  4. Sammlung Informationen Wallbox & ioBroker-Integration
    6.4k
wallboxphotovoltaikelektromobilität
192 Beiträge 23 Kommentatoren 49.2k Aufrufe 23 Beobachtet
  • Q Qlink
    @sneak-l8
    @sneak-l8
    done
    Kann es sein, dass er eventuell die Werte von meinem Energymeter nicht richtig interpretieren kann, sprich das die im falschen Format sind oder sowas ähnliches ?
    2021-03-26 09:49:36.408  - info: host.iob01 stopInstance system.adapter.kecontact.0 (force=false, process=true)
    2021-03-26 09:49:36.424  - info: kecontact.0 (1448) Got terminate signal TERMINATE_YOURSELF
    2021-03-26 09:49:36.424  - info: kecontact.0 (1448) terminating
    2021-03-26 09:49:36.424  - info: kecontact.0 (1448) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-03-26 09:49:36.424  - info: host.iob01 stopInstance system.adapter.kecontact.0 send kill signal
    2021-03-26 09:49:37.044  - info: host.iob01 instance system.adapter.kecontact.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-03-26 09:49:39.441  - info: host.iob01 instance system.adapter.kecontact.0 started with pid 2236
    2021-03-26 09:49:40.130  - debug: kecontact.0 (2236) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-03-26 09:49:40.145  - debug: kecontact.0 (2236) Objects client ready ... initialize now
    2021-03-26 09:49:40.145  - debug: kecontact.0 (2236) Objects create System PubSub Client
    2021-03-26 09:49:40.161  - debug: kecontact.0 (2236) Objects create User PubSub Client
    2021-03-26 09:49:40.161  - debug: kecontact.0 (2236) Objects client initialize lua scripts
    2021-03-26 09:49:40.161  - debug: kecontact.0 (2236) Objects connected to redis: 127.0.0.1:9001
    2021-03-26 09:49:40.177  - debug: kecontact.0 (2236) objectDB connected
    2021-03-26 09:49:40.177  - debug: kecontact.0 (2236) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-03-26 09:49:40.177  - debug: kecontact.0 (2236) States create System PubSub Client
    2021-03-26 09:49:40.177  - debug: kecontact.0 (2236) States create User PubSub Client
    2021-03-26 09:49:40.192  - debug: kecontact.0 (2236) States connected to redis: 127.0.0.1:9000
    2021-03-26 09:49:40.192  - debug: kecontact.0 (2236) statesDB connected
    2021-03-26 09:49:40.458  - info: kecontact.0 (2236) starting. Version 1.1.1 in C:/iobroker/iob01/node_modules/iobroker.kecontact, node: v10.17.0, js-controller: 3.2.16
    2021-03-26 09:49:45.483  - info: kecontact.0 (2236) starting charging station in active mode
    2021-03-26 09:49:45.483  - info: kecontact.0 (2236) minimum amperage not speficied or too low, using default value of 6000
    2021-03-26 09:49:45.483  - debug: kecontact.0 (2236) UDP server listening on 0.0.0.0:7090
    2021-03-26 09:49:45.483  - debug: kecontact.0 (2236) UDP broadcast server listening on 0.0.0.0:7092
    2021-03-26 09:49:45.483  - debug: kecontact.0 (2236) subscribe state sma-em.0.1901701237.pregard - current value: 0
    2021-03-26 09:49:45.483  - debug: kecontact.0 (2236) update state kecontact.0.sma-em.0.1901701237.pregard with value:0
    2021-03-26 09:49:45.483  - debug: kecontact.0 (2236) subscribe state sma-em.0.1901701237.psurplus - current value: 5270.200000000001
    2021-03-26 09:49:45.483  - debug: kecontact.0 (2236) update state kecontact.0.sma-em.0.1901701237.psurplus with value:5270.200000000001
    2021-03-26 09:49:45.702  - debug: kecontact.0 (2236) Sent "i" to 192.168.30.15:7090
    2021-03-26 09:49:45.702  - debug: kecontact.0 (2236) UDP datagram from 192.168.30.15:7090: ""Firmware":"P30 v 3.10.16 (200708-201734)""
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.eTotal with value:66878.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.ePres with value:1378
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.pf with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.p with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.i3 with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.i2 with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.i1 with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.u3 with value:235
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.u2 with value:238
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.u1 with value:236
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.uptime with value:1466410
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.input with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.output with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.timeoutFailsafe with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.currentFailsafe with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.currentUser with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.maxCurrentPercent with value:33.3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.maxCurrent with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.enableUser with value:true
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.enableSys with value:true
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.plug with value:7
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.error2 with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.error1 with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.state with value:2
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.firmware with value:P30 v 3.10.16 (200708-201734)
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.product with value:KC-P30-ES2400B2-M0R
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.display with value:volle Ladeleistung
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.automatic.pauseWallbox with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.automatic.photovoltaics with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.plugTimestamp with value:2021-03-26T08:33:36.975Z
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.chargeTimestamp with value:2021-03-26T08:34:08.222Z
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.lastChargeStart with value:2021-03-25T11:37:39.198Z
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.lastChargeFinish with value:2021-03-25T14:47:01.716Z
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.lastChargeAmount with value:15.0547
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.COM-module with value:true
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.backend with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.DIP-Sw1 with value:0x26
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.DIP-Sw2 with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.currentTimer with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.timeoutCurrentTimer with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.setenergy with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.authON with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.authreq with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.automatic.addPower with value:500
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.surplus with value:null
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.maxPower with value:false
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.statistics.chargingPhases with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.json with value:[{"ID":"100","Session ID":9,"Curr HW":20000,"E start":655001,"E pres":13780,"started[s]":1616747606,"ended[s]":0,"started":"2021-03-26 08:33:26.000","ended":"0","reason":0,"timeQ":0,"RFID tag":"0000000000000000","RFID class":"f4d82c69000000000000","Serial":"20296767","Sec":1466411}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.sessionid with value:9
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.eStart with value:65500.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.ePres with value:1378
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.started_s with value:1616747606
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.ended_s with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.started with value:2021-03-26 08:33:26.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.ended with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.reason with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.timeQ with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.rfid_class with value:f4d82c69000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_00.sec with value:1466411
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.json with value:[{"ID":"101","Session ID":8,"Curr HW":20000,"E start":504454,"E pres":150547,"started[s]":1616672249,"ended[s]":1616683611,"started":"2021-03-25 11:37:29.000","ended":"2021-03-25 14:46:51.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"9b07e84a000000000000","Serial":"20296767","Sec":1466411}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.sessionid with value:8
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.eStart with value:50445.4
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.ePres with value:15054.7
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.started_s with value:1616672249
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.ended_s with value:1616683611
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.started with value:2021-03-25 11:37:29.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.ended with value:2021-03-25 14:46:51.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.rfid_class with value:9b07e84a000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_01.sec with value:1466411
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.json with value:[{"ID":"102","Session ID":7,"Curr HW":20000,"E start":322901,"E pres":181553,"started[s]":1616164422,"ended[s]":1616175449,"started":"2021-03-19 14:33:42.000","ended":"2021-03-19 17:37:29.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"fe1e8b2b000000000000","Serial":"20296767","Sec":1466411}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.sessionid with value:7
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.eStart with value:32290.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.ePres with value:18155.3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.started_s with value:1616164422
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.ended_s with value:1616175449
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.started with value:2021-03-19 14:33:42.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.ended with value:2021-03-19 17:37:29.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.rfid_class with value:fe1e8b2b000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_02.sec with value:1466411
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.json with value:[{"ID":"103","Session ID":6,"Curr HW":20000,"E start":222666,"E pres":100235,"started[s]":1615638239,"ended[s]":1615648318,"started":"2021-03-13 12:23:59.000","ended":"2021-03-13 15:11:58.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"76e4d316000000000000","Serial":"20296767","Sec":1466412}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.sessionid with value:6
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.eStart with value:22266.6
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.ePres with value:10023.5
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.started_s with value:1615638239
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.ended_s with value:1615648318
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.started with value:2021-03-13 12:23:59.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.ended with value:2021-03-13 15:11:58.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.rfid_class with value:76e4d316000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_03.sec with value:1466412
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.json with value:[{"ID":"104","Session ID":5,"Curr HW":20000,"E start":181890,"E pres":40776,"started[s]":1615290689,"ended[s]":1615294745,"started":"2021-03-09 11:51:29.000","ended":"2021-03-09 12:59:05.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"76e4d316000000000000","Serial":"20296767","Sec":1466412}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.sessionid with value:5
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.eStart with value:18189
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.ePres with value:4077.6
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.started_s with value:1615290689
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.ended_s with value:1615294745
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.started with value:2021-03-09 11:51:29.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.ended with value:2021-03-09 12:59:05.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.rfid_class with value:76e4d316000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_04.sec with value:1466412
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.json with value:[{"ID":"105","Session ID":4,"Curr HW":20000,"E start":133509,"E pres":48381,"started[s]":1615207786,"ended[s]":1615212627,"started":"2021-03-08 12:49:46.000","ended":"2021-03-08 14:10:27.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"b9ca830c000000000000","Serial":"20296767","Sec":1466412}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.sessionid with value:4
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.eStart with value:13350.9
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.ePres with value:4838.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.started_s with value:1615207786
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.ended_s with value:1615212627
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.started with value:2021-03-08 12:49:46.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.ended with value:2021-03-08 14:10:27.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.rfid_class with value:b9ca830c000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_05.sec with value:1466412
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.json with value:[{"ID":"106","Session ID":3,"Curr HW":20000,"E start":32654,"E pres":100855,"started[s]":1615117666,"ended[s]":1615127564,"started":"2021-03-07 11:47:46.000","ended":"2021-03-07 14:32:44.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"82c4800c000000000000","Serial":"20296767","Sec":1466413}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.sessionid with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.eStart with value:3265.4
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.ePres with value:10085.5
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.started_s with value:1615117666
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.ended_s with value:1615127564
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.started with value:2021-03-07 11:47:46.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.ended with value:2021-03-07 14:32:44.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.rfid_class with value:82c4800c000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_06.sec with value:1466413
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.json with value:[{"ID":"107","Session ID":2,"Curr HW":20000,"E start":32654,"E pres":0,"started[s]":1615117466,"ended[s]":1615117659,"started":"2021-03-07 11:44:26.000","ended":"2021-03-07 11:47:39.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"fdfe073f000000000000","Serial":"20296767","Sec":1466413}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.sessionid with value:2
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.eStart with value:3265.4
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.ePres with value:0
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.started_s with value:1615117466
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.ended_s with value:1615117659
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.started with value:2021-03-07 11:44:26.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.ended with value:2021-03-07 11:47:39.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.rfid_class with value:fdfe073f000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_07.sec with value:1466413
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.json with value:[{"ID":"108","Session ID":1,"Curr HW":20000,"E start":2269,"E pres":30385,"started[s]":1613817709,"ended[s]":1613818767,"started":"2021-02-20 10:41:49.000","ended":"2021-02-20 10:59:27.000","reason":1,"timeQ":3,"RFID tag":"0000000000000000","RFID class":"fdfe073f000000000000","Serial":"20296767","Sec":1466413}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.sessionid with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.currentHardware with value:20000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.eStart with value:226.9
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.ePres with value:3038.5
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.started_s with value:1613817709
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.ended_s with value:1613818767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.started with value:2021-02-20 10:41:49.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.ended with value:2021-02-20 10:59:27.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.reason with value:1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.timeQ with value:3
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.rfid_class with value:fdfe073f000000000000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_08.sec with value:1466413
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.json with value:[{"ID":"109","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466414}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.sessionid with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.currentHardware with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.eStart with value:-0.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.ePres with value:-0.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.started_s with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.ended_s with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.reason with value:255
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.timeQ with value:255
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_09.sec with value:1466414
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.json with value:[{"ID":"110","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466414}]
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.sessionid with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.currentHardware with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.eStart with value:-0.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.ePres with value:-0.1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.started_s with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.ended_s with value:-1
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.reason with value:255
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.timeQ with value:255
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.serial with value:20296767
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_10.sec with value:1466414
    2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.json with value:[{"ID":"111","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466414}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_11.sec with value:1466414
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.json with value:[{"ID":"112","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466414}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_12.sec with value:1466414
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.json with value:[{"ID":"113","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466385}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_13.sec with value:1466385
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.json with value:[{"ID":"114","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466385}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_14.sec with value:1466385
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.json with value:[{"ID":"115","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466385}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_15.sec with value:1466385
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.json with value:[{"ID":"116","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466386}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_16.sec with value:1466386
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.json with value:[{"ID":"117","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466386}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_17.sec with value:1466386
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.json with value:[{"ID":"118","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466386}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_18.sec with value:1466386
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.json with value:[{"ID":"119","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466387}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_19.sec with value:1466387
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.json with value:[{"ID":"120","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466387}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_20.sec with value:1466387
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.json with value:[{"ID":"121","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466387}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_21.sec with value:1466387
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.json with value:[{"ID":"122","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466388}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_22.sec with value:1466388
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.json with value:[{"ID":"123","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466388}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_23.sec with value:1466388
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.json with value:[{"ID":"124","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466388}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_24.sec with value:1466388
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.json with value:[{"ID":"125","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466389}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_25.sec with value:1466389
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.json with value:[{"ID":"126","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466389}]
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.sessionid with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.currentHardware with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.eStart with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.ePres with value:-0.1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.started_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.ended_s with value:-1
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.reason with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.timeQ with value:255
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.serial with value:20296767
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_26.sec with value:1466389
    2021-03-26 09:49:45.748  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.json with value:[{"ID":"127","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466389}]
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.sessionid with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.currentHardware with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.eStart with value:-0.1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.ePres with value:-0.1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.started_s with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.ended_s with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.reason with value:255
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.timeQ with value:255
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.serial with value:20296767
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_27.sec with value:1466389
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.json with value:[{"ID":"128","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466389}]
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.sessionid with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.currentHardware with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.eStart with value:-0.1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.ePres with value:-0.1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.started_s with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.ended_s with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.reason with value:255
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.timeQ with value:255
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.serial with value:20296767
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_28.sec with value:1466389
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.json with value:[{"ID":"129","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466390}]
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.sessionid with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.currentHardware with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.eStart with value:-0.1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.ePres with value:-0.1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.started_s with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.ended_s with value:-1
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.started with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.ended with value:2106-02-07 06:28:15.000
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.reason with value:255
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.timeQ with value:255
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.rfid_class with value:ffffffffffffffffffff
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.serial with value:20296767
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_29.sec with value:1466390
    2021-03-26 09:49:45.764  - debug: kecontact.0 (2236) update state kecontact.0.Sessions.Session_30.json with value:[{"ID":"130","Session ID":-1,"Curr HW":-1,"E start":-1,"E pres":-1,"started[s]":-1,"ended[s]":-1,"started":"2106-02-07 06:28:15.000","ended":"2106-02-07 06:28:15.000","reason":255,"timeQ":255,"RFID tag":"ffffffffffffffff","RFID class":"ffffffffffffffffffff","Serial":"20296767","Sec":1466390}]
    Sneak-L8
    #95
    @qlink Leider hat es den Spoiler etwas durcheinander gebracht. Man muss ihn zigmal öffnen. Evlt. liegt es dara, dass der Output nicht mit "Code" markiert ist. Kannst Du das ändern? Dann kann ich ihn mir ansehen ohne erst 100 mal klicken zu müssen.
    Q 1 Antwort Letzte Antwort
    • S Sneak-L8
      Q Offline
      Q Offline
      Qlink
      #96
      @sneak-l8
      habs grad aktualisiert mit code tag ...
      • Q Qlink
        @sneak-l8
        Sneak-L8
        #97
        @qlink So, hab's gerade entdeckt. Ganz trivial...
        2021-03-26 09:49:45.733  - debug: kecontact.0 (2236) update state kecontact.0.display with value:volle Ladeleistung
        Du hast den state kecontact.0.automatic.photovoltaics auf false sitzen, dann liefert die Wallbox immer die volle Leistung. Diesen Schalter auf true setzen und schon sollte es funktionieren.
        Um den Zustand leicht zu erkennen, wird der Zustand auch immer am Wallbox-Display angezeigt.
        Bei der Gelegenheit habe ich (für eine künftige Version) den Default-Wert auf Automatik = an gestellt.
        • S Sneak-L8
          Q Offline
          Q Offline
          Qlink
          #98
          @sneak-l8
          Vielen Dank für deine Hilfe.
          Das war die Ursache!
          Jetzt funktionierts genau wie eingestellt.
          Genialer Adapter!
          Beste Grüße
          • Q Offline
            Q Offline
            Qlink
            #99
            @Sneak-L8
            Hab mich doch wohl etwas zu früh gefreut, oder verstehe ich die Settings eventuell wieder falsch.
            Ich habe bei Mindestladezeit 7200s eingestellt.
            Sollte er dann nicht, egal wie die aktuelle PV Situation aussieht, auf jeden Fall mal 2h laden... ?
            Ich hab gerade angesteckt und er stoppt von selbst nach kurzer Zeit den Ladevorgang, weil Ladeunterschreitung ...
            kecontact.0	2021-03-29 13:59:08.892	info	(4876) stop charging
            kecontact.0	2021-03-29 13:58:38.876	info	(4876) dynamic adaption of charging to 6000 mA
            kecontact.0	2021-03-29 13:53:08.772	info	(4876) stop charging
            kecontact.0	2021-03-29 13:52:38.763	info	(4876) dynamic adaption of charging to 8500 mA
            kecontact.0	2021-03-29 13:52:08.762	info	(4876) dynamic adaption of charging to 7000 mA
            kecontact.0	2021-03-29 13:51:38.749	info	(4876) stop charging
            kecontact.0	2021-03-29 13:50:38.730	info	(4876) dynamic adaption of charging to 6500 mA
            kecontact.0	2021-03-29 13:50:08.720	info	(4876) dynamic adaption of charging to 6000 mA
            kecontact.0	2021-03-29 13:49:38.711	info	(4876) dynamic adaption of charging to 7000 mA
            kecontact.0	2021-03-29 13:48:38.694	info	(4876) dynamic adaption of charging to 6500 mA
            kecontact.0	2021-03-29 13:48:08.683	info	(4876) dynamic adaption of charging to 6000 mA
            kecontact.0	2021-03-29 13:47:38.670	info	(4876) dynamic adaption of charging to 7500 mA
            kecontact.0	2021-03-29 13:47:08.662	info	(4876) dynamic adaption of charging to 7000 mA
            kecontact.0	2021-03-29 13:46:38.654	info	(4876) dynamic adaption of charging to 6500 mA
            kecontact.0	2021-03-29 13:46:08.649	info	(4876) dynamic adaption of charging to 6000 mA
            kecontact.0	2021-03-29 13:45:38.640	info	(4876) dynamic adaption of charging to 6500 mA
            kecontact.0	2021-03-29 13:45:08.626	info	(4876) dynamic adaption of charging to 7000 mA
            kecontact.0	2021-03-29 13:44:38.613	info	(4876) dynamic adaption of charging to 8000 mA
            kecontact.0	2021-03-29 13:44:08.596	info	(4876) dynamic adaption of charging to 7500 mA
            kecontact.0	2021-03-29 13:43:38.590	info	(4876) stop charging
            kecontact.0	2021-03-29 13:42:38.576	info	(4876) stop charging
            kecontact.0	2021-03-29 13:42:08.573	info	(4876) dynamic adaption of charging to 8500 mA
            kecontact.0	2021-03-29 13:41:38.564	info	(4876) stop charging
            kecontact.0	2021-03-29 13:41:08.551	info	(4876) dynamic adaption of charging to 9500 mA
            kecontact.0	2021-03-29 13:40:38.542	info	(4876) stop charging
            kecontact.0	2021-03-29 13:40:03.020	info	(4876) dynamic adaption of charging to 8500 mA
            kecontact.0	2021-03-29 13:40:03.020	info	(4876) vehicle plugged to wallbox
            • Q Qlink
              @Sneak-L8
              Sneak-L8
              #100
              @qlink was mich wundert, ist dass bei Dir der Logeintrag "vehicle (re)starts to charge" fehlt. So sieht es bei mir aus:
              kecontact.0	2021-03-29 13:31:07.605	info	(11211) dynamic adaption of charging to 9500 mA
              kecontact.0	2021-03-29 13:30:37.603	info	(11211) dynamic adaption of charging to 11500 mA
              kecontact.0	2021-03-29 13:29:07.600	info	(11211) vehicle (re)starts to charge
              kecontact.0	2021-03-29 13:29:07.599	info	(11211) dynamic adaption of charging to 8500 mA
              kecontact.0	2021-03-29 13:28:37.596	info	(11211) dynamic adaption of charging to 7500 mA
              kecontact.0	2021-03-29 13:28:37.587	info	(11211) vehicle plugged to wallbox
              Dadurch wird der Startzeitpunkt fürs Laden nicht initialisiert und liegt weit in der Vergangenheit. Dann sind die 7200 Sekunden immer schon um. Findest Du in einem älteren Log den Eintrag, dass das Laden gestartet wurde? Musst ggfs. auch die Tage davor anschauen. Ist da dann was Auffäligen drumherum zu sehen?
              • S Sneak-L8
                Q Offline
                Q Offline
                Qlink
                #101
                @sneak-l8 said in Sammlung Informationen Wallbox & ioBroker-Integration:
                (re)starts
                Hab den Eintrag im Log vor 3 Tagen gefunden:
                2021-03-26 09:33:36.970  - info: kecontact.0 (1804) vehicle plugged to wallbox
                2021-03-26 09:34:08.222  - info: kecontact.0 (1804) vehicle (re)starts to charge
                2021-03-26 09:39:11.134  - info: host.iob01 stopInstance system.adapter.kecontact.0 (force=false, process=true)
                2021-03-26 09:39:11.135  - info: kecontact.0 (1804) Got terminate signal TERMINATE_YOURSELF
                2021-03-26 09:39:11.135  - info: kecontact.0 (1804) terminating
                2021-03-26 09:39:11.135  - info: kecontact.0 (1804) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-03-26 09:39:11.134  - info: host.iob01 stopInstance system.adapter.kecontact.0 send kill signal
                2021-03-26 09:39:11.810  - info: host.iob01 instance system.adapter.kecontact.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-03-26 09:39:14.172  - info: host.iob01 instance system.adapter.kecontact.0 started with pid 10068
                2021-03-26 09:39:15.174  - info: kecontact.0 (10068) starting. Version 1.1.1 in C:/iobroker/iob01/node_modules/iobroker.kecontact, node: v10.17.0, js-controller: 3.2.16
                2021-03-26 09:39:20.206  - info: kecontact.0 (10068) starting charging station in active mode
                2021-03-26 09:39:20.206  - info: kecontact.0 (10068) minimum amperage not speficied or too low, using default value of 6000
                2021-03-26 09:44:52.430  - info: host.iob01 stopInstance system.adapter.kecontact.0 (force=false, process=true)
                2021-03-26 09:44:52.431  - info: kecontact.0 (10068) Got terminate signal TERMINATE_YOURSELF
                2021-03-26 09:44:52.431  - info: kecontact.0 (10068) terminating
                2021-03-26 09:44:52.431  - info: kecontact.0 (10068) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-03-26 09:44:52.430  - info: host.iob01 stopInstance system.adapter.kecontact.0 send kill signal
                2021-03-26 09:44:53.086  - info: host.iob01 instance system.adapter.kecontact.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-03-26 09:44:55.459  - info: host.iob01 instance system.adapter.kecontact.0 started with pid 1448
                2021-03-26 09:44:56.117  - debug: kecontact.0 (1448) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2021-03-26 09:44:56.133  - debug: kecontact.0 (1448) Objects client ready ... initialize now
                2021-03-26 09:44:56.148  - debug: kecontact.0 (1448) Objects create System PubSub Client
                2021-03-26 09:44:56.148  - debug: kecontact.0 (1448) Objects create User PubSub Client
                2021-03-26 09:44:56.148  - debug: kecontact.0 (1448) Objects client initialize lua scripts
                2021-03-26 09:44:56.164  - debug: kecontact.0 (1448) Objects connected to redis: 127.0.0.1:9001
                2021-03-26 09:44:56.164  - debug: kecontact.0 (1448) objectDB connected
                2021-03-26 09:44:56.164  - debug: kecontact.0 (1448) Redis States: Use Redis connection: 127.0.0.1:9000
                2021-03-26 09:44:56.179  - debug: kecontact.0 (1448) States create System PubSub Client
                2021-03-26 09:44:56.179  - debug: kecontact.0 (1448) States create User PubSub Client
                2021-03-26 09:44:56.179  - debug: kecontact.0 (1448) States connected to redis: 127.0.0.1:9000
                2021-03-26 09:44:56.179  - debug: kecontact.0 (1448) statesDB connected
                2021-03-26 09:44:56.367  - info: kecontact.0 (1448) starting. Version 1.1.1 in C:/iobroker/iob01/node_modules/iobroker.kecontact, node: v10.17.0, js-controller: 3.2.16
                • Q Qlink
                  (re)starts
                  Sneak-L8
                  #102
                  @qlink Schau mal bitte in den State nach plugTiemstamp. Ist der gefüllt? Dann erkennt der Adapter nicht, dass das Fahrzeug zwischenzeitlich abgestekt wurde. Beim Anstecken sollte der state aber auf "null" gesetzt werden...
                  • S Sneak-L8
                    Q Offline
                    Q Offline
                    Qlink
                    #103
                    @sneak-l8
                    Der ist aktuell nicht gefüllt...ist auch aktuell nix angesteckt.
                    • Q Qlink
                      @sneak-l8
                      Sneak-L8
                      #104
                      @qlink Und wenn Du jetzt wieder einsteckst gibt es auch keine Mindestladezeit? Die States sehen eigentlich alle gut aus.
                      Bitte mal nochmal Deine kompletten Einstellungen des Adapters und ein Log vom Einstecken, Ladeunterschreitung und Ausstecken. Bitteauch die State vor/nach Einstecken und um den Zeitpunkt der Ladeunterschreitung.
                      Kann mir gerade so keinen Reim drauf machen, was das Problem ist ...
                      • S Sneak-L8
                        Q Offline
                        Q Offline
                        Qlink
                        #105
                        @sneak-l8
                        Hab das Auto gerade angesteckt und lädt auch brav mit 5A...
                        aber wie man sieht bleibt der plugTimestamp trotzdem leer
                        Kann es sein, dass es daran liegt, das ich das Kabel immer nur beim Auto ausstecke ?
                        Das andere Ende des Kabels in der Wallbox lasse ich immer angesteckt...
                        Beste Grüße
                        • Q Qlink
                          @sneak-l8
                          Beste Grüße
                          Sneak-L8
                          schrieb am zuletzt editiert von Sneak-L8
                          #106
                          @qlink Ah, bei Dir ist das Kabel an der Wallbox nicht fest angeschlagen? Kannst Du mir den Wert des states "plug" sagen, wenn Du an- bzw. abgesteckt hast? Evtl. verhält sich das anders als beschrieben...
                          • S Sneak-L8
                            Q Offline
                            Q Offline
                            Qlink
                            #107
                            @sneak-l8
                            Wenn der Stecker fürs Auto nicht angesteckt ist zeigt er den Wert 1 an.
                            Wenn ich den Stecker beim Auto anstecke und lade zeigt er den Wert 7 an.
                            • Q Qlink
                              @sneak-l8
                              Sneak-L8
                              #108
                              @qlink Schade, ich hatte gehofft, dass beide Werte >= 5 sind. So muss ich weiter suchen. Bin aber gerade dabei, den Adapter etwas zu erweitern. Mehr Doku in der Readme, PV-Automatik standardmäßig auf "ein", automatischer Check auf neue Firmware....
                              Dabei fiel mir auf, dass ich immer mehrmals "stop charging" bekomme, ohne dass das Laden begonnen wurde. Da bin ich auch auf der Suche nach der Ursache. Festgestellt habe ich dabei, dass er aus unerfindlichen Gründen immer wieder mal kurz die Ladung mit 6A startet, obwohl der Überschuss gar nicht ausreicht. Vielleicht hängt der Fehler ja zusammen (auch wenn ich bisher noch keinen Zusammenhang sehe).... Ich werde mich wieder melden.
                              • S Sneak-L8
                                Sneak-L8
                                #109
                                @Qlink ich habe mal eine v.1.1.2 erstellt.
                                Damit ist der Fehler behoben, dass die Wallbox zwischendurch immer mal kurz lädt, ohne dass ein ausreichender Überschuss vorhanden war. Außerdem prüft der Adapter nun, ob die Firmware noch aktuell ist. Details unter https://forum.iobroker.net/topic/43918/test-adapter-kecontact-v1-1-x-github-latest
                                Kannst Du mal schauen, ob es mit dieser Version immer noch Probleme gibt? Falls ja, den Test mit Log-Level debug wiederholen und mir das Log zusenden.
                                Viele Grüße
                                Sneak-L8
                                S Q 2 Antworten Letzte Antwort
                                • S Sneak-L8
                                  Viele Grüße
                                  Sneak-L8
                                  Sneak-L8
                                  #110
                                  Falls schon aktualisiert, bitte nochmal, da ich die teilweise nicht berückschtigte Mindestladedauer korrigiert habe.
                                  • R Offline
                                    roughestboy
                                    #111
                                    @haus-automatisierung
                                    Ich bin an der Alfen Wallbox interessiert und habe Deine Videos gesehen.
                                    Ist mittlerweile klar, ob die Box per Software (über modbus) zwischen 1- und 3phasig umschaltbar ist, und wie weit kann man minimal den Ladestrom runterregeln ? Im Video wurden 6A gezeigt, bei denen es (noch) funktioniert, aber auch 2A, bei denen es nicht mehr funktioniert. geht da noch weniger, also 5,4, oder noch 3 Ampere ?
                                    • R roughestboy
                                      haus-automatisierungH Offline
                                      #112
                                      @roughestboy sagte in Sammlung Informationen Wallbox & ioBroker-Integration:
                                      Ja, das geht. Habe ich selbst noch nicht getestet, aber es git ein Register dafür. Stand nur noch nicht in der Doku damals und wurde in den Kommentaren schon bestätigt.
                                      📚 Meine Dokumentation
                                      • S Sneak-L8
                                        Viele Grüße
                                        Sneak-L8
                                        Q Offline
                                        Q Offline
                                        Qlink
                                        schrieb am zuletzt editiert von Qlink
                                        #113
                                        Viele Grüße
                                        Sneak-L8
                                        @Sneak-L8 Hätte heute mal wieder einen Versuch mit dem aktiven Modus des Adapters (1.1.2) gemacht. Die Minimum Charging Time wird nun berücksichtigt soweit ich das sehe...
                                        Allerdings regelt er nicht richtig bei mir. Er hüpft immer zwischen 6A und 19A hin und her, obwohl er mit 19A klarerweise einen hohen Netzbezug verursacht. Sobald er den Netzbezug registriert regelt er auf 6A runter, dann wieder auf 19A hoch usw. ...
                                        Hier das Log:
                                        kecontact.txt
                                        • Q Qlink
                                          Viele Grüße
                                          Sneak-L8
                                          Hier das Log:
                                          kecontact.txt
                                          Sneak-L8
                                          #114
                                          @qlink Das ist echt seltsam. Ich sehe gut, dass der Berechnete Überchuss anhand von regard und surplus des sma-em mal etwas im Netzbezug und dann wieder im Überschuss liegt.
                                          Kann es sein, dass der Stromverbrauch Deiner Wallbox auf einem anderen Zähler hängt? Oder diese evtl. erst hinter dem sma-em ans Stromnetz geklemmt ist. Meine Vermutung ist nämlich, dass der Stromverbrauch der Wallbox in den Werten surplus/regard nicht enthalten ist. Dadurch würden sich die Sprünge erklären. Denn der aktuelle Verbrauch der Wallbox wird in den Überschuss eingerechnet (sma-em.surplus minus sma-em.regard + wallbox.p(ower)). Kannst Du das mal prüfen?
