  4. [gelöst]Zigbee startet nach Update nicht mehr
zigbee adpater
22 Beiträge 4 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • amg_666A amg_666
    @crunchip Das war es leider nicht. Die NPM 7 ist mir wieder "reingerutscht" weil ich unter Proxmox winen älteren Snapshot eingespielt hatte...
    Also iobroker npm neu installiert, jetzt
    Node.js: v14.16.1
    NPM: v6.14.12
    Danach iobroker fixer (war in Ordnung, danach zigbee Update führt zum gleichen Fehler.
    Auf der Adminoberfläche sagt er Beendet mit Fehler:
    Fertig mit Fehler: internal/modules/cjs/loader.js:883 throw err; ^Error: Cannot find module 'mime'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15) at Function.Module._load (internal/modules/cjs/loader.js:725:27) at Module.require (internal/modules/cjs/loader.js:952:19) at require (internal/modules/cjs/helpers.js:88:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:525:24) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:225:28 at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2557:9) at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:205:13) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:419:21 at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:223:55 { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]}
    Im log komischerweise diese Meldung:
    host.iobroker	2021-04-16 09:45:01.062	error	Please consider running the installation fixer when on Linux.
    host.iobroker	2021-04-16 09:45:01.062	error	could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Pleas
    host.iobroker	2021-04-16 09:45:00.191	error	instance system.adapter.ical.3 terminated with code 10 (CANNOT_FIND_ADAPTER_DIR)
    An Berechtigungen hab ich nichts verstellt und der Fixer ist durchgelaufen (?)
    crunchipC Abwesend
    crunchipC Abwesend
    @amg_666 sagte in Zigbee startet nach Update nicht mehr:
    Macht man auch nicht, ein snapshot ist nur ne "Momentaufnahme" und kein Backup.
    Von daher hebt man die eigentlich nicht auf, zumal, wenn du ein Backup zurück spielst, die snapshots eh verschwinden.
    Node.js: v14.16.1
    NPM: v6.14.12
    Wie hast du das gemacht?
    Version von node?
    Mit welcher Meldung?
    • amg_666A Offline
      amg_666A Offline
      amg_666
      @crunchip sagte in Zigbee startet nach Update nicht mehr:
      curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
      sudo apt-get install -y nodejs
      Version von node?
      andreas@iobroker:/opt/iobroker$ node -v
      v14.16.1
      Hatte ich mir nicht notiert, aber sinngemäß dass der Fixer durchgelaufen und alles in Ordnung ist und man mit iobroker start wieder starten soll
      • amg_666A amg_666
        Version von node?
        v14.16.1
        @amg_666
        Warum nutzt du nicht den Paketmanager, um node zu bändigen installieren?
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
        Wie sieht die Installation denn nun aus?
          @amg_666
          amg_666A Offline
          amg_666A Offline
          amg_666
          @thomas-braun Wenn ich nach der Anleitung vorgehe (ab Teil Teil 1.1 Node-Upgrade/ Wechsel der nodejs-Version:) dan passt soweit alles und am Ende bekomme ich
          root@iobroker:/opt/iobroker# which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/nodejs
          v14.16.1
          /usr/bin/node
          v14.16.1
          /usr/bin/npm
          6.14.12
          nodejs:
            Installed: 14.16.1-1nodesource1
            Candidate: 14.16.1-1nodesource1
            Version table:
           *** 14.16.1-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main amd64 Packages
               10.24.0~dfsg-1~deb10u1 500
                  500 http://ftp.debian.org/debian buster/main amd64 Packages
                  500 http://security.debian.org buster/updates/main amd64 Packages
          • amg_666A amg_666
            /usr/bin/nodejs
            v14.16.1
            /usr/bin/node
            v14.16.1
            /usr/bin/npm
            6.14.12
            nodejs:
              Version table:
            @amg_666
            Man meldet sich auch nicht als root an.
              @amg_666
              crunchipC Abwesend
              crunchipC Abwesend
              @thomas-braun ist wahrscheinlich im proxmox terminal
              Ist es nicht noch ratsam den npm cache zu löschen?
                @crunchip
                Bei proxmox wäre der host anders, oder?
                Klar, npm cache kann man auch mal löschen.
                • amg_666A Offline
                  amg_666A Offline
                  amg_666
                  @thomas-braun ich geb heute abend mal ein update, npm cache clean probier ich aus.
                  • amg_666A Offline
                    amg_666A Offline
                    amg_666
                    @amg_666 Also, nochmal angemeldet, nicht über proxmox Konsole sondern über PuTTY und mit einem "normalen" user, nicht root.
                    iobroker fixer:
                    andreas@iobroker:/opt/iobroker$ curl -sL https://iobroker.net/fix.sh | bash -
                    library: loaded
                    Library version=2021-04-07
                        Welcome to the ioBroker installation fixer!
                        Script version: 2021-04-07
                        You might need to enter your password a couple of times.
                        Installing prerequisites (1/3)
                    [sudo] password for andreas:
                    Hit:1 http://security.debian.org buster/updates InRelease
                    Hit:2 http://ftp.debian.org/debian buster InRelease
                    Hit:3 http://ftp.debian.org/debian buster-updates InRelease
                    Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
                    Reading package lists... Done
                    Installed gcc-c++
                        Checking ioBroker user and directory permissions (2/3)
                        Checking autostart (3/3)
                    Enabling autostart...
                    Autostart enabled!
                        Your installation was fixed successfully
                        Run iobroker start to start ioBroker again!
                    andreas@iobroker:/opt/iobroker$ iobroker start
                    npm cache clean habe ich nicht gemacht, weil er am meckern war dass das nicht notwendig ist:
                    andreas@iobroker:/opt/iobroker$ npm cache clean
                    npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data e        xtracted from the cache is guaranteed to be valid. If you want to make sure ever        ything is consistent, use 'npm cache verify' instead. On the other hand, if you'        re debugging an issue with the installer, you can use `npm install --cache /tmp/        empty-cache` to use a temporary cache instead of nuking the actual one.
                    npm ERR!
                    npm ERR! If you're sure you want to delete the entire cache, rerun this command        with --force.
                    npm ERR!     /home/andreas/.npm/_logs/2021-04-16T11_16_38_943Z-debug.log
                    npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
                    npm ERR!
                    npm ERR!     /home/andreas/.npm/_logs/2021-04-16T11_17_02_316Z-debug.log
                    npm cache verifiy liefert
                    andreas@iobroker:/opt/iobroker$ npm cache verify
                    Cache verified and compressed (~/.npm/_cacache):
                    Content verified: 1 (1535980 bytes)
                    Content garbage-collected: 1 (1535980 bytes)
                    Index entries: 1
                    Finished in 0.129s
                    Update des Adapters aus der Adminoberfläche liefert wieder den Fehler
                    log bringt danach Fehler auch bei anderen Adaptern:
                    host.iobroker	2021-04-16 13:48:01.038	error	Please consider running the installation fixer when on Linux.
                    host.iobroker	2021-04-16 13:48:01.037	error	could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Pleas
                    host.iobroker	2021-04-16 13:48:00.154	error	instance system.adapter.daswetter.0 terminated with code 10 (CANNOT_FIND_ADAPTER_DIR)
                    host.iobroker	2021-04-16 13:48:00.036	info	instance system.adapter.daswetter.0 started with pid 4600
                    host.iobroker	2021-04-16 13:45:33.904	info	iobroker exit 1
                    host.iobroker	2021-04-16 13:45:33.894	error	iobroker internal/modules/cjs/loader.js:883 throw err; ^Error: Cannot find module 'mime'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js- /opt/iobroker/node
                    host.iobroker	2021-04-16 13:45:01.042	error	Please consider running the installation fixer when on Linux.
                    host.iobroker	2021-04-16 13:45:01.041	error	could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Pleas
                    host.iobroker	2021-04-16 13:45:00.238	error	instance system.adapter.ical.3 terminated with code 10 (CANNOT_FIND_ADAPTER_DIR)
                    host.iobroker	2021-04-16 13:45:00.040	info	instance system.adapter.ical.3 started with pid 4593
                    smartmeter.0	2021-04-16 13:44:42.876	info	(13972) Received 10 values, 5 updated
                    javascript.0	2021-04-16 13:44:09.934	info	(3766) script.js.common.Statusanzeige_gross: request: http://192.168.2.82/cm?cmnd=Led11 0,0,0
                    web.0	2021-04-16 13:44:08.366	info	(3962) ==>Connected system.user.admin from ::ffff:192.168.2.105
                    web.0	2021-04-16 13:44:08.298	info	(3962) <==Disconnect system.user.admin from ::ffff:192.168.2.105 flot
                    host.iobroker	2021-04-16 13:43:47.278	info	iobroker info sharp Using cached /home/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br
                    host.iobroker	2021-04-16 13:40:09.986	info	instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
                    ical.2	2021-04-16 13:40:09.408	info	(4261) Terminated (NO_ERROR): Without reason
                    ical.2	2021-04-16 13:40:04.076	info	(4261) processing URL: Geburtstag https://calendar.google.com/calendar/ical/lqbnk2mjfq76g1pq1mg0v962q4%40group.calendar.google.com/private-3381bd6686823f0e378489decbeb2378/basic.ics
                    host.iobroker	2021-04-16 13:40:03.751	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    host.iobroker	2021-04-16 13:40:03.490	info	iobroker NPM version: 6.14.12npm install iobroker.zigbee@1.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
                    ical.2	2021-04-16 13:40:03.097	info	(4261) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v14.16.1, js-controller: 3.2.16
                    zigbee.0	2021-04-16 13:40:03.118	info	(3977) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0	2021-04-16 13:40:03.117	info	(3977) terminating
                    zigbee.0	2021-04-16 13:40:02.783	info	(3977) Zigbee: disabling joining new devices.
                    zigbee.0	2021-04-16 13:40:02.781	info	(3977) cleaned everything up...
                    zigbee.0	2021-04-16 13:40:02.780	info	(3977) Got terminate signal TERMINATE_YOURSELF
                    host.iobroker	2021-04-16 13:40:02.820	info	stopInstance system.adapter.zigbee.0 send kill signal
                    host.iobroker	2021-04-16 13:40:02.763	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                    host.iobroker	2021-04-16 13:40:02.762	info	"system.adapter.zigbee.0" disabled
                    host.iobroker	2021-04-16 13:40:02.709	info	iobroker host.iobroker Adapter "system.adapter.zigbee.0" is stopped.
                    host.iobroker	2021-04-16 13:40:02.637	info	iobroker Update zigbee from @1.4.4 to @1.5.1
                    host.iobroker	2021-04-16 13:40:00.449	info	instance system.adapter.ical.2 started with pid 4261
                    host.iobroker	2021-04-16 13:40:00.203	info	iobroker upgrade zigbee
                    • amg_666A amg_666
                      iobroker fixer:
                      library: loaded
                      Installed gcc-c++
                      Autostart enabled!
                      npm ERR!
                      npm ERR!
                      Index entries: 1
                      Finished in 0.129s
                      Und?
                      Das kann vom root-login kommen. Damit kann man sich ganz wunderbar das System zerfriemeln. Deswegen nutzt man den halt auch nicht.
                        Und?
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        @thomas-braun Also neu aufsetzen und dann ein Backup einspielen, oder?
                        • amg_666A amg_666
                          @amg_666
                          Keine Ahnung. Musst du wissen, was du machen willst oder musst.
                          • amg_666A Offline
                            amg_666A Offline
                            amg_666
                            @thomas-braun sagte in Zigbee startet nach Update nicht mehr:
                            Wenn ich das wüsste, dann würde ich die Frage ja nicht posten :-)
                            Aber mal im Ernst: Durch Root kann ich mir diverse Rechte "zerschießen" und ich dachte dass das doch genau ein Thema ist, was derr Fixer korrigiert (?)
                            • amg_666A amg_666
                              @amg_666
                              Der Fixer ist aber auch nicht der Wunderheiler für verbogene Systeme. Das kann funktionieren, muss aber nicht. Kommt halt darauf an was da genau verfummelt wurde.
                              Besser halt erst gar nicht per unnötigem root-login das System kaputt machen.
                              Wenn du nicht weißt wo da anzusetzen ist: Installier es neu.
                              • amg_666A Offline
                                amg_666A Offline
                                amg_666
                                @thomas-braun Ich setz es auf gelöst :-)
                                1. Bei den fehlerhaften Installationen hat er ja maßgeblich js-controller Module angemeckert die angeblich nicht vorhanden sind. Ich habe jetzt mit
                                npm install iobroker.js-controller
                                den js-controller neu installiert und da kamen dann einige Unstimmigkeiten (unkompatible Funktionstypen, falsche lockfile Versionen etc)
                                Nach Installation ließ sich iobroker nicht starten , also nochmal fixer und jetzt läuft es und auch der zigbee ging ohne Probleme auf die neue Version.
                                npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@        1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my        best with it!
                                > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                > node lib/preinstallCheck.js
                                > epoll@2.0.10 install /opt/iobroker/node_modules/epoll
                                > node-gyp rebuild
                                make: Entering directory '/opt/iobroker/node_modules/epoll/build'
                                  CXX(target) Release/obj.target/epoll/src/epoll.o
                                  SOLINK_MODULE(target) Release/obj.target/epoll.node
                                  COPY Release/epoll.node
                                make: Leaving directory '/opt/iobroker/node_modules/epoll/build'
                                > bufferutil@4.0.3 install /opt/iobroker/node_modules/bufferutil
                                > node-gyp-build
                                > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                                > node-gyp rebuild
                                make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                                  CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                                In file included from ../../nan/nan.h:56,
                                                 from ../src/unix_dgram.cc:5:
                                /home/iobroker/.cache/node-gyp/14.16.1/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                                       (node::addon_register_func) (regfunc),                          \
                                /home/iobroker/.cache/node-gyp/14.16.1/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X'
                                   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                                ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                                 NODE_MODULE(unix_dgram, Initialize)
                                  SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                                  COPY Release/unix_dgram.node
                                make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                                > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                                > node rebuild.js
                                ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                                > utf-8-validate@5.0.4 install /opt/iobroker/node_modules/utf-8-validate
                                > node-gyp-build
                                > canvas@2.7.0 install /opt/iobroker/node_modules/canvas
                                > node-pre-gyp install --fallback-to-build
                                node-pre-gyp WARN Using request for node-pre-gyp https download
                                [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" is installed via remote
                                > @serialport/bindings@9.0.7 install /opt/iobroker/node_modules/@serialport/bindings
                                > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                                > sharp@0.26.2 install /opt/iobroker/node_modules/sharp
                                > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
                                > @serialport/bindings@9.0.4 install /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                                > @serialport/bindings@9.0.4 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                                > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                                > node-gyp rebuild
                                make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
                                  CXX(target) Release/obj.target/diskusage/src/main.o
                                                 from ../src/main.cpp:3:
                                ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
                                 NODE_MODULE(diskusage, Init)
                                  CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                                  SOLINK_MODULE(target) Release/obj.target/diskusage.node
                                  COPY Release/diskusage.node
                                make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
                                > iobroker.vis@1.3.8 install /opt/iobroker/node_modules/iobroker.vis
                                > node main.js --install
                                > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
                                > node iobroker.js setup first
                                object _design/system updated
                                The following notifications happened during sync:
                                - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                                ioBroker configuration updated
                                > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
                                > node scripts/postinstall
                                > core-js@3.10.0 postinstall /opt/iobroker/node_modules/core-js
                                > node -e "try{require('./postinstall')}catch(e){}"
                                Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                                The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                                > https://opencollective.com/core-js
                                > https://www.patreon.com/zloirock
                                Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                                > serialport@9.0.6 postinstall /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/serialport
                                > node thank-you.js
                                Thank you for using serialport!
                                If you rely on this package, please consider supporting our open collective:
                                > https://opencollective.com/serialport/donate
                                > serialport@9.0.6 postinstall /opt/iobroker/node_modules/zigbee-herdsman/node_modules/serialport
                                > node thank-you.js
                                > iobroker.javascript@5.1.3 postinstall /opt/iobroker/node_modules/iobroker.javascript
                                > node ./install/installTypings.js
                                Installing NodeJS typings...
                                latest @types: 14, installed node: 14
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                + iobroker.js-controller@3.2.16
                                added 2480 packages from 458 contributors, removed 5 packages and updated 1628 packages in 296.338s
                                137 packages are looking for funding
                                  run `npm fund` for details
                                • amg_666A amg_666
                                  > node-gyp rebuild
                                  > node-gyp-build
                                  > node-gyp rebuild
                                  > node rebuild.js
                                  > node-gyp-build
                                  > node-gyp rebuild
                                  > node thank-you.js
                                  > node thank-you.js
                                  @amg_666
                                  Über npm installiert man das ja auch anders:
                                  cd /opt/iobroker
                                  sudo -H -u iobroker npm install iobroker.js-controller
                                  • amg_666A Offline
                                    amg_666A Offline
                                    amg_666
                                    @thomas-braun im how-to steht unter Punkt 3 d) nur npm install..., da hatte ich das her.
                                    Aber jetzt läufts ja, insofern ist es für mich ok.
                                    • amg_666A amg_666
                                      @amg_666 Mal geschaut von wann das HowTo ist?
