  4. IoBroker.mpd
IoBroker.mpd
103 Beiträge 15 Kommentatoren 29.3k Aufrufe 5 Beobachtet
  • R Offline
    rascal
    Der Fehler tritt nicht immer auf, bin noch nicht dahinter gekommen, womit es zusammen hängt.
    Info von: mpd -V
    ~ $ sudo mpd -V
    Music Player Daemon 0.19.1
    Copyright (C) 2003-2007 Warren Dukes <warren.dukes@gmail.com>Copyright (C) 2008-2014 Max Kellermann <max@duempel.org>This is free software; see the source for copying conditions.  There is NO
    warranty; not even MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Database plugins:
     simple proxy upnp
    Storage plugins:
     local smbclient nfs
    Neighbor plugins:
     smbclient upnp
    Decoders plugins:
     [mad] mp3 mp2
     [mpg123] mp3
     [vorbis] ogg oga
     [oggflac] ogg oga
     [flac] flac
     [opus] opus ogg oga
     [sndfile] wav aiff aif au snd paf iff svx sf voc w64 pvf xi htk caf sd2
     [audiofile] wav au aiff aif
     [dsdiff] dff
     [dsf] dsf
     [faad] aac
     [mpcdec] mpc
     [wavpack] wv
     [modplug] 669 amf ams dbm dfm dsm far it med mdl mod mtm mt2 okt s3m stm ult umx xm
     [mikmod] amf dsm far gdm imf it med mod mtm s3m stm stx ult uni xm
     [sidplay] sid mus str prg P00
     [wildmidi] mid
     [fluidsynth] mid
     [adplug] amd d00 hsc laa rad raw sa2
     [ffmpeg] 16sv 3g2 3gp 4xm 8svx aa3 aac ac3 afc aif aifc aiff al alaw amr anim apc ape asf atrac au aud avi avm2 avs bap bfi c93 cak cin cmv cpk daud dct divx dts dv dvd dxa eac3 film flac flc fli fll flx flv g726 gsm gxf iss m1v m2v m2t m2ts m4a m4b m4v mad mj2 mjpeg mjpg mka mkv mlp mm mmf mov mp+ mp1 mp2 mp3 mp4 mpc mpeg mpg mpga mpp mpu mve mvi mxf nc nsv nut nuv oga ogm ogv ogx oma ogg omg psp pva qcp qt r3d ra ram rl2 rm rmvb roq rpl rvc shn smk snd sol son spx str swf tgi tgq tgv thp ts tsp tta xa xvid uv uv2 vb vid vob voc vp6 vmd wav webm wma wmv wsaud wsvga wv wve
     [gme] ay gbs gym hes kss nsf nsfe sap spc vgm vgz
     [pcm]
    Output plugins:
     shout null fifo pipe alsa roar ao oss openal pulse jack httpd recorder
    Encoder plugins:
     null vorbis opus lame wave flac
    Archive plugins:
     [bz2] bz2
     [zzip] zip
     [iso] iso
    Input plugins:
     file alsa archive curl ffmpeg smbclient nfs mms cdio_paranoia
    Playlist plugins:
     extm3u m3u pls xspf asx rss soundcloud cue embcue
    Protocols:
     file:// http:// https:// mms:// mmsh:// mmst:// mmsu:// gopher:// rtp:// rtsp:// rtmp:// rtmpt:// rtmps:// smb:// nfs:// cdda:// alsa://</max@duempel.org></warren.dukes@gmail.com>
    • Alex1808A Offline
      Alex1808A Offline
      Alex1808
      @rascal:
      Der Fehler tritt nicht immer auf, bin noch nicht dahinter gekommen, womit es zusammen hängt. `
      Es gibt eine neue version. Probleme mit Saylt konnte Instalator lokalisieren und beheben. :)
      • R Offline
        rascal
        Dankeschön, werde ich gleich mal updaten
          BlueEssi
          Im SayIt-Adapter steht bei mir "MPD" nicht zur Auswahl. Was mache ich falsch? Ich hatte bereits vorher SayIt-Instanzen eingerichtet. Müssen alle neu installiert und eingerichtet werden?
          • R Offline
            rascal
            Update der Adapter mpd und sayit über den github Button links oben
            Gesendet von meinem HUAWEI CRR-L09 mit Tapatalk
              BlueEssi
              @rascal:
              Update der Adapter mpd und sayit über den github Button links oben `
              Den mpd-Adapter habe ich schon über den normalen Weg installieren können. mpd steht nur in den sayit-Adapter-Einstellungen nicht als Ausgabekanal zur Auswahl. Oder verstehe ich das Prinzip falsch.
              • R Offline
                rascal
                @BlueEssi:
                @rascal:
                Den mpd-Adapter habe ich schon über den normalen Weg installieren können. mpd steht nur in den sayit-Adapter-Einstellungen nicht als Ausgabekanal zur Auswahl. Oder verstehe ich das Prinzip falsch. `
                Ausgabekanal?
                Im Sayit Adapter wählst du mpd aus und unten die genaue mpd-Adapter-Instanz.
                Im mpd Adapter gibst du nur die IP Adresse des Rechners an, welcher den MPD-Daemon am laufen hat (Vorsicht, beim mpd-Daemon muss man im config File das "Bind to localhost" mit # auskommentieren und den Daemon neu starten.
                • wendy2702W Online
                  wendy2702W Online
                  Welche Version vom SayIt Adapter hast du installiert?
                    BlueEssi
                    @wendy2702:
                    Welche Version vom SayIt Adapter hast du installiert? `
                    Die Weboberfläche hat mir, trotz nicht durchgelaufener Installation, gesagt, ich hätte 1.3.2 installiert. Dem war offenbar nicht wirklich so.
                    Ich habe den Adapter mit allen Instanzen deinstalliert, alle Objekte gelöscht und neugestartet. Danach lief die Installation durch und MPD steht zur Auswahl.
                    Danke.
                      mayer
                      Hi, ich habe jetzt alle Adapter auf aktuellem Stand, MPD läuft auf einem Raspi, der MPD Adapter ist auch verbunden aber in der
                      Auswahl von Sayit kann ich MPD nicht finden.
                      Hab keine Idee mehr.
                      Gruss, mayer
                      • Alex1808A Offline
                        Alex1808A Offline
                        Alex1808
                        @mayer:
                        Gruss, mayer `
                        Dann ist die SayIt Adapter nicht aktuell. Installiere SayIt vom Git.
                        • R Offline
                          rascal
                          Hey,
                          ich habe einen Sayit-Adapter auf alle gestellt, funktioniert soweit sehr gut.
                          Was mir nur aufgefallen ist: Wenn eine mpd-Instanz disabled/angehalten ist, dann Produziert er im Log error Messages, wäre toll wenn du die abfangen könntest.
                          WARNING:	2017-01-12 11:23:02.114	error	cannot find message with id = 9075368
                          WARNING:	2017-01-12 11:23:02.113	error	cannot find message with id = 9075368
                          WARNING:	2017-01-12 11:23:02.111	error	cannot find message with id = 9075368
                          WARNING:	2017-01-12 11:23:02.110	error	cannot find message with id = 9075368
                          sayit.0	2017-01-12 11:23:02.090	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
                          sayit.0	2017-01-12 11:23:01.947	info	saying: Das ist ein Test Nummer 2
                          WARNING:	2017-01-12 11:23:00.972	error	cannot find message with id = 9075360
                          WARNING:	2017-01-12 11:23:00.971	error	cannot find message with id = 9075360
                          WARNING:	2017-01-12 11:23:00.968	error	cannot find message with id = 9075360
                          WARNING:	2017-01-12 11:23:00.967	error	cannot find message with id = 9075360
                          sayit.0	2017-01-12 11:23:00.944	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
                          sayit.0	2017-01-12 11:23:00.942	info	saying: /opt/iobroker/node_modules/iobroker.sayit/scifi.mp3
                          WARNING:	2017-01-12 11:21:56.364	error	cannot find message with id = 9075352
                          WARNING:	2017-01-12 11:21:56.363	error	cannot find message with id = 9075352
                          WARNING:	2017-01-12 11:21:56.362	error	cannot find message with id = 9075352
                          WARNING:	2017-01-12 11:21:56.361	error	cannot find message with id = 9075352
                          sayit.0	2017-01-12 11:21:56.333	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
                          sayit.0	2017-01-12 11:21:56.090	info	saying: Das ist ein Test
                          WARNING:	2017-01-12 11:21:55.145	error	cannot find message with id = 9075344
                          WARNING:	2017-01-12 11:21:55.137	error	cannot find message with id = 9075344
                          WARNING:	2017-01-12 11:21:55.134	error	cannot find message with id = 9075344
                          WARNING:	2017-01-12 11:21:55.130	error	cannot find message with id = 9075344
                          WARNING:	2017-01-12 11:21:55.114	error	cannot find message with id = 9075344
                          WARNING:	2017-01-12 11:21:55.112	error	cannot find message with id = 9075344
                          sayit.0	2017-01-12 11:21:55.087	info	Send to MPD 100;http://192.168.1.10:8082/state/sayit.0.tts.mp3
                          sayit.0	2017-01-12 11:21:55.083	info	saying: /opt/iobroker/node_modules/iobroker.sayit/scifi.mp3
                          LG Martin
                          • Alex1808A Offline
                            Alex1808A Offline
                            Alex1808
                            @rascal:
                            Hey,
                            LG Martin `
                            Das ist doch aber logisch.. error Messages kommen vom sayit. Dann muss auch sayit gestoppt werden oder ein andere player als MPD ausgewählt werden. ;)
                            • R Offline
                              rascal
                              Irgendwie schon, nur ein bisschen störend, ich habe eine mpd-Instanz zum Testen und damit die meiste Zeit inaktiv.
                              • Alex1808A Offline
                                Alex1808A Offline
                                Alex1808
                                @rascal:
                                Irgendwie schon, nur ein bisschen störend, ich habe eine mpd-Instanz zum Testen und damit die meiste Zeit inaktiv. `
                                Dann welle doch bei sayit Wiedergabe über browser und gut is es :)
                                • Alex1808A Offline
                                  Alex1808A Offline
                                  Alex1808
                                  Übrigens, wurde ein gestufte volume Reduzierung vor dem Ansage hinzugefügt. (Install vom Git)
                                  • R Offline
                                    rascal
                                    @Alex1808:
                                    Übrigens, wurde ein gestufte volume Reduzierung vor dem einsage hinzugefügt. (Inntal vom Git) `
                                    was meinst du damit? Welches volume wird reduziert und wie stark?
                                    • Alex1808A Offline
                                      Alex1808A Offline
                                      Alex1808
                                      @rascal:
                                      @Alex1808:
                                      was meinst du damit? Welches volume wird reduziert und wie stark? `
                                      Also z.b. wenn du am MPD gerade Musik abspielst und dann kommt eine Meldung/Ansage vom SayIt, früher wurde Musik Wiedergabe gestoppt, Lautstärke vom 80% (oder was vorher eingestellt wurde) stufenlos auf 0% gesetzt dann auf Lautstärke mit dem wert was die du mit Ansage schickst gesetzt z.b. auf 100%, dann kommt selbst die Ansage, und zum Schluss wird Lautstärke wieder auf 80% und Wiedergabe vom Musik ebenfalls wiederhergestellt.
                                      Jetzt ist praktisch das gleiche nur die Musik Wiedergabe nicht sofort gestoppt wird sondern wird leiser.
                                      • R Offline
                                        rascal
                                        Ah.. natürlich.. Denkfehler von mir. Coole Sache.
                                        Mein Problem ist nur, dass ich Squeezebox verwende und die Lautstärke bei Squeezebox über ein Script ändern muss, wenn ich eine Ansage loslasse.
                                        Aber coole Sache dass du das eingebaut hast.
                                        • Alex1808A Offline
                                          Alex1808A Offline
                                          Alex1808
                                          @rascal:
                                          Aber coole Sache dass du das eingebaut hast. `
                                          Nee, nicht ich, Adapter wird vom user "Instalator" entwickelt! :)
