auch vergessen, da IOBroker automatisch Node12 installiert. Es sei denn Du hast da vorher schon was zerfummelt.
