  4. Upgrade auf Grafana 7 + influxdb + ioBroker
    2.6k
    4.5k
vishow-to
158 Beiträge 10 Kommentatoren 20.1k Aufrufe 13 Beobachtet
  • ostseereiterO ostseereiter
    pi@raspberrypi:~ $ systemctl status grafana-server.service
    ● grafana-server.service - Grafana instance
       Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vend
       Active: active (running) since Sat 2021-04-24 18:17:16 BST; 3h 5min ago
         Docs: http://docs.grafana.org
     Main PID: 2376 (grafana-server)
        Tasks: 11 (limit: 2062)
       CGroup: /system.slice/grafana-server.service
               └─2376 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --p
    Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl
    Apr 24 18:17:18 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:18+0100 lvl
    Apr 24 19:07:46 raspberrypi grafana-server[2376]: t=2021-04-24T19:07:46+0100 lvl
    Apr 24 19:08:42 raspberrypi grafana-server[2376]: t=2021-04-24T19:08:42+0100 lvl
    lines 1-19/19 (END)
    #147
    @ostseereiter Bitte vollständig. Da fehlt das Zeilenende.
    ostseereiterO 1 Antwort Letzte Antwort
      ostseereiterO Offline
      ostseereiter
      #148
        Loaded: loaded (/usr/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
        Active: active (running) since Sat 2021-04-24 18:17:16 BST; 3h 19min ago
                └─2376 /usr/sbin/grafana-server --config=/etc/grafana/grafana.ini --pidfile=/var/run/grafana/grafana-server.pid --packaging=deb cfg:default.paths.logs=/var/log/grafana cfg:defaul
      Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Path Provisioning" logger=settings path=/etc/grafana/provisioning
      Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="App mode production" logger=settings
      Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Writing PID file" logger=server path=/var/run/grafana/grafana-server.pid pid=2376
      Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Connecting to DB" logger=sqlstore dbtype=sqlite3
      Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Starting DB migrations" logger=migrator
      Apr 24 18:17:16 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:16+0100 lvl=info msg="Starting plugin search" logger=plugins
      Apr 24 18:17:18 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:18+0100 lvl=info msg="Registering plugin" logger=plugins id=input
      Apr 24 18:17:18 raspberrypi grafana-server[2376]: t=2021-04-24T18:17:18+0100 lvl=info msg="HTTP Server Listen" logger=http.server address=[::]:3000 protocol=http subUrl= socket=
      Apr 24 19:07:46 raspberrypi grafana-server[2376]: t=2021-04-24T19:07:46+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=1 uname= method=GET path=/ status=302 remote_addr
      Apr 24 19:08:42 raspberrypi grafana-server[2376]: t=2021-04-24T19:08:42+0100 lvl=info msg="Request Completed" logger=context userId=0 orgId=1 uname= method=GET path=/d/Gvhk9Tkgz/temperatur_
      pi@raspberrypi:~ $
      Gruß OSR
      Plattform
        pi@raspberrypi:~ $
        #149
        @ostseereiter Stimmt eigentlich alles.
        Und wie hast du die Version 7.4.x nun installiert?
          ostseereiter
          #150
          Guten morgen
          mit diesen Befehlen:
          echo "deb https://packages.grafana.com/oss/deb stable main" | sudo tee -a /etc/apt/sources.list.d/grafana.list
          wget -q -O - https://packages.grafana.com/gpg.key | sudo apt-key add -
          sudo apt update
          apt policy grafana
          sudo apt dist-upgrade
          Gruß OSR
          Plattform
            Guten morgen
            sudo apt update
            apt policy grafana
            crunchipC Abwesend
            crunchipC Abwesend
            #151
            @ostseereiter erneut den echo Befehl?? möchtest die Liste wieder füllen?😀
            bevor ihr nochmal nen Tag "verblödelt", schmeiß doch Grafana runter, kontrolliere, ob irgendwo noch was vorhanden ist und installiere danach einmal Grafana frisch.
            Natürlich vorher den Ordner (var/lib/grafana) wegsichern, da liegt deine grafana.db
            löscht nur Grafana
            sudo apt-get remove grafana
            sollte Grafana löschen incl. aller abhängigeiten
            sudo apt-get remove --auto-remove grafana
            restlos entfernen incl. temporären Daten und Abhängigkeiten
            sudo apt-get purge grafana
              löscht nur Grafana
              ostseereiter
              #152
              @crunchip dann könnte ich doch glei Grafana neu auf den iobroker installieren?
              Gruß OSR
              Plattform
              B crunchipC 2 Antworten Letzte Antwort
                Beowolf
                schrieb am zuletzt editiert von Beowolf
                #153
                @ostseereiter
                Man kann nicht Grafana AUF ioBroker installieren. Die beiden Sachen haben eigentlich nichts miteinander zu tun.
                So richtig hast Du glaube ich nicht verstanden wie das alles zusammen hängt, oder?
                Mit ioBroker kannst Du Daten, Zustände usw. von den verschiedenen "SmartHome Sensoren" auf einer Plattform zusammen führen. Von dort aus kannst Du diese Daten in eine Datenbank z.B. InfluxDB schreiben. Von dort holt Grafana nun wieder die Daten und zeigt sie an.
                Ist so etwas vereinfacht ausgedrückt.
                • B Beowolf
                  @ostseereiter
                  ostseereiter
                  #154
                  @beowolf lach ich meinte ja auf den Computer wo iobroker läuft. Das einzigste was mich abschreckt sind die Einstellungen bevor der richtig läuft.
                  Gruß OSR
                  Plattform
                    #155
                    @ostseereiter
                    Hast du kein Backup für grafana?
                      @ostseereiter
                      ostseereiter
                      #156
                      @thomas-braun ja habe ich
                      Gruß OSR
                      Plattform
                        crunchipC Abwesend
                        crunchipC Abwesend
                        #157
                        @ostseereiter kannst du, deinen anderen thread hab ich schon gelesen
                          ostseereiter
                          #158
                          @crunchip Ich wollte neu machen weil ja komplett neu aufsetzten auf ein anderes System
                          Gruß OSR
                          Plattform
