  4. Zigbee ZM-RT201 PIR Motion Sensor wird nicht erkannt
    5.6k
zigbee cc26x2r1pirproxmoxzigbee adapter
27 Beiträge 4 Kommentatoren 3.5k Aufrufe 2 Beobachtet
  • A atheos
    @asgothian stimmt das dann so wie ichs hier gemacht hab:
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @atheos Sollte es. Wenn es nicht geht bitte das Log vom Startup posten.
    A.
    • AsgothianA Asgothian
      A.
      atheos
      @asgothian leider hat das wieder nicht funktioniert. Wenn ich den Zigbee Adapter erneut starte bekomme ich folgendes im Log zu sehen:
      zigbee.0	2021-05-31 22:20:33.252	error	(3276) Device 0x00124b00060ea04e "undefined" not described in statesMapping.
      zigbee.0	2021-05-31 22:20:33.191	info	(3276) Zigbee started
      zigbee.0	2021-05-31 22:20:33.190	info	(3276) 0x00158d000407d2e6 (addr 64800): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
      zigbee.0	2021-05-31 22:20:33.190	info	(3276) 0x00158d0003e7b01b (addr 15724): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
      zigbee.0	2021-05-31 22:20:33.189	info	(3276) 0x00158d00024866a6 (addr 47345): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      zigbee.0	2021-05-31 22:20:33.189	info	(3276) 0x00124b00060ea04e (addr 13987): Not supported (model undefined)(Unknown)
      zigbee.0	2021-05-31 22:20:33.188	info	(3276) 0x7cb03eaa0a0ac75c (addr 20927): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2021-05-31 22:20:33.188	info	(3276) 0x7cb03eaa0a0ac2c5 (addr 53103): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0	2021-05-31 22:20:33.187	info	(3276) 0x00158d00042546fb (addr 43257): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
      zigbee.0	2021-05-31 22:20:33.185	info	(3276) 0x00158d000230e7a3 (addr 37169): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      zigbee.0	2021-05-31 22:20:33.168	info	(3276) Currently 8 devices are joined:
      zigbee.0	2021-05-31 22:20:33.162	info	(3276) --> transmitPower : high
      zigbee.0	2021-05-31 22:20:33.162	info	(3276) Unable to disable LED, unsupported function.
      zigbee.0	2021-05-31 22:20:33.161	info	(3276) Disable LED
      zigbee.0	2021-05-31 22:20:33.155	info	(3276) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210120}}
      zigbee.0	2021-05-31 22:20:31.399	info	(3276) Installed Version: ioBroker/ioBroker.zigbee#master
      zigbee.0	2021-05-31 22:20:31.230	info	(3276) Starting Zigbee npm ...
      zigbee.0	2021-05-31 22:20:31.191	info	(3276) Apply converter from module: /opt/iobroker/iobroker-data/zigbee_0/ZM-RT201PIR.js
      zigbee.0	2021-05-31 22:20:31.173	info	(3276) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.1.0, js-controller: 3.2.16
      host.ioBroker	2021-05-31 22:20:29.979	info	instance system.adapter.zigbee.0 started with pid 3276
      host.ioBroker	2021-05-31 22:20:29.921	info	"system.adapter.zigbee.0" enabled
      host.ioBroker	2021-05-31 22:20:27.938	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zigbee.0	2021-05-31 22:20:27.400	info	(1559) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-05-31 22:20:27.400	info	(1559) terminating
      host.ioBroker	2021-05-31 22:20:26.940	info	stopInstance system.adapter.zigbee.0 send kill signal
      zigbee.0	2021-05-31 22:20:26.900	info	(1559) Zigbee: disabling joining new devices.
      zigbee.0	2021-05-31 22:20:26.899	info	(1559) cleaned everything up...
      zigbee.0	2021-05-31 22:20:26.898	info	(1559) Got terminate signal TERMINATE_YOURSELF
      host.ioBroker	2021-05-31 22:20:26.895	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
      • A atheos
        @atheos sagte in Zigbee ZM-RT201 PIR Motion Sensor wird nicht erkannt:
        node: v16.1.0
        Damit bist du aber auch weit in 'unknown territory'. Und dann selbst dort nicht 'auf Stand'.
          node: v16.1.0
          atheos
          @thomas-braun was müsste ich hier machen bzw. auf welche Version updaten?
          • A atheos
            @atheos
            Die empfohlene Version ist derzeitig node12 inkl. npm@6
            Wie man die ggf. am besten wechselt steht in meiner Signatur.
              @atheos
              atheos
              @thomas-braun danke für den Hinweis auf die Signatur. Werde versuchen die Version 12 zu installieren. Hoffe ich bekomme das hin.
              • A atheos
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @atheos
                Das sollte soweit ok sein. Es kann sein das Du das Gerät noch neu pairen musst.
                A.
                  @atheos
                  A.
                  atheos
                  @asgothian das habe ich bereits versucht aber bekomme wieder als unknown Gerät und unter den Objekten ist das auch nicht aufgeführt.
                  • A atheos
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @atheos Bitte poste das Log vom Anlernversuch.
                    A.
                      @atheos
                      atheos
                      @thomas-braun said in Zigbee ZM-RT201 PIR Motion Sensor wird nicht erkannt:
                      kämpfe seit einem Tag damit auf die node 12 version zu installieren aber ohne Erfolg irgendwann ging gar nix mehr weil ich zu viel Kaput gemacht hab :( Zum Glück hatte ich noch ein Snapshot zwar nicht neu aber immerhin habe ich endlich alles wieder zurück.
                      @asgothian said in Zigbee ZM-RT201 PIR Motion Sensor wird nicht erkannt:
                      zigbee.0	2021-06-01 21:58:29.135	info	(3276) Zigbee: stop joining
                      tankerkoenig.0	2021-06-01 21:58:27.976	warn	(1028) State "tankerkoenig.0.stations.8.e10.combined" has no existing object, this might lead to an error in future versions
                      tankerkoenig.0	2021-06-01 21:58:27.866	info	(1028) Reading data from tankerkoenig ...
                      zigbee.0	2021-06-01 21:58:00.876	warn	(3276) Device '0x00124b00060ea04e' announced itself
                      zigbee.0	2021-06-01 21:57:54.570	error	(3276) Failed to interview '0x00124b00060ea04e', device has not succesfully been paired. undefined
                      zigbee.0	2021-06-01 21:57:40.882	info	(3276) Starting interview of '0x00124b00060ea04e'
                      das kommt dann raus. Vielleicht ist die .js Datei nicht richtig? Hab den code von der Seite welches ich erwähnt hab.
                      AsgothianA Thomas BraunT 2 Antworten Letzte Antwort
                      • A atheos
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        @atheos Nein, das ist es nicht. Du musst den Sensor wach halten damit er während des Anlernvorgang kommunizieren kann, ansonsten passiert genau das.
                        A.
                        • A atheos
                          Wo klemmt es genau? Das HowTo ist eigentlich recht gut umsetzbar, finde ich jedenfalls.
                            A.
                            atheos
                            @asgothian ich hab echt alles schon versucht und nicht immer kommt im Log das gleiche raus. 10 sec. Taste gehalten loslassen wieder drauf usw. Und so eine genaue Anleitung dazu gibt es auch nicht wie man das anlernt. Ich seh nur das die LED rot leuchtet mal schnell mal langsam...
                              atheos
                              hab halt mit dem Punkt "Teil 1.1 Node-Upgrade/ Wechsel der nodejs-Version" versucht alles so wie dort. Dann bis zum Befehl "sudo apt install nodejs=VERSIONSNUMMER-1nodesource1" gekommen da kam ich glaub nicht weiter und hab auch wo anders geschaut und hab alles durcheinander gebracht. Bin halt echt nicht der Linux kenner führe nur das aus was ich irgendwo finde. Ich denke wenn ich das einmal gemacht hab weiß ich auch was das bedeutet usw. aber erst mal das zu können.. Ich weiß jetzt auch nicht ob damit das Problem gelöst ist wenn ich auf die 12er Version upgrade. Versuch ist es natürlich wert wenn man das halt kann.
                              • A atheos
                                AsgothianA Offline
                                AsgothianA Offline
                                Asgothian
                                @atheos Du musst zusehen das
                                • du den Sensor 1 mal resettest damit die Meldung kommt das das Interview startet
                                • danach drückst Du den Knopf mit dem du den zurück gesetzt hast in etwa alle 2 sekunden kurz um den Sensor zu wecken.
                                Damit hat es bei mir bei so ziemlich allen Batteriebetriebenen Geräten geklappt.
                                Solange die Meldung
                                kommt bricht die Kommunikation während des Pairings ab.
                                A.
                                • A atheos
                                  Ist was für einen separaten Thread.
                                    Solange die Meldung
                                    A.
                                    atheos
                                    Solange die Meldung
                                    Du bist der beste ich hab schonmal einen Erfolg aber jetzt muss ich schauen ob das auch funktioniert zumindest finde ich in den Objekten den Datenpunt ZM-RT201
                                    Der wert ist immer auf true warum auch immer.
                                    • A atheos
                                      Solange die Meldung
                                      atheos
                                      So sieht es mit den Geräteinformationen aus
                                      2df0a088-eccc-4ee7-9842-4a2ca34f6748-image.png @atheos
                                      • A atheos
                                        atheos
                                        Update: Habe jetzt einen anderen Code genommen und eine zweite *.js Datei erstellt. Diesen wieder als External Converter eingetragen. Einen zweiten Sensor angelernt jetzt sieht es so aus:
                                        Habe mir ein Blockly gemacht testweise wenn ich ins Zimmer komme das Licht eingeschaltet wird und dafür nehme ich in den Objekten den Datenpunkt link_quality:
                                        Dieser funktioniert auch sobald ich rein komme geht licht an. Stimmt das dass man den Wert von link_quality nehmen muss weil dieser sich immer ändert.
                                        So sieht mein test Blockly aus
                                        • A atheos
                                          atheos
                                          Hallo nochmal gibt es eventuell noch eine Idee warum die anderen Datenpunkt außer link_quality nicht funktionieren? Z.b. occupancy sonst bringt mir das alles nichts. Ich kann nicht mit link_quality triggern wäre nicht richtig und der Wert ändert sich auch immer. So würde z.B. mein Blockly aussehen wenn hier true oder false ausgegeben wäre:
