  4. RPI2 Adapter: GPIO Ports von ERweiterungskarte
31 Beiträge 5 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • WalW Wal
    @wolfgangfb ,
    ok dann schalte den Sonoff-Adapter auf debug. das machst du in den Instanzen. Der Sonoff-Adapter ist im Prinzip auch ein MQTT-Server, ich weis nur nicht ob der die Erweiterungen erkennt.
    W Offline
    W Offline
    WolfgangFB
    @wal
    Hi
    Ich habe es geschafft, den Debugmodus zu aktivieren.
    Wenn ich das richtig interpretiere kommen die Änderungen für D0 auch an. Aber in den Datenpunkten wird einfach nichts geändert.
    sonoff.0	2021-05-11 19:48:06.966	debug	(10493) stateChange sonoff.0.DVES_sensor29.Time: {"val":"2021-05-11T18:48:07","ack":true,"ts":1620755286961,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1620755286961}
    sonoff.0	2021-05-11 19:48:06.958	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Event":"Done"}
    sonoff.0	2021-05-11 19:48:06.952	debug	(10493) Set State after task: sonoff.0.DVES_sensor29.Time
    sonoff.0	2021-05-11 19:48:06.952	debug	(10493) process task: {"type":"addObject","id":"sonoff.0.DVES_sensor29.Time","data":{"_id":"sonoff.0.DVES_sensor29.Time","common":{"type":"string","role":"state","read":true,"write":true,"name":"DVES
    sonoff.0	2021-05-11 19:48:06.951	debug	(10493) updateState sonoff.0.DVES_sensor29.Time - 1
    sonoff.0	2021-05-11 19:48:06.951	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Time":"2021-05-11T18:48:07","MCP230XX_INT":{"D0":1,"MS":350}}
    sonoff.0	2021-05-11 19:48:06.617	debug	(10493) stateChange sonoff.0.DVES_sensor29.Time: {"val":"2021-05-11T18:48:06","ack":true,"ts":1620755286612,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1620755286112}
    sonoff.0	2021-05-11 19:48:06.609	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Event":"Done"}
    sonoff.0	2021-05-11 19:48:06.602	debug	(10493) Set State after task: sonoff.0.DVES_sensor29.Time
    sonoff.0	2021-05-11 19:48:06.602	debug	(10493) process task: {"type":"addObject","id":"sonoff.0.DVES_sensor29.Time","data":{"_id":"sonoff.0.DVES_sensor29.Time","common":{"type":"string","role":"state","read":true,"write":true,"name":"DVES
    sonoff.0	2021-05-11 19:48:06.601	debug	(10493) updateState sonoff.0.DVES_sensor29.Time - 1
    sonoff.0	2021-05-11 19:48:06.600	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Time":"2021-05-11T18:48:06","MCP230XX_INT":{"D0":1,"MS":50}}
    sonoff.0	2021-05-11 19:48:06.566	debug	(10493) stateChange sonoff.0.DVES_sensor29.Time: {"val":"2021-05-11T18:48:06","ack":true,"ts":1620755286561,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1620755286112}
    sonoff.0	2021-05-11 19:48:06.556	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Event":"Done"}
    sonoff.0	2021-05-11 19:48:06.552	debug	(10493) Set State after task: sonoff.0.DVES_sensor29.Time
    sonoff.0	2021-05-11 19:48:06.552	debug	(10493) process task: {"type":"addObject","id":"sonoff.0.DVES_sensor29.Time","data":{"_id":"sonoff.0.DVES_sensor29.Time","common":{"type":"string","role":"state","read":true,"write":true,"name":"DVES
    sonoff.0	2021-05-11 19:48:06.551	debug	(10493) updateState sonoff.0.DVES_sensor29.Time - 1
    sonoff.0	2021-05-11 19:48:06.550	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Time":"2021-05-11T18:48:06","MCP230XX_INT":{"D0":0,"MS":50}}
    sonoff.0	2021-05-11 19:48:06.518	debug	(10493) stateChange sonoff.0.DVES_sensor29.Time: {"val":"2021-05-11T18:48:06","ack":true,"ts":1620755286513,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1620755286112}
    sonoff.0	2021-05-11 19:48:06.507	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Event":"Done"}
    sonoff.0	2021-05-11 19:48:06.504	debug	(10493) Set State after task: sonoff.0.DVES_sensor29.Time
    sonoff.0	2021-05-11 19:48:06.503	debug	(10493) process task: {"type":"addObject","id":"sonoff.0.DVES_sensor29.Time","data":{"_id":"sonoff.0.DVES_sensor29.Time","common":{"type":"string","role":"state","read":true,"write":true,"name":"DVES
    sonoff.0	2021-05-11 19:48:06.503	debug	(10493) updateState sonoff.0.DVES_sensor29.Time - 1
    sonoff.0	2021-05-11 19:48:06.502	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Time":"2021-05-11T18:48:06","MCP230XX_INT":{"D0":1,"MS":400}}
    sonoff.0	2021-05-11 19:48:06.120	debug	(10493) stateChange sonoff.0.DVES_sensor29.Time: {"val":"2021-05-11T18:48:06","ack":true,"ts":1620755286112,"q":0,"from":"system.adapter.sonoff.0","user":"system.user.admin","lc":1620755286112}
    sonoff.0	2021-05-11 19:48:06.106	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Event":"Done"}
    sonoff.0	2021-05-11 19:48:06.103	debug	(10493) Set State after task: sonoff.0.DVES_sensor29.Time
    sonoff.0	2021-05-11 19:48:06.103	debug	(10493) process task: {"type":"addObject","id":"sonoff.0.DVES_sensor29.Time","data":{"_id":"sonoff.0.DVES_sensor29.Time","common":{"type":"string","role":"state","read":true,"write":true,"name":"DVES
    sonoff.0	2021-05-11 19:48:06.102	debug	(10493) updateState sonoff.0.DVES_sensor29.Time - 1
    sonoff.0	2021-05-11 19:48:06.101	debug	(10493) [DVES_sensor29] Received: stat/I2C_sensor29test/RESULT = {"Time":"2021-05-11T18:48:06","MCP230XX_INT":{"D0":1,"MS":250}}
    W 1 Antwort Letzte Antwort
    • W WolfgangFB
      @wal
      Hi
      W Offline
      W Offline
      WolfgangFB
      @wolfgangfb
      Nachtrag:
      ich habe den Pin 0 mal auf Mode 4 gestellt (INPUT mode, report on HIGH, pull-up enabled), es wird auch schön bei jedem Schließen eine Meldung abgefeuert die auch im Broker ankommt, nur der Datenpunkt bleibt auf 0 stehen.
      Auch wenn ich auf Mode 3 stelle (Interrupt bei Low) das gleiche, die Meldungen kommen an, es ändert sich aber nichts am Datenpunkt, immer 0.
      (Mein Gedanke war, dass die Meldung vielleicht ankommt, aber gleich wieder zurückgesetzt wird).
      WalW UncleSamU 2 Antworten Letzte Antwort
      • W WolfgangFB
        @wolfgangfb
        Nachtrag:
        WalW Offline
        WalW Offline
        Wal
        @wolfgangfb ,
        der datenpunkt ist nur 1 wenn an D0 Masse anliegt. Sobald du die Masse entfernst wird er wieder 0.
        Walter
        DoorIO-Adapter
        • W WolfgangFB
          @wolfgangfb
          Nachtrag:
          UncleSamU Offline
          UncleSamU Offline
          UncleSam
          @wolfgangfb sagte in RPI2 Adapter: GPIO Ports von ERweiterungskarte:
          Mach doch mal ein Skript / Blockly, das etwas macht mit der Änderung des Datenpunktes (z.B. ein Log ausgeben). Dann siehst du ob sich tatsächlich nichts ändert oder du es nur nicht siehst.
          Oder: du schaust dir einfach den Zeitstempel des Datenpunktes an (mit der Maus drüber fahren).
          @UncleSam: Was meinst Du mit "neuem espeasy Adapter"?
          Sorry, ich meinte den ioBroker.esphome Adapter.
          Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
          ♡-lichen Dank an meine Sponsoren
          • WalW Wal
            @wolfgangfb ,
            W Offline
            W Offline
            WolfgangFB
            @wal
            Bei mir ist der Datenpunkt immer auf 0, egal ob der Pin auf Masse ist oder per Pullup auf VCC.
            • UncleSamU UncleSam
              W Offline
              W Offline
              WolfgangFB
              @unclesam
              Das habe ich auch schon gemacht, wenn ich auf den Datenpunkt triggere (any) kommt einfach nichts, triggere ich auf den Punkt "time" bekomme ich jeden Zeitpunkt, wenn ich den Zustand des Pins ändere (nur eben der Zustand nicht :-(
              Ich habe versucht den esphome Adapter zu installieren.
              Den muss ich ja wohl über github installieren. Ich bin auf die "Katze" gegangen, habe die url https://github.com/DrozmotiX/ioBroker.esphome eingegeben, bekomme die Meldung "Installiere aus URL..." und das seit einer viertel Stunde, da tut sich einfach nichts.
              WalW FredFF 2 Antworten Letzte Antwort
              • W WolfgangFB
                @unclesam
                WalW Offline
                WalW Offline
                Wal
                @wolfgangfb
                da wird der Sonoff-Adapter das nicht können.
                Versuche den Mqtt-Adapter als Server, der kann das auf jeden Fall . Wichtig ist den Port nur einmal benutzen und den Filter in den Adapter Einstellungen setzen (mqtt. 0.*).
                Walter
                DoorIO-Adapter
                • W WolfgangFB
                  @unclesam
                  FredFF Online
                  FredFF Online
                  FredF
                  Most Active Forum Testing
                  Dieser Adapter ist noch in der Beta Version und nur über Änderung des Verwahrungsortes zu installieren. Funktioniert so wie er soll, man sollte aber wissen was Beta bedeutet...
                  • W Offline
                    W Offline
                    WolfgangFB
                    @fredf
                    Danke für den freundlichen Hinweis. Wirklich geholfen hat er mir aber nicht. Verwahrungsort ist "Beta (latest).
                    Gehe ich auf "Installieren aus eigener URL" habe ich die Auswahl zwischen "von Github" und "beliebig".
                    Gehe ich auf "von Github" kann ich "esphome [DrozmotiX]" auswählen. Es kommt:
                    Kommando-Ausführung: $ ./iobroker url "https://github.com/DrozmotiX/ioBroker.esphome/tarball/master" esphome --debug
                    aber passieren tut nichts
                    gehe ich auf "beliebig" und gebe per Cpoy&paste "https://github.com/DrozmotiX/ioBroker.esphome" als URL ein kommt
                    "Kommando-Ausführung: $ ./iobroker url "https://github.com/DrozmotiX/ioBroker.esphome"
                    aber es passiert auch nichts (außer dass der blaue Balken wie blöd von links nach rechts wandert).
                    Könntest Du mir evtl sagen (...man sollte aber wissen was Beta bedeutet...), was ich noch über "Beta" wissen sollte, damit der Adapter auch bei mir macht, was er sollte?
                    • W WolfgangFB
                      @fredf
                      FredFF Online
                      FredFF Online
                      FredF
                      @wolfgangfb Bei Beta Verwahrungsort wird dieser Adapter normal über die Admin Oberfläche angeboten
                      • W Offline
                        W Offline
                        WolfgangFB
                        OK, ich habe den ESPHome Adapter jetzt installiert bekommen und auch versucht mein Node MCU ESP8266 mit dem MCP23017 einzubinden. Hier habe ich aber ein Problem:
                        In der Sektion mcp23s17 weiß ich nicht, was ich als cs_pin eintragen soll.
                        Dann sagt mir Adapter, dass ich zusätzlich einen Eintrag "spi" benötige. In der Beispieldatei ist hier GPIO12, 13 und 14 verwendet. Das kann es aber bei mir nicht sein weil ich da schon einen Temperatursensor dran habe (der auch manchmal geht).
                        Ich habe ehrlich gesagt keine Ahnung, was ich da bei clk_pin mosi_pin und miso_pin eintragen soll.
                        Immerhin werden die Datenpunkte schon einmal angelegt. Ich bin guter Dinge relativ nahe an meinem Ziel zu sein.
                        UncleSamU 1 Antwort Letzte Antwort
                        • W WolfgangFB
                          UncleSamU Offline
                          UncleSamU Offline
                          UncleSam
                          Fällt dir nicht auf, dass da ein "S" im Namen ist? Der MCP23S17 wird über SPI angehängt und hat nichts mit dem MCP23017 zu tun, der über I2C angesprochen wird.
                          • W Offline
                            W Offline
                            WolfgangFB
                            @unclesam
                            Danke, das ist mir tatsächlich nicht aufgefallen. Manchmal habe ich eben Tomaten auf den Augen. Da hätte ich noch ewig probieren können.
                            Jetzt geht auch der 23017 und ich sehe die aktualisierten Datenpunkte :-)
                            Was mich noch etwas irritiert ist, dass es manchmal Ewigkeiten (ca. 30 Minuten) dauert, bis die einzelnen Nodes auf grün gehen. Im EspHome Dashboard kann ich sofort die Logs mit den Ereignissen sehen, da sind sie also. Warum das manchmal (nicht immer) so lange dauert würde ich schon gerne wissen (zumal in den Logs nichts zu sehen ist).
                            • W WolfgangFB
                              @unclesam
                              UncleSamU Offline
                              UncleSamU Offline
                              UncleSam
                              Ich denke, das wäre ein separates Thema wert. Dort wird dir dann vielleicht auch Dutchman helfen können.
