  4. [gelöst]Zigbee startet nach Update nicht mehr
zigbee adpater
22 Beiträge 4 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • amg_666A Offline
    amg_666A Offline
    amg_666
    @thomas-braun ich geb heute abend mal ein update, npm cache clean probier ich aus.
    • amg_666A Offline
      amg_666A Offline
      amg_666
      @amg_666 Also, nochmal angemeldet, nicht über proxmox Konsole sondern über PuTTY und mit einem "normalen" user, nicht root.
      iobroker fixer:
      andreas@iobroker:/opt/iobroker$ curl -sL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2021-04-07
          Welcome to the ioBroker installation fixer!
          Script version: 2021-04-07
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      [sudo] password for andreas:
      Hit:1 http://security.debian.org buster/updates InRelease
      Hit:2 http://ftp.debian.org/debian buster InRelease
      Hit:3 http://ftp.debian.org/debian buster-updates InRelease
      Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      andreas@iobroker:/opt/iobroker$ iobroker start
      npm cache clean habe ich nicht gemacht, weil er am meckern war dass das nicht notwendig ist:
      andreas@iobroker:/opt/iobroker$ npm cache clean
      npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data e        xtracted from the cache is guaranteed to be valid. If you want to make sure ever        ything is consistent, use 'npm cache verify' instead. On the other hand, if you'        re debugging an issue with the installer, you can use `npm install --cache /tmp/        empty-cache` to use a temporary cache instead of nuking the actual one.
      npm ERR!
      npm ERR! If you're sure you want to delete the entire cache, rerun this command        with --force.
      npm ERR!     /home/andreas/.npm/_logs/2021-04-16T11_16_38_943Z-debug.log
      npm ERR! As of npm@5, the npm cache self-heals from corruption issues and data extracted from the cache is guaranteed to be valid. If you want to make sure everything is consistent, use 'npm cache verify' instead. On the other hand, if you're debugging an issue with the installer, you can use `npm install --cache /tmp/empty-cache` to use a temporary cache instead of nuking the actual one.
      npm ERR!
      npm ERR!     /home/andreas/.npm/_logs/2021-04-16T11_17_02_316Z-debug.log
      npm cache verifiy liefert
      andreas@iobroker:/opt/iobroker$ npm cache verify
      Cache verified and compressed (~/.npm/_cacache):
      Content verified: 1 (1535980 bytes)
      Content garbage-collected: 1 (1535980 bytes)
      Index entries: 1
      Finished in 0.129s
      Update des Adapters aus der Adminoberfläche liefert wieder den Fehler
      Fertig mit Fehler: internal/modules/cjs/loader.js:883 throw err; ^Error: Cannot find module 'mime'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15) at Function.Module._load (internal/modules/cjs/loader.js:725:27) at Module.require (internal/modules/cjs/loader.js:952:19) at require (internal/modules/cjs/helpers.js:88:18) at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js:525:24) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:225:28 at installNpm (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2557:9) at finishUpgrade (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:205:13) at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:419:21 at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:223:55 { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js', '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js', '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]}
      log bringt danach Fehler auch bei anderen Adaptern:
      host.iobroker	2021-04-16 13:48:01.038	error	Please consider running the installation fixer when on Linux.
      host.iobroker	2021-04-16 13:48:01.037	error	could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Pleas
      host.iobroker	2021-04-16 13:48:00.154	error	instance system.adapter.daswetter.0 terminated with code 10 (CANNOT_FIND_ADAPTER_DIR)
      host.iobroker	2021-04-16 13:48:00.036	info	instance system.adapter.daswetter.0 started with pid 4600
      host.iobroker	2021-04-16 13:45:33.904	info	iobroker exit 1
      host.iobroker	2021-04-16 13:45:33.894	error	iobroker internal/modules/cjs/loader.js:883 throw err; ^Error: Cannot find module 'mime'Require stack:- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpload.js- /opt/iobroker/node
      host.iobroker	2021-04-16 13:45:01.042	error	Please consider running the installation fixer when on Linux.
      host.iobroker	2021-04-16 13:45:01.041	error	could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Pleas
      host.iobroker	2021-04-16 13:45:00.238	error	instance system.adapter.ical.3 terminated with code 10 (CANNOT_FIND_ADAPTER_DIR)
      host.iobroker	2021-04-16 13:45:00.040	info	instance system.adapter.ical.3 started with pid 4593
      smartmeter.0	2021-04-16 13:44:42.876	info	(13972) Received 10 values, 5 updated
      javascript.0	2021-04-16 13:44:09.934	info	(3766) script.js.common.Statusanzeige_gross: request: http://192.168.2.82/cm?cmnd=Led11 0,0,0
      web.0	2021-04-16 13:44:08.366	info	(3962) ==>Connected system.user.admin from ::ffff:192.168.2.105
      web.0	2021-04-16 13:44:08.298	info	(3962) <==Disconnect system.user.admin from ::ffff:192.168.2.105 flot
      host.iobroker	2021-04-16 13:43:47.278	info	iobroker info sharp Using cached /home/iobroker/.npm/_libvips/libvips-8.10.0-linux-x64.tar.br
      host.iobroker	2021-04-16 13:40:09.986	info	instance system.adapter.ical.2 terminated with code 0 (NO_ERROR)
      ical.2	2021-04-16 13:40:09.408	info	(4261) Terminated (NO_ERROR): Without reason
      ical.2	2021-04-16 13:40:04.076	info	(4261) processing URL: Geburtstag https://calendar.google.com/calendar/ical/lqbnk2mjfq76g1pq1mg0v962q4%40group.calendar.google.com/private-3381bd6686823f0e378489decbeb2378/basic.ics
      host.iobroker	2021-04-16 13:40:03.751	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.iobroker	2021-04-16 13:40:03.490	info	iobroker NPM version: 6.14.12npm install iobroker.zigbee@1.5.1 --loglevel error --prefix "/opt/iobroker" (System call)
      ical.2	2021-04-16 13:40:03.097	info	(4261) starting. Version 1.9.3 in /opt/iobroker/node_modules/iobroker.ical, node: v14.16.1, js-controller: 3.2.16
      zigbee.0	2021-04-16 13:40:03.118	info	(3977) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0	2021-04-16 13:40:03.117	info	(3977) terminating
      zigbee.0	2021-04-16 13:40:02.783	info	(3977) Zigbee: disabling joining new devices.
      zigbee.0	2021-04-16 13:40:02.781	info	(3977) cleaned everything up...
      zigbee.0	2021-04-16 13:40:02.780	info	(3977) Got terminate signal TERMINATE_YOURSELF
      host.iobroker	2021-04-16 13:40:02.820	info	stopInstance system.adapter.zigbee.0 send kill signal
      host.iobroker	2021-04-16 13:40:02.763	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
      host.iobroker	2021-04-16 13:40:02.762	info	"system.adapter.zigbee.0" disabled
      host.iobroker	2021-04-16 13:40:02.709	info	iobroker host.iobroker Adapter "system.adapter.zigbee.0" is stopped.
      host.iobroker	2021-04-16 13:40:02.637	info	iobroker Update zigbee from @1.4.4 to @1.5.1
      host.iobroker	2021-04-16 13:40:00.449	info	instance system.adapter.ical.2 started with pid 4261
      host.iobroker	2021-04-16 13:40:00.203	info	iobroker upgrade zigbee
      • amg_666A amg_666
        iobroker fixer:
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        npm ERR!
        npm ERR!
        Index entries: 1
        Finished in 0.129s
        @amg_666 sagte in Zigbee startet nach Update nicht mehr:
        Und?
        Das kann vom root-login kommen. Damit kann man sich ganz wunderbar das System zerfriemeln. Deswegen nutzt man den halt auch nicht.
          Und?
          amg_666A Offline
          amg_666A Offline
          amg_666
          @thomas-braun Also neu aufsetzen und dann ein Backup einspielen, oder?
          • amg_666A amg_666
            @amg_666
            Keine Ahnung. Musst du wissen, was du machen willst oder musst.
            • amg_666A Offline
              amg_666A Offline
              amg_666
              @thomas-braun sagte in Zigbee startet nach Update nicht mehr:
              Wenn ich das wüsste, dann würde ich die Frage ja nicht posten :-)
              Aber mal im Ernst: Durch Root kann ich mir diverse Rechte "zerschießen" und ich dachte dass das doch genau ein Thema ist, was derr Fixer korrigiert (?)
              • amg_666A amg_666
                @amg_666
                Der Fixer ist aber auch nicht der Wunderheiler für verbogene Systeme. Das kann funktionieren, muss aber nicht. Kommt halt darauf an was da genau verfummelt wurde.
                Besser halt erst gar nicht per unnötigem root-login das System kaputt machen.
                Wenn du nicht weißt wo da anzusetzen ist: Installier es neu.
                • amg_666A Offline
                  amg_666A Offline
                  amg_666
                  @thomas-braun Ich setz es auf gelöst :-)
                  1. Bei den fehlerhaften Installationen hat er ja maßgeblich js-controller Module angemeckert die angeblich nicht vorhanden sind. Ich habe jetzt mit
                  npm install iobroker.js-controller
                  den js-controller neu installiert und da kamen dann einige Unstimmigkeiten (unkompatible Funktionstypen, falsche lockfile Versionen etc)
                  Nach Installation ließ sich iobroker nicht starten , also nochmal fixer und jetzt läuft es und auch der zigbee ging ohne Probleme auf die neue Version.
                  npm WARN read-shrinkwrap This version of npm is compatible with lockfileVersion@        1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my        best with it!
                  > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                  > node lib/preinstallCheck.js
                  > epoll@2.0.10 install /opt/iobroker/node_modules/epoll
                  > node-gyp rebuild
                  make: Entering directory '/opt/iobroker/node_modules/epoll/build'
                    CXX(target) Release/obj.target/epoll/src/epoll.o
                    SOLINK_MODULE(target) Release/obj.target/epoll.node
                    COPY Release/epoll.node
                  make: Leaving directory '/opt/iobroker/node_modules/epoll/build'
                  > bufferutil@4.0.3 install /opt/iobroker/node_modules/bufferutil
                  > node-gyp-build
                  > unix-dgram@2.0.3 install /opt/iobroker/node_modules/unix-dgram
                  > node-gyp rebuild
                  make: Entering directory '/opt/iobroker/node_modules/unix-dgram/build'
                    CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.o
                  In file included from ../../nan/nan.h:56,
                                   from ../src/unix_dgram.cc:5:
                  /home/iobroker/.cache/node-gyp/14.16.1/include/node/node.h:758:43: warning: cast between incompatible function types from 'void (*)(v8::Local<v8::Object>)' to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
                         (node::addon_register_func) (regfunc),                          \
                  /home/iobroker/.cache/node-gyp/14.16.1/include/node/node.h:792:3: note: in expansion of macro 'NODE_MODULE_X'
                     NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                  ../src/unix_dgram.cc:404:1: note: in expansion of macro 'NODE_MODULE'
                   NODE_MODULE(unix_dgram, Initialize)
                    SOLINK_MODULE(target) Release/obj.target/unix_dgram.node
                    COPY Release/unix_dgram.node
                  make: Leaving directory '/opt/iobroker/node_modules/unix-dgram/build'
                  > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                  > node rebuild.js
                  ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                  > utf-8-validate@5.0.4 install /opt/iobroker/node_modules/utf-8-validate
                  > node-gyp-build
                  > canvas@2.7.0 install /opt/iobroker/node_modules/canvas
                  > node-pre-gyp install --fallback-to-build
                  node-pre-gyp WARN Using request for node-pre-gyp https download
                  [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" is installed via remote
                  > @serialport/bindings@9.0.7 install /opt/iobroker/node_modules/@serialport/bindings
                  > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                  > sharp@0.26.2 install /opt/iobroker/node_modules/sharp
                  > (node install/libvips && node install/dll-copy && prebuild-install) || (node-gyp rebuild && node install/dll-copy)
                  > @serialport/bindings@9.0.4 install /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                  > @serialport/bindings@9.0.4 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                  > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
                  > node-gyp rebuild
                  make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
                    CXX(target) Release/obj.target/diskusage/src/main.o
                                   from ../src/main.cpp:3:
                  ../src/main.cpp:42:1: note: in expansion of macro 'NODE_MODULE'
                   NODE_MODULE(diskusage, Init)
                    CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
                    SOLINK_MODULE(target) Release/obj.target/diskusage.node
                    COPY Release/diskusage.node
                  make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
                  > iobroker.vis@1.3.8 install /opt/iobroker/node_modules/iobroker.vis
                  > node main.js --install
                  > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
                  > node iobroker.js setup first
                  object _design/system updated
                  The following notifications happened during sync:
                  - Ignoring Directory "hm-rega" because officially not created as meta object. Please remove directory!
                  ioBroker configuration updated
                  > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
                  > node scripts/postinstall
                  > core-js@3.10.0 postinstall /opt/iobroker/node_modules/core-js
                  > node -e "try{require('./postinstall')}catch(e){}"
                  Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                  The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                  > https://opencollective.com/core-js
                  > https://www.patreon.com/zloirock
                  Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                  > serialport@9.0.6 postinstall /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/serialport
                  > node thank-you.js
                  Thank you for using serialport!
                  If you rely on this package, please consider supporting our open collective:
                  > https://opencollective.com/serialport/donate
                  > serialport@9.0.6 postinstall /opt/iobroker/node_modules/zigbee-herdsman/node_modules/serialport
                  > node thank-you.js
                  > iobroker.javascript@5.1.3 postinstall /opt/iobroker/node_modules/iobroker.javascript
                  > node ./install/installTypings.js
                  Installing NodeJS typings...
                  latest @types: 14, installed node: 14
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  + iobroker.js-controller@3.2.16
                  added 2480 packages from 458 contributors, removed 5 packages and updated 1628 packages in 296.338s
                  137 packages are looking for funding
                    run `npm fund` for details
                  • amg_666A amg_666
                    > node-gyp rebuild
                    > node-gyp-build
                    > node-gyp rebuild
                    > node rebuild.js
                    > node-gyp-build
                    > node-gyp rebuild
                    > node thank-you.js
                    > node thank-you.js
                    @amg_666
                    Über npm installiert man das ja auch anders:
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    • amg_666A Offline
                      amg_666A Offline
                      amg_666
                      @thomas-braun im how-to steht unter Punkt 3 d) nur npm install..., da hatte ich das her.
                      Aber jetzt läufts ja, insofern ist es für mich ok.
                      • amg_666A amg_666
                        @amg_666 Mal geschaut von wann das HowTo ist?
