  4. Max7219 Wemos - loadSysConfig Fehler
    apollon77A
36 Beiträge 5 Kommentatoren 5.8k Aufrufe 5 Beobachtet
  • D
    D
    day83
    ich hab versucht mit auch so eine Matrix LED zu bauen - Anleitung wie hier.
    https://github.com/liv-in-sky/MatrixDisplayESP8266
    Leider funktioniert der Sketch nicht ganz ==> Fehler 'loadSysConfig'...
    Jemand eine Idee?
    Arduino: 1.8.13 (Windows 10), Board: "WeMos D1 R1, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    In file included from C:\Users\Franzi_Day\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include/sys/stdio.h:6:0,
                     from C:\Users\Franzi_Day\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include/stdio.h:63,
                     from C:\Users\Franzi_Day\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266/Arduino.h:32,
                     from sketch\sketch_Vers_3.ino.cpp:1:
    C:\Users\Franzi_Day\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/sdk/libc/xtensa-lx106-elf/include/sys/pgmspace.h:25:130: error: 'const char HTTP_HEAD []' redeclared as different kind of symbol
       #define PROGMEM __attribute__((section( "\".irom.text." __FILE__ "." __STRINGIZE(__LINE__) "."  __STRINGIZE(__COUNTER__) "\"")))
    C:\Users\Franzi_Day\Documents\Arduino\libraries\WM/WM.h:26:24: note: in expansion of macro 'PROGMEM'
     const char HTTP_HEAD[] PROGMEM            = "<!DOCTYPE html><html lang=\"en\"><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1, user-scalable=no\"/><title>{v}</title>";
    In file included from C:\Users\Franzi_Day\Documents\Arduino\libraries\WM/WM.h:17:0,
                     from E:\Smarthome\Display\Display version 3\sketch_Vers_3\sketch_Vers_3.ino:9:
    C:\Users\Franzi_Day\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WebServer\src/ESP8266WebServer.h:34:39: error: previous declaration of 'HTTPMethod HTTP_HEAD'
     enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
    E:\Smarthome\Display\Display version 3\sketch_Vers_3\sketch_Vers_3.ino: In function 'void setup()':
    sketch_Vers_3:258:24: error: 'loadSysConfig' was not declared in this scope
         if (!loadSysConfig()) {
    sketch_Vers_3:274:21: error: 'doWifiConnect' was not declared in this scope
       if (doWifiConnect() == true) {
    sketch_Vers_3:277:21: error: 'getNtpTime' was not declared in this scope
         setSyncProvider(getNtpTime);
    sketch_Vers_3:303:22: error: 'startOTAhandling' was not declared in this scope
         startOTAhandling();
    sketch_Vers_3:311:79: error: 'calcDate' was not declared in this scope
                    else if (MAX_DEVICES>8 && MAX_DEVICES<16) {datum=calcDate(now());}
    sketch_Vers_3:312:42: error: 'calcDate' was not declared in this scope
                    else {datum=calcDate(now());}
    sketch_Vers_3:314:37: error: 'calcTime' was not declared in this scope
                    Zeit = calcTime(now());
    E:\Smarthome\Display\Display version 3\sketch_Vers_3\sketch_Vers_3.ino: In function 'void loop()':
    sketch_Vers_3:330:26: error: 'saveSysConfig' was not declared in this scope
           if (!saveSysConfig()) {
    sketch_Vers_3:359:33: error: 'handleUDP' was not declared in this scope
       String udpMessage = handleUDP();
    sketch_Vers_3:530:36: error: 'calcTime' was not declared in this scope
                   Zeit = calcTime(now());zeitHolen=0;Serial.println("Zeitholen RESET------------------------------------------");}
    sketch_Vers_3:531:89: error: 'calcDate' was not declared in this scope
                   if (Zeit == "00 : 00" || (ntpSave)) { if (!zeitHelp) {datum=calcDate(now()); zeitHelp=true; ntpSave=false;}}   //wegen DATUM Umstellung
    sketch_Vers_3:577:33: error: 'calcTime' was not declared in this scope
                Zeit = calcTime(now());zeitHolenStandard=0;Serial.println("ZeitholenStandard RESET------------------------------------------");//}
    sketch_Vers_3:579:86: error: 'calcDate' was not declared in this scope
                if (Zeit == "00 : 00" || (ntpSave)) { if (!zeitHelp) {datum=calcDate(now()); zeitHelp=true; ntpSave=false;Serial.println("Tag holen : " +datum);}}   //wegen DATUM Umstellung
    Mehrere Bibliotheken wurden für "WiFiUdp.h" gefunden
     Benutzt: C:\Users\Franzi_Day\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi
     Nicht benutzt: C:\Program Files (x86)\Arduino\libraries\WiFi
    exit status 1
    Ungültige Bibliothek C:\Users\Franzi_Day\Documents\Arduino\libraries\ConfigFileHandling in keine Header-Dateien (.h) in C:\Users\Franzi_Day\Documents\Arduino\libraries\ConfigFileHandling gefunden gefunden
    Ungültige Bibliothek C:\Users\Franzi_Day\Documents\Arduino\libraries\OTA in keine Header-Dateien (.h) in C:\Users\Franzi_Day\Documents\Arduino\libraries\OTA gefunden gefunden
    Dieser Bericht wäre detaillierter, wenn die Option
    "Ausführliche Ausgabe während der Kompilierung"
    in Datei -> Voreinstellungen aktiviert wäre.
    Re: ESP Matrix Anzeige fully IoBroker steuerbar
    M liv-in-skyL 3 Antworten Letzte Antwort
    • D day83
      Jemand eine Idee?
           startOTAhandling();
      exit status 1
      M
      M
      MCU
      @day83 Das hast du vorher gemacht:
      In Arduino IDE unter Voreinstellungen unbedingt
                     -  http://arduino.esp8266.com/versions/2.4.1/package_esp8266com_index.json  -
      als "Zusätzliche Boardverwalter-URL einsetzen !!!!!!
      Vielleicht erkennt @liv-in-sky das Problem?
      • M MCU
        D
        D
        day83
        @mcu said in Max7219 Wemos - loadSysConfig Fehler:
        Jooo, als Boadverwalter ist auch das ESP8266 by Esp8266 Community installiert mit der Vers 2.7.4.
        Als Board kann ich aber nur den WEMOS D1 R2 auswählen...
        • D day83
          Jemand eine Idee?
               startOTAhandling();
          exit status 1
          liv-in-skyL
          liv-in-skyL
          @day83 das geht nur mit dem boardverwalter 2.4.1 . und den richtigen libraties im ordner - ich weiß nicht warum - habe nur dieses projekt gemacht
          • D day83
            Jemand eine Idee?
                 startOTAhandling();
            exit status 1
            liv-in-skyL
            liv-in-skyL
            @day83
            wenn 2.4.1. nich funk. probier 2.3
            • D
              D
              day83
              @liv-in-sky
              Hab edie 2.4.1 genommen, jetzt geht es....
              Danke - Testet weiter.
              Leider hab ich die URL beim Konfigurieren falsch eingegeben - wie kann ich die im Nachinein ändern??
              Hab den Sketsch nochmal neu drauf, aber die KOnfig kommt nicht nochmal. Auch Taster gedrückthalten und Strom bringt mich nicht in die Config
              • D day83
                @liv-in-sky
                liv-in-skyL
                liv-in-skyL
                @day83 das geht leider nur, wenn du den wemos löscht - also so eine leere bin drauf flasht - mußte ich auch immer weider mal machen
                • liv-in-skyL liv-in-sky
                  D
                  D
                  day83
                  @liv-in-sky
                  Okay hab ich gemacht.
                  Das Flashen hat funktioniert - die Config hab ich auch gemacht.
                  Leider bleibt das Display dunkel.
                  Am USB Port angeschlossen, zeigt das Display kurz "run..." an, dann nix mehr.
                  Hab als URL das angegeben:
                  http://192.168.178.39:8087/getPlainValue/javascript.0.ESPMatrix.Matrix
                  Die Datenpunkte sind auch angelegt (als Datenpunkte; Zeichenkette!!!!)
                  Der Simple-API Adapter läuft auf "grün mit diesen Einstellungen:
                  Wenn ich auf die Homepage 192.168.xxx.xx:8087 gehe, kommt diese Meldung:
                  { "error": "command unknown", "getPlainValue": "http://192.168.178.39:8087/getPlainValue/stateID", "get": "http://192.168.178.39:8087/get/stateID/?prettyPrint", "getBulk": "http://192.168.178.39:8087/getBulk/stateID1,stateID2/?prettyPrint", "set": "http://192.168.178.39:8087/set/stateID?value=1&prettyPrint", "toggle": "http://192.168.178.39:8087/toggle/stateID&prettyPrint", "setBulk": "http://192.168.178.39:8087/setBulk?stateID1=0.7&stateID2=0&prettyPrint", "setValueFromBody": "http://192.168.178.39:8087/setValueFromBody?stateID1", "objects": "http://192.168.178.39:8087/objects?pattern=system.adapter.admin.0*&prettyPrint", "states": "http://192.168.178.39:8087/states?pattern=system.adapter.admin.0*&prettyPrint", "search": "http://192.168.178.39:8087/search?pattern=system.adapter.admin.0*&prettyPrint", "query": "http://192.168.178.39:8087/query/stateID1,stateID2/?dateFrom=2019-06-06T12:00:00.000Z&dateTo=2019-06-06T12:00:00.000Z&noHistory=false&prettyPrint" }
                  Was stimmt den da nicht?
                  Vielen Dank euch alle
                  liv-in-skyL M 4 Antworten Letzte Antwort
                  • D day83
                    @liv-in-sky
                    liv-in-skyL
                    liv-in-skyL
                    @day83
                    so sieht das bei mir im moment aus - die adpter settings sind die selben wie bei dir - auch wenn ich einen datenpunkt unter javascript.x.... nehme, funktioniert es
                    wird dir die ip adresse angezeigt auf dem display, wenn du einschaltest ?
                    hast du die modul anzahl im script angepaßt ?
                    • D day83
                      @liv-in-sky
                      liv-in-skyL
                      liv-in-skyL
                      @day83 leider weiß ich nicht, wo das run.... herkommt - das kenn ich nicht
                      bei mir:
                      • D day83
                        @liv-in-sky
                        M
                        M
                        MCU
                        Falsche geschaut.
                        • D day83
                          @liv-in-sky
                          liv-in-skyL
                          liv-in-skyL
                          @day83 was steht im script an dieser stelle ?
                          durchsuche mal alle sketches in arduino nach dem "run..." - wo steht das bei dir
                            @day83
                            D
                            D
                            day83
                            @liv-in-sky
                            Die MAX hab ich auf 16 geändert, da ich 2x8 habe... Richtig so?
                            • D day83
                              @liv-in-sky
                              liv-in-skyL
                              liv-in-skyL
                              @day83 denke schon - ich habe 4*4er module und gebe 16 ein
                                D
                                D
                                day83
                                @liv-in-sky
                                Hab die ZIP aus Deinem Beitrag runtergeladen - heute nochmal Arduino komplett deinstall inkl. liberys gelöscht und alles aus Deiner Zip genommen - flashen ohne Fehler!
                                • D day83
                                  @liv-in-sky
                                  liv-in-skyL
                                  liv-in-skyL
                                  @day83 nimm mal das - ich weiß nicht mehr, ob ich nur das oder mehr geändert hatte
                                  MatrixDisplayESP8266.ino
                                  • D day83
                                    @liv-in-sky
                                    liv-in-skyL
                                    liv-in-skyL
                                    @day83
                                    und schreibe mal was langes in den matrix datenpunkt - ohne ; (strichpunkt) am ende
                                    testtesttest anstatt hallo;
                                    • D day83
                                      @liv-in-sky
                                      liv-in-skyL
                                      liv-in-skyL
                                      @day83 irgendwo wird der ntp server festgelegt - überprüfe den mal - ich glaube, ich hatte da auch ml ein problem damit - bei mir macht das die fritzbox - ung zeile 108
                                        D
                                        D
                                        day83
                                        @liv-in-sky
                                        Bei dem neuen *ino datei bring er diese Fehlermeldung:
                                        Arduino: 1.8.13 (Windows 10), Board: "WeMos D1 R2 & mini, 80 MHz, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
                                        java.nio.file.InvalidPathException: Illegal character [?] in path at index 2: \\?\E:\Smarthome\Display\Display version 3\MatrixDisplayESP8266-2b1d3d79ac80b28d9d0eecbcbe5cd035dffa356e\MatrixDisplayESP8266-2b1d3d79ac80b28d9d0eecbcbe5cd035dffa356e\MatrixDisplayESP8266 neu\1616503029840-matrixdisplayesp8266\1616503029840-matrixdisplayesp8266.ino
                                        	at sun.nio.fs.WindowsPathParser.nextSlash(WindowsPathParser.java:212)
                                        	at sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:111)
                                        	at sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:77)
                                        	at sun.nio.fs.WindowsPath.parse(WindowsPath.java:94)
                                        	at sun.nio.fs.WindowsFileSystem.getPath(WindowsFileSystem.java:255)
                                        	at java.io.File.toPath(File.java:2234)
                                        	at processing.app.BaseNoGui.saveFile(BaseNoGui.java:897)
                                        	at processing.app.SketchFile.save(SketchFile.java:287)
                                        	at processing.app.Sketch.save(Sketch.java:138)
                                        	at processing.app.SketchController.save(SketchController.java:352)
                                        	at processing.app.Editor.handleSave2(Editor.java:1908)
                                        	at processing.app.Editor.handleSave(Editor.java:1883)
                                        	at processing.app.Editor.handleExport(Editor.java:2023)
                                        	at processing.app.EditorToolbar.handleSelectionPressed(EditorToolbar.java:498)
                                        	at processing.app.EditorToolbar.mousePressed(EditorToolbar.java:448)
                                        	at java.awt.Component.processMouseEvent(Component.java:6536)
                                        	at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
                                        	at java.awt.Component.processEvent(Component.java:6304)
                                        	at java.awt.Container.processEvent(Container.java:2239)
                                        	at java.awt.Component.dispatchEventImpl(Component.java:4889)
                                        	at java.awt.Container.dispatchEventImpl(Container.java:2297)
                                        	at java.awt.Component.dispatchEvent(Component.java:4711)
                                        	at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
                                        	at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4532)
                                        	at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
                                        	at java.awt.Container.dispatchEventImpl(Container.java:2283)
                                        	at java.awt.Window.dispatchEventImpl(Window.java:2746)
                                        	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
                                        	at java.awt.EventQueue.access$500(EventQueue.java:97)
                                        	at java.awt.EventQueue$3.run(EventQueue.java:709)
                                        	at java.awt.EventQueue$3.run(EventQueue.java:703)
                                        	at java.security.AccessController.doPrivileged(Native Method)
                                        	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
                                        	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
                                        	at java.awt.EventQueue$4.run(EventQueue.java:733)
                                        	at java.awt.EventQueue$4.run(EventQueue.java:731)
                                        	at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
                                        	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
                                        	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
                                        	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
                                        	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
                                        	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
                                        	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
                                        C:\Users\FRANZI~1\AppData\Local\Temp\arduino_modified_sketch_18343\1616503029840-matrixdisplayesp8266.ino: In function 'void setup()':
                                        1616503029840-matrixdisplayesp8266:297:79: error: 'calcDate' was not declared in this scope
                                                        else if (MAX_DEVICES>8 && MAX_DEVICES<16) {datum=calcDate(now()); datumJa=1;}
                                        1616503029840-matrixdisplayesp8266:298:42: error: 'calcDate' was not declared in this scope
                                                        else {datum=calcDate(now()); datumJa=2;}
                                        C:\Users\FRANZI~1\AppData\Local\Temp\arduino_modified_sketch_18343\1616503029840-matrixdisplayesp8266.ino: In function 'void loop()':
                                        1616503029840-matrixdisplayesp8266:529:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:551:86: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:591:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:614:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:680:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:744:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:768:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:792:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:816:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:840:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:864:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:888:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:913:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:938:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:962:89: error: 'calcDate' was not declared in this scope
                                        1616503029840-matrixdisplayesp8266:986:89: error: 'calcDate' was not declared in this scope
                                         Benutzt: C:\Users\Franzi_Day\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi
                                        exit status 1
                                        • D day83
                                          @liv-in-sky
                                          exit status 1
                                          liv-in-skyL
                                          liv-in-skyL
                                          @day83
                                          das könnte durch das kopieren passiert sein - umlaute und so
                                          kopier mal von hier
                                          https://github.com/liv-in-sky/test-matrix
                                          84.0k
