  4. Wasserzähler (Funk 868) auslesen.
diehl868funkwasserzähleroms
220 Beiträge 23 Kommentatoren 91.1k Aufrufe 24 Beobachtet
  • hg6806H hg6806
    @michi_pi
    Sieht vielversprechend aus.
    pi@raspberrypi:~ $ cd wmbusmeters
    pi@raspberrypi:~/wmbusmeters $ sudo make install
    Building 1.1.0-44-ga26bac3
    binaries: installed /usr/bin/wmbusmeters and /usr/sbin/wmbusmetersd
    man page: installed /usr/share/man/man1/wmbusmeters.1.gz
    group: added wmbusmeters
    user: added wmbusmeters
    user: added wmbusmeters to dialout group
    user: added wmbusmeters to uucp group
    user: added wmbusmeters to plugdev group
    log: created /var/log/wmbusmeters/meter_readings
    logrotate: created /etc/logrotate.d/wmbusmeters
    conf file: created /etc/wmbusmeters.conf
    conf dir: created /etc/wmbusmeters.d
    systemd: no changes to /lib/systemd/system/wmbusmeters.service
    pi@raspberrypi:~/wmbusmeters $ sudo systemctl daemon-reload
    pi@raspberrypi:~/wmbusmeters $ sudo systemctl start wmbusmeters
    pi@raspberrypi:~/wmbusmeters $ systemctl status wmbusmeters.service
    ● wmbusmeters.service - "wmbusmeters service"
       Loaded: loaded (/lib/systemd/system/wmbusmeters.service; enabled; vendor preset: enabled)
       Active: active (running) since Thu 2021-04-01 13:55:23 CEST; 51s ago
         Docs: https://github.com/weetmuts/wmbusmeters
               man:wmbusmeters(1)
      Process: 13729 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=0/SUCCESS)
      Process: 13730 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=0/SUCCESS)
      Process: 13731 ExecStartPre=/bin/mkdir -p /run/wmbusmeters (code=exited, status=0/SUCCESS)
      Process: 13732 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /run/wmbusmeters (code=exited, status=0/SUCCESS)
      Process: 13733 ExecStart=/usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid (code=exited, status=0/SUCCESS)
     Main PID: 13734 (wmbusmetersd)
        Tasks: 3 (limit: 4915)
       CGroup: /system.slice/wmbusmeters.service
               └─13734 /usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid
    Apr 01 13:55:23 raspberrypi systemd[1]: Starting "wmbusmeters service"...
    Apr 01 13:55:23 raspberrypi systemd[1]: Started "wmbusmeters service".
    Ich muss dann noch die Config und meinwasserzaehler rüberkopieren/schreiben und teste dann mal.
    Michi_Pi
    #131
    @hg6806 ja sieht gut aus.
    wenn du die config änderst dann nochmal folgendes eingeben.
    sudo systemctl restart wmbusmeters
    hg6806H 1 Antwort Letzte Antwort
    • M Michi_Pi
      hg6806H Offline
      hg6806H Offline
      hg6806
      schrieb am zuletzt editiert von hg6806
      #132
      @michi_pi
      So, es läuft jetzt endlich!!!
      Was eine Geburt! Ich bin auch echt froh, das mit meinem Halbwissen durchgezogen zu haben.
      Generell war wohl anfangs die Installation nicht in Ordnung, deshalb wurde der Service nicht gestartet.
      Schön und einfacher wäre es trotzdem das Ganze mit dem CUL Adapter zu machen, aber ich glaube da ist man noch nicht so weit.
      • hg6806H hg6806
        @michi_pi
        Michi_Pi
        #133
        @hg6806 sagte in Wasserzähler (Funk 868) auslesen.:
        Was eine Geburt!
        das stimmt :D aber immerhin läuft es jetzt.
        Ja ein Adapter wäre naturlich schon nice. Bei mir wurde mit dem CUL Adapter nichtmal der der Stick erkannt. Daraufhin bin ich dann auf wmbusmeters gestoßen.
        Hatte anfangs auch schwierigkeiten, aber eher mit dem Stick als mit wmbusmeters. Allerdings läuft es jetzt seit Oktober ohne Probleme zuverlässig.
        • M Michi_Pi
          Was eine Geburt!
          hg6806H Offline
          hg6806H Offline
          hg6806
          #134
          @michi_pi
          Ja, Danke nochmals für die hervorragende Unterstützung und auch nochmal ein herzliches Dankeschön an @mickym
          • hg6806H Offline
            hg6806H Offline
            hg6806
            #135
            Noch eine Kleinigkeit.
            In der git-Beschreibung stand nichts.
            Kann man per SW irgendwie die hell blinkende LED ausschalten?
            Notfalls löte ich sie aus.
            • hg6806H hg6806
              Michi_Pi
              #136
              @hg6806 ja die nervt ein wenig. Weiß nicht ob man die einfach so deaktivieren kann.
              Hab mal gesehen dass man die im Sketch selbst deaktivieren kann. Wollte aber da nicht rumspielen.
              Ich habe jetzt ein Gehäuse dazu und da sieht man jetzt das blinken kaum mehr.
              • O Offline
                O Offline
                oxident
                #137
                Ich frage mich gerade, ob man mit dem AES-Schlüssel auch in der Lage wäre, Daten auf einem Diehl HYDRUS 171A zu verändern.
                Es geht mir nicht darum, das zu machen, jedoch wäre das ein prima Gegenargument der Wasserversorger, wenn es um die Herausgabe des Schlüssels geht...
                • O oxident
                  SBorgS Offline
                  SBorgS Offline
                  SBorg
                  #138
                  @oxident Wenn geht es nur lokal per IR-Schnittstelle. Kann ich mir aber nicht vorstellen, dass dies überhaupt vorgesehen ist. Immerhin handelt es sich um eine geeichte Messvorrichtung zur Abrechnung von Verbräuchen. Damit wäre jede Abrechnung anfechtbar, schließlich könnte ja auch das Wasserwerk meinen Verbrauch "hoch drehen"...
                  LG SBorg ( SBorg auf GitHub)
                  O 1 Antwort Letzte Antwort
                  • SBorgS SBorg
                    O Offline
                    O Offline
                    oxident
                    #139
                    @sborg Ja, so denke ich auch. Aber mir ist zu Ohren gekommen, dass die Wasserwerke derzeit Anfragen zu dem AES-Key oft aus genau zwei Gründen abweisen:
                    • Datenschutz (?)
                    • Manipulierbarkeit des Zählers
                      In der Anleitung zum Diehl habe ich nichts dergleichen gefunden, aber irgendwie muss ja der Zähler bei der Installation auch programmiert werden können, oder?
                    Falls das nur per IR geht, um so besser ;-)
                    • M Michi_Pi
                      @hg6806 einfach mit uninstall
                      sudo systemctl stop wmbusmeters
                      cd wmbusmeters
                      sudo make uninstall
                      Wenn du dann diese Zeilen ausführst, kannst du dann mal zeigen was in dem make test für ein Ergebnis gekommen ist?
                      git clone https://github.com/weetmuts/wmbusmeters.git
                      cd wmbusmeters
                      make && make test
                      gerald123
                      #140
                      @michi_pi
                      Hallo michi_pi, ich hoffe du kannst mir kurz helfen.
                      Ich möchte eine ältere Version (0.9.35) von wmbusmeter installieren, leider komme ich nicht drauf wie ich den git clone Befehl dafür schreiben muss.
                      Synology 918+ 4GB; ioBroker auf RPI4; Zigbee; Sonoff
                      • G gerald123
                        @michi_pi
                        Michi_Pi
                        #141
                        Hallo @gerald123 versuchs mal damit
                        git clone https://github.com/weetmuts/wmbusmeters.git -b v0.9.35
                        oder
                        git clone --branch 0.9.35 wmbusmeters
                        so genau weiß ich es auch nicht, hatte ich bisher noch nicht gemacht. Wenn dann nur upgedatet :D
                        Wieso brauchst du genau diese Version?
                        G 1 Antwort Letzte Antwort
                        • M Michi_Pi
                          oder
                          gerald123
                          #142
                          @michi_pi Dankeschön für die rasche Antwort.
                          Ich habe mit dieser Version einen Nano Cul an einem Raspi am laufen. Nun möchte ich einen weiteren Nano Cul an einem anderen Raspi installieren und bekomme es mit der neuen Version einfach nicht zum laufen, darum möchte ich jetzt testen ob es mit der unterschiedlichen Version zu tuen hat.
                          • G gerald123
                            Michi_Pi
                            #143
                            @gerald123 achso okay. Hat es nun geklappt?
                            • M Michi_Pi
                              gerald123
                              #144
                              @michi_pi ja, das mit der Version hat geklappt.
                              Leider findet er aber meinen Nano Cul noch nicht.
                              • G gerald123
                                Michi_Pi
                                #145
                                @gerald123 wird der funktionierende an dem anderen pi erkannt?
                                • M Michi_Pi
                                  gerald123
                                  schrieb am zuletzt editiert von gerald123
                                  #146
                                  @michi_pi Jetzt habe ich es geschafft das keiner mehr erkannt wird 😖
                                  root@raspberrypi:~/wmbusmeters# wmbusmeters --listento=t1 /dev/ttyUSB0
                                  Wmbus devices found but no meters supplied. You must supply which link modes to listen to. Eg. auto:c1
                                  Ich habe alles nochmal nach dieser Anleitung installiert, leider funktioniert es nicht und ich komme auch nicht mehr weiter.
                                  https://github.com/zibous/ha-watermeter/blob/master/docs/wmbusmeters-nano_cul.md
                                  • G gerald123
                                    Michi_Pi
                                    #147
                                    @gerald123 okay, du hast wohl einfach nur mehrere instanzen laufen. Deshalb wird vermutlich nichts gefunden.
                                    was bringt den
                                    • M Michi_Pi
                                      was bringt den
                                      gerald123
                                      #148
                                      @michi_pi sagte in Wasserzähler (Funk 868) auslesen.:
                                      Momentan habe ich bei der letzten Installation wieder die aktuelle Version aufgespielt.
                                      Das kommt beim Status:
                                      root@raspberrypi:~/wmbusmeters# systemctl status wmbusmeters
                                         Active: active (running) since Fri 2021-05-07 20:20:29 CEST; 33min ago
                                                 man:wmbusmeters(1)
                                        Process: 1653 ExecStartPre=/bin/mkdir -p /var/log/wmbusmeters/meter_readings (code=exited, status=0/SUCCESS)
                                        Process: 1654 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /var/log/wmbusmeters (code=exited, status=0/SUCCESS)
                                        Process: 1655 ExecStartPre=/bin/mkdir -p /run/wmbusmeters (code=exited, status=0/SUCCESS)
                                        Process: 1656 ExecStartPre=/bin/chown -R wmbusmeters:wmbusmeters /run/wmbusmeters (code=exited, status=0/SUCCESS)
                                        Process: 1657 ExecStart=/usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid (code=exited, status=0/SUCCESS)
                                       Main PID: 1658 (wmbusmetersd)
                                          Tasks: 3 (limit: 2062)
                                                 └─1658 /usr/sbin/wmbusmetersd /run/wmbusmeters/wmbusmeters.pid
                                      Mai 07 20:20:28 raspberrypi systemd[1]: Starting "wmbusmeters service"...
                                      Mai 07 20:20:29 raspberrypi wmbusmetersd[1657]: (wmbusmeters) started /run/wmbusmeters/wmbusmeters.pid
                                      Mai 07 20:20:29 raspberrypi systemd[1]: Started "wmbusmeters service".
                                      • G gerald123
                                                   man:wmbusmeters(1)
                                        Michi_Pi
                                        #149
                                        @gerald123 das sieht ja schon mal gut aus.
                                        NanoCul wird auch angezeigt mit?
                                        $ ls -l /dev/serial/by-id
                                        • M Michi_Pi
                                          gerald123
                                          #150
                                          root@raspberrypi:~/wmbusmeters# ls -l /dev/serial/by-id
                                          insgesamt 0
                                          lrwxrwxrwx 1 root root 13 Mai  7 18:31 usb-SHK_NANO_CUL_868-if00-port0 -> ../../ttyUSB0
