  4. Test Adapter Somfy Tahoma v0.3.x GitHub
somfytahomarollladensteuerung
294 Beiträge 34 Kommentatoren 75.5k Aufrufe 33 Beobachtet
  • S smarteshome2020
    Hallo, ich bin mir nicht sicher ob ich hier richtig bin, aber mein iobroker meldet seit zwei Tagen immer folgende Warunung. Kann mir da jemand helfen?
    (28547) Body: {"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"}
    tahoma.0 2020-12-09 10:18:04.764 warn (28547) Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"},"headers":{"date":"Wed, 09 Dec 2020 09:18:04 GMT","server":"overkiz","strict-transp
    drapo
    #250
    hab auch seit längerem permanent fehler im log.
    tahoma.0	2021-01-13 09:35:57.929	warn	(885) Body: {"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"}
    tahoma.0	2021-01-13 09:35:57.929	warn	(885) Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"},"headers":{"date":"Wed, 13 Jan 2021 08:35:57 GMT","server":"overkiz","strict-transpor
    tahoma.0	2021-01-13 09:35:57.929	warn	(885) error during tahomalink request: null, request path: events/xxx```
    ```/fetch with payload:{}
    tahoma.0	2021-01-13 09:35:38.000	warn	(885) Body: {"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"}
    tahoma.0	2021-01-13 09:35:37.999	warn	(885) Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"},"headers":{"date":"Wed, 13 Jan 2021 08:35:37 GMT","server":"overkiz","strict-transpor
    tahoma.0	2021-01-13 09:35:37.999	warn	(885) error during tahomalink request: null, request path: events/xxx/fetch with payload:{}
    tahoma.0	2021-01-13 09:35:17.937	warn	(885) Body: {"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"}
    tahoma.0	2021-01-13 09:35:17.937	warn	(885) Response: {"statusCode":400,"body":{"errorCode":"UNSPECIFIED_ERROR","error":"No registered event listener"},"headers":{"date":"Wed, 13 Jan 2021 08:35:17 GMT","server":"overkiz","strict-transpor
    tahoma.0	2021-01-13 09:35:17.935	warn	(885) error during tahomalink request: null, request path: events/xxx/fetch with payload:{}
    jemand eine idee wie ich das lösen kann?
    • D drapo
      Master-Rudi
      schrieb am zuletzt editiert von Master-Rudi
      #251
      @drapo
      Ich habe das gleiche Problem. Schon seit längerem.
      @StrathCole
      Weiß leider keine Lösung. Scheint als ob der Adapter nicht weiter entwickelt wird?
      StrathColeS 1 Antwort Letzte Antwort
      • M Master-Rudi
        @drapo
        @StrathCole
        StrathColeS Offline
        StrathColeS Offline
        StrathCole
        #252
        @master-rudi Aktuell habe ich keine Zeit, intensiv an Adaptern zu arbeiten. Bei mir läuft der Adapter aber schon seit längerer Zeit ganz ohne Probleme. Daher habe ich auch keinen "Druck", da etwas aufwändig dran zu machen, und kann auch nicht selbst ausprobieren, woran der Fehler liegen könnte.
        SolarWatt-Anlage mit 9,6 kWp – KOSTAL Plenticore Plus 10 – BYD B-Box HV 8,96 – Viessmann Vitocal 333g – Zehnder ComfoD 350 (Comfoair 350) mit RS232-Ethernet-Konverter
        D M 2 Antworten Letzte Antwort
        • StrathColeS StrathCole
          drapo
          #253
          @strathcole machst Du aber auch immer die Updates auf die Tahoma Box? Diese Woche war ja z.B. gerade eins. Weiss nicht ob das Einfluss hat.
          Bei mir ist es so dass wenn ich den Adapter 30min stoppe und dann wieder starte habe ich ein paar Tage ruhe bevor die Meldungen dann wieder erscheinen.
          • D drapo
            StrathColeS Offline
            StrathColeS Offline
            StrathCole
            #254
            @drapo Eigentlich mache ich immer alle Updates. Das letzte kann aber sein, dass es noch nicht drauf ist, da ich mich die letzten 2-3 Wochen nicht ums SmartHome gekümmert habe.
              tino1410
              schrieb am zuletzt editiert von tino1410
              #255
              bei mir werden keine vernünftigen commands angezeigt bei den RTS-Rollläden von Somfy über Tahoma. Was kann ich machen, dass diese richtig angezeigt werden ("up", "down", "my", "open", "close", "stop")?
              Ich hoffe, dass ihr mir helfen könnt. Der Adapter ist sonst super.
              Gruß Tino
                Master-Rudi
                #256
                @strathcole
                Kein Problem... Ich deaktiviere den Adapter von 22 Uhr - 6 Uhr. Das hilft etwas... aber nicht viel.
                Falls ich unterstüzen kann, sag bescheid!
                  thege
                  #257
                  hat eventuell noch jemand das Problem, dass Befehle regelmäßig nicht erfolgreich ausgeführt werden?
                  Im Log tauchen dann immer 400er-Fehler (TOO_MANY_OPERATIONS_IN_PROGRESS) auf und die nachfolgenden Befehle zum Steuern der Rollläden haben keinen Effekt (die Änderung des Status steht im Log, aber der Rollladen fährt nicht). Die Fehler tauchen allerdings auch regelmäßig auf, wenn gar kein Script zur Rollladensteuerung läuft.
                  Hier mal ein beispielhafter Auszug aus dem Log:
                  2021-03-14 19:26:00.389 - warn: tahoma.0 (23649) error during tahomalink request: null, request path: /setup/devices/states/refresh with payload:{}
                  2021-03-14 19:26:00.391 - warn: tahoma.0 (23649) Response: {"statusCode":400,"body":{"errorCode":"TOO_MANY_OPERATIONS_IN_PROGRESS","error":"Too many asynchronous jobs, try again later (job was Full refresh all states)"},"headers":{"date":"Sun, 14 Mar 2021 18:25:59 GMT","server":"overkiz","strict-transport-security":"max-age=31536000; includeSubDomains","content-type":"application/json;charset=UTF-8","connection":"close","transfer-encoding":"chunked"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"www.tahomalink.com","port":443,"hostname":"www.tahomalink.com","hash":null,"search":null,"query":null,"pathname":"/enduser-mobile-web/enduserAPI//setup/devices/states/refresh","path":"/enduser-mobile-web/enduserAPI//setup/devices/states/refresh","href":"https://www.tahomalink.com/enduser-mobile-web/enduserAPI//setup/devices/states/refresh"},"method":"POST","headers":{"User-Agent":"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_7_5) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/49.0.2623.112 Safari/537.36","cookie":"JSESSIONID=1632732872DD1D6F361FC3C87925F4AB","accept":"application/json","content-type":"application/json","content-length":2}}}
                  2021-03-14 19:26:00.392 - warn: tahoma.0 (23649) Body: {"errorCode":"TOO_MANY_OPERATIONS_IN_PROGRESS","error":"Too many asynchronous jobs, try again later (job was Full refresh all states)"}
                  2021-03-14 19:26:00.392 - warn: tahoma.0 (23649) refresh device state failed
                  Eine Änderung des Abrufintervalls in den Einstellungen hat keine Besserung gebracht. Insgesamt habe ich 15 Rollläden im Einsatz, die über eine Connexoon-Box gesteuert werden. Die Zeitsteuerung über die Somfy Connexoon-App auf dem Handy funktioniert hingegen problemlos.
                  • T thege
                    SaschaS
                    #258
                    @thege und alle anderen,
                    bei mir tritt zur Zeit ein ähnlicher Fehler auf:
                    tahoma.0 (24844) error during tahomalink request: Error: connect ETIMEDOUT 178.32.15.131:443, request path: events/5708fcd3-ac10-3e01-0169-e762ab72ec50/fetch with payload:{}
                    tahoma.0 (24844) refresh device state failed
                    tahoma.0 (24844) eventRegisterID = 5744d73e-ac10-3e01-0169-e762f53f3554
                    tahoma.0 (24844) error during tahomalink request: undefined ->401 retry login
                    tahoma.0 (24844) Login failed three times, waiting 2 minutes before retrying.
                    Das End vom Lied ist aber das gleiche. Die Befehle werden nicht ausgeführt. Ich in diesen Fällen gelingt mir aber auch nicht mehr der Login auf die Webseite https://www.tahomalink.com/enduser-mobile-web/steer-html5-client/tahoma/?
                    Einzige Abhilfe ist der von @StrathCole beschrieben Workaround den Adapter mal über Nacht zu deaktiveren. Dann funktioniert es meist am nächsten Tag wieder. Aber das sollte natürlich keine Lösung sein.
                    @StrathCole Hattest du schon die Zeit den Adapter weiterzuentwicklen bzw. gibt es eine neuere Version als 0.3.3
                    • M Master-Rudi
                      @strathcole
                      SaschaS
                      #259
                      @master-rudi Wie deaktivierst und aktivierst du den Adapter zeitgesteuert? Mit Hilfe eines eigenen Javascripts?
                      S M 2 Antworten Letzte Antwort
                      • S SaschaS
                        SaschaS
                        #260
                        Hat schon jemand mal den Ansatz probiert, dass immer wenn im Log die Fehlermeldung kommt "error during tahomalink request: undefined ->401 retry login" sich der Adapter für ein definiertes Zeitintervall deaktiviert?
                        Die Idee kam mir gestern Abend noch.
                        G 1 Antwort Letzte Antwort
                        • S SaschaS
                          gammler2003
                          #261
                          @saschas
                          Here we go...inkl. Telegram-Benachrichtigungen.
                          //Skript startet Tahoma-Adapter bei Warnungen im Log neu
                          var warten = 5; //Wartezeit bis zum Restart
                          var warten_ms = warten*60000; //Wartezeit bis zum Restart in ms
                          var warten_buf =warten_ms+60000;
                          var sleep = false;
                          onLog('warn', data => {
                          var check = data.message.includes("tahoma");
                          if (check==true && sleep==false)
                              sleep=true;
                              var text = "Tahoma Fehler identifiziert. Adapter wird gestoppt und in "+ warten + " Minuten wieder aktiviert";
                              telegram (text);
                              setState("system.adapter.tahoma.0.alive", false);
                              setTimeout(function() {
                                  setState("system.adapter.tahoma.0.alive", true);
                                  var text = "Tahoma Adapter wieder gestartet";
                                  telegram (text);
                              }, warten_ms);
                                  sleep=false;
                                  var text = "Adapterüberwachung wieder aktiv";
                                  telegram (text);
                              }, warten_buf);
                          • G gammler2003
                            @saschas
                            var sleep = false;
                                sleep=true;
                                telegram (text);
                                    telegram (text);
                                }, warten_ms);
                                    sleep=false;
                                    telegram (text);
                                }, warten_buf);
                            SaschaS
                            #262
                            @gammler2003 Wow! Hast du das jetzt extra auf mein Verlangen geschrieben, oder hast du das selbst bei dir auch im Einsatz?
                            Du frägst ja jetzt generell nach einer "warn" Meldung von tahoma ab. Gibt es da keine Probleme, dass zu früh / zu oft der Adapter aus/an geschaltet wird?
                            • S SaschaS
                              gammler2003
                              #263
                              @saschas Teilweise habe ich es bereits im Einsatz - wobei es noch nicht perfekt läuft. Wenn die Tahoma sich "verschluckt", dann richtig. Vermutlich hilft es, die triggernde Warnmeldung einzuschränken und/oder das Pausenintervall zu verlängern.
                              Aber vom Grundsatz her ist das die Lösung...
                              E 1 Antwort Letzte Antwort
                              • G gammler2003
                                el_malto
                                #264
                                @gammler2003 sagte in Test Adapter Somfy Tahoma v0.3.x GitHub:
                                Leider nein, dass ist nur ein Workaround.
                                • S SaschaS
                                  Master-Rudi
                                  #265
                                  @saschas said in Test Adapter Somfy Tahoma v0.3.x GitHub:
                                  Nein ich mache es mit einem simplen quick & dirty blockly:
                                  Ist aber keine allzu perfekte Lösung.
                                  • G gammler2003
                                    @saschas
                                    var sleep = false;
                                        sleep=true;
                                        telegram (text);
                                            telegram (text);
                                        }, warten_ms);
                                            sleep=false;
                                            telegram (text);
                                        }, warten_buf);
                                    Master-Rudi
                                    #266
                                    @gammler2003 said in Test Adapter Somfy Tahoma v0.3.x GitHub:
                                    Das werde ich mal testen und evtl noch etwas ausbauen. Danke für den Ansatz, war immer etwas zu faul :-) Hoffe auf einen funktionierenden fix. Aber der Adapter scheint tot zu sein... Nur eine Frage der Zeit bis ein TaHoma Update die Funktionalität komplett killt...
                                    • M Master-Rudi
                                      blackeagle998
                                      schrieb am zuletzt editiert von blackeagle998
                                      #267
                                      @master-rudi
                                      als Ansatz für eine Erweiterung:
                                      Ich habe den logparser Adapter und werte das Log hinsichtlich Tahoma Fehlermeldungen aus. Wenn die mehrfach hintereinander kommen, starte ich den Adapter neu.
                                      Hat bisher zumindest funktioniert.
                                        derdominik
                                        #268
                                        Hallo, ich habe heute den jscontroller aktualisiert und seit dem kommt bei jedem Status-Refresh folgende WARN-Meldungen:
                                        State "tahoma.0.devices.Studio_1.states.io:PriorityLockLevelState" has no existing object, this might lead to an error in future versions
                                        State "tahoma.0.devices.Studio_1.states.io:PriorityLockOriginatorState" has no existing object, this might lead to an error in future versions
                                        Hat jemand eine Idee wie ich die Meldungen wegbekomme?
                                        G D S 3 Antworten Letzte Antwort
                                        • D derdominik
                                          gammler2003
                                          #269
                                          @derdominik Leider nein, bekomme aber identische Warnmeldungen.
