  4. PH-Messung
PH-Messung
432 Beiträge 48 Kommentatoren 185.3k Aufrufe 50 Beobachtet
  • coyoteC coyote
    @apollon77 you have mail ;-)
    apollon77A
    apollon77A
    @coyote Ok, I start to collect here the stuff I saw in the Wireshark:
    • (01) App sends a UDP broadcast with data "00 00 00 03 03 00 00 03" to port 12414
    • App sends MDNS query to 224.0.0.251 _%9E5E7C8F47989526C9BCD95D24084F6F0B27C5ED._sub._googlecast._tcp.local, "QU" question PTR _googlecast._tcp.local, "QU" question
    • (02) Device Answers with UDP message from port 12414 to App
      00:00:00:03:68:00:00:04:00:16:43:46:71:70:4a:54:53:79:6d:43:45:39:50:4c:6c:70:31:44:70:62:68:59:00:06:48:3f:da:87:dc:47:00:00:00:20:32:64:33:64:39:35:34:64:39:62:62:37:34:31:62:34:61:31:39:62:61:31:31:35:33:31:30:34:39:33:32:62:00:00:00:00:00:00:00:02:61:70:69:2e:67:69:7a:77:69:74:73:2e:63:6f:6d:3a:38:30:00:34:2e:30:2e:38:00
      ( hCFqpJTSymCE9PLlp1DpbhYH?ÚÜG 2d3d954d9bb741b4a19ba1153104932bapi.gizwits.com:804.0.8)
    • App connects to device on port 12416 and Device and App communicates on that port
    • (03) App sends 00:00:00:03:03:00:00:06
    • (04) Device answers: 00:00:00:03:0f:00:00:07:00:0a:X1:X2:X3:X4:X5:X6:X7:X8:X9:X0
    • (05) App sends : 00:00:00:03:0f:00:00:08:00:0a:X1:X2:X3:X4:X5:X6:X7:X8:X9:X0
    • (06) Device answers: 00:00:00:03:04:00:00:09:00
    • (07) App sends : 00:00:00:03:04:00:00:90:02
    • (08) Device answers: 00:00:00:03:0d:00:00:91:03:00:02:dc:08:9d:00:00:00:00
    • (09) App sends : 00:00:00:03:08:00:00:93:00:00:00:04:02
    • (10) Device answers: 00:00:00:03:11:00:00:94:00:00:00:04:03:00:02:dc:08:9d:00:00:00:00
    • (11) App sends : 00:00:00:03:03:00:00:15
    • (12) Device answers: 00:00:00:03:03:00:00:16
    ... and the last two repeat every 4s (seems like a ping/pong)
    Das passt grob spontan zu dem Protokoll von hier https://github.com/gizwits/gokit-GAgent/blob/master/software/lan/lan.c#L291
    • 00 00 00 03 sind immer die lokalen ersten Bytes
    • byte Nummer 8 ist das "Kommando" (also wenn App->Device) ... damit von oben
      • (---) code 01 -- UDP to device - onBoarding message ... 00 XX <XX bytes ssid> 00 YY <YY bytes ssidpwd> (unsure with 00xx/yy or if only xx/yy?)
      • (---) code 02 -- UDP from device - onBoarding response ... just as OK message
      • (01): code 03 -- UDP to device - Discover message
      • (02): code 04 ?? -- UDP from device - Discover response
      • (---) code 05 ?? -- UDP from device active broadcast from device
      • (03): code 06 -- TCP to device: user bind passcode; Device returns passcode for login command
      • (04): code 07 -- TCP from device: device answers with data and 10 chars as passcode
      • (05): code 08 -- TCP to device: user login : Device wants to see the same passcode as sent above
      • (06): code 09 -- TCP from device: login result: 00=ok, 01=error
      • (07): code 90 -- TCP to device: send p0 to uart ... schreibt "02" ans Device
      • (08): code 91 ?? TCP answer from serial?? 03:00 02:dc 08:9d 00:00 00:00
      • (09): code 93 ?? -- TCP to device - unknown 00:00:00:04:02
      • (10): code 94 ?? -- TCP from device - unknown 00:00 00:04 03:00 02:dc 08:9d 00:00 00:00
      • (11) code 15: -- TCP to device: "tick" aka ping
      • (12) code 16: should be "pong" then
    If we now would have info on the values on display vs data it would help :-)
    • 02dc could be 732 with idea from above with /100 == 7,32 ... PH??
    • 089d could be 2205 with idea from above -2000 === 205 ... ORP?
      @coyote ??
    The two other 00 00 at the end could be the switch states ... but also would need to be verified.
    Ingo
    coyoteC 1 Antwort Letzte Antwort
    • apollon77A apollon77
        @coyote ??
      Ingo
      coyoteC
      coyoteC
      coyote
      @apollon77 sounds good ;-)
      Will do more test today with wireshark and and will write down the values from the display or take pictures.
      The switches cannot be triggered manually.
      The device is currently not in use by me, there are no probes connected, so the values are not directly plausible (ORP 0.2 etc.)
      • Marc RM Marc R
        Hi yall, my first post so be gentle...
        I connected the TX/RX inside the PH-803W with my UART to see what is shown there:
        f9d7f5c5-3913-4b22-9f41-91401981d447.jpg 091217d5-f679-44f3-9227-bdad52436c79.jpg
        Seems it sends the same binary data that Anti was able to reroute to his MQTT? While my router has the NAT functionality, I unfortunately cannot define virtual IP addresses, so that route is not viable for me and probably most here. But if we can make sense of the TX/RX Data, we could potentially add another ESP on this port and let it send the data to where we want it to be sent?
        Hope this makes sense and is helpful for the discussuion, Cheers
        A
        A
        Anti
        @marc-r Thats nice Marc-r. So the ESP just bring the Serial kommunikation to the Network. What I allready suspected but didn't checked. I think, like you, is the most simple way to flash the original ESP (or put a second one if you want to keep the original).
        for the completness: 9600 8N1
        I think I will make that, to don't have the MQTT in the middle.
        apollon77A Marc RM 2 Antworten Letzte Antwort
        • A Anti
          apollon77A
          apollon77A
          @anti Why you dio not implement the LAN protocol? (or wait until I did?) For me personally hardware modifications are meeh ... but I think everyone has it's own opinion here :-)
          But in gfact does not hatter ... so we need to dectode the values ... we know 4 bytes already :-) So assumption stay that the 2x 0000 at the end are the states of the switches
          • A Anti
            Marc RM
            Marc RM
            Marc R
            @anti you mean load something like Tasmota on the existing ESP? I have a lot of Sonoff switches which I "tasmotized", so I know how that works, but I'm not sure if the PH-803W would be compatible?
            • Marc RM Marc R
              A
              A
              Anti
              @marc-r I'm not so deep in the MQTT/Tasmota Topic. So not sure what you can do with Tasmota, here in this use case we want to put a serial Input somewhere. When Tasmota can do that, you should be okay with that. I was thinking about a little Programm on ESP putting the serial e.g. on a Webpage. This is probably a few minutes programming Job. I think i prefare this, because my Pool also will be controlled by an ESP. If a Server is in the middle is one more thing that can fail.
              But anyway i can wait if the other guys here find the "LAN Protocol" Solution. If i can use that from another ESP, i will probably make like this.
              Well i just thought i can connect the 803W serial connect directly my control ESP ... this is also a good failsafe alternative.
              • Marc RM
                Marc RM
                Marc R
                @anti Tasmota is an awesome open-source firmware for all kinds of ESP8266 devices to connect them via MQTT to automation systems such as Home Assistant and others. Have a look here: https://tasmota.github.io/docs/
                I virtually loaded it on about 60 devices so far, but try are Sonoff and Shelly switches and I'm not sure how the PH-803W would handle it.
                I'm just adding this as another alternative to the paths you guys are already following. I'm not saying it's better or worse. If you guys find a fairly simple way to send the PH-803W data to MQTT, I'm all for it!
                • apollon77A
                  apollon77A
                  Ok, mit weiteren Wireshark Mitschnitten von @coyote bin ich denke etwas weiter ... immer noch viele Annahmen, daber die kann man dann ja mal verifizieren. habe auch eine vermutung wo die Schaltwerte stecken (Bit flags) und würde tippen das andere Bits da drin vllt im Display für Anzeigen genutzt werden ...
                  Ich habe mal alles unter https://github.com/Apollon77/node-ph803w/blob/main/PROTOCOL.md zusammengefasst.
                  Als nächstes schaue ich mal das ich das als node.js Library implementiere
                  Ich habe auch für "unsere ESP Freunde" mal eine vermutete minimale Kommunikation unter https://github.com/Apollon77/node-ph803w/blob/main/PROTOCOL.md#minimum-interaction-scheme aufgeschrieben ... wäre zu verifizieren ...
                  Have fun
                    Have fun
                    C
                    C
                    Chaosbrother
                    @apollon77 Respekt.👍 Aber ich versteh nur noch Bahnhof🙄 . Mal abwarten wie es weitergeht.
                    Trotzdem DANKE für die Info´s und deine Mühe
                    • apollon77A
                      apollon77A
                      Ok, dann mal nächster Schritt ... ich hab mal was gebaut.
                      • Man nehme am besten einen Rechner wo nodejs drauf ist (also der von iobroker ist super)
                      • per SSH einloggen und in das Vezeichnis gehen
                      • Man lege sich ein neues Verzechnis an, am besten direkt im User-Verzeichnis (also NICHT!! in /opt/iobroker)
                      • npm install Apollon77/node-ph803w
                      • cd node_modules/node-ph803w/example
                      • node data.js 111.222.333.444 (mit 111.222.333.444 die IP des PH803W Geräts im lokalen Netzwerk
                      Dann sollte sich das Beispielskript verbinden, Passcode holen, einloggen und jede Datenänderung die es gibt sollte eine Logzeile geben mit den Werten. Eine Datenzeile muss in jedem Fall kommen - hoffentlich mehr sobald sich was ändert. Das nehme ich gern mal.
                      Falls irgendwas nicht geht bitte mal unter Linux mit DEBUG=ph803w* node data.js 111.222.333.444 starten, dann sollte mehr log kommen.
                      Zu testen ist:
                      • Das die werte mit dem Display passen und idealerweise auch was die "Schaltzustände" angeht
                      • Das bei Änderungen neue Werte kommen (es ist immer noch ein bissl unklar welches Kommando das auslöst)
                      • Die zwei "binFlag1/2" Felder haben vermutlich eine Verbindung zu DIngen im Display (annahme). Das wäre zu prüfen und hier schreiben zu was was gehört :-)
                      Dann schauen wir mal wie gut blindes Programmieren so tut :-)
                      Ingo
                        Zu testen ist:
                        Ingo
                        S
                        S
                        SoerenKaiser99
                        @apollon77
                        Coole Nummer :D
                        Es ginge aber auch (ein wenig einfacher) mit nem Wemos D1 / NodeMCU und ner analogen PH Sonde :D... Nur so nebenbei 👍
                        Wemos D1 PH-Sonde
                        U apollon77A 2 Antworten Letzte Antwort
                        • A
                          A
                          Anti
                          Wo bleibt denn da der Spaß? :-P
                          Nein ist natürlich auch ein weg. Hab sowas sogar hier liegen war irgendwie nie dazu gekommen das weiterzuverfolgen :/
                          • A Anti
                            S
                            S
                            SoerenKaiser99
                            @anti weis ich doch. War ein wenig ironisch gemeint :) Versteh schon.. Herrausforderung und so.
                            Hatte ich auch vor... Bin dann aber die Tage mangels Zeit umgeschwenkt. Jetzt regelt die phileo den pH wert, n shelly steuert den Chlorinator und die Pumpe ( danke an paul :D ) und n blueconnect sendet stündlich die Daten :D ... läuft!
                            • S SoerenKaiser99
                              @apollon77
                              Coole Nummer :D
                              Wemos D1 PH-Sonde
                              U
                              U
                              UncleB
                              @soerenkaiser99 hast du ne Ahnung welche Sonde der Herr genau verwendet?
                              • S SoerenKaiser99
                                @apollon77
                                Coole Nummer :D
                                Wemos D1 PH-Sonde
                                apollon77A
                                apollon77A
                                @soerenkaiser99 ich denke nur eine Sonde ist einfacher als zwei weil die challenges bei zwei Sonden sind größer wegen galvanischer Trennung und Dingen das sich die Sonden nicht gegenseitig beeinflussen. Aber ja.
                                Ich persönlich bastele lieber mit Software als mit Hardware (hab gelernt das ich bei Zweiterem für mich ein besseres Aufwand-nutzen-Frust Verhältnis habe) ;-)) ich hab bei mir auch in Summe drei arduinos im Haus verbaut für Dinge und hoffe das geht nie wieder kaputt weil ich fadt nicht mehr weiß wie das alles war und worauf ich achten muss ;-)
                                coyoteC S 2 Antworten Letzte Antwort
                                  coyoteC
                                  coyoteC
                                  coyote
                                  @apollon77
                                  Wollte mal installieren, aber...
                                  /home/coyote/ph803w# npm install Apollon77/node-ph803w
                                  npm ERR! Can't install github:Apollon77/node-ph803w#f51066522bac3a191b11010126e6aaf2ccf48e7f: Missing package version
                                  npm ERR!     /root/.npm/_logs/2021-05-28T05_48_51_894Z-debug.log
                                  • coyoteC coyote
                                    @apollon77
                                    apollon77A
                                    apollon77A
                                    @coyote Erwischt ... retry please
                                      coyoteC
                                      coyoteC
                                      coyote
                                      #66
                                      @apollon77
                                      Schätze das ist ok so:
                                      root@debian:/home/coyote/ph803w# npm install Apollon77/node-ph803w        npm WARN saveError ENOENT: no such file or directory, open '/home/coyote/ph803w/        package.json'
                                      npm notice created a lockfile as package-lock.json. You should commit this file.
                                      npm WARN enoent ENOENT: no such file or directory, open '/home/coyote/ph803w/pac        kage.json'
                                      npm WARN ph803w No description
                                      npm WARN ph803w No repository field.
                                      npm WARN ph803w No README data
                                      npm WARN ph803w No license field.
                                      + node-ph803w@0.0.1
                                      added 3 packages from 4 contributors and audited 3 packages in 4.175s
                                      found 0 vulnerabilities
                                         │      New major version of npm available! 6.14.12 → 7.15.0      │
                                         │   Changelog: https://github.com/npm/cli/releases/tag/v7.15.0   │
                                         │               Run npm install -g npm to update!                │
                                      • coyoteC coyote
                                        @apollon77
                                        + node-ph803w@0.0.1
                                        apollon77A
                                        apollon77A
                                        #67
                                        @coyote Ja
                                          @coyote Ja
                                          S
                                          S
                                          skinni
                                          #68
                                          Hab keine Sonden angeschlossen, aber soweit siehts gut aus. Ich freu mich auf den adapter 😇
                                          Data: {"binFlags1":"11","binFlags2":"10","ph":7.77,"redox":-44,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.76,"redox":-44,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.76,"redox":-38,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.77,"redox":-68,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.8,"redox":-69,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.81,"redox":-70,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.83,"redox":-72,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.83,"redox":-73,"phSwitch":false,"redoxSwitch":true}
                                          Data: {"binFlags1":"100","binFlags2":"10","ph":7.82,"redox":-73,"phSwitch":false,"redoxSwitch":true}
                                          33.2k
                                          84.3k
