  4. [gelöst] smartmeter instaz gelb
35 Beiträge 3 Kommentatoren 3.5k Aufrufe 2 Beobachtet
    @wendy2702
    2021-03-07 16:03:31.921 - info: javascript.0 (1229) received all states
    2021-03-07 16:03:31.981 - info: javascript.0 (1229) Start javascript script.js.common.Stromzäler
    2021-03-07 16:03:32.128 - info: javascript.0 (1229) script.js.common.Stromzäler: registered 1 subscription and 0 schedules
    2021-03-07 16:03:32.150 - info: javascript.0 (1229) Start javascript script.js.common.Stromzähler_2__Skriipt
    2021-03-07 16:03:32.162 - info: javascript.0 (1229) script.js.common.Stromzähler_2__Skriipt: registered 1 subscription and 0 schedules
    2021-03-07 16:05:23.664 - info: smartmeter.0 (829) Error: No or too long answer from Serial Device after last request.
    2021-03-07 16:05:23.669 - warn: smartmeter.0 (829) No or too long answer from Serial Device after last request.
    2021-03-07 16:07:26.691 - info: smartmeter.0 (829) Error: No or too long answer from Serial Device after last request.
    2021-03-07 16:07:26.693 - warn: smartmeter.0 (829) No or too long answer from Serial Device after last request.
    2021-03-07 16:07:37.932 - info: smartmeter.0 (829) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"manufacturer":"Silicon Labs","serialNumber":"0047","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"manufacturer":"Silicon Labs","serialNumber":"0027","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0027-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB1"}]
    2021-03-07 16:09:29.709 - info: smartmeter.0 (829) Error: No or too long answer from Serial Device after last request.
    2021-03-07 16:09:29.711 - warn: smartmeter.0 (829) No or too long answer from Serial Device after last request.
    2021-03-07 16:11:32.727 - info: smartmeter.0 (829) Error: No or too long answer from Serial Device after last request.
    2021-03-07 16:11:32.729 - warn: smartmeter.0 (829) No or too long answer from Serial Device after last request.
    2021-03-07 16:13:35.745 - info: smartmeter.0 (829) Error: No or too long answer from Serial Device after last request.
    2021-03-07 16:13:35.747 - warn: smartmeter.0 (829) No or too long answer from Serial Device after last request.
    wendy2702W Online
    wendy2702W Online
    @marcel-drzal Fehlen noch ein paar Infos.
    Log bitte auch noch auf Debug stellen.
    Dazu den Experten Modus auf der Instanzseite aktivieren: Im bild oben links und dann hinter der Instanz von Info auf Debug stellen. Beispiel zeigt DWD Adapter:
    • ? Offline
      2021-03-07 16:25:01.346 - debug: smartmeter.0 (1615) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2021-03-07 16:25:01.402 - debug: smartmeter.0 (1615) Objects client ready ... initialize now
      2021-03-07 16:25:01.406 - debug: smartmeter.0 (1615) Objects create System PubSub Client
      2021-03-07 16:25:01.409 - debug: smartmeter.0 (1615) Objects create User PubSub Client
      2021-03-07 16:25:01.411 - debug: smartmeter.0 (1615) Objects client initialize lua scripts
      2021-03-07 16:25:01.433 - debug: smartmeter.0 (1615) Objects connected to redis: 127.0.0.1:9001
      2021-03-07 16:25:01.452 - debug: smartmeter.0 (1615) objectDB connected
      2021-03-07 16:25:01.457 - debug: smartmeter.0 (1615) Redis States: Use Redis connection: 127.0.0.1:9000
      2021-03-07 16:25:01.470 - debug: smartmeter.0 (1615) States create System PubSub Client
      2021-03-07 16:25:01.473 - debug: smartmeter.0 (1615) States create User PubSub Client
      2021-03-07 16:25:01.486 - debug: smartmeter.0 (1615) States connected to redis: 127.0.0.1:9000
      2021-03-07 16:25:01.488 - debug: smartmeter.0 (1615) statesDB connected
      2021-03-07 16:25:01.717 - debug: smartmeter.0 (1615) Plugin sentry Initialize Plugin (enabled=true)
      2021-03-07 16:25:02.131 - info: smartmeter.0 (1615) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.21.0, js-controller: 3.2.16
      2021-03-07 16:25:02.185 - debug: smartmeter.0 (1615) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"3","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":0,"obisFallbackMedium":0}
      2021-03-07 16:25:02.191 - debug: smartmeter.0 (1615) CREATE SERIALPORT: 9600 8 1 none
      2021-03-07 16:25:02.208 - debug: smartmeter.0 (1615) SERIALPORT OPEN
      2021-03-07 16:25:02.238 - debug: smartmeter.0 (1615) SET MESSAGE TIMEOUT TIMER: 120000
      2021-03-07 16:25:02.252 - debug: smartmeter.0 (1615) connected set to false
      2021-03-07 16:26:01.423 - debug: smartmeter.0 (1615) Message received = {"command":"listUart","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":14,"ack":false,"time":1615130761418},"_id":11081440}
      2021-03-07 16:26:01.716 - info: smartmeter.0 (1615) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"manufacturer":"Silicon Labs","serialNumber":"0047","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"manufacturer":"Silicon Labs","serialNumber":"0027","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0027-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB1"}]
      2021-03-07 16:26:01.719 - debug: smartmeter.0 (1615) sendTo "listUart" to system.adapter.admin.0 from system.adapter.smartmeter.0
      2021-03-07 16:26:56.537 - debug: smartmeter.0 (1615) system.adapter.admin.0: logging true
      2021-03-07 16:27:02.240 - debug: smartmeter.0 (1615) MESSAGE TIMEOUT TRIGGERED
      2021-03-07 16:27:02.242 - debug: smartmeter.0 (1615) Error: No or too long answer from Serial Device after last request.
      2021-03-07 16:27:02.246 - warn: smartmeter.0 (1615) No or too long answer from Serial Device after last request.
      2021-03-07 16:27:02.247 - debug: smartmeter.0 (1615) Error: No or too long answer from Serial Device after last request.
      2021-03-07 16:27:02.249 - debug: smartmeter.0 (1615) Transport Reset!! Restart = true
      2021-03-07 16:27:02.260 - debug: smartmeter.0 (1615) SERIALPORT CLOSE
      2021-03-07 16:27:02.262 - debug: smartmeter.0 (1615) SCHEDULE NEXT RUN IN 3s
      2021-03-07 16:27:05.266 - debug: smartmeter.0 (1615) CREATE SERIALPORT: 9600 8 1 none
      2021-03-07 16:27:05.275 - debug: smartmeter.0 (1615) SERIALPORT OPEN
      2021-03-07 16:27:05.280 - debug: smartmeter.0 (1615) SET MESSAGE TIMEOUT TIMER: 120000
      DrehstromzählerTyp ISKRA MT681
        wendy2702W Online
        wendy2702W Online
        @marcel-drzal Ich warte mal bis alle Fragen beantwortet sind.
        ? 2 Antworten Letzte Antwort
        • wendy2702W wendy2702
          @wendy2702
          danke für eure Hilfe
            @wendy2702 sollte alles beantwortet haben. 👍
              wendy2702W Online
              wendy2702W Online
              @marcel-drzal MIt der Information des Zählertypes spuckt die Suche unter anderem das aus:
              https://forum.iobroker.net/topic/14292/hilfe-smartmeter-adapter?page=1
              Und noch gaaaaannnnnzzzzz viele andere:
              https://forum.iobroker.net/search?term=ISKRA MT681&in=titlesposts
                @wendy2702 Hallo
                leider geht er immer noch nicht, habe mit den Einstellungen versucht, was ich gelesen hatte. Leider immer noch gelb. was liest du aus dem Log?
                r.0 (1923) SERIALPORT OPEN
                2021-03-08 13:30:21.691 - debug: smartmeter.0 (1923) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:30:21.711 - debug: smartmeter.0 (1923) connected set to false
                2021-03-08 13:31:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:31:42.530 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
                2021-03-08 13:31:42.541 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 send kill signal
                2021-03-08 13:31:42.542 - info: smartmeter.0 (1923) Got terminate signal TERMINATE_YOURSELF
                2021-03-08 13:31:42.554 - debug: smartmeter.0 (1923) SERIALPORT CLOSE
                2021-03-08 13:31:42.557 - info: smartmeter.0 (1923) terminating
                2021-03-08 13:31:42.560 - debug: smartmeter.0 (1923) Plugin sentry destroyed
                2021-03-08 13:31:42.562 - info: smartmeter.0 (1923) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-03-08 13:31:43.135 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-03-08 13:31:45.675 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 started with pid 1939
                2021-03-08 13:31:47.218 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging false
                2021-03-08 13:31:48.166 - debug: smartmeter.0 (1939) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2021-03-08 13:31:48.221 - debug: smartmeter.0 (1939) Objects client ready ... initialize now
                2021-03-08 13:31:48.225 - debug: smartmeter.0 (1939) Objects create System PubSub Client
                2021-03-08 13:31:48.227 - debug: smartmeter.0 (1939) Objects create User PubSub Client
                2021-03-08 13:31:48.230 - debug: smartmeter.0 (1939) Objects client initialize lua scripts
                2021-03-08 13:31:48.251 - debug: smartmeter.0 (1939) Objects connected to redis: 127.0.0.1:9001
                2021-03-08 13:31:48.269 - debug: smartmeter.0 (1939) objectDB connected
                2021-03-08 13:31:48.274 - debug: smartmeter.0 (1939) Redis States: Use Redis connection: 127.0.0.1:9000
                2021-03-08 13:31:48.287 - debug: smartmeter.0 (1939) States create System PubSub Client
                2021-03-08 13:31:48.290 - debug: smartmeter.0 (1939) States create User PubSub Client
                2021-03-08 13:31:48.303 - debug: smartmeter.0 (1939) States connected to redis: 127.0.0.1:9000
                2021-03-08 13:31:48.305 - debug: smartmeter.0 (1939) statesDB connected
                2021-03-08 13:31:48.607 - debug: smartmeter.0 (1939) Plugin sentry Initialize Plugin (enabled=true)
                2021-03-08 13:31:48.990 - info: smartmeter.0 (1939) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 13:31:49.041 - debug: smartmeter.0 (1939) SmartmeterObis options: {"debug":2,"protocol":"D0Protocol","transport":"SerialResponseTransport","requestInterval":"3","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolD0WakeupCharacters":0,"obisFallbackMedium":0}
                2021-03-08 13:31:49.047 - debug: smartmeter.0 (1939) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:31:49.060 - debug: smartmeter.0 (1939) SERIALPORT OPEN
                2021-03-08 13:31:49.093 - debug: smartmeter.0 (1939) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:31:49.112 - debug: smartmeter.0 (1939) connected set to false
                2021-03-08 13:32:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:32:01.435 - debug: smartmeter.0 (1939) Message received = {"command":"listUart","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":32,"ack":false,"time":1615206721431},"_id":45775062}
                2021-03-08 13:32:01.728 - info: smartmeter.0 (1939) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"manufacturer":"Silicon Labs","serialNumber":"0047","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"manufacturer":"Silicon Labs","serialNumber":"0027","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0027-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB1"}]
                2021-03-08 13:32:01.731 - debug: smartmeter.0 (1939) sendTo "listUart" to system.adapter.admin.0 from system.adapter.smartmeter.0
                2021-03-08 13:32:12.739 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging true
                2021-03-08 13:32:12.742 - debug: smartmeter.0 (1939) system.adapter.admin.0: logging true
                2021-03-08 13:33:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:33:49.095 - debug: smartmeter.0 (1939) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:33:49.097 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:33:49.101 - warn: smartmeter.0 (1939) No or too long answer from Serial Device after last request.
                2021-03-08 13:33:49.102 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:33:49.103 - debug: smartmeter.0 (1939) Transport Reset!! Restart = true
                2021-03-08 13:33:49.114 - debug: smartmeter.0 (1939) SERIALPORT CLOSE
                2021-03-08 13:33:49.117 - debug: smartmeter.0 (1939) SCHEDULE NEXT RUN IN 3s
                2021-03-08 13:33:52.120 - debug: smartmeter.0 (1939) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:33:52.128 - debug: smartmeter.0 (1939) SERIALPORT OPEN
                2021-03-08 13:33:52.133 - debug: smartmeter.0 (1939) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:34:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:34:40.491 - debug: smartmeter.1 (1701) CREATE SERIALPORT: 300 7 1 even
                2021-03-08 13:34:40.498 - debug: smartmeter.1 (1701) SERIALPORT OPEN
                2021-03-08 13:34:40.502 - debug: smartmeter.1 (1701) SERIALPORT RESET BAUDRATE TO 300
                2021-03-08 13:34:40.505 - debug: smartmeter.1 (1701) INITIAL MESSAGES TO SEND: 2
                2021-03-08 13:34:40.507 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
                2021-03-08 13:34:40.509 - debug: smartmeter.1 (1701) TO SEND 2:
                2021-03-08 13:34:40.510 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
                2021-03-08 13:34:40.511 - debug: smartmeter.1 (1701) TO SEND 1: /?!
                2021-03-08 13:34:40.676 - debug: smartmeter.1 (1701) DONE SEND 1
                2021-03-08 13:34:40.928 - debug: smartmeter.1 (1701) DONE SEND 0
                2021-03-08 13:34:40.929 - debug: smartmeter.1 (1701) SET MESSAGE TIMEOUT TIMER2: 120000
                2021-03-08 13:35:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:35:52.135 - debug: smartmeter.0 (1939) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:35:52.137 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:35:52.139 - warn: smartmeter.0 (1939) No or too long answer from Serial Device after last request.
                2021-03-08 13:35:52.140 - debug: smartmeter.0 (1939) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:35:52.141 - debug: smartmeter.0 (1939) Transport Reset!! Restart = true
                2021-03-08 13:35:52.151 - debug: smartmeter.0 (1939) SERIALPORT CLOSE
                2021-03-08 13:35:52.154 - debug: smartmeter.0 (1939) SCHEDULE NEXT RUN IN 3s
                2021-03-08 13:35:55.155 - debug: smartmeter.0 (1939) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:35:55.164 - debug: smartmeter.0 (1939) SERIALPORT OPEN
                2021-03-08 13:35:55.168 - debug: smartmeter.0 (1939) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:36:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:36:37.322 - debug: smartmeter.0 (1939) Message received = {"command":"listUart","message":null,"from":"system.adapter.admin.0","callback":{"message":null,"id":34,"ack":false,"time":1615206997319},"_id":45775064}
                2021-03-08 13:36:37.603 - info: smartmeter.0 (1939) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyS0"},{"manufacturer":"Silicon Labs","serialNumber":"0047","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB0"},{"manufacturer":"Silicon Labs","serialNumber":"0027","pnpId":"usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0027-if00-port0","vendorId":"10c4","productId":"ea60","path":"/dev/ttyUSB1"}]
                2021-03-08 13:36:37.605 - debug: smartmeter.0 (1939) sendTo "listUart" to system.adapter.admin.0 from system.adapter.smartmeter.0
                2021-03-08 13:36:40.931 - debug: smartmeter.1 (1701) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:36:40.933 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:36:40.934 - warn: smartmeter.1 (1701) No or too long answer from Serial Device after last request.
                2021-03-08 13:36:40.935 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:36:40.936 - debug: smartmeter.1 (1701) Transport Reset!! Restart = true
                2021-03-08 13:36:40.937 - debug: smartmeter.1 (1701) STOP
                2021-03-08 13:36:40.938 - debug: smartmeter.1 (1701) CLEAR MESSAGE TIMEOUT TIMER
                2021-03-08 13:36:40.946 - debug: smartmeter.1 (1701) SERIALPORT CLOSE
                2021-03-08 13:36:40.947 - debug: smartmeter.1 (1701) SERIALPORT REMOVE LISTENERS
                2021-03-08 13:36:40.949 - debug: smartmeter.1 (1701) CURRENT SIGNON MESSAGE COUNTER 1 OF 1
                2021-03-08 13:36:40.951 - debug: smartmeter.1 (1701) DELETE rest of data (0) because new Message start with a new Request Message
                2021-03-08 13:36:40.952 - debug: smartmeter.1 (1701) SCHEDULE NEXT RUN IN 300000s
                2021-03-08 13:36:42.324 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging false
                2021-03-08 13:36:42.325 - debug: smartmeter.0 (1939) system.adapter.admin.0: logging false
                2021-03-08 13:37:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:37:10.882 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 (force=false, process=true)
                2021-03-08 13:37:10.891 - info: smartmeter.0 (1939) Got terminate signal TERMINATE_YOURSELF
                2021-03-08 13:37:10.891 - info: host.raspberrypi1 stopInstance system.adapter.smartmeter.0 send kill signal
                2021-03-08 13:37:10.898 - debug: smartmeter.0 (1939) SERIALPORT CLOSE
                2021-03-08 13:37:10.900 - info: smartmeter.0 (1939) terminating
                2021-03-08 13:37:10.902 - debug: smartmeter.0 (1939) Plugin sentry destroyed
                2021-03-08 13:37:10.903 - info: smartmeter.0 (1939) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2021-03-08 13:37:11.035 - debug: smartmeter.1 (1701) system.adapter.admin.0: logging true
                2021-03-08 13:37:11.038 - debug: smartmeter.0 (1939) system.adapter.admin.0: logging true
                2021-03-08 13:37:11.535 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2021-03-08 13:37:13.971 - info: host.raspberrypi1 instance system.adapter.smartmeter.0 started with pid 1986
                2021-03-08 13:37:16.478 - debug: smartmeter.0 (1986) Redis Objects: Use Redis connection: 127.0.0.1:9001
                2021-03-08 13:37:16.534 - debug: smartmeter.0 (1986) Objects client ready ... initialize now
                2021-03-08 13:37:16.538 - debug: smartmeter.0 (1986) Objects create System PubSub Client
                2021-03-08 13:37:16.541 - debug: smartmeter.0 (1986) Objects create User PubSub Client
                2021-03-08 13:37:16.543 - debug: smartmeter.0 (1986) Objects client initialize lua scripts
                2021-03-08 13:37:16.564 - debug: smartmeter.0 (1986) Objects connected to redis: 127.0.0.1:9001
                2021-03-08 13:37:16.582 - debug: smartmeter.0 (1986) objectDB connected
                2021-03-08 13:37:16.587 - debug: smartmeter.0 (1986) Redis States: Use Redis connection: 127.0.0.1:9000
                2021-03-08 13:37:16.600 - debug: smartmeter.0 (1986) States create System PubSub Client
                2021-03-08 13:37:16.603 - debug: smartmeter.0 (1986) States create User PubSub Client
                2021-03-08 13:37:16.616 - debug: smartmeter.0 (1986) States connected to redis: 127.0.0.1:9000
                2021-03-08 13:37:16.618 - debug: smartmeter.0 (1986) statesDB connected
                2021-03-08 13:37:16.860 - debug: smartmeter.0 (1986) Plugin sentry Initialize Plugin (enabled=true)
                2021-03-08 13:37:17.269 - info: smartmeter.0 (1986) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.smartmeter, node: v12.21.0, js-controller: 3.2.16
                2021-03-08 13:37:17.320 - debug: smartmeter.0 (1986) SmartmeterObis options: {"debug":2,"protocol":"SmlProtocol","transport":"SerialResponseTransport","requestInterval":"3","anotherQueryDelay":"1000","transportSerialPort":"/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0047-if00-port0","transportSerialBaudrate":null,"transportSerialMessageTimeout":null,"protocolSmlIgnoreInvalidCRC":false,"obisFallbackMedium":0}
                2021-03-08 13:37:17.325 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:37:17.339 - debug: smartmeter.0 (1986) SERIALPORT OPEN
                2021-03-08 13:37:17.371 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:37:17.404 - debug: smartmeter.0 (1986) connected set to false
                2021-03-08 13:38:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:39:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:39:17.373 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:39:17.375 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:39:17.378 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
                2021-03-08 13:39:17.379 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:39:17.380 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
                2021-03-08 13:39:17.388 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
                2021-03-08 13:39:17.391 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
                2021-03-08 13:39:20.393 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:39:20.402 - debug: smartmeter.0 (1986) SERIALPORT OPEN
                2021-03-08 13:39:20.407 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:40:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:41:00.001 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:41:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:41:20.410 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:41:20.411 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:41:20.412 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
                2021-03-08 13:41:20.413 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:41:20.413 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
                2021-03-08 13:41:20.418 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
                2021-03-08 13:41:20.420 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
                2021-03-08 13:41:23.422 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:41:23.431 - debug: smartmeter.0 (1986) SERIALPORT OPEN
                2021-03-08 13:41:23.435 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:41:40.955 - debug: smartmeter.1 (1701) CREATE SERIALPORT: 300 7 1 even
                2021-03-08 13:41:40.963 - debug: smartmeter.1 (1701) SERIALPORT OPEN
                2021-03-08 13:41:40.967 - debug: smartmeter.1 (1701) SERIALPORT RESET BAUDRATE TO 300
                2021-03-08 13:41:40.971 - debug: smartmeter.1 (1701) INITIAL MESSAGES TO SEND: 2
                2021-03-08 13:41:40.975 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
                2021-03-08 13:41:40.976 - debug: smartmeter.1 (1701) TO SEND 2:
                2021-03-08 13:41:40.977 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
                2021-03-08 13:41:40.978 - debug: smartmeter.1 (1701) TO SEND 1: /?!
                2021-03-08 13:41:41.137 - debug: smartmeter.1 (1701) DONE SEND 1
                2021-03-08 13:41:41.389 - debug: smartmeter.1 (1701) DONE SEND 0
                2021-03-08 13:41:41.390 - debug: smartmeter.1 (1701) SET MESSAGE TIMEOUT TIMER2: 120000
                2021-03-08 13:42:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:43:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:43:23.438 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:43:23.440 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:43:23.441 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
                2021-03-08 13:43:23.442 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:43:23.443 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
                2021-03-08 13:43:23.448 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
                2021-03-08 13:43:23.450 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
                2021-03-08 13:43:26.452 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:43:26.461 - debug: smartmeter.0 (1986) SERIALPORT OPEN
                2021-03-08 13:43:26.466 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:43:41.391 - debug: smartmeter.1 (1701) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:43:41.393 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:43:41.394 - warn: smartmeter.1 (1701) No or too long answer from Serial Device after last request.
                2021-03-08 13:43:41.396 - debug: smartmeter.1 (1701) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:43:41.397 - debug: smartmeter.1 (1701) Transport Reset!! Restart = true
                2021-03-08 13:43:41.398 - debug: smartmeter.1 (1701) STOP
                2021-03-08 13:43:41.399 - debug: smartmeter.1 (1701) CLEAR MESSAGE TIMEOUT TIMER
                2021-03-08 13:43:41.405 - debug: smartmeter.1 (1701) SERIALPORT CLOSE
                2021-03-08 13:43:41.407 - debug: smartmeter.1 (1701) SERIALPORT REMOVE LISTENERS
                2021-03-08 13:43:41.409 - debug: smartmeter.1 (1701) CURRENT SIGNON MESSAGE COUNTER 1 OF 1
                2021-03-08 13:43:41.411 - debug: smartmeter.1 (1701) DELETE rest of data (0) because new Message start with a new Request Message
                2021-03-08 13:43:41.413 - debug: smartmeter.1 (1701) SCHEDULE NEXT RUN IN 300000s
                2021-03-08 13:44:00.004 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:45:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:45:26.469 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:45:26.471 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:45:26.472 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
                2021-03-08 13:45:26.474 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:45:26.475 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
                2021-03-08 13:45:26.487 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
                2021-03-08 13:45:26.489 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
                2021-03-08 13:45:29.491 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:45:29.498 - debug: smartmeter.0 (1986) SERIALPORT OPEN
                2021-03-08 13:45:29.502 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:46:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:47:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:47:29.505 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:47:29.507 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:47:29.508 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
                2021-03-08 13:47:29.509 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:47:29.510 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
                2021-03-08 13:47:29.520 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
                2021-03-08 13:47:29.522 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
                2021-03-08 13:47:32.523 - debug: smartmeter.0 (1986) CREATE SERIALPORT: 9600 8 1 none
                2021-03-08 13:47:32.530 - debug: smartmeter.0 (1986) SERIALPORT OPEN
                2021-03-08 13:47:32.533 - debug: smartmeter.0 (1986) SET MESSAGE TIMEOUT TIMER: 120000
                2021-03-08 13:48:00.003 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:48:41.416 - debug: smartmeter.1 (1701) CREATE SERIALPORT: 300 7 1 even
                2021-03-08 13:48:41.424 - debug: smartmeter.1 (1701) SERIALPORT OPEN
                2021-03-08 13:48:41.428 - debug: smartmeter.1 (1701) SERIALPORT RESET BAUDRATE TO 300
                2021-03-08 13:48:41.431 - debug: smartmeter.1 (1701) INITIAL MESSAGES TO SEND: 2
                2021-03-08 13:48:41.436 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 0 IN GETNEXTMESSAGE
                2021-03-08 13:48:41.438 - debug: smartmeter.1 (1701) TO SEND 2:
                2021-03-08 13:48:41.439 - debug: smartmeter.1 (1701) CURRENT PROCESS STEP 1 IN GETNEXTMESSAGE
                2021-03-08 13:48:41.441 - debug: smartmeter.1 (1701) TO SEND 1: /?!
                2021-03-08 13:48:41.605 - debug: smartmeter.1 (1701) DONE SEND 1
                2021-03-08 13:48:41.857 - debug: smartmeter.1 (1701) DONE SEND 0
                2021-03-08 13:48:41.858 - debug: smartmeter.1 (1701) SET MESSAGE TIMEOUT TIMER2: 120000
                2021-03-08 13:49:00.002 - warn: javascript.0 (1449) State "javascript.0.variables.dayTime" has no existing object, this might lead to an error in future versions
                2021-03-08 13:49:32.536 - debug: smartmeter.0 (1986) MESSAGE TIMEOUT TRIGGERED
                2021-03-08 13:49:32.538 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:49:32.539 - warn: smartmeter.0 (1986) No or too long answer from Serial Device after last request.
                2021-03-08 13:49:32.540 - debug: smartmeter.0 (1986) Error: No or too long answer from Serial Device after last request.
                2021-03-08 13:49:32.541 - debug: smartmeter.0 (1986) Transport Reset!! Restart = true
                2021-03-08 13:49:32.546 - debug: smartmeter.0 (1986) SERIALPORT CLOSE
                2021-03-08 13:49:32.547 - debug: smartmeter.0 (1986) SCHEDULE NEXT RUN IN 3s
                  @wendy2702 Hallo
                  wendy2702W Online
                  wendy2702W Online
                  @marcel-drzal Poste mal ein Screenshot der Einstellungen und drehe zum testen den Lesekopf mal um 180 Grad.
                  Hast du aktuell nur einen oder beide Lesekoepfe angeschlossen?
                    @wendy2702 ich habe den Lesekopf zu testzwecken noch nicht am Zähler, da ich erst am aufbau bin. ich wollte ihn mit einer Taschenlampe antriggern?
                      @wendy2702 beide und auch mal mit einem Versucht selbe resultat
                        wendy2702W Online
                        wendy2702W Online
                        @marcel-drzal sagte in smartmeter instaz gelb:
                        Sorry aber ist jetzt ein Scherz, oder? 😞
                        Was erwartest du vom Lesekopf und dem Adapter wenn du ihn mit einer Taschenlampe anleuchtest?
                        Kannst du mit 9600Baud und dem entsprechenden Protokoll die Taschenlampe bedienen?
                        Der Adapter wird erst GRÜN wenn er valide Daten empfängt.
                        Also bevor der Lesekopf nicht auf dem Zähler sitzt müssen wir hier nichts weiter prüfen und Zeit verschwenden.
                          @wendy2702 Danke dir es Funktioniert nun nach einbau.
                          noch einer Frage
                          Ich habe 2 Raspi mit Multihost.
                          Kann nun im iobroker mit einer IP beide bedienen.
                          Die influxDB auf dem Master Loggt nur daten vom Master (Nr 2). (zBsp,; KNX welcher auf dem Master ist)
                          Die Stromdaten befinden sich aber auf dem Slave.
                          Muss 2 Influx Dadenbanke erstellen oder geht das auch anders? Brauche sie für Grafana, dort sehe ich auch nur die influx Daten von KNX und keine Stromdaten.
                          hoffe ihr könnt mir Helfen.
                          HomoranH wendy2702W 2 Antworten Letzte Antwort
                            noch einer Frage
                            zeig mal die Objekte vom zweiten Zähler
                              noch einer Frage
                              wendy2702W Online
                              wendy2702W Online
                              Die Daten vom Smartmeter sollten bei richtiger Master - Slave Konfiguration auch auf dem Master unter den Objekten sichtbar sein. Zumindest ist es bei mir so. Bedeutet du solltest unter den Objekten alle Datenpunkte sehen was wir gerne, wie @Homoran geschrieben hat, mit einem Screenshot sehen würden.
                                Rasperry1 Slave
                                Rasperry2 Master siehe oben ds Bild
                                ? HomoranH 2 Antworten Letzte Antwort
                                  Rasperry1 Slave
                                  0431dad9-ad06-44fd-8376-9db0280bf850-grafik.png ich sehe Alle
                                  und in Grafana kommen nur Daten von KNX an welcher unter dem Master auch läuft
                                  vom Slave kommt nicht an über InfluxDB
                                    wendy2702W Online
                                    wendy2702W Online
                                    @marcel-drzal Hast du denn das Schreiben in Influx für die Datenpunkte aktiviert ?
                                      Rasperry1 Slave
                                      da sehe ich leider nicht die Datenpunkte
                                          @marcel-drzal so!
                                          und jetzt noch die Einstellungen im Schraubenschlüssel
