  4. Upgrade auf Grafana 7 + influxdb + ioBroker
    2.6k
    4.5k
vishow-to
158 Beiträge 10 Kommentatoren 20.1k Aufrufe 13 Beobachtet
  • ostseereiterO ostseereiter
    pi@raspberrypi:~ $ systemctl status grafana-server.service
    ● grafana-server.service - Grafana instance
      Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
      Active: active (running) since Sat 2021-04-24 18:17:16 BST; 3h 19min ago
        Docs: http://docs.grafana.org
    Main PID: 2376 (grafana-server)
       Tasks: 11 (limit: 2062)
      CGroup: /system.slice/grafana-server.service
              └─2376 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:defaul
    Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Path Provisioning" logger=settings path=/etc/grafana/provisioning
    Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="App mode production" logger=settings
    Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Writing PID file" logger=server path=/var/run/grafana/grafana-server.pid pid=2376
    Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
    Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Starting DB migrations" logger=migrator
    Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Starting plugin search" logger=plugins
    Apr 24 18:17:18 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:18+0100 lvl=info msg="Registering plugin" logger=plugins id=input
    Apr 24 18:17:18 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:18+0100 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3000 protocol=http subUrl= socket=
    Apr 24 19:07:46 raspberrypi grafana-server[2376]: t=2021-04-24T19:07:46+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=1 uname= method=GET path=/ status=302 remote_addr
    Apr 24 19:08:42 raspberrypi grafana-server[2376]: t=2021-04-24T19:08:42+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=1 uname= method=GET path=/d/Gvhk9Tkgz/temperatur_
    pi@raspberrypi:~ $
    #149
    @ostseereiter Stimmt eigentlich alles.
    Und wie hast du die Version 7.4.x nun installiert?
    ostseereiterO 1 Antwort Letzte Antwort
      ostseereiterO Offline
      ostseereiter
      #150
      Guten morgen
      mit diesen Befehlen:
      echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
      wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
      sudo apt update
      apt policy grafana
      sudo apt dist-upgrade
      Gruß OSR
      Plattform
        Guten morgen
        sudo apt update
        apt policy grafana
        crunchipC Abwesend
        crunchipC Abwesend
        #151
        @ostseereiter erneut den echo Befehl?? möchtest die Liste wieder füllen?😀
        bevor ihr nochmal nen Tag "verblödelt", schmeiß doch Grafana runter, kontrolliere, ob irgendwo noch was vorhanden ist und installiere danach einmal Grafana frisch.
        Natürlich vorher den Ordner (var/lib/grafana) wegsichern, da liegt deine grafana.db
        löscht nur Grafana
        sudo apt-get remove grafana
        sollte Grafana löschen incl. aller abhängigeiten
        sudo apt-get remove --auto-remove grafana
        restlos entfernen incl. temporären Daten und Abhängigkeiten
        sudo apt-get purge grafana
          löscht nur Grafana
          ostseereiter
          #152
          @crunchip dann könnte ich doch glei Grafana neu auf den iobroker installieren?
          Gruß OSR
          Plattform
          B crunchipC 2 Antworten Letzte Antwort
            Beowolf
            schrieb am zuletzt editiert von Beowolf
            #153
            @ostseereiter
            Man kann nicht Grafana AUF ioBroker installieren. Die beiden Sachen haben eigentlich nichts miteinander zu tun.
            So richtig hast Du glaube ich nicht verstanden wie das alles zusammen hängt, oder?
            Mit ioBroker kannst Du Daten, Zustände usw. von den verschiedenen "SmartHome Sensoren" auf einer Plattform zusammen führen. Von dort aus kannst Du diese Daten in eine Datenbank z.B. InfluxDB schreiben. Von dort holt Grafana nun wieder die Daten und zeigt sie an.
            Ist so etwas vereinfacht ausgedrückt.
            • B Beowolf
              @ostseereiter
              ostseereiter
              #154
              @beowolf lach ich meinte ja auf den Computer wo iobroker läuft. Das einzigste was mich abschreckt sind die Einstellungen bevor der richtig läuft.
              Gruß OSR
              Plattform
                #155
                @ostseereiter
                Hast du kein Backup für grafana?
                  @ostseereiter
                  ostseereiter
                  #156
                  @thomas-braun ja habe ich
                  Gruß OSR
                  Plattform
                    crunchipC Abwesend
                    crunchipC Abwesend
                    #157
                    @ostseereiter kannst du, deinen anderen thread hab ich schon gelesen
                      ostseereiter
                      #158
                      @crunchip Ich wollte neu machen weil ja komplett neu aufsetzten auf ein anderes System
                      Gruß OSR
                      Plattform
