<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs]]></title><description><![CDATA[<p dir="auto">Admin 5 bringt schon mal nach länger Laufzeit und/oder umfangreicherem Log diese Meldung, wenn ich auf den Reiter 'Protokoll' wechsle:</p>
<pre><code>Cannot get logs: TypeError: Cannot read property 'message' of undefined
</code></pre>
<p dir="auto">In der Konsole kann ich aber jederzeit z. B. per</p>
<pre><code>iobroker logs
</code></pre>
<p dir="auto">auf das log zugreifen.</p>
<p dir="auto">Versionen:</p>
<pre><code>echad@chet:/opt/iobroker $ iobroker update
Used repository: live-beta
hash unchanged, use cached sources
update done
Adapter    "admin"         : 5.1.5    , installed 5.1.5
Adapter    "alexa2"        : 3.9.0    , installed 3.9.0
Adapter    "backitup"      : 2.1.12   , installed 2.1.12
Adapter    "ble"           : 0.12.0   , installed 0.12.0
Adapter    "cec2"          : 0.1.0    , installed 0.1.0
Adapter    "cloud"         : 4.0.11   , installed 4.0.11
Adapter    "deconz"        : 1.3.15   , installed 1.3.15
Adapter    "devices"       : 0.3.16   , installed 0.3.16
Adapter    "echarts"       : 0.4.14   , installed 0.4.14
Adapter    "firetv"        : 1.0.0    , installed 1.0.0
Adapter    "history"       : 1.9.13   , installed 1.9.13
Adapter    "info"          : 1.7.15   , installed 1.7.15
Adapter    "iot"           : 1.8.22   , installed 1.8.22
Adapter    "javascript"    : 5.1.3    , installed 5.1.3
Controller "js-controller" : 3.3.11   , installed 3.3.11
Adapter    "mihome"        : 1.3.7    , installed 1.3.7
Adapter    "mihome-vacuum" : 3.1.10   , installed 3.1.10
Adapter    "miio"          : 0.0.13   , installed 0.0.13
Adapter    "nuki"          : 1.4.4    , installed 1.4.4
Adapter    "nuki-extended" : 2.3.0    , installed 2.3.0
Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
Adapter    "socketio"      : 3.1.4    , installed 3.1.4
Adapter    "tado"          : 0.2.7    , installed 0.3.0-3
Adapter    "tr-064"        : 4.2.12   , installed 4.2.12
Adapter    "tradfri"       : 2.7.3    , installed 2.7.3
Adapter    "vodafone-speedtest": 0.0.7   , installed 0.0.7
Adapter    "web"           : 3.4.1    , installed 3.4.1
Adapter    "whatsapp-cmb"  : 0.1.6    , installed 0.1.6
Adapter    "zigbee"        : 1.5.6    , installed 1.5.6
</code></pre>
]]></description><link>https://forum.iobroker.net/topic/45472/admin5-reactui-cannot-get-logs</link><generator>RSS for Node</generator><lastBuildDate>Mon, 25 May 2026 10:53:08 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/45472.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Jun 2021 20:07:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Tue, 08 Jun 2021 21:13:13 GMT]]></title><description><![CDATA[<p dir="auto">3.9.1 installieren</p>
]]></description><link>https://forum.iobroker.net/post/640391</link><guid isPermaLink="true">https://forum.iobroker.net/post/640391</guid><dc:creator><![CDATA[apollon77]]></dc:creator><pubDate>Tue, 08 Jun 2021 21:13:13 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Thu, 03 Jun 2021 08:42:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/varg" aria-label="Profile: varg">@<bdi>varg</bdi></a> Ja, einmal die Stunde wenn man nichts macht bzw. auch wenn man per Alexa2-Adapter etwas macht macht. Da kommt dann oft erst die Meldung im Log aber keine Reaktion. Erst beim erneuten Versuch klappt es dann. Ist schon seit Tagen so bei mir. Kann da <a class="plugin-mentions-user plugin-mentions-a" href="/user/apollon77" aria-label="Profile: apollon77">@<bdi>apollon77</bdi></a> etwas machen oder muss man warten bis Amazon fertig mit schrauben ist?</p>
]]></description><link>https://forum.iobroker.net/post/637580</link><guid isPermaLink="true">https://forum.iobroker.net/post/637580</guid><dc:creator><![CDATA[Dr. Bakterius]]></dc:creator><pubDate>Thu, 03 Jun 2021 08:42:06 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Thu, 03 Jun 2021 04:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/varg" aria-label="Profile: varg">@<bdi>varg</bdi></a> bei mir heute permanent...</p>
]]></description><link>https://forum.iobroker.net/post/637523</link><guid isPermaLink="true">https://forum.iobroker.net/post/637523</guid><dc:creator><![CDATA[da_Woody]]></dc:creator><pubDate>Thu, 03 Jun 2021 04:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Thu, 03 Jun 2021 04:58:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/da_woody" aria-label="Profile: da_woody">@<bdi>da_woody</bdi></a></p>
<pre><code>alexa2.0	2021-06-03 05:51:20.237	info	(14739) Alexa-Push-Connection established. Disable Polling
</code></pre>
<p dir="auto">habe ich seit einiger Zeit auch permanent (1-2 x /h) im log. Bin aber noch auf admin 4.2.1</p>
]]></description><link>https://forum.iobroker.net/post/637521</link><guid isPermaLink="true">https://forum.iobroker.net/post/637521</guid><dc:creator><![CDATA[varg]]></dc:creator><pubDate>Thu, 03 Jun 2021 04:58:05 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 21:06:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/637139">Admin5 - ReactUI // Cannot get logs</a>:<br />
<img src="/assets/uploads/files/1622642871512-flach.gif" alt="flach.gif" class=" img-fluid img-markdown" /></p>
<blockquote>
<p dir="auto">Ach, ich werde einfach weiter die Kommandozeile quälen. Neumodisches GUI-Zeuch...</p>
</blockquote>
<p dir="auto">der war gut! :)<br />
aber wie du schreibst, das taucht auf, dann gehts wieder. kein grund, nix. oft tagelang alles ok.</p>
<p dir="auto">edit: jetzt um 23:00 is es wieder da!<br />
<img src="/assets/uploads/files/1622667904101-ae37c072-1f61-47b4-b914-fcf3d888d8fa-grafik.png" alt="ae37c072-1f61-47b4-b914-fcf3d888d8fa-grafik.png" class=" img-fluid img-markdown" /><br />
kurz später:<br />
<img src="/assets/uploads/files/1622667997056-0dcb40cc-bc34-46f6-9c2e-a51c858a32b9-grafik.png" alt="0dcb40cc-bc34-46f6-9c2e-a51c858a32b9-grafik.png" class=" img-fluid img-markdown" /><br />
und gleich drauf wieder der fehler...</p>
]]></description><link>https://forum.iobroker.net/post/637251</link><guid isPermaLink="true">https://forum.iobroker.net/post/637251</guid><dc:creator><![CDATA[da_Woody]]></dc:creator><pubDate>Wed, 02 Jun 2021 21:06:57 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 12:08:31 GMT]]></title><description><![CDATA[<p dir="auto">@dr-bakterius</p>
<p dir="auto">Jein. Nur ganz entfernt ähnlich.<br />
Ich sehe in der Weboberfläche gar nichts vom log, nur unten als 'Fußzeile' die og. Meldung.</p>
]]></description><link>https://forum.iobroker.net/post/637224</link><guid isPermaLink="true">https://forum.iobroker.net/post/637224</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Jun 2021 12:08:31 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 12:00:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Ähnliches Problem wie hier? -&gt; <a href="https://forum.iobroker.net/topic/42786/undefined-im-log">https://forum.iobroker.net/topic/42786/undefined-im-log</a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/foxriver76" aria-label="Profile: foxriver76">@<bdi>foxriver76</bdi></a> sagte in <a href="/post/591050">undefined im LOG</a>:</p>
<blockquote>
<p dir="auto">Das undefined kommt beim aufräumen der alten Logfiles, daher meist ein mal täglich nachts.</p>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/637215</link><guid isPermaLink="true">https://forum.iobroker.net/post/637215</guid><dc:creator><![CDATA[Dr. Bakterius]]></dc:creator><pubDate>Wed, 02 Jun 2021 12:00:45 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 07:51:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a> Nee, ich finde in keinem Log was dazu.<br />
Nur wenn ich den Reiter 'Protokoll' anklicke kommt ein entsprechendes PopUp in der GUI.<br />
Ach, ich werde einfach weiter die Kommandozeile quälen. Neumodisches GUI-Zeuch... :-D</p>
]]></description><link>https://forum.iobroker.net/post/637139</link><guid isPermaLink="true">https://forum.iobroker.net/post/637139</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Jun 2021 07:51:02 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 07:15:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> hast du dann nen timestamp wann es aufgetreten ist ?</p>
]]></description><link>https://forum.iobroker.net/post/637112</link><guid isPermaLink="true">https://forum.iobroker.net/post/637112</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Wed, 02 Jun 2021 07:15:52 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 07:10:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a> Kann ich nicht mal quantifizieren. Ist nur ein 'gefühlt umfangreicheres' Log. In der Regel habe ich da nämlich über Stunden keinerlei Einträge, deswegen empfinde ich wohl ein paar hundert Zeilen schon als umfangreich. Ich werde es mal genauer beobachten.</p>
]]></description><link>https://forum.iobroker.net/post/637107</link><guid isPermaLink="true">https://forum.iobroker.net/post/637107</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Jun 2021 07:10:37 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 06:55:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> ahhh ok lesen bildet.. hätte dein Eingangspost aufmerksamer lesen sollen...</p>
<p dir="auto">aber definiere umfangreichem LOG ??</p>
<p dir="auto">ich log auch relativ viel... aber kommt bei mir nicht vor</p>
]]></description><link>https://forum.iobroker.net/post/637095</link><guid isPermaLink="true">https://forum.iobroker.net/post/637095</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Wed, 02 Jun 2021 06:55:00 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 06:05:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> ich hab das auch hin und wieder. plötzlich gehts dann wieder für längere zeit.</p>
]]></description><link>https://forum.iobroker.net/post/637073</link><guid isPermaLink="true">https://forum.iobroker.net/post/637073</guid><dc:creator><![CDATA[da_Woody]]></dc:creator><pubDate>Wed, 02 Jun 2021 06:05:59 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 05:37:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a> Ich stehe auf dem Schlauch...<br />
Aus der Admin-Oberfläche ist die Meldung aus dem ersten Post ja herauskopiert.</p>
]]></description><link>https://forum.iobroker.net/post/637057</link><guid isPermaLink="true">https://forum.iobroker.net/post/637057</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Jun 2021 05:37:04 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 05:10:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> nicht im log. da ist alles ok. schau in der Admin oberfläche.. Protokoll</p>
]]></description><link>https://forum.iobroker.net/post/637048</link><guid isPermaLink="true">https://forum.iobroker.net/post/637048</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Wed, 02 Jun 2021 05:10:26 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 04:57:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/arteck" aria-label="Profile: arteck">@<bdi>arteck</bdi></a><br />
Im log steht nix, hätte ich sonst gepostet.</p>
]]></description><link>https://forum.iobroker.net/post/637045</link><guid isPermaLink="true">https://forum.iobroker.net/post/637045</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Wed, 02 Jun 2021 04:57:00 GMT</pubDate></item><item><title><![CDATA[Reply to Admin5 - ReactUI &#x2F;&#x2F; Cannot get logs on Wed, 02 Jun 2021 04:53:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> es gab mal einen Fehler der die message nicht richtig geschrieben hat im Admin...</p>
<p dir="auto">schaumal ins log ob da die Quelle bzw Nachricht immer da sind.</p>
]]></description><link>https://forum.iobroker.net/post/637044</link><guid isPermaLink="true">https://forum.iobroker.net/post/637044</guid><dc:creator><![CDATA[arteck]]></dc:creator><pubDate>Wed, 02 Jun 2021 04:53:28 GMT</pubDate></item></channel></rss>
