  4. iobroker Skripte Seite leer nach javascript Adapter update
23 Beiträge 5 Kommentatoren 2.4k Aufrufe 5 Beobachtet
    @mading
    Bitte keine Screenshots von Textmeldungen sondern auch als Text in CodeTags eingebettet ins Forum kopieren.
    madingM
    madingM
    mading
    @thomas-braun sorry, gerne.
    javascript.0	2021-03-22 16:06:23.424	info	(3437) script.js.Meldung_Einbruch_Rauch: registered 1 subscription and 0 schedules
    javascript.0	2021-03-22 16:06:23.418	info	(3437) Start javascript script.js.Meldung_Einbruch_Rauch
    javascript.0	2021-03-22 16:06:23.417	info	(3437) script.js.verpasster_Anruf: registered 1 subscription and 0 schedules
    javascript.0	2021-03-22 16:06:23.409	info	(3437) Start javascript script.js.verpasster_Anruf
    javascript.0	2021-03-22 16:06:23.408	info	(3437) script.js.Hausinfos_per_Telegramm: registered 0 subscriptions and 1 schedule
    javascript.0	2021-03-22 16:06:23.402	info	(3437) Start javascript script.js.Hausinfos_per_Telegramm
    javascript.0	2021-03-22 16:06:23.401	info	(3437) script.js.Fronius_Berechnung: registered 0 subscriptions and 3 schedules
    javascript.0	2021-03-22 16:06:23.386	info	(3437) Start javascript script.js.Fronius_Berechnung
    javascript.0	2021-03-22 16:06:23.370	info	(3437) script.js.Telegram_Müllinfo: registered 0 subscriptions and 2 schedules
    javascript.0	2021-03-22 16:06:23.302	info	(3437) Start javascript script.js.Telegram_Müllinfo
    javascript.0	2021-03-22 16:06:21.991	info	(3437) received all states
    javascript.0	2021-03-22 16:06:21.970	info	(3437) received all objects
    javascript.0	2021-03-22 16:06:19.778	info	(3437) requesting all objects
    javascript.0	2021-03-22 16:06:19.775	info	(3437) requesting all states
    javascript.0	2021-03-22 16:06:19.653	info	(3437) starting. Version 5.0.14 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.21.0, js-controller: 3.2.16
    javascript.0	2021-03-22 16:06:19.638	info	(3437) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    javascript.0	2021-03-22 16:06:12.976	info	2
    javascript.0	2021-03-22 16:06:12.976	info	(3279) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    javascript.0	2021-03-22 16:06:12.974	info	(3279) terminating
    javascript.0	2021-03-22 16:06:12.970	info	(3279) Stop script script.js.Meldung_Einbruch_Rauch
    javascript.0	2021-03-22 16:06:12.969	info	(3279) Stop script script.js.verpasster_Anruf
    javascript.0	2021-03-22 16:06:12.969	info	(3279) Stop script script.js.Hausinfos_per_Telegramm
    javascript.0	2021-03-22 16:06:12.968	info	(3279) Stop script script.js.Fronius_Berechnung
    javascript.0	2021-03-22 16:06:12.967	info	(3279) Stop script script.js.Telegram_Müllinfo
    javascript.0	2021-03-22 16:06:12.964	info	(3279) Got terminate signal TERMINATE_YOURSELF
    madingM 1 Antwort Letzte Antwort
    • madingM mading
      madingM
      madingM
      mading
      Iobroker fixer brachte auch leider keine Lösung
      • madingM mading
        @thomas-braun Danke dir, habe ich umgestellt. Leider hat sich nichts geändert. Bin auf 5.0.14 gegangen. javascript loggt nichts im debug Modus.
        @mading sagte in iobroker Skripte Seite leer nach javascript Adapter update:
        was hat sich nicht geändert?
        vom umstellen auf stable bleiben die alten Beta-Versionen natürlich.
        die musst du manell downgraden
        jolu1705J 1 Antwort Letzte Antwort
          jolu1705J
          jolu1705J
          jolu1705
          @homoran said in iobroker Skripte Seite leer nach javascript Adapter update:
          Wie geht das?
          • jolu1705J jolu1705
            Wie geht das?
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            @jolu1705 @Homoran
            Ist doch schon:
              Wie geht das?
              @jolu1705 sagte in iobroker Skripte Seite leer nach javascript Adapter update:
              Wie geht das?
              du gehst auf die Seite Adapter
              Wenn da verfügbar eine niedrigere Version als installiert anzeigt, kannst du im Expertenmodus über das Icon (mehrere gestapelte Blätter mit einem Plus) = "beliebige Version installieren" diese "verfügbare" auswählen
              madingM jolu1705J 2 Antworten Letzte Antwort
                Wie geht das?
                madingM
                madingM
                mading
                @homoran welche adapter betrifft dies? Alle iobroker „core“? Gibt es eine Möglichkeit heraus zu finden welche Adapter nicht-stable Versionen installiert haben?
                  Wie geht das?
                  jolu1705J
                  jolu1705J
                  jolu1705
                  @homoran Ich hatte 5.1.1 installiert und bin nun auf 5.0.14 stable zurück.
                  Das hat funktioniert und ich habe wieder was gelernt, danke!
                  Gibt es eine Möglichkeit alle installierten Adapter per SSH Kommando von der Beta auf die Stable umzuziehen ohne das manuell machen zu müssen?
                  • madingM mading
                    @homoran sagte in iobroker Skripte Seite leer nach javascript Adapter update:
                    • madingM mading
                      Thomas BraunT
                      Thomas BraunT
                      @mading
                      Wenn der Verwahrort 'stable/default' aktiv ist dann alle Adapter bei denen die installierte Version höher als die verfügbare ist.
                        Thomas BraunT
                        Thomas BraunT
                        Nein. Jedenfalls nix fertiges. Könnte man wohl skripten, hat aber noch niemand.
                        So viele sind das ja wohl hoffentlich nicht. Oder du lässt die Versionen drin und wartest bis die stable-Version die Versionsnummer überholt, dann wird die installiert.
                        • madingM mading
                          heute gab es ein Update auf die neuste javascript Version. Leider wird der Skripteditor etc nicht mehr angezeigt. Nach dem Klick auf Skripte kommt das animierte iobroker Logo kurz, dann bleibt der Screen grau. Sh Foto anbei!
                          Aktuellste Version iobroker etc. restart javascript Adapter hat nichts gebracht, reboot des pi auch nichts :/
                          |Hardwaresystem:| Rpi4
                          |Arbeitsspeicher:| 4GB |
                          |Festplattenart:| SD-Karte
                          |Betriebssystem:| Raspbian|
                          |Node-Version:| ? |
                          |Nodejs-Version:| 12.21.0 |
                          |NPM-Version:| 6.14.11 |
                          |Installationsart:| Skript |
                          |Image genutzt:| Nein |
                          D
                          D
                          deta
                          @mading Mit heutigen 5.1.2 wieder alles io!
                          • D deta
                            Thomas BraunT
                            Thomas BraunT
                            @deta Ja, aber immer noch eine Beta-Version.
                              D
                              D
                              deta
                              @thomas-braun sagte in iobroker Skripte Seite leer nach javascript Adapter update:
                              richtig. Jeder der das Installiert weis hoffe ich was er macht. Wollte ja nur damit sagen, das es in der Version dann wieder geht.
                              33.2k
                              84.3k
