  4. Admin Problem
    6.5k
Admin Problem
iobrokeradapter
74 Beiträge 11 Kommentatoren 10.4k Aufrufe 6 Beobachtet
  • _ _techniker_
    Ich hänge mich mal mit dran, da ich das selbe Problem habe und nicht gelöst bekomme.
    Anbei alles was ich gemacht habe. Finde keinen Fehler.
    pi@ioBroker-RasPi4:~ $ iobroker status
    Objects type: file
    States  type: file
    pi@ioBroker-RasPi4:~ $ iobroker stop
    pi@ioBroker-RasPi4:~ $ iobroker fix
    library: loaded
    Library version=2021-04-07
        Welcome to the ioBroker installation fixer!
        Script version: 2021-04-07
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
    Holen:2 http://archive.raspberrypi.org/debian buster InRelease [32,9 kB]
    OK:3 https://deb.nodesource.com/node_12.x buster InRelease
    Holen:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
    Holen:5 http://archive.raspberrypi.org/debian buster/main armhf Packages [372 kB]
    Es wurden 13,4 MB in 17 s geholt (807 kB/s).
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@ioBroker-RasPi4:~ $ iobroker list adapters
    system.adapter.admin                   : admin          - v4.2.1
    system.adapter.backitup                : backitup       - v1.8.5
    system.adapter.cloud                   : cloud          - v4.0.10
    system.adapter.daswetter               : daswetter      - v3.0.4
    system.adapter.device-reminder         : device-reminder - v1.0.6
    system.adapter.devices                 : devices        - v0.3.16
    system.adapter.discovery               : discovery      - v2.5.0
    system.adapter.flot                    : flot           - v1.10.6
    system.adapter.fritzbox                : fritzbox       - v0.2.1
    system.adapter.g-homa                  : g-homa         - v0.5.3
    system.adapter.habpanel                : habpanel       - v0.4.3
    system.adapter.history                 : history        - v1.9.12
    system.adapter.ical                    : ical           - v1.9.0
    system.adapter.icons-icons8            : icons-icons8   - v0.0.1
    system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
    system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
    system.adapter.influxdb                : influxdb       - v1.9.4
    system.adapter.info                    : info           - v1.7.15
    system.adapter.innogy-smarthome        : innogy-smarthome - v0.3.6
    system.adapter.jarvis                  : jarvis         - v2.1.0
    system.adapter.javascript              : javascript     - v4.10.9
    system.adapter.linkeddevices           : linkeddevices  - v1.4.2
    system.adapter.logparser               : logparser      - v1.1.0
    system.adapter.mobile                  : mobile         - v1.0.1
    system.adapter.net-tools               : net-tools      - v0.1.2
    system.adapter.netatmo                 : netatmo        - v1.3.3
    system.adapter.netatmo-crawler         : netatmo-crawler - v0.3.9
    system.adapter.node-red                : node-red       - v2.2.0
    system.adapter.ping                    : ping           - v1.4.12
    system.adapter.rpi2                    : rpi2           - v1.2.0
    system.adapter.sayit                   : sayit          - v1.12.2
    system.adapter.simple-api              : simple-api     - v2.5.3
    system.adapter.socketio                : socketio       - v3.1.4
    system.adapter.sonoff                  : sonoff         - v2.4.0
    system.adapter.sourceanalytix          : sourceanalytix - v0.4.8-alpha.8
    system.adapter.sql                     : sql            - v1.15.5
    system.adapter.tankerkoenig            : tankerkoenig   - v2.0.9
    system.adapter.telegram                : telegram       - v1.8.0
    system.adapter.text2command            : text2command   - v2.0.7
    system.adapter.vis                     : vis            - v1.3.4
    system.adapter.vis-bars                : vis-bars       - v0.1.4
    system.adapter.vis-fancyswitch         : vis-fancyswitch - v1.1.0
    system.adapter.vis-history             : vis-history    - v1.0.0
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
    system.adapter.vis-justgage            : vis-justgage   - v1.0.2
    system.adapter.vis-materialdesign      : vis-materialdesign - v0.4.2
    system.adapter.vis-metro               : vis-metro      - v1.1.2
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
    system.adapter.vis-weather             : vis-weather    - v2.5.2
    system.adapter.web                     : web            - v3.2.3
    system.adapter.wifilight               : wifilight      - v1.1.0
    pi@ioBroker-RasPi4:~ $ iobroker list instances
      system.adapter.admin.0                  : admin                 : ioBroker-RasPi4                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.backitup.0               : backitup              : ioBroker-RasPi4                          -  enabled
      system.adapter.cloud.0                  : cloud                 : ioBroker-RasPi4                          - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker-RasPi4                          - disabled
      system.adapter.device-reminder.0        : device-reminder       : ioBroker-RasPi4                          - disabled
      system.adapter.devices.0                : devices               : ioBroker-RasPi4                          - disabled
      system.adapter.discovery.0              : discovery             : ioBroker-RasPi4                          - disabled
      system.adapter.flot.0                   : flot                  : ioBroker-RasPi4                          - disabled
      system.adapter.fritzbox.0               : fritzbox              : ioBroker-RasPi4                          - disabled
      system.adapter.g-homa.0                 : g-homa                : ioBroker-RasPi4                          - disabled
      system.adapter.habpanel.0               : habpanel              : ioBroker-RasPi4                          - disabled
      system.adapter.history.0                : history               : ioBroker-RasPi4                          - disabled
      system.adapter.ical.0                   : ical                  : ioBroker-RasPi4                          - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker-RasPi4                          - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker-RasPi4                          - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker-RasPi4                          - disabled
      system.adapter.influxdb.0               : influxdb              : ioBroker-RasPi4                          - disabled, port: 8086
      system.adapter.influxdb.1               : influxdb              : ioBroker-RasPi4                          - disabled, port: 8086
      system.adapter.info.0                   : info                  : ioBroker-RasPi4                          - disabled
      system.adapter.jarvis.0                 : jarvis                : ioBroker-RasPi4                          - disabled
      system.adapter.javascript.0             : javascript            : ioBroker-RasPi4                          - disabled
      system.adapter.linkeddevices.0          : linkeddevices         : ioBroker-RasPi4                          - disabled
      system.adapter.logparser.0              : logparser             : ioBroker-RasPi4                          - disabled
      system.adapter.mobile.0                 : mobile                : ioBroker-RasPi4                          - disabled
      system.adapter.net-tools.0              : net-tools             : ioBroker-RasPi4                          - disabled
      system.adapter.netatmo-crawler.0        : netatmo-crawler       : ioBroker-RasPi4                          - disabled
      system.adapter.netatmo.0                : netatmo               : ioBroker-RasPi4                          - disabled
      system.adapter.node-red.0               : node-red              : ioBroker-RasPi4                          - disabled, port: 1880, bind: 192.168.2.100
      system.adapter.ping.0                   : ping                  : ioBroker-RasPi4                          - disabled
      system.adapter.rpi2.0                   : rpi2                  : ioBroker-RasPi4                          - disabled
      system.adapter.sayit.0                  : sayit                 : ioBroker-RasPi4                          - disabled
      system.adapter.sonoff.0                 : sonoff                : ioBroker-RasPi4                          - disabled, port: 1883, bind: 192.168.2.100
      system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker-RasPi4                          - disabled
      system.adapter.sql.0                    : sql                   : ioBroker-RasPi4                          - disabled
      system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker-RasPi4                          - disabled
      system.adapter.telegram.0               : telegram              : ioBroker-RasPi4                          - disabled, port: 8443, bind: 0.0.0.0
      system.adapter.text2command.0           : text2command          : ioBroker-RasPi4                          - disabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker-RasPi4                          - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker-RasPi4                          - disabled
      system.adapter.vis-history.0            : vis-history           : ioBroker-RasPi4                          - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker-RasPi4                          - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker-RasPi4                          - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker-RasPi4                          - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-RasPi4                          - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker-RasPi4                          - disabled
      system.adapter.vis.0                    : vis                   : ioBroker-RasPi4                          - disabled
      system.adapter.web.0                    : web                   : ioBroker-RasPi4                          - disabled, port: 8082, bind: 192.168.2.100, run as: admin
      system.adapter.wifilight.0              : wifilight             : ioBroker-RasPi4                          - disabled
    + instance is alive
    pi@ioBroker-RasPi4:~ $ npm -v && nodejs -v
    6.14.12
    v12.22.1
    pi@ioBroker-RasPi4:~ $ free -h
    Mem:          924Mi        89Mi       197Mi       5,0Mi       637Mi       771Mi
    Swap:          99Mi       1,0Mi        98Mi
    pi@ioBroker-RasPi4:~ $ sudo iobroker start
    pi@ioBroker-RasPi4:~ $ sudo iobroker status
    Objects type: file
    States  type: file
    pi@ioBroker-RasPi4:~ $ tail -f /opt/iobroker/log/iobroker.current.log
    2021-04-27 16:43:14.959  - info: host.ioBroker-WZ received SIGTERM
    2021-04-27 16:43:15.103  - info: host.ioBroker-WZ terminated
    2021-04-27 16:45:54.410  - info: host.ioBroker-WZ iobroker.js-controller version 3.2.16 js-controller starting
    2021-04-27 16:45:54.429  - info: host.ioBroker-WZ Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-04-27 16:45:54.431  - info: host.ioBroker-WZ hostname: ioBroker-WZ, node: v12.22.1
    2021-04-27 16:45:54.433  - info: host.ioBroker-WZ ip addresses: 192.168.2.100 fe80::9f2b:2c44:cc7f:f55b
    2021-04-27 16:45:56.988  - info: host.ioBroker-WZ connected to Objects and States
    2021-04-27 16:45:57.174  - info: host.ioBroker-WZ added notifications configuration of host
    2021-04-27 16:45:59.086  - info: host.ioBroker-WZ 48 instances found
    2021-04-27 16:45:59.259  - warn: host.ioBroker-WZ does not start any instances on this host
    @_techniker_ sagte in Admin Problem:
    + instance is alive
    ich sehe in der Liste kein einziges +
    _ 1 Antwort Letzte Antwort
      + instance is alive
      _ Offline
      _ Offline
      _techniker_
      Was meinst du mit + genau?
      • _ _techniker_
        das Gegenstück von - ????
        Hast du dir die Ausgabe von iobroker list instances komplett angesehen?
          _ Offline
          _ Offline
          _techniker_
          schrieb am zuletzt editiert von _techniker_
          jetzt verstehe ich.
          Was könnte das Problem sein?
          Habe nur ein Backup eingespielt.
          • _ _techniker_
            jetzt verstehe ich.
            da kommen wir langsam an Infos!
            sonst noch was, was du verschwiegen hast?
            • was für ein Backup?
            • wie eingespielt?
            • irgendetwas verändert im Vergleich zum Originalsystem, von dem das Backup stammt?
            • _ _techniker_
              Objects type: file
              States  type: file
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              + instance is alive
              6.14.12
              v12.22.1
              Objects type: file
              States  type: file
              crunchipC Abwesend
              crunchipC Abwesend
              @_techniker_ fehlt da nicht das
              Edit log nicht zu ende gelesen
                • wie eingespielt?
                _ Offline
                _ Offline
                _techniker_
                Habe ioBroker neu aufgesetzt und dann mit
                iobroker restore 2021_04_14-19_05_54_backupiobroker.tar.gz
                ein Backup zurückgespielt.
                • _ _techniker_
                  • auf dem selben System?
                  • mit der selben IP?
                    _ Offline
                    _ Offline
                    _techniker_
                    Ja
                    • _ _techniker_
                      Ja
                      Ja
                      dann bitte iobroker start ausführen
                        Ja
                        _ Offline
                        _ Offline
                        _techniker_
                        hab ich
                        • _ _techniker_
                          hab ich
                          hab ich
                          und jetzt noch mal
                            hab ich
                            und jetzt noch mal
                            _ Offline
                            _ Offline
                            _techniker_
                            @homoran said in Admin Problem:
                            + instance is alive
                            • _ _techniker_
                              hab ich
                              sudo iobroker start
                              Starte den iobroker NICHT per sudo im root-Kontext.
                              sudo iobroker stop
                              iobroker fix
                              iobroker start
                              • _ _techniker_
                                + instance is alive
                                @_techniker_
                                läuft ja immer noch nicht
                                iobroker start admin
                                und dann tail -f /opt/iobroker/log/iobroker.current.log
                                  @_techniker_
                                  _ Offline
                                  _ Offline
                                  _techniker_
                                  Nun kommt ein fehler
                                  pi@ioBroker-RasPi4:~ $ iobroker start admin
                                  No connection to databases possible ...
                                  2021-04-27 18:50:25.357  - info: host.ioBroker-WZ iobroker.js-controller version 3.2.16 js-controller starting
                                  2021-04-27 18:50:25.375  - info: host.ioBroker-WZ Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
                                  2021-04-27 18:50:25.378  - info: host.ioBroker-WZ hostname: ioBroker-WZ, node: v12.22.1
                                  2021-04-27 18:50:25.380  - info: host.ioBroker-WZ ip addresses: 192.168.2.100 fe80::9f2b:2c44:cc7f:f55b
                                  2021-04-27 18:50:28.417  - info: host.ioBroker-WZ connected to Objects and States
                                  2021-04-27 18:50:28.611  - info: host.ioBroker-WZ added notifications configuration of host
                                  2021-04-27 18:50:30.702  - info: host.ioBroker-WZ 48 instances found
                                  2021-04-27 18:50:30.859  - warn: host.ioBroker-WZ does not start any instances on this host
                                  2021-04-27 18:54:03.244  - info: host.ioBroker-WZ received SIGTERM
                                  2021-04-27 18:54:03.344  - info: host.ioBroker-WZ terminated
                                  • _ _techniker_
                                    was für eine Hardware?
                                    lief vorher redis?
                                    • _ _techniker_
                                      @_techniker_
                                      Nicht jede Rückmeldung aus der Konsole ist eine Fehlermeldung.
                                      iobroker status
                                      liefert?
                                        lief vorher redis?
                                        _ Offline
                                        _ Offline
                                        _techniker_
                                        RasPi4
                                        Nach der Installation lief alles normal.
                                        Backup einspielen ohne Fehlermeldung.
                                        Kein Aufrufen im Browser möglich.
                                        • _ _techniker_
                                          RasPi4
                                          @_techniker_
                                          Komplette Ausgabe. Inkl. ALLER Zeilen in der Konsole.
                                          So:
                                          pi@raspberrypi:~ $ iobroker status
                                          Objects type: file
                                          States  type: redis
                                          pi@raspberrypi:~ $
