  4. Admin5 - ReactUI // Cannot get logs
17 Beiträge 6 Kommentatoren 701 Aufrufe 6 Beobachtet
  • Thomas BraunT Online
    Admin 5 bringt schon mal nach länger Laufzeit und/oder umfangreicherem Log diese Meldung, wenn ich auf den Reiter 'Protokoll' wechsle:
    Cannot get logs: TypeError: Cannot read property 'message' of undefined
    In der Konsole kann ich aber jederzeit z. B. per
    iobroker logs
    auf das log zugreifen.
    Versionen:
    echad@chet:/opt/iobroker $ iobroker update
    Used repository: live-beta
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.5    , installed 5.1.5
    Adapter    "alexa2"        : 3.9.0    , installed 3.9.0
    Adapter    "backitup"      : 2.1.12   , installed 2.1.12
    Adapter    "ble"           : 0.12.0   , installed 0.12.0
    Adapter    "cec2"          : 0.1.0    , installed 0.1.0
    Adapter    "cloud"         : 4.0.11   , installed 4.0.11
    Adapter    "deconz"        : 1.3.15   , installed 1.3.15
    Adapter    "devices"       : 0.3.16   , installed 0.3.16
    Adapter    "echarts"       : 0.4.14   , installed 0.4.14
    Adapter    "firetv"        : 1.0.0    , installed 1.0.0
    Adapter    "history"       : 1.9.13   , installed 1.9.13
    Adapter    "info"          : 1.7.15   , installed 1.7.15
    Adapter    "iot"           : 1.8.22   , installed 1.8.22
    Adapter    "javascript"    : 5.1.3    , installed 5.1.3
    Controller "js-controller" : 3.3.11   , installed 3.3.11
    Adapter    "mihome"        : 1.3.7    , installed 1.3.7
    Adapter    "mihome-vacuum" : 3.1.10   , installed 3.1.10
    Adapter    "miio"          : 0.0.13   , installed 0.0.13
    Adapter    "nuki"          : 1.4.4    , installed 1.4.4
    Adapter    "nuki-extended" : 2.3.0    , installed 2.3.0
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
    Adapter    "tado"          : 0.2.7    , installed 0.3.0-3
    Adapter    "tr-064"        : 4.2.12   , installed 4.2.12
    Adapter    "tradfri"       : 2.7.3    , installed 2.7.3
    Adapter    "vodafone-speedtest": 0.0.7   , installed 0.0.7
    Adapter    "web"           : 3.4.1    , installed 3.4.1
    Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
    Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
    arteckA Dr. BakteriusD 2 Antworten Letzte Antwort
      iobroker logs
      Versionen:
      update done
      arteckA Offline
      arteckA Offline
      arteck
      @thomas-braun es gab mal einen Fehler der die message nicht richtig geschrieben hat im Admin...
      schaumal ins log ob da die Quelle bzw Nachricht immer da sind.
      • arteckA arteck
        @arteck
        Im log steht nix, hätte ich sonst gepostet.
          @arteck
          arteckA Offline
          arteckA Offline
          arteck
          @thomas-braun nicht im log. da ist alles ok. schau in der Admin oberfläche.. Protokoll
          • arteckA arteck
            @arteck Ich stehe auf dem Schlauch...
            Aus der Admin-Oberfläche ist die Meldung aus dem ersten Post ja herauskopiert.
            da_WoodyD arteckA 2 Antworten Letzte Antwort
              da_WoodyD Offline
              da_WoodyD Offline
              @thomas-braun ich hab das auch hin und wieder. plötzlich gehts dann wieder für längere zeit.
                arteckA Offline
                arteckA Offline
                arteck
                @thomas-braun ahhh ok lesen bildet.. hätte dein Eingangspost aufmerksamer lesen sollen...
                aber definiere umfangreichem LOG ??
                ich log auch relativ viel... aber kommt bei mir nicht vor
                • arteckA arteck
                  @arteck Kann ich nicht mal quantifizieren. Ist nur ein 'gefühlt umfangreicheres' Log. In der Regel habe ich da nämlich über Stunden keinerlei Einträge, deswegen empfinde ich wohl ein paar hundert Zeilen schon als umfangreich. Ich werde es mal genauer beobachten.
                    arteckA Offline
                    arteckA Offline
                    arteck
                    @thomas-braun hast du dann nen timestamp wann es aufgetreten ist ?
                    • arteckA arteck
                      @arteck Nee, ich finde in keinem Log was dazu.
                      Nur wenn ich den Reiter 'Protokoll' anklicke kommt ein entsprechendes PopUp in der GUI.
                      Ach, ich werde einfach weiter die Kommandozeile quälen. Neumodisches GUI-Zeuch... :-D
                        iobroker logs
                        Versionen:
                        update done
                        Dr. BakteriusD Offline
                        Dr. Bakterius
                        @thomas-braun Ähnliches Problem wie hier? -> https://forum.iobroker.net/topic/42786/undefined-im-log
                        @foxriver76 sagte in undefined im LOG:
                        Das undefined kommt beim aufräumen der alten Logfiles, daher meist ein mal täglich nachts.
                          @dr-bakterius
                          Jein. Nur ganz entfernt ähnlich.
                          Ich sehe in der Weboberfläche gar nichts vom log, nur unten als 'Fußzeile' die og. Meldung.
                            da_WoodyD Offline
                            da_WoodyD Offline
                            @thomas-braun sagte in Admin5 - ReactUI // Cannot get logs:
                            der war gut! :)
                            aber wie du schreibst, das taucht auf, dann gehts wieder. kein grund, nix. oft tagelang alles ok.
                            edit: jetzt um 23:00 is es wieder da!
                            kurz später:
                            und gleich drauf wieder der fehler...
                            V 1 Antwort Letzte Antwort
                            • da_WoodyD da_Woody
                              der war gut! :)
                              kurz später:
                              V Offline
                              V Offline
                              varg
                              schrieb am zuletzt editiert von varg
                              @da_woody
                              alexa2.0	2021-06-03 05:51:20.237	info	(14739) Alexa-Push-Connection established. Disable Polling
                              habe ich seit einiger Zeit auch permanent (1-2 x /h) im log. Bin aber noch auf admin 4.2.1
                              da_WoodyD Dr. BakteriusD 2 Antworten Letzte Antwort
                              • V varg
                                @da_woody
                                da_WoodyD Offline
                                da_WoodyD Offline
                                @varg bei mir heute permanent...
                                • V varg
                                  @da_woody
                                  Dr. Bakterius
                                  @varg Ja, einmal die Stunde wenn man nichts macht bzw. auch wenn man per Alexa2-Adapter etwas macht macht. Da kommt dann oft erst die Meldung im Log aber keine Reaktion. Erst beim erneuten Versuch klappt es dann. Ist schon seit Tagen so bei mir. Kann da @apollon77 etwas machen oder muss man warten bis Amazon fertig mit schrauben ist?
                                  • apollon77A Offline
                                    3.9.1 installieren
