  4. [gelöst] smartmeter instaz gelb
35 Beiträge 3 Kommentatoren 3.5k Aufrufe 2 Beobachtet
    2021-03-07 16:25:01.346 - debug: smartmeter.0 (1615) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2021-03-07 16:25:01.402 - debug: smartmeter.0 (1615) Objects client ready ... initialize now
    2021-03-07 16:25:01.406 - debug: smartmeter.0 (1615) Objects create System PubSub Client
    2021-03-07 16:25:01.409 - debug: smartmeter.0 (1615) Objects create User PubSub Client
    2021-03-07 16:25:01.411 - debug: smartmeter.0 (1615) Objects client initialize lua scripts
    2021-03-07 16:25:01.433 - debug: smartmeter.0 (1615) Objects connected to redis: 127.0.0.1:9001
    2021-03-07 16:25:01.452 - debug: smartmeter.0 (1615) objectDB connected
    2021-03-07 16:25:01.457 - debug: smartmeter.0 (1615) Redis States: Use Redis connection: 127.0.0.1:9000
    2021-03-07 16:25:01.470 - debug: smartmeter.0 (1615) States create System PubSub Client
    2021-03-07 16:25:01.473 - debug: smartmeter.0 (1615) States create User PubSub Client
    2021-03-07 16:25:01.486 - debug: smartmeter.0 (1615) States connected to redis: 127.0.0.1:9000
    2021-03-07 16:25:01.488 - debug: smartmeter.0 (1615) statesDB connected
    2021-03-07 16:25:01.717 - debug: smartmeter.0 (1615) Plugin sentry Initialize Plugin (enabled=true)
    2021-03-07 16:25:02.131 - info: smartmeter.0 (1615) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.21.0, js-controller: 3.2.16
    2021-03-07 16:25:02.185 - debug: smartmeter.0 (1615) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"3","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":0,"obisFallbackMedium":0}
    2021-03-07 16:25:02.191 - debug: smartmeter.0 (1615) CREATE SERIALPORT: 9600 8 1 none
    2021-03-07 16:25:02.208 - debug: smartmeter.0 (1615) SERIALPORT OPEN
    2021-03-07 16:25:02.238 - debug: smartmeter.0 (1615) SET MESSAGE TIMEOUT TIMER: 120000
    2021-03-07 16:25:02.252 - debug: smartmeter.0 (1615) connected set to false
    2021-03-07 16:26:01.423 - debug: smartmeter.0 (1615) Message received = {"command":"listUart","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":14,"ack":false,"time":1615130761418},"_id":11081440}
    2021-03-07 16:26:01.716 - info: smartmeter.0 (1615) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"manufacturer":"Silicon Labs","serialNumber":"0047","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"manufacturer":"Silicon Labs","serialNumber":"0027","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0027-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB1"}]
    2021-03-07 16:26:01.719 - debug: smartmeter.0 (1615) sendTo "listUart" to system.adapter.admin.0 from system.adapter.smartmeter.0
    2021-03-07 16:26:56.537 - debug: smartmeter.0 (1615) system.adapter.admin.0: logging true
    2021-03-07 16:27:02.240 - debug: smartmeter.0 (1615) MESSAGE TIMEOUT TRIGGERED
    2021-03-07 16:27:02.242 - debug: smartmeter.0 (1615) Error: No or too long answer from Serial Device after last request.
    2021-03-07 16:27:02.246 - warn: smartmeter.0 (1615) No or too long answer from Serial Device after last request.
    2021-03-07 16:27:02.247 - debug: smartmeter.0 (1615) Error: No or too long answer from Serial Device after last request.
    2021-03-07 16:27:02.249 - debug: smartmeter.0 (1615) Transport Reset!! Restart = true
    2021-03-07 16:27:02.260 - debug: smartmeter.0 (1615) SERIALPORT CLOSE
    2021-03-07 16:27:02.262 - debug: smartmeter.0 (1615) SCHEDULE NEXT RUN IN 3s
    2021-03-07 16:27:05.266 - debug: smartmeter.0 (1615) CREATE SERIALPORT: 9600 8 1 none
    2021-03-07 16:27:05.275 - debug: smartmeter.0 (1615) SERIALPORT OPEN
    2021-03-07 16:27:05.280 - debug: smartmeter.0 (1615) SET MESSAGE TIMEOUT TIMER: 120000
    DrehstromzählerTyp ISKRA MT681
    wendy2702W Online
    wendy2702W Online
    @marcel-drzal Ich warte mal bis alle Fragen beantwortet sind.
    ? 2 Antworten Letzte Antwort
    • wendy2702W wendy2702
      @wendy2702
      danke für eure Hilfe
        @wendy2702 sollte alles beantwortet haben. 👍
          wendy2702W Online
          wendy2702W Online
          @marcel-drzal MIt der Information des Zählertypes spuckt die Suche unter anderem das aus:
          https://forum.iobroker.net/topic/14292/hilfe-smartmeter-adapter?page=1
          Und noch gaaaaannnnnzzzzz viele andere:
          https://forum.iobroker.net/search?term=ISKRA MT681&in=titlesposts
            @wendy2702 Hallo
            leider geht er immer noch nicht, habe mit den Einstellungen versucht, was ich gelesen hatte. Leider immer noch gelb. was liest du aus dem Log?
            r.0 (1923) SERIALPORT OPEN
            2021-03-08 13:30:21.691 - debug: smartmeter.0 (1923) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:30:21.711 - debug: smartmeter.0 (1923) connected set to false
            2021-03-08 13:31:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:31:42.530 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
            2021-03-08 13:31:42.541 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 send kill signal
            2021-03-08 13:31:42.542 - info: smartmeter.0 (1923) Got terminate signal TERMINATE_YOURSELF
            2021-03-08 13:31:42.554 - debug: smartmeter.0 (1923) SERIALPORT CLOSE
            2021-03-08 13:31:42.557 - info: smartmeter.0 (1923) terminating
            2021-03-08 13:31:42.560 - debug: smartmeter.0 (1923) Plugin sentry destroyed
            2021-03-08 13:31:42.562 - info: smartmeter.0 (1923) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-03-08 13:31:43.135 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-03-08 13:31:45.675 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 started with pid 1939
            2021-03-08 13:31:47.218 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging false
            2021-03-08 13:31:48.166 - debug: smartmeter.0 (1939) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2021-03-08 13:31:48.221 - debug: smartmeter.0 (1939) Objects client ready ... initialize now
            2021-03-08 13:31:48.225 - debug: smartmeter.0 (1939) Objects create System PubSub Client
            2021-03-08 13:31:48.227 - debug: smartmeter.0 (1939) Objects create User PubSub Client
            2021-03-08 13:31:48.230 - debug: smartmeter.0 (1939) Objects client initialize lua scripts
            2021-03-08 13:31:48.251 - debug: smartmeter.0 (1939) Objects connected to redis: 127.0.0.1:9001
            2021-03-08 13:31:48.269 - debug: smartmeter.0 (1939) objectDB connected
            2021-03-08 13:31:48.274 - debug: smartmeter.0 (1939) Redis States: Use Redis connection: 127.0.0.1:9000
            2021-03-08 13:31:48.287 - debug: smartmeter.0 (1939) States create System PubSub Client
            2021-03-08 13:31:48.290 - debug: smartmeter.0 (1939) States create User PubSub Client
            2021-03-08 13:31:48.303 - debug: smartmeter.0 (1939) States connected to redis: 127.0.0.1:9000
            2021-03-08 13:31:48.305 - debug: smartmeter.0 (1939) statesDB connected
            2021-03-08 13:31:48.607 - debug: smartmeter.0 (1939) Plugin sentry Initialize Plugin (enabled=true)
            2021-03-08 13:31:48.990 - info: smartmeter.0 (1939) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.21.0, js-controller: 3.2.16
            2021-03-08 13:31:49.041 - debug: smartmeter.0 (1939) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"3","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":0,"obisFallbackMedium":0}
            2021-03-08 13:31:49.047 - debug: smartmeter.0 (1939) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:31:49.060 - debug: smartmeter.0 (1939) SERIALPORT OPEN
            2021-03-08 13:31:49.093 - debug: smartmeter.0 (1939) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:31:49.112 - debug: smartmeter.0 (1939) connected set to false
            2021-03-08 13:32:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:32:01.435 - debug: smartmeter.0 (1939) Message received = {"command":"listUart","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":32,"ack":false,"time":1615206721431},"_id":45775062}
            2021-03-08 13:32:01.728 - info: smartmeter.0 (1939) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"manufacturer":"Silicon Labs","serialNumber":"0047","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"manufacturer":"Silicon Labs","serialNumber":"0027","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0027-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB1"}]
            2021-03-08 13:32:01.731 - debug: smartmeter.0 (1939) sendTo "listUart" to system.adapter.admin.0 from system.adapter.smartmeter.0
            2021-03-08 13:32:12.739 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging true
            2021-03-08 13:32:12.742 - debug: smartmeter.0 (1939) system.adapter.admin.0: logging true
            2021-03-08 13:33:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:33:49.095 - debug: smartmeter.0 (1939) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:33:49.097 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:33:49.101 - warn: smartmeter.0 (1939) No or too long answer from Serial Device after last request.
            2021-03-08 13:33:49.102 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:33:49.103 - debug: smartmeter.0 (1939) Transport Reset!! Restart = true
            2021-03-08 13:33:49.114 - debug: smartmeter.0 (1939) SERIALPORT CLOSE
            2021-03-08 13:33:49.117 - debug: smartmeter.0 (1939) SCHEDULE NEXT RUN IN 3s
            2021-03-08 13:33:52.120 - debug: smartmeter.0 (1939) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:33:52.128 - debug: smartmeter.0 (1939) SERIALPORT OPEN
            2021-03-08 13:33:52.133 - debug: smartmeter.0 (1939) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:34:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:34:40.491 - debug: smartmeter.1 (1701) CREATE SERIALPORT: 300 7 1 even
            2021-03-08 13:34:40.498 - debug: smartmeter.1 (1701) SERIALPORT OPEN
            2021-03-08 13:34:40.502 - debug: smartmeter.1 (1701) SERIALPORT RESET BAUDRATE TO 300
            2021-03-08 13:34:40.505 - debug: smartmeter.1 (1701) INITIAL MESSAGES TO SEND: 2
            2021-03-08 13:34:40.507 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
            2021-03-08 13:34:40.509 - debug: smartmeter.1 (1701) TO SEND 2:
            2021-03-08 13:34:40.510 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
            2021-03-08 13:34:40.511 - debug: smartmeter.1 (1701) TO SEND 1: /?!
            2021-03-08 13:34:40.676 - debug: smartmeter.1 (1701) DONE SEND 1
            2021-03-08 13:34:40.928 - debug: smartmeter.1 (1701) DONE SEND 0
            2021-03-08 13:34:40.929 - debug: smartmeter.1 (1701) SET MESSAGE TIMEOUT TIMER2: 120000
            2021-03-08 13:35:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:35:52.135 - debug: smartmeter.0 (1939) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:35:52.137 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:35:52.139 - warn: smartmeter.0 (1939) No or too long answer from Serial Device after last request.
            2021-03-08 13:35:52.140 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:35:52.141 - debug: smartmeter.0 (1939) Transport Reset!! Restart = true
            2021-03-08 13:35:52.151 - debug: smartmeter.0 (1939) SERIALPORT CLOSE
            2021-03-08 13:35:52.154 - debug: smartmeter.0 (1939) SCHEDULE NEXT RUN IN 3s
            2021-03-08 13:35:55.155 - debug: smartmeter.0 (1939) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:35:55.164 - debug: smartmeter.0 (1939) SERIALPORT OPEN
            2021-03-08 13:35:55.168 - debug: smartmeter.0 (1939) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:36:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:36:37.322 - debug: smartmeter.0 (1939) Message received = {"command":"listUart","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":34,"ack":false,"time":1615206997319},"_id":45775064}
            2021-03-08 13:36:37.603 - info: smartmeter.0 (1939) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"manufacturer":"Silicon Labs","serialNumber":"0047","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"manufacturer":"Silicon Labs","serialNumber":"0027","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0027-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB1"}]
            2021-03-08 13:36:37.605 - debug: smartmeter.0 (1939) sendTo "listUart" to system.adapter.admin.0 from system.adapter.smartmeter.0
            2021-03-08 13:36:40.931 - debug: smartmeter.1 (1701) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:36:40.933 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:36:40.934 - warn: smartmeter.1 (1701) No or too long answer from Serial Device after last request.
            2021-03-08 13:36:40.935 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:36:40.936 - debug: smartmeter.1 (1701) Transport Reset!! Restart = true
            2021-03-08 13:36:40.937 - debug: smartmeter.1 (1701) STOP
            2021-03-08 13:36:40.938 - debug: smartmeter.1 (1701) CLEAR MESSAGE TIMEOUT TIMER
            2021-03-08 13:36:40.946 - debug: smartmeter.1 (1701) SERIALPORT CLOSE
            2021-03-08 13:36:40.947 - debug: smartmeter.1 (1701) SERIALPORT REMOVE LISTENERS
            2021-03-08 13:36:40.949 - debug: smartmeter.1 (1701) CURRENT SIGNON MESSAGE COUNTER 1 OF 1
            2021-03-08 13:36:40.951 - debug: smartmeter.1 (1701) DELETE rest of data (0) because new Message start with a new Request Message
            2021-03-08 13:36:40.952 - debug: smartmeter.1 (1701) SCHEDULE NEXT RUN IN 300000s
            2021-03-08 13:36:42.324 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging false
            2021-03-08 13:36:42.325 - debug: smartmeter.0 (1939) system.adapter.admin.0: logging false
            2021-03-08 13:37:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:37:10.882 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
            2021-03-08 13:37:10.891 - info: smartmeter.0 (1939) Got terminate signal TERMINATE_YOURSELF
            2021-03-08 13:37:10.891 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 send kill signal
            2021-03-08 13:37:10.898 - debug: smartmeter.0 (1939) SERIALPORT CLOSE
            2021-03-08 13:37:10.900 - info: smartmeter.0 (1939) terminating
            2021-03-08 13:37:10.902 - debug: smartmeter.0 (1939) Plugin sentry destroyed
            2021-03-08 13:37:10.903 - info: smartmeter.0 (1939) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2021-03-08 13:37:11.035 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging true
            2021-03-08 13:37:11.038 - debug: smartmeter.0 (1939) system.adapter.admin.0: logging true
            2021-03-08 13:37:11.535 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2021-03-08 13:37:13.971 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 started with pid 1986
            2021-03-08 13:37:16.478 - debug: smartmeter.0 (1986) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2021-03-08 13:37:16.534 - debug: smartmeter.0 (1986) Objects client ready ... initialize now
            2021-03-08 13:37:16.538 - debug: smartmeter.0 (1986) Objects create System PubSub Client
            2021-03-08 13:37:16.541 - debug: smartmeter.0 (1986) Objects create User PubSub Client
            2021-03-08 13:37:16.543 - debug: smartmeter.0 (1986) Objects client initialize lua scripts
            2021-03-08 13:37:16.564 - debug: smartmeter.0 (1986) Objects connected to redis: 127.0.0.1:9001
            2021-03-08 13:37:16.582 - debug: smartmeter.0 (1986) objectDB connected
            2021-03-08 13:37:16.587 - debug: smartmeter.0 (1986) Redis States: Use Redis connection: 127.0.0.1:9000
            2021-03-08 13:37:16.600 - debug: smartmeter.0 (1986) States create System PubSub Client
            2021-03-08 13:37:16.603 - debug: smartmeter.0 (1986) States create User PubSub Client
            2021-03-08 13:37:16.616 - debug: smartmeter.0 (1986) States connected to redis: 127.0.0.1:9000
            2021-03-08 13:37:16.618 - debug: smartmeter.0 (1986) statesDB connected
            2021-03-08 13:37:16.860 - debug: smartmeter.0 (1986) Plugin sentry Initialize Plugin (enabled=true)
            2021-03-08 13:37:17.269 - info: smartmeter.0 (1986) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.21.0, js-controller: 3.2.16
            2021-03-08 13:37:17.320 - debug: smartmeter.0 (1986) SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"3","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false,"obisFallbackMedium":0}
            2021-03-08 13:37:17.325 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:37:17.339 - debug: smartmeter.0 (1986) SERIALPORT OPEN
            2021-03-08 13:37:17.371 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:37:17.404 - debug: smartmeter.0 (1986) connected set to false
            2021-03-08 13:38:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:39:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:39:17.373 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:39:17.375 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:39:17.378 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
            2021-03-08 13:39:17.379 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:39:17.380 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
            2021-03-08 13:39:17.388 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
            2021-03-08 13:39:17.391 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
            2021-03-08 13:39:20.393 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:39:20.402 - debug: smartmeter.0 (1986) SERIALPORT OPEN
            2021-03-08 13:39:20.407 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:40:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:41:00.001 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:41:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:41:20.410 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:41:20.411 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:41:20.412 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
            2021-03-08 13:41:20.413 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:41:20.413 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
            2021-03-08 13:41:20.418 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
            2021-03-08 13:41:20.420 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
            2021-03-08 13:41:23.422 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:41:23.431 - debug: smartmeter.0 (1986) SERIALPORT OPEN
            2021-03-08 13:41:23.435 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:41:40.955 - debug: smartmeter.1 (1701) CREATE SERIALPORT: 300 7 1 even
            2021-03-08 13:41:40.963 - debug: smartmeter.1 (1701) SERIALPORT OPEN
            2021-03-08 13:41:40.967 - debug: smartmeter.1 (1701) SERIALPORT RESET BAUDRATE TO 300
            2021-03-08 13:41:40.971 - debug: smartmeter.1 (1701) INITIAL MESSAGES TO SEND: 2
            2021-03-08 13:41:40.975 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
            2021-03-08 13:41:40.976 - debug: smartmeter.1 (1701) TO SEND 2:
            2021-03-08 13:41:40.977 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
            2021-03-08 13:41:40.978 - debug: smartmeter.1 (1701) TO SEND 1: /?!
            2021-03-08 13:41:41.137 - debug: smartmeter.1 (1701) DONE SEND 1
            2021-03-08 13:41:41.389 - debug: smartmeter.1 (1701) DONE SEND 0
            2021-03-08 13:41:41.390 - debug: smartmeter.1 (1701) SET MESSAGE TIMEOUT TIMER2: 120000
            2021-03-08 13:42:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:43:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:43:23.438 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:43:23.440 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:43:23.441 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
            2021-03-08 13:43:23.442 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:43:23.443 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
            2021-03-08 13:43:23.448 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
            2021-03-08 13:43:23.450 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
            2021-03-08 13:43:26.452 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:43:26.461 - debug: smartmeter.0 (1986) SERIALPORT OPEN
            2021-03-08 13:43:26.466 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:43:41.391 - debug: smartmeter.1 (1701) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:43:41.393 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:43:41.394 - warn: smartmeter.1 (1701) No or too long answer from Serial Device after last request.
            2021-03-08 13:43:41.396 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:43:41.397 - debug: smartmeter.1 (1701) Transport Reset!! Restart = true
            2021-03-08 13:43:41.398 - debug: smartmeter.1 (1701) STOP
            2021-03-08 13:43:41.399 - debug: smartmeter.1 (1701) CLEAR MESSAGE TIMEOUT TIMER
            2021-03-08 13:43:41.405 - debug: smartmeter.1 (1701) SERIALPORT CLOSE
            2021-03-08 13:43:41.407 - debug: smartmeter.1 (1701) SERIALPORT REMOVE LISTENERS
            2021-03-08 13:43:41.409 - debug: smartmeter.1 (1701) CURRENT SIGNON MESSAGE COUNTER 1 OF 1
            2021-03-08 13:43:41.411 - debug: smartmeter.1 (1701) DELETE rest of data (0) because new Message start with a new Request Message
            2021-03-08 13:43:41.413 - debug: smartmeter.1 (1701) SCHEDULE NEXT RUN IN 300000s
            2021-03-08 13:44:00.004 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:45:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:45:26.469 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:45:26.471 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:45:26.472 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
            2021-03-08 13:45:26.474 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:45:26.475 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
            2021-03-08 13:45:26.487 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
            2021-03-08 13:45:26.489 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
            2021-03-08 13:45:29.491 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:45:29.498 - debug: smartmeter.0 (1986) SERIALPORT OPEN
            2021-03-08 13:45:29.502 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:46:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:47:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:47:29.505 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:47:29.507 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:47:29.508 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
            2021-03-08 13:47:29.509 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:47:29.510 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
            2021-03-08 13:47:29.520 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
            2021-03-08 13:47:29.522 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
            2021-03-08 13:47:32.523 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
            2021-03-08 13:47:32.530 - debug: smartmeter.0 (1986) SERIALPORT OPEN
            2021-03-08 13:47:32.533 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
            2021-03-08 13:48:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:48:41.416 - debug: smartmeter.1 (1701) CREATE SERIALPORT: 300 7 1 even
            2021-03-08 13:48:41.424 - debug: smartmeter.1 (1701) SERIALPORT OPEN
            2021-03-08 13:48:41.428 - debug: smartmeter.1 (1701) SERIALPORT RESET BAUDRATE TO 300
            2021-03-08 13:48:41.431 - debug: smartmeter.1 (1701) INITIAL MESSAGES TO SEND: 2
            2021-03-08 13:48:41.436 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
            2021-03-08 13:48:41.438 - debug: smartmeter.1 (1701) TO SEND 2:
            2021-03-08 13:48:41.439 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
            2021-03-08 13:48:41.441 - debug: smartmeter.1 (1701) TO SEND 1: /?!
            2021-03-08 13:48:41.605 - debug: smartmeter.1 (1701) DONE SEND 1
            2021-03-08 13:48:41.857 - debug: smartmeter.1 (1701) DONE SEND 0
            2021-03-08 13:48:41.858 - debug: smartmeter.1 (1701) SET MESSAGE TIMEOUT TIMER2: 120000
            2021-03-08 13:49:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
            2021-03-08 13:49:32.536 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
            2021-03-08 13:49:32.538 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:49:32.539 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
            2021-03-08 13:49:32.540 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
            2021-03-08 13:49:32.541 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
            2021-03-08 13:49:32.546 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
            2021-03-08 13:49:32.547 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
              @wendy2702 Hallo
              wendy2702W Online
              wendy2702W Online
              @marcel-drzal Poste mal ein Screenshot der Einstellungen und drehe zum testen den Lesekopf mal um 180 Grad.
              Hast du aktuell nur einen oder beide Lesekoepfe angeschlossen?
                @wendy2702 ich habe den Lesekopf zu testzwecken noch nicht am Zähler, da ich erst am aufbau bin. ich wollte ihn mit einer Taschenlampe antriggern?
                  @wendy2702 beide und auch mal mit einem Versucht selbe resultat
                    wendy2702W Online
                    wendy2702W Online
                    @marcel-drzal sagte in smartmeter instaz gelb:
                    Sorry aber ist jetzt ein Scherz, oder? 😞
                    Was erwartest du vom Lesekopf und dem Adapter wenn du ihn mit einer Taschenlampe anleuchtest?
                    Kannst du mit 9600Baud und dem entsprechenden Protokoll die Taschenlampe bedienen?
                    Der Adapter wird erst GRÜN wenn er valide Daten empfängt.
                    Also bevor der Lesekopf nicht auf dem Zähler sitzt müssen wir hier nichts weiter prüfen und Zeit verschwenden.
                      @wendy2702 Danke dir es Funktioniert nun nach einbau.
                      noch einer Frage
                      Ich habe 2 Raspi mit Multihost.
                      Kann nun im iobroker mit einer IP beide bedienen.
                      Die influxDB auf dem Master Loggt nur daten vom Master (Nr 2). (zBsp,; KNX welcher auf dem Master ist)
                      Die Stromdaten befinden sich aber auf dem Slave.
                      Muss 2 Influx Dadenbanke erstellen oder geht das auch anders? Brauche sie für Grafana, dort sehe ich auch nur die influx Daten von KNX und keine Stromdaten.
                      hoffe ihr könnt mir Helfen.
                      HomoranH wendy2702W 2 Antworten Letzte Antwort
                        noch einer Frage
                        zeig mal die Objekte vom zweiten Zähler
                          noch einer Frage
                          wendy2702W Online
                          wendy2702W Online
                          Die Daten vom Smartmeter sollten bei richtiger Master - Slave Konfiguration auch auf dem Master unter den Objekten sichtbar sein. Zumindest ist es bei mir so. Bedeutet du solltest unter den Objekten alle Datenpunkte sehen was wir gerne, wie @Homoran geschrieben hat, mit einem Screenshot sehen würden.
                            Rasperry1 Slave
                            Rasperry2 Master siehe oben ds Bild
                            ? HomoranH 2 Antworten Letzte Antwort
                              Rasperry1 Slave
                              0431dad9-ad06-44fd-8376-9db0280bf850-grafik.png ich sehe Alle
                              und in Grafana kommen nur Daten von KNX an welcher unter dem Master auch läuft
                              vom Slave kommt nicht an über InfluxDB
                                wendy2702W Online
                                wendy2702W Online
                                @marcel-drzal Hast du denn das Schreiben in Influx für die Datenpunkte aktiviert ?
                                  Rasperry1 Slave
                                  da sehe ich leider nicht die Datenpunkte
                                      @marcel-drzal so!
                                      und jetzt noch die Einstellungen im Schraubenschlüssel
                                        @marcel-drzal so!
                                        ich glaub das Problem liegt im Multihost rasperry1 Slave und rasperry2 Master.
                                        Grafana läuft ja unter 192.168.178.44/24
                                        wie stell ich das im Slave (Rasperry1) ein? was denk du
                                        Werte werden gelockt im Schraubenschlüssel 1acb6bc8-e8e3-47f4-80fb-6721d3e4e0e0-grafik.png
                                        nur nicht auf Grafana weiter gegeben
                                          nein!
                                          denn...
                                          dann ist das ein Grafana Problem
