  4. Einige VIS Widgets aktualisieren sich nicht
    6.5k
106 Beiträge 28 Kommentatoren 28.9k Aufrufe 20 Beobachtet
    @joelli sagte in Einige VIS Widgets aktualisieren sich nicht:
    Der Ruhezustand ist deaktiviert.
    Davon gibt es Einstellungen in diversen Menüs. Je nach Android-Version und Hersteller
    Die anderen Widgets aktualisieren alle.
    Das sagt mir aber immer noch nicht welche es nicht tun
    joelli
    @Homoran
    Hab es heute nicht mehr geschafft. Werde die Tage mal meine Wdget Einstellungen posten.
    Edit:
    Hier das Widget als Export (sorry, geht bestimmt auch anders... kann das aber nicht besser):
    [{"tpl":"tplBulbOnOffCtrl","data":{"oid":"hm-rpc.0.MEQ035xxxx.1.STATE","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"icon_off":"img/bulb_off.png","icon_on":"img/bulb_on.png","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"min":"0","max":"1","visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","name":"Licht Büro Andre","lc-type":"last-change","lc-is-interval":false,"lc-is-moment":false,"lc-format":"hh:mm:ss","lc-position-vert":"bottom","lc-position-horz":"right","lc-offset-vert":"-16","lc-offset-horz":"-55","lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"lc-oid":"hm-rpc.0.MEQ035xxxx.1.STATE","g_ccontrol":false},"style":{"left":"865px","top":"825px","width":"50px","height":"50px","background-color":"#b3a66b","z-index":"3","position":"","overflow-x":"visible","overflow-y":"visible","border-radius":"20px","border-width":"2px","border-style":"solid","opacity":"0.7"},"widgetSet":"basic"}]
    Mein VIS sieht so aus:
    Hier noch der Screenshot vom Widget im VIS Editor:
    Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
    Hier gehts zur Hilfe.
    ioBroker Multihost: 1x Rock64 & 1x Raspi3+ / 2x Raspi3 RaspiMatic / 73 HM Geräte / 2x Echo 2te Gen / diverse Sonoff & ESP8266 Tasmota über mqtt / Harmony Hub / 4x MotionEye / Fritzbox 7490 / Robonect / Ventus W830
    • J joelli
      @Homoran
      Edit:
      joelli
      Hallo Leute,
      Hat jemand eine Idee?
      • JB_SullivanJ Offline
        JB_Sullivan
        Der Thread ist ja nun schon sehr alt - haben sich in der Zwischenzeit neue Erkenntnisse ergeben?
        Seit einigen Wochen wird auch meine VIS immer wieder von nicht stattfindenden Aktualisierungen heim gesucht.
        u.a. ist da auch ein VIEW dabei, was in der Form seit 2 Jahren unverändert ist. Es schaltet Sonoff Aktoren per Knopfdruck und erhält dann vom Tasmota geflashten Aktor die Rückmeldung.
        Im Datenpunkt kommt die Rückmeldung an, jedoch wird diese im VIEW nur nach Betätigung von "F5" auch angezeigt. Eine automatischen Aktualisierung findet eher sporadisch statt. Dabei spielt es keine Rolle, ob Android Tablett, iOS Tablett oder Windows PC
        Neben den hier verwendeten Widgets für die Schaltknöpfe (jqui-Icon Toggle / basic- ValueList HTML Style) ist mir dieses Phänomen auch bei Datenpunkten aufgefallen welche Zahlenwerte aktualisieren sollen. Da wäre z.B. basic-number.
        Andere Widgets wiederum aktualisieren sich wie die "wilde Wutz". Zu nennen wäre da z.B. hqwidgets - Odometer und basic string (unescped). Hier gibt es gar keine Schwierigkeiten den Inhalt des Datenpunktes zeitnah ins VIS zu schreiben.
        Wie funktioniert das überhaupt mit der Aktualisierung? Werden veränderte DP Inhalte per Broadcast ins ViS geschickt, oder holt das VIS je nach angewählter Seite die darin enthaltenen DP`s ab? Also werden nur die Datenpunkte über das Netz angefordert, die das VIE zur Darstellung benötigt?
        Wenn das der Fall ist, gibt es irgendwo eine Einstellung in welchen Intervallen die DP`s bei geöffnetem VIEW abgeholt werden sollen? Wenn sie per Broadcast ankommen, muss dem aber irgend ein Bit vorangestellt sein, was den Browser zum aktualisieren veranlaßt.
        Wäre schön, wenn jemand der "Wissenden" den ganzen Vorgang mal erklären könnte.
        • liv-in-skyL Offline
          liv-in-skyL Offline
          habt ihr mal die entwicklertools von chrome geöffnet - unter dem console tab kann man sehen, ob es zu fehlern kommt - da muss zwar nix drinstehen aber manchmal findet sich dort ein hinweis
          ich hatte schon widget, die habe darin einen fehler angezeigt bei einem widget - anschliessend, nach dem fehler, wurde der rest der view nicht mehr richtig geladen
          Gurke258G 1 Antwort Letzte Antwort
          • liv-in-skyL liv-in-sky
            Gurke258G Offline
            Gurke258G Offline
            Gurke258
            schrieb am zuletzt editiert von Gurke258
            Ich habe vorhin auch nen Thread eröffnet mit nem ähnlichen Thema:
            https://forum.iobroker.net/topic/43789/vis-keine-aktualisierung-mehr
            Der Tipp mit Chrome ist interessant, müsste ich mal testen.
            Edit:
            Nach dem diese Meldung kommt, gehts nicht mehr. Hab jetzt in der Console des Browsers geschaut.
            Error: Error: can't create states object for hm-rpc.0.LEQ1483852.1.TEMPERATURE(TypeError: Cannot read property 'toFixed' of undefined): "TypeError: Cannot read property 'toFixed' of undefined\n    at update (http://localhost:8082/vis/widgets/vis-material-advanced/js/vis-material-advanced.js:263:52)\n    at a.<anonymous> (http://localhost:8082/vis/widgets/vis-material-advanced/js/vis-material-advanced.js:270:17)\n    at a.t.dispatch (http://localhost:8082/vis/lib/js/can.custom.min.js:18:1252)\n    at Object.stop (http://localhost:8082/vis/lib/js/can.custom.min.js:44:451)\n    at a._setAttrs (http://localhost:8082/vis/lib/js/can.custom.min.js:48:4021)\n    at attr (http://localhost:8082/vis/lib/js/can.custom.min.js:48:1571)\n    at Object.updateState (http://localhost:8082/vis/js/vis.js:2899:29)\n    at http://localhost:8082/vis/js/vis.js:3456:21\n    at http://localhost:8082/vis/js/vis.js:3668:9"
              JB_Sullivan
              schrieb am zuletzt editiert von JB_Sullivan
              Ich habe auch mal F12 gedrückt - OH, da ist immer irgend etwas rot UND vor allen Dingen ist mir aufgefallen, das offensichtlich das gesamte VIS Projekt geladen wird, auch wenn man nur eine Seite aufruft.
              Wenn es dann irgendwo im Projekt harkt, bleiben vielleicht auch Sachen auf der Strecke die eigentlich aktualisiert werden müssen.
              Hier mal ein Beispiel, was u.a. so an Fehlermeldungen ausgegeben wird.
              DevTools failed to load SourceMap: Could not load content for http://10.122.60.87:8082/lib/js/socket.io.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
              VM1157 index.html:4040 Version vis-canvas-gauges: 0.1.5
              VM1162 index.html:4580 Version vis-colorpicker: 1.2.0
              fritzdect.js:46 Version fritzdect: 0.0.2
              info.js:21 Version Info-Adapter-Widget: 0.0.9
              index.html:6487 Version vis-jqui-mfd: 1.0.12
              justgage.js:115 Version justgage: 1.0.2
              index.html#001_Main:1 Failed to find a valid digest in the 'integrity' attribute for resource 'http://10.122.60.87:8082/vis/widgets/materialdesign/lib/raw/sentry/bundle.min.js' with computed SHA-256 integrity 'J7PbSqMvbqR4Xaqpc8fyJq+uNYam02vi6B8830eoFtA='. The resource has been blocked.
              lib.min.js:43 Download the Vue Devtools extension for a better development experience:
              https://github.com/vuejs/vue-devtools
              lib.min.js:43 You are running Vue in development mode.
              Make sure to turn on production mode when deploying for production.
              See more tips at https://vuejs.org/guide/deployment.html
              index.html:12042 Version vis-plumb: 1.0.0
              trashschedule.js:130 Version trashschedule: 1.0.3
              conn.js:305 2021-04-01T16:35:14.371Z Connected => authenticate
              conn.js:326 2021-04-01T16:35:14.467Z Authenticated: true
              materialdesign.js:33 Version vis-materialdesign: 0.5.1-beta
              widgets.min.js:1 Uncaught (in promise) TypeError: Sentry.init is not a function
                  at Object._initializeSentry (widgets.min.js:1)
                  at Object.initializeSentry (widgets.min.js:1)
              Hier noch so ein Block - Bohh ist ja alles Voll mit Fehlermeldungen - na dafür läuft das Projekt aber noch ganz ordentlich 😁 😁
              Version vis-hqwidgets: 1.1.7
              conn.js:1256 Error: can't render tplJscolor w02776 on "070_PV_Anlage":
              conn.js:1256 Error: 0 - TypeError: str.match is not a functionTypeError: str.match is not a function
              conn.js:1256 Error: 1 -     at jscolor.fromString (http://10.122.60.87:8082/vis/widgets/colorpicker/js/jscolor.js:1190:17)
              conn.js:1256 Error: 2 -     at _rgbChanged (http://10.122.60.87:8082/vis/index.html:4678:28)
              conn.js:1256 Error: 3 -     at Object.jscolor (http://10.122.60.87:8082/vis/index.html:4683:17)
              conn.js:1256 Error: 4 -     at Object.eval (tplJscolor.js:53:83)
              conn.js:1256 Error: 5 -     at Function.<anonymous> (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:64:6166)
              conn.js:1256 Error: 6 -     at Object.a.each (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:24:294)
              conn.js:1256 Error: 7 -     at http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:64:6147
              conn.js:1256 Error: 8 -     at HTMLInputElement.<anonymous> (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:58:1841)
              conn.js:1256 Error: 9 -     at Object.a.each (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:24:294)
              conn.js:1256 Error: 10 -     at Function.hookup (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:58:1751)
              conn.js:1256 Error: Error: can't create states object for fronius.0.powerflow.inverter1.SOC(TypeError: str.match is not a function): "TypeError: str.match is not a function\n    at jscolor.fromString (http://10.122.60.87:8082/vis/widgets/colorpicker/js/jscolor.js:1190:17)\n    at a._rgbChanged (http://10.122.60.87:8082/vis/index.html:4678:28)\n    at a.t.dispatch (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:18:1252)\n    at Object.stop (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:44:451)\n    at a._setAttrs (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:48:4021)\n    at attr (http://10.122.60.87:8082/vis/lib/js/can.custom.min.js:48:1571)\n    at Object.updateState (http://10.122.60.87:8082/vis/js/vis.js:2923:29)\n    at http://10.122.60.87:8082/vis/js/vis.js:3480:21\n    at http://10.122.60.87:8082/vis/js/vis.js:3697:9"
              vis.js:3051 Uncaught DOMException: Blocked a frame with origin "http://10.122.60.87:8082" from accessing a cross-origin frame.
                  at HTMLIFrameElement.<anonymous> (http://10.122.60.87:8082/vis/js/vis.js:3051:40)
                  at Function.each (http://10.122.60.87:8082/lib/js/jquery-1.11.2.min.js:2:2975)
                  at m.fn.init.each (http://10.122.60.87:8082/lib/js/jquery-1.11.2.min.js:2:835)
                  at Object.updateIframeZoom (http://10.122.60.87:8082/vis/js/vis.js:3050:25)
                  at Object.postChangeView (http://10.122.60.87:8082/vis/js/vis.js:1931:14)
                  at http://10.122.60.87:8082/vis/js/vis.js:1866:26
                  at http://10.122.60.87:8082/vis/js/vis.js:955:35
                  at Object.renderViews (http://10.122.60.87:8082/vis/js/vis.js:785:27)
                  at http://10.122.60.87:8082/vis/js/vis.js:791:18
                  at http://10.122.60.87:8082/vis/js/vis.js:974:35
              (anonymous) @ vis.js:3051
              each @ jquery-1.11.2.min.js:2
              updateIframeZoom @ vis.js:3050
              postChangeView @ vis.js:1931
              (anonymous) @ vis.js:1866
              (anonymous) @ vis.js:955
              renderViews @ vis.js:785
              (anonymous) @ vis.js:791
              (anonymous) @ vis.js:974
              setTimeout (async)
              (anonymous) @ vis.js:972
              subscribeStates @ vis.js:2841
              renderView @ vis.js:828
              renderViews @ vis.js:790
              setTimeout (async)
              (anonymous) @ vis.js:946
              (anonymous) @ vis.js:2865
              (anonymous) @ conn.js:801
              r.onack @ socket.io.js:8
              r.onpacket @ socket.io.js:8
              (anonymous) @ socket.io.js:8
              r.emit @ socket.io.js:6
              r.ondecoded @ socket.io.js:6
              a.add @ socket.io.js:6
              r.ondata @ socket.io.js:6
              r.onPacket @ socket.io.js:6
              (anonymous) @ socket.io.js:6
              r.onPacket @ socket.io.js:7
              r.onData @ socket.io.js:7
              ws.onmessage @ socket.io.js:8
              instrument.js:109 DashboardModel.on is deprecated use events.subscribe
              • Gurke258G Gurke258
                Edit:
                liv-in-skyL Offline
                liv-in-skyL Offline
                @gurke258
                scheint das evtl. eine formel in einem widget nicht funktioniert - toFixed() wird ausgeführt, aber dar wert ist undefined
                  @gurke258
                  Gurke258G Offline
                  Gurke258G Offline
                  Gurke258
                  @liv-in-sky
                  Ist aber merkwürdig, da der Adapter ja den realen Wert liefert. Scheint demzufolge am Widget zu liegen?!
                  • JB_SullivanJ JB_Sullivan
                    setTimeout (async)
                    setTimeout (async)
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    @jb_sullivan sagte in Einige VIS Widgets aktualisieren sich nicht:
                    kannst du das widget zuerst exportiern, zwischenspeichern und anschliessend löschen ?
                      @liv-in-sky
                      liv-in-skyL Offline
                      liv-in-skyL Offline
                      @gurke258 das können wohl am besten die ersteller des adapters beantworten - weißt du denn welches widget es ist- kann ich nicht rauslesen
                        Gurke258G Offline
                        Gurke258G Offline
                        Gurke258
                        @liv-in-sky
                        Jap -> https://github.com/iobroker-community-adapters/ioBroker.vis-material-advanced/issues/24
                        habe dem Entwickler schon geschrieben.
                          @liv-in-sky
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @gurke258
                          hast du darin ein binding ?
                            @gurke258
                            Gurke258G Offline
                            Gurke258G Offline
                            Gurke258
                            @liv-in-sky
                            in wie fern? Ich habe das Widget eingebunden ja, aber nicht nur 1x sondern 5x. Und es scheint nur bei dem einen probleme zu machen.
                            liv-in-skyL 3 Antworten Letzte Antwort
                              @liv-in-sky
                              liv-in-skyL Offline
                              liv-in-skyL Offline
                              @gurke258 kannst du es löschen und neu erstellen - manchmal hilft das
                                @liv-in-sky
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @gurke258 wenn du es löscht, mach einen browser refresh des vis-editor tabs - damit sicher ist, dass es weg ist - ich mußte schon im filesystem widgets löschen, weil sie nicht mehr über den editor löschbar waren
                                  @liv-in-sky
                                  liv-in-skyL Offline
                                  liv-in-skyL Offline
                                  @gurke258 noch ne frage - ist der datenpunkt vom typ number oder string - der fixed befehl kann nur auf numbers angewendet werden (soviel ich weiß)
                                    Gurke258G Offline
                                    Gurke258G Offline
                                    Gurke258
                                    @liv-in-sky
                                    ist gelöscht, aktualisiert und neu hinzugefügt ^^
                                    Trotzdem noch das Problem
                                      @liv-in-sky
                                      liv-in-skyL Offline
                                      liv-in-skyL Offline
                                      @gurke258 gesehen ? https://forum.iobroker.net/post/608362
                                        Gurke258G Offline
                                        Gurke258G Offline
                                        Gurke258
                                        @liv-in-sky
                                        Ja gesehen ^^ Nur warst du schneller im fragen als ich im Antworten... ^^
                                        Scheint Number zu sein. Immerhin funktioniert es ja bei den anderen 4 ohne Fehlern.
                                          @liv-in-sky
                                          liv-in-skyL Offline
                                          liv-in-skyL Offline
                                          @gurke258 wenn du dem problem-widget einen anderen dp gibst - funktioniert es dann -wenn ja könntest du auf git noch den raw des dp posten - evtl stimmt da was nicht
