  4. pivCCU3 nach update Raspberry nicht mehr erreichbar
    6.6k
70 Beiträge 5 Kommentatoren 10.2k Aufrufe 3 Beobachtet
    @ati
    dmesg -T
    Vermutlich aber Dateisystem zersägt.
    Ati
    pi@raspberrypi:~ $ dmesg -T
    [Wed Mar 24 11:16:57 2021] Booting Linux on physical CPU 0x0
    [Wed Mar 24 11:16:57 2021] Linux version 5.4.79-v7+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:22:33 GMT 2020
    [Wed Mar 24 11:16:57 2021] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [Wed Mar 24 11:16:57 2021] CPU: div instructions available: patching division code
    [Wed Mar 24 11:16:57 2021] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [Wed Mar 24 11:16:57 2021] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
    [Wed Mar 24 11:16:57 2021] Memory policy: Data cache writealloc
    [Wed Mar 24 11:16:57 2021] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
    [Wed Mar 24 11:16:57 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [Wed Mar 24 11:16:57 2021] On node 0 totalpages: 242688
    [Wed Mar 24 11:16:57 2021]   Normal zone: 2133 pages used for memmap
    [Wed Mar 24 11:16:57 2021]   Normal zone: 0 pages reserved
    [Wed Mar 24 11:16:57 2021]   Normal zone: 242688 pages, LIFO batch:63
    [Wed Mar 24 11:16:57 2021] percpu: Embedded 20 pages/cpu s49740 r8192 d23988 u81920
    [Wed Mar 24 11:16:57 2021] pcpu-alloc: s49740 r8192 d23988 u81920 alloc=20*4096
    [Wed Mar 24 11:16:57 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Wed Mar 24 11:16:57 2021] Built 1 zonelists, mobility grouping on.  Total pages: 240555
    [Wed Mar 24 11:16:57 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=e92f3fb0-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Wed Mar 24 11:16:57 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [Wed Mar 24 11:16:57 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [Wed Mar 24 11:16:57 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
    [Wed Mar 24 11:16:57 2021] Memory: 880480K/970752K available (9216K kernel code, 698K rwdata, 2608K rodata, 1024K init, 827K bss, 24736K reserved, 65536K cma-reserved)
    [Wed Mar 24 11:16:57 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [Wed Mar 24 11:16:57 2021] ftrace: allocating 29201 entries in 58 pages
    [Wed Mar 24 11:16:57 2021] rcu: Hierarchical RCU implementation.
    [Wed Mar 24 11:16:57 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [Wed Mar 24 11:16:57 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Wed Mar 24 11:16:57 2021] random: get_random_bytes called from start_kernel+0x324/0x4f8 with crng_init=0
    [Wed Mar 24 11:16:57 2021] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
    [Wed Mar 24 11:16:57 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [Wed Mar 24 11:16:57 2021] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [Wed Mar 24 11:16:57 2021] Switching to timer-based delay loop, resolution 52ns
    [Wed Mar 24 11:16:57 2021] Console: colour dummy device 80x30
    [Wed Mar 24 11:16:57 2021] printk: console [tty1] enabled
    [Wed Mar 24 11:16:57 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [Wed Mar 24 11:16:57 2021] pid_max: default: 32768 minimum: 301
    [Wed Mar 24 11:16:57 2021] LSM: Security Framework initializing
    [Wed Mar 24 11:16:57 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Wed Mar 24 11:16:57 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Wed Mar 24 11:16:57 2021] Disabling memory control group subsystem
    [Wed Mar 24 11:16:57 2021] CPU: Testing write buffer coherency: ok
    [Wed Mar 24 11:16:57 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Wed Mar 24 11:16:57 2021] Setting up static identity map for 0x100000 - 0x10003c
    [Wed Mar 24 11:16:57 2021] rcu: Hierarchical SRCU implementation.
    [Wed Mar 24 11:16:57 2021] smp: Bringing up secondary CPUs ...
    [Wed Mar 24 11:16:57 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Wed Mar 24 11:16:57 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Wed Mar 24 11:16:57 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Wed Mar 24 11:16:57 2021] smp: Brought up 1 node, 4 CPUs
    [Wed Mar 24 11:16:57 2021] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [Wed Mar 24 11:16:57 2021] CPU: All CPU(s) started in HYP mode.
    [Wed Mar 24 11:16:57 2021] CPU: Virtualization extensions available.
    [Wed Mar 24 11:16:57 2021] devtmpfs: initialized
    [Wed Mar 24 11:16:57 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [Wed Mar 24 11:16:57 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [Wed Mar 24 11:16:57 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [Wed Mar 24 11:16:57 2021] pinctrl core: initialized pinctrl subsystem
    [Wed Mar 24 11:16:57 2021] NET: Registered protocol family 16
    [Wed Mar 24 11:16:57 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [Wed Mar 24 11:16:57 2021] audit: initializing netlink subsys (disabled)
    [Wed Mar 24 11:16:57 2021] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
    [Wed Mar 24 11:16:57 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [Wed Mar 24 11:16:57 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Wed Mar 24 11:16:57 2021] Serial: AMBA PL011 UART driver
    [Wed Mar 24 11:16:57 2021] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [Wed Mar 24 11:16:57 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-11-30 22:13, variant start
    [Wed Mar 24 11:16:57 2021] raspberrypi-firmware soc:firmware: Firmware hash is ab1181cc0cb6df52bfae3b1d3fef0ce7c325166c
    [Wed Mar 24 11:16:57 2021] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
    [Wed Mar 24 11:16:57 2021] SCSI subsystem initialized
    [Wed Mar 24 11:16:57 2021] usbcore: registered new interface driver usbfs
    [Wed Mar 24 11:16:57 2021] usbcore: registered new interface driver hub
    [Wed Mar 24 11:16:57 2021] usbcore: registered new device driver usb
    [Wed Mar 24 11:16:57 2021] clocksource: Switched to clocksource arch_sys_counter
    [Wed Mar 24 11:16:57 2021] VFS: Disk quotas dquot_6.6.0
    [Wed Mar 24 11:16:57 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [Wed Mar 24 11:16:57 2021] FS-Cache: Loaded
    [Wed Mar 24 11:16:57 2021] CacheFiles: Loaded
    [Wed Mar 24 11:16:57 2021] thermal_sys: Registered thermal governor 'step_wise'
    [Wed Mar 24 11:16:57 2021] NET: Registered protocol family 2
    [Wed Mar 24 11:16:57 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [Wed Mar 24 11:16:57 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [Wed Mar 24 11:16:57 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [Wed Mar 24 11:16:57 2021] TCP: Hash tables configured (established 8192 bind 8192)
    [Wed Mar 24 11:16:57 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Wed Mar 24 11:16:57 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Wed Mar 24 11:16:57 2021] RPC: Registered named UNIX socket transport module.
    [Wed Mar 24 11:16:57 2021] RPC: Registered udp transport module.
    [Wed Mar 24 11:16:57 2021] RPC: Registered tcp transport module.
    [Wed Mar 24 11:16:57 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [Wed Mar 24 11:16:57 2021] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [Wed Mar 24 11:16:57 2021] Initialise system trusted keyrings
    [Wed Mar 24 11:16:57 2021] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [Wed Mar 24 11:16:57 2021] FS-Cache: Netfs 'nfs' registered for caching
    [Wed Mar 24 11:16:57 2021] NFS: Registering the id_resolver key type
    [Wed Mar 24 11:16:57 2021] Key type id_resolver registered
    [Wed Mar 24 11:16:57 2021] Key type id_legacy registered
    [Wed Mar 24 11:16:57 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [Wed Mar 24 11:16:57 2021] Key type asymmetric registered
    [Wed Mar 24 11:16:57 2021] Asymmetric key parser 'x509' registered
    [Wed Mar 24 11:16:57 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [Wed Mar 24 11:16:57 2021] io scheduler mq-deadline registered
    [Wed Mar 24 11:16:57 2021] io scheduler kyber registered
    [Wed Mar 24 11:16:57 2021] bcm2708_fb soc:fb: FB found 1 display(s)
    [Wed Mar 24 11:16:57 2021] Console: switching to colour frame buffer device 228x61
    [Wed Mar 24 11:16:57 2021] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1824x984
    [Wed Mar 24 11:16:57 2021] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
    [Wed Mar 24 11:16:57 2021] bcm2835-rng 3f104000.rng: hwrng registered
    [Wed Mar 24 11:16:57 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [Wed Mar 24 11:16:57 2021] vc-sm: Videocore shared memory driver
    [Wed Mar 24 11:16:57 2021] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [Wed Mar 24 11:16:57 2021] brd: module loaded
    [Wed Mar 24 11:16:57 2021] loop: module loaded
    [Wed Mar 24 11:16:57 2021] Loading iSCSI transport class v2.0-870.
    [Wed Mar 24 11:16:57 2021] libphy: Fixed MDIO Bus: probed
    [Wed Mar 24 11:16:57 2021] usbcore: registered new interface driver lan78xx
    [Wed Mar 24 11:16:57 2021] usbcore: registered new interface driver smsc95xx
    [Wed Mar 24 11:16:57 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Wed Mar 24 11:16:58 2021] Core Release: 2.80a
    [Wed Mar 24 11:16:58 2021] Setting default values for core params
    [Wed Mar 24 11:16:58 2021] Finished setting default values for core params
    [Wed Mar 24 11:16:58 2021] Using Buffer DMA mode
    [Wed Mar 24 11:16:58 2021] Periodic Transfer Interrupt Enhancement - disabled
    [Wed Mar 24 11:16:58 2021] Multiprocessor Interrupt Enhancement - disabled
    [Wed Mar 24 11:16:58 2021] OTG VER PARAM: 0, OTG VER FLAG: 0
    [Wed Mar 24 11:16:58 2021] Dedicated Tx FIFOs mode
    [Wed Mar 24 11:16:58 2021] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
    [Wed Mar 24 11:16:58 2021] FIQ FSM acceleration enabled for :
                               Non-periodic Split Transactions
                               Periodic Split Transactions
                               High-Speed Isochronous Endpoints
                               Interrupt/Control Split Transaction hack enabled
    [Wed Mar 24 11:16:58 2021] dwc_otg: Microframe scheduler enabled
    [Wed Mar 24 11:16:58 2021] WARN::hcd_init_fiq:457: FIQ on core 1
    [Wed Mar 24 11:16:58 2021] WARN::hcd_init_fiq:458: FIQ ASM at 8070b948 length 36
    [Wed Mar 24 11:16:58 2021] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
    [Wed Mar 24 11:16:58 2021] dwc_otg 3f980000.usb: DWC OTG Controller
    [Wed Mar 24 11:16:58 2021] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [Wed Mar 24 11:16:58 2021] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
    [Wed Mar 24 11:16:58 2021] Init: Port Power? op_state=1
    [Wed Mar 24 11:16:58 2021] Init: Power Port (0)
    [Wed Mar 24 11:16:58 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
    [Wed Mar 24 11:16:58 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Wed Mar 24 11:16:58 2021] usb usb1: Product: DWC OTG Controller
    [Wed Mar 24 11:16:58 2021] usb usb1: Manufacturer: Linux 5.4.79-v7+ dwc_otg_hcd
    [Wed Mar 24 11:16:58 2021] usb usb1: SerialNumber: 3f980000.usb
    [Wed Mar 24 11:16:58 2021] hub 1-0:1.0: USB hub found
    [Wed Mar 24 11:16:58 2021] hub 1-0:1.0: 1 port detected
    [Wed Mar 24 11:16:58 2021] dwc_otg: FIQ enabled
    [Wed Mar 24 11:16:58 2021] dwc_otg: NAK holdoff enabled
    [Wed Mar 24 11:16:58 2021] dwc_otg: FIQ split-transaction FSM enabled
    [Wed Mar 24 11:16:58 2021] Module dwc_common_port init
    [Wed Mar 24 11:16:58 2021] usbcore: registered new interface driver usb-storage
    [Wed Mar 24 11:16:58 2021] mousedev: PS/2 mouse device common for all mice
    [Wed Mar 24 11:16:58 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [Wed Mar 24 11:16:58 2021] sdhci: Secure Digital Host Controller Interface driver
    [Wed Mar 24 11:16:58 2021] sdhci: Copyright(c) Pierre Ossman
    [Wed Mar 24 11:16:58 2021] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
    [Wed Mar 24 11:16:58 2021] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
    [Wed Mar 24 11:16:58 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [Wed Mar 24 11:16:58 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [Wed Mar 24 11:16:58 2021] hidraw: raw HID events driver (C) Jiri Kosina
    [Wed Mar 24 11:16:58 2021] usbcore: registered new interface driver usbhid
    [Wed Mar 24 11:16:58 2021] usbhid: USB HID core driver
    [Wed Mar 24 11:16:58 2021] vchiq: vchiq_init_state: slot_zero = (ptrval)
    [Wed Mar 24 11:16:58 2021] [vc_sm_connected_init]: start
    [Wed Mar 24 11:16:58 2021] [vc_sm_connected_init]: end - returning 0
    [Wed Mar 24 11:16:58 2021] Initializing XFRM netlink socket
    [Wed Mar 24 11:16:58 2021] NET: Registered protocol family 17
    [Wed Mar 24 11:16:58 2021] Key type dns_resolver registered
    [Wed Mar 24 11:16:58 2021] Registering SWP/SWPB emulation handler
    [Wed Mar 24 11:16:58 2021] registered taskstats version 1
    [Wed Mar 24 11:16:58 2021] Loading compiled-in X.509 certificates
    [Wed Mar 24 11:16:58 2021] Key type ._fscrypt registered
    [Wed Mar 24 11:16:58 2021] Key type .fscrypt registered
    [Wed Mar 24 11:16:58 2021] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 53, base_baud = 50000000) is a 16550
    [Wed Mar 24 11:16:58 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [Wed Mar 24 11:16:58 2021] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Wed Mar 24 11:16:58 2021] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
    [Wed Mar 24 11:16:58 2021] sdhost: log_buf @ (ptrval) (f7507000)
    [Wed Mar 24 11:16:58 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Wed Mar 24 11:16:58 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Wed Mar 24 11:16:59 2021] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [Wed Mar 24 11:16:59 2021] of_cfs_init
    [Wed Mar 24 11:16:59 2021] of_cfs_init: OK
    [Wed Mar 24 11:16:59 2021] Waiting for root device PARTUUID=e92f3fb0-02...
    [Wed Mar 24 11:16:59 2021] Indeed it is in host mode hprt0 = 00021501
    [Wed Mar 24 11:16:59 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Wed Mar 24 11:16:59 2021] random: fast init done
    [Wed Mar 24 11:16:59 2021] mmc0: host does not support reading read-only switch, assuming write-enable
    [Wed Mar 24 11:16:59 2021] mmc0: new high speed SDHC card at address 0001
    [Wed Mar 24 11:16:59 2021] mmcblk0: mmc0:0001 00000 14.6 GiB
    [Wed Mar 24 11:16:59 2021]  mmcblk0: p1 p2
    [Wed Mar 24 11:16:59 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Wed Mar 24 11:16:59 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Wed Mar 24 11:16:59 2021] devtmpfs: mounted
    [Wed Mar 24 11:16:59 2021] Freeing unused kernel memory: 1024K
    [Wed Mar 24 11:16:59 2021] Run /sbin/init as init process
    [Wed Mar 24 11:16:59 2021] mmc1: new high speed SDIO card at address 0001
    [Wed Mar 24 11:16:59 2021] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [Wed Mar 24 11:16:59 2021] Indeed it is in host mode hprt0 = 00001101
    [Wed Mar 24 11:16:59 2021] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
    [Wed Mar 24 11:16:59 2021] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [Wed Mar 24 11:16:59 2021] hub 1-1:1.0: USB hub found
    [Wed Mar 24 11:16:59 2021] hub 1-1:1.0: 5 ports detected
    [Wed Mar 24 11:16:59 2021] systemd[1]: System time before build time, advancing clock.
    [Wed Mar 24 11:16:59 2021] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [Wed Mar 24 11:16:59 2021] NET: Registered protocol family 10
    [Wed Mar 24 11:16:59 2021] Segment Routing with IPv6
    [Wed Mar 24 11:16:59 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [Wed Mar 24 11:16:59 2021] systemd[1]: Detected architecture arm.
    [Wed Mar 24 11:16:59 2021] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
    [Wed Mar 24 11:16:59 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [Wed Mar 24 11:16:59 2021] smsc95xx v1.0.6
    [Wed Mar 24 11:17:00 2021] systemd[1]: Set hostname to <raspberrypi>.
    [Wed Mar 24 11:17:00 2021] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:2c:12:5f
    [Wed Mar 24 11:17:00 2021] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
    [Wed Mar 24 11:17:00 2021] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2113, bcdDevice= 1.08
    [Wed Mar 24 11:17:00 2021] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
    [Wed Mar 24 11:17:00 2021] usb 1-1.3: Product: Dell KB216 Wired Keyboard
    [Wed Mar 24 11:17:00 2021] input: Dell KB216 Wired Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2113.0001/input/input0
    [Wed Mar 24 11:17:00 2021] hid-generic 0003:413C:2113.0001: input,hidraw0: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-3f980000.usb-1.3/input0
    [Wed Mar 24 11:17:00 2021] input: Dell KB216 Wired Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:413C:2113.0002/input/input1
    [Wed Mar 24 11:17:00 2021] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:413C:2113.0002/input/input2
    [Wed Mar 24 11:17:00 2021] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-3f980000.usb-1.3/input1
    [Wed Mar 24 11:17:00 2021] systemd[1]: /lib/systemd/system/pivccu.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/pivccu3.pid → /run/pivccu3.pid; please update the unit file accordingly.
    [Wed Mar 24 11:17:00 2021] random: systemd: uninitialized urandom read (16 bytes read)
    [Wed Mar 24 11:17:00 2021] systemd[1]: Listening on Journal Socket (/dev/log).
    [Wed Mar 24 11:17:00 2021] systemd[1]: Listening on fsck to fsckd communication Socket.
    [Wed Mar 24 11:17:00 2021] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [Wed Mar 24 11:17:00 2021] systemd[1]: Listening on udev Control Socket.
    [Wed Mar 24 11:17:00 2021] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [Wed Mar 24 11:17:00 2021] systemd[1]: Created slice User and Session Slice.
    [Wed Mar 24 11:17:00 2021] usb 1-1.2: new full-speed USB device number 5 using dwc_otg
    [Wed Mar 24 11:17:00 2021] usb 1-1.2: New USB device found, idVendor=062a, idProduct=4102, bcdDevice=81.13
    [Wed Mar 24 11:17:00 2021] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [Wed Mar 24 11:17:00 2021] usb 1-1.2: Product: 2.4G Wireless Mouse
    [Wed Mar 24 11:17:00 2021] usb 1-1.2: Manufacturer: MOSART Semi.
    [Wed Mar 24 11:17:00 2021] input: MOSART Semi. 2.4G Wireless Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:062A:4102.0003/input/input3
    [Wed Mar 24 11:17:00 2021] input: MOSART Semi. 2.4G Wireless Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:062A:4102.0003/input/input4
    [Wed Mar 24 11:17:00 2021] hid-generic 0003:062A:4102.0003: input,hiddev96,hidraw2: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-3f980000.usb-1.2/input0
    [Wed Mar 24 11:17:01 2021] systemd-journald[124]: Received request to flush runtime journal from PID 1
    [Wed Mar 24 11:17:02 2021] mc: Linux media interface: v0.10
    [Wed Mar 24 11:17:02 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [Wed Mar 24 11:17:02 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [Wed Mar 24 11:17:02 2021] [vc_sm_connected_init]: start
    [Wed Mar 24 11:17:02 2021] [vc_sm_connected_init]: installed successfully
    [Wed Mar 24 11:17:02 2021] videodev: Linux video capture interface: v2.00
    [Wed Mar 24 11:17:02 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [Wed Mar 24 11:17:02 2021] bcm2835_audio bcm2835_audio: card created with 4 channels
    [Wed Mar 24 11:17:02 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [Wed Mar 24 11:17:02 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [Wed Mar 24 11:17:02 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [Wed Mar 24 11:17:02 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [Wed Mar 24 11:17:02 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Wed Mar 24 11:17:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [Wed Mar 24 11:17:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Wed Mar 24 11:17:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [Wed Mar 24 11:17:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Wed Mar 24 11:17:02 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [Wed Mar 24 11:17:02 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Wed Mar 24 11:17:02 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [Wed Mar 24 11:17:02 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [Wed Mar 24 11:17:02 2021] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
    [Wed Mar 24 11:17:02 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [Wed Mar 24 11:17:02 2021] usbcore: registered new interface driver brcmfmac
    [Wed Mar 24 11:17:02 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt failed with error -2
    [Wed Mar 24 11:17:03 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
    [Wed Mar 24 11:17:03 2021] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
    [Wed Mar 24 11:17:03 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
    [Wed Mar 24 11:17:04 2021] random: crng init done
    [Wed Mar 24 11:17:04 2021] random: 7 urandom warning(s) missed due to ratelimiting
    [Wed Mar 24 11:17:04 2021] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [Wed Mar 24 11:17:04 2021] br0: port 1(eth0) entered blocking state
    [Wed Mar 24 11:17:04 2021] br0: port 1(eth0) entered disabled state
    [Wed Mar 24 11:17:04 2021] device eth0 entered promiscuous mode
    [Wed Mar 24 11:17:04 2021] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [Wed Mar 24 11:17:04 2021] br0: port 1(eth0) entered forwarding state
    [Wed Mar 24 11:17:06 2021] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
    [Wed Mar 24 11:17:08 2021] Bluetooth: Core ver 2.22
    [Wed Mar 24 11:17:08 2021] NET: Registered protocol family 31
    [Wed Mar 24 11:17:08 2021] Bluetooth: HCI device and connection manager initialized
    [Wed Mar 24 11:17:08 2021] Bluetooth: HCI socket layer initialized
    [Wed Mar 24 11:17:08 2021] Bluetooth: L2CAP socket layer initialized
    [Wed Mar 24 11:17:08 2021] Bluetooth: SCO socket layer initialized
    [Wed Mar 24 11:17:08 2021] Bluetooth: HCI UART driver ver 2.3
    [Wed Mar 24 11:17:08 2021] Bluetooth: HCI UART protocol H4 registered
    [Wed Mar 24 11:17:08 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [Wed Mar 24 11:17:08 2021] Bluetooth: HCI UART protocol Broadcom registered
    [Wed Mar 24 11:17:08 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [Wed Mar 24 11:17:08 2021] Bluetooth: BNEP filters: protocol multicast
    [Wed Mar 24 11:17:08 2021] Bluetooth: BNEP socket layer initialized
    [Wed Mar 24 11:22:04 2021] br0: port 2(vethpivccu) entered blocking state
    [Wed Mar 24 11:22:04 2021] br0: port 2(vethpivccu) entered disabled state
    [Wed Mar 24 11:22:04 2021] device vethpivccu entered promiscuous mode
    [Wed Mar 24 11:22:05 2021] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
    [Wed Mar 24 11:22:05 2021] eth0: renamed from vethW4UKL4
    [Wed Mar 24 11:22:05 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [Wed Mar 24 11:22:05 2021] IPv6: ADDRCONF(NETDEV_CHANGE): vethpivccu: link becomes ready
    [Wed Mar 24 11:22:05 2021] br0: port 2(vethpivccu) entered blocking state
    [Wed Mar 24 11:22:05 2021] br0: port 2(vethpivccu) entered forwarding state
    [Wed Mar 24 11:22:05 2021] br0: port 2(vethpivccu) entered disabled state
    [Wed Mar 24 11:22:05 2021] device vethpivccu left promiscuous mode
    pi@raspberrypi:~ $
    laut WinSCP sind die Rechte in var 755
    • A Ati
      pi@raspberrypi:~ $
      @ati sagte in pivCCU3 nach update Raspberry nicht mehr erreichbar:
      Das nutzt dir aber nix, wenn die ganze root-Partition ro gemounted wird.
      Den üblichen remount rw kann ich nicht finden.
      Und Tools, die ein WIN im Namen tragen würde ich aus Prinzip nicht in die Nähe eines Linux lassen... :-D
        Ati
        @thomas-braun 😊 😊 😊
        /offtopic
        Ich bin kein gebürtiger Linuxer. Alles nur angenommen. Und WinSCP ist halt eine Schweizer Taschenmesser. Das und sonst gar nix. Ich finde es schon mega umständlich vom Mac aus zu hantieren im Linux.
        /on topic
        Ist schon merkwürdig, dass durch ein simples Update eine Partition auf RO gesetzt wird.
        • A Ati
          @thomas-braun 😊 😊 😊
          /offtopic
          /on topic
          Wird sie auch nicht. Da klemmt es an anderer Stelle, meist hat das Speichermedium einen Schuß. Wobei dann eigentlich andere/mehr Meldungen dazu im dmesg zu finden sind.
          Starte den Pi mal sauber durch:
          sudo reboot
          und dann bitte nochmal die Ausgabe von
          dmesg -T
          A 2 Antworten Letzte Antwort
            sudo reboot
            dmesg -T
            Ati
            Habe dazu grad was im Netz gefunden. Da sei es nciht unüblich, dass beim ersten Start Ro gesetzt ist um nicht sofort an die Systemdateien ranzukommen (Schutz) Und weiter dann wird RW draus.
            sudo mount -o remount,rw /
            So kann man das wohl ändern.
            • A Ati
              @ati
              Das kenne ich natürlich.
              Bei dir fehlt aber das remount, das wird i.d.R. halt automatisch auf einer sauberen Partition gemacht. Warum das bei dir nicht passiert, keine Ahnung.
                sudo reboot
                dmesg -T
                Ati
                dauert noch, Start Job braucht wieder 5 Minuten
                • A Ati
                  @ati
                  Hast du eigentlich piVCCU als Image auf die Karte gebügelt oder manuell auf ein 'reines Raspberry OS lite' gesetzt?
                    @ati
                    Ati
                    ist schon eine Weile her, aber ich glaube das war ein offizielles Raspberry und dann pivCCU reininstalliert.
                    Weihnachten vergangenes Jahr habe ich das von CCU2 auf CCU3 hochgehoben. Das ging alles reibungslos.
                    Momentan nach Neustart bekommt er wieder keine IPv4 Adresse, oder holt sie sie sich nicht. Das kan ich nicht sehen. Aber der Raspi ist dadurch wieder nicht erreichbar. Deswegen läuft offenbar auch der Start Job. Was ich baer inzwischen sehene konnte- pivCCU wurde nach dem RW Befehl ausgeführt und erfolgreich gestartet. Scahde nur , dass man das nicht nutzen kann 🙄
                    wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                    • A Ati
                      wendy2702W Offline
                      wendy2702W Offline
                      @ati nur Pivccu installiert oder noch was anderes ?
                      • A Ati
                        Was meinst du damit genau?
                        Bekommst du jetzt per SSH an eine Kommandozeile?
                          @thomas-braun sagte in pivCCU3 nach update Raspberry nicht mehr erreichbar:
                          Ist auch Mumpitz.
                          Damit ist auch die imho unglückliche Voreinstellung seitens Raspberry OS gemeint. Das startet immer in dieses Target, auch wenn gar keine graphische Oberfläche installiert ist.
                          Das Standard-Passwort mit einem y drin ist genauso unglücklich gewählt.
                          aber nur, wenn man nicht per SSH draufgeht ;-)
                          • wendy2702W wendy2702
                            Ati
                            @wendy2702
                            nur pivCCU. Früher war da noch ein iobroker mit drauf. Den habe ich aber vor zwei Jahren umgelagert.
                            sudo ifconfig eth0 192.168.0.9 Netmask 255.255.255.0
                            Netmask: Host name lookup failure
                            geht auch nicht
                              Ati
                              nein . Ich habe eine Bildschirm dran. Da sehe ich ja die Meldungen
                              • A Ati
                                wendy2702W Offline
                                wendy2702W Offline
                                @ati und eine Tastatur ?
                                  Ati
                                  @wendy2702
                                  ja sicher. Und eine Maus auch, die ich aber nur beim ersten Start brauchte - weil grafische Oberfläche
                                  • A Ati
                                    @wendy2702
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    @ati
                                    cat /etc/network/interfaces
                                    • A Ati
                                      @wendy2702
                                      @ati
                                      Ich weiß das piVCCU an den Netzwerkinterfaces 'rummacht', deswegen ist eth0 wohl nicht das richtige Interface. Die IP ist ja auch 'self assigned'.
                                        @ati
                                        Ati
                                        @wendy2702
                                        auto lo
                                        iface lo inet loopback
                                        iface eth0 inet manual
                                        auto br0
                                        iface br0 inet dhcp
                                        bridgew_ports eth0
                                        Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
                                        • A Ati
                                          @wendy2702
                                          auto lo
                                          auto br0
                                          iface br0 inet dhcp
                                          bridgew_ports eth0
                                          @ati
                                          ip a
