  4. IObroker Install NPM Err!
16 Beiträge 3 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • Markus BärenhäuserM Markus Bärenhäuser
    /usr/bin/nodejs
    v12.22.0
    /usr/bin/node
    v12.22.0
    /usr/bin/npm
    6.14.12
    nodejs:
      Installiert:           12.22.0-1nodesource1
      Installationskandidat: 12.22.0-1nodesource1
      Versionstabelle:
     *** 12.22.0-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x bionic/main amd64 Packages
         8.10.0~dfsg-2ubuntu0.4 500
            500 http://de.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages
         8.10.0~dfsg-2ubuntu0.2 500
            500 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages
         8.10.0~dfsg-2 500
            500 http://de.archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
    Markus BärenhäuserM Offline
    Markus Bärenhäuser
    curl -sL https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2021-01-23
        Welcome to the ioBroker installer!
        Installer version: 2020-12-07
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    OK:1 http://ppa.launchpad.net/elementary-os/stable/ubuntu bionic InRelease
    OK:2 http://de.archive.ubuntu.com/ubuntu bionic InRelease
    OK:3 https://deb.nodesource.com/node_12.x bionic InRelease
    OK:4 http://de.archive.ubuntu.com/ubuntu bionic-updates InRelease
    OK:5 http://ppa.launchpad.net/elementary-os/os-patches/ubuntu bionic InRelease
    OK:6 http://de.archive.ubuntu.com/ubuntu bionic-backports InRelease
    Holen:7 http://packages.elementary.io/appcenter bionic InRelease [5.908 B]
    Holen:8 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB]
    Holen:9 http://packages.elementary.io/appcenter bionic/main amd64 DEP-11 Metadata [295 kB]
    Es wurden 390 kB in 2 s geholt (196 kB/s).
    Changing npm registry to https://registry.npmjs.org
    Installed gcc-c++
        Creating ioBroker user and directory (2/4)
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    npm ERR! Unexpected end of JSON input while parsing near '...irAmZQV9hx7x0op75YpHY'
    npm ERR!     /home/frodonet/.npm/_logs/2021-04-05T16_24_38_316Z-debug.log
        Finalizing installation (4/4)
    Enabling autostart...
    Autostart enabled!
        ioBroker was installed successfully
        Open http://192.168.1.134:8081 in a browser and start configuring!
    You need to re-login before doing anything else on the console!
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      wendy2702W Online
      wendy2702W Online
      @markus-bärenhäuser hast du Node & NPM selber installiert?
      Markus BärenhäuserM 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        Markus Bärenhäuser
        @wendy2702
        Jupp und alles nach anleitung (der Aktuellen) hier im Forum
          @wendy2702
          wendy2702W Online
          wendy2702W Online
          @markus-bärenhäuser
          Warum so ein „altes“ Ubuntu?
          Warum ein Server mit GUI?
          Kannst du, wenn du das Ubuntu verwenden willst das nochmal mit einer nackten Installation starten ohne vorher Node/Npm manuell zu installieren. Das macht der installer automatisch richtig mit.
            @markus-bärenhäuser
            Markus Bärenhäuser
            @wendy2702 Das ist Elementary OS und eigendlich noch gar nicht so alt. Bin kein Linux spezi daher hatte ich davon ein VM am laufen. Muss mal schauen wie ich die Daten (iobroker-data) von der VM runterbekomme. und dann könnte ich eine einfach VM aufsetzten.. Aber ich möchte verstehen was da nicht läuft. Wollte ihn nur schnell wieder am laufen haben ... Und ich weiss ich habe vergessen die VM vor dem Update zu sichern....
              wendy2702W Online
              wendy2702W Online
              @markus-bärenhäuser
              Dann gib uns doch mal etwas mehr Infos zur Installation.
              Welche HW?
              VM, Container....?
              Was meinst du mit Backup? Hattest du schon eine laufenden iobroker Installation oder wie habe ich das zu verstehen?
                @markus-bärenhäuser
                Welche HW?
                VM, Container....?
                Markus Bärenhäuser
                @wendy2702
                Der IOBroker war auf der VM am Laufen. Seit ca mai letzten JAhres. Ich wollte das Update machen wie beschrieben und dabei ist irgend etwas schief gelaufen. Danach war der IObroker weg. Ich hatte aber die iobroker-Data aber gesichert wie auch dort beschrieben. .
                Markus BärenhäuserM wendy2702W 2 Antworten Letzte Antwort
                  @wendy2702
                  Markus Bärenhäuser
                  Sorry vergessen es ist eine VM auf einem Unraid Server. Mit einen Cord I5 8500
                  die VM bekommt 2 CPus und hat 4 GB RAM und eine 60 GB HDD.
                    @markus-bärenhäuser Stell das Grundsystem auf eine gescheite Basis. Ein Debian ohne Desktop z.B.
                    Elementary OS ist ein Desktopsystem, kein Serversystem.
                      @wendy2702
                      wendy2702W Online
                      wendy2702W Online
                      @markus-bärenhäuser sagte in IObroker Install NPM Err!:
                      Du hast davon nichts beschrieben. Dein erster Post handelt vom einer neu Installation.
                      Welches Update?
                      Wo beschrieben?
                      Was gesichert und wo steht das geschrieben?
