  4. Seite neu Laden lässt ioBroker neustarten
32 Beiträge 4 Kommentatoren 3.3k Aufrufe 3 Beobachtet
    @ronny-gerndt
    iobroker status
    iobroker list adapters
    iobroker list instances
    top
    free -m
    who -r
    liefert?
    Ronny GerndtR Offline
    Ronny Gerndt
    @thomas-braun ich komm aus der Windows Welt ;) Da geh ich nur zur Not mal in die Kommandozeile :D
    pi@raspberrypi:/opt/iobroker $ iobroker status
    Objects type: file
    States  type: file
    pi@raspberrypi:/opt/iobroker $ iobroker list adapters
    system.adapter.admin                   : admin          - v4.2.1
    system.adapter.alexa2                  : alexa2         - v3.8.1
    system.adapter.backitup                : backitup       - v2.0.5
    system.adapter.daswetter               : daswetter      - v3.0.4
    system.adapter.deconz                  : deconz         - v1.3.11
    system.adapter.fritzbox                : fritzbox       - v0.2.1
    system.adapter.fritzdect               : fritzdect      - v0.2.4
    system.adapter.haassohn                : haassohn       - v1.0.3
    system.adapter.heatingcontrol          : heatingcontrol - v2.2.0
    system.adapter.ical                    : ical           - v1.7.4
    system.adapter.icons-material-svg      : icons-material-svg - v0.1.0
    system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
    system.adapter.info                    : info           - v1.7.14
    system.adapter.javascript              : javascript     - v5.0.14
    system.adapter.simple-api              : simple-api     - v2.5.3
    system.adapter.tankerkoenig            : tankerkoenig   - v2.0.5
    system.adapter.tr-064                  : tr-064         - v4.2.4
    system.adapter.trashschedule           : trashschedule  - v1.1.1
    system.adapter.vis                     : vis            - v1.3.4
    system.adapter.vis-hqwidgets           : vis-hqwidgets  - v1.1.7
    system.adapter.vis-material-advanced   : vis-material-advanced - v1.3.0
    system.adapter.vis-metro               : vis-metro      - v1.1.2
    system.adapter.vis-timeandweather      : vis-timeandweather - v1.1.7
    system.adapter.web                     : web            - v3.3.0
    system.adapter.whatsapp-cmb            : whatsapp-cmb   - v0.1.6
    pi@raspberrypi:/opt/iobroker $ iobroker list instances
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled
      system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              - disabled
      system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
    + instance is alive
    pi@raspberrypi:/opt/iobroker $ top
    top - 14:17:33 up 2 days, 16:14,  2 users,  load average: 0,12, 0,12, 0,10
    Tasks: 159 total,   1 running, 158 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  6,9 us,  4,2 sy,  0,0 ni, 88,9 id,  0,0 wa,  0,0 hi,  0,0 si,  0,0 st
    MiB Mem :   3906,0 total,   2426,1 free,    708,5 used,    771,4 buff/cache
    MiB Swap:    100,0 total,    100,0 free,      0,0 used.   3148,6 avail Mem
      PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
      476 root      20   0   48564  22324  12764 S  18,8   0,6   1:00.93 vncserver+
     8834 pi        20   0   10436   2924   2544 R  18,8   0,1   0:00.04 top
      540 root      20   0  173068  53056  36572 S   6,2   1,3   8:30.40 Xorg
        1 root      20   0   34820   8328   6524 S   0,0   0,2   0:08.11 systemd
        2 root      20   0       0      0      0 S   0,0   0,0   0:00.45 kthreadd
        3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
        4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
        8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu+
        9 root      20   0       0      0      0 S   0,0   0,0   0:03.60 ksoftirqd+
       10 root      20   0       0      0      0 I   0,0   0,0   0:52.62 rcu_sched
       11 root      20   0       0      0      0 I   0,0   0,0   0:00.00 rcu_bh
       12 root      rt   0       0      0      0 S   0,0   0,0   0:00.07 migration+
       13 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/0
       14 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/1
       15 root      rt   0       0      0      0 S   0,0   0,0   0:00.07 migration+
       16 root      20   0       0      0      0 S   0,0   0,0   0:02.16 ksoftirqd+
       19 root      20   0       0      0      0 S   0,0   0,0   0:00.00 cpuhp/2
    Fields Management for window 1:Def, whose current sort field is %CPU
       Navigate with Up/Dn, Right selects for move then <Enter> or Left commits,
       'd' or <Space> toggles display, 's' sets sort.  Use 'q' or <Esc> to end!
    * PID     = Process Id      PGRP    = Process Group   OOMs    = OOMEM Score c
    * USER    = Effective Use   TTY     = Controlling T   ENVIRON = Environment v
    * PR      = Priority        TPGID   = Tty Process G   vMj     = Major Faults
    * NI      = Nice Value      SID     = Session Id      vMn     = Minor Faults
    * VIRT    = Virtual Image   nTH     = Number of Thr   USED    = Res+Swap Size
    * RES     = Resident Size   P       = Last Used Cpu   nsIPC   = IPC namespace
    * SHR     = Shared Memory   TIME    = CPU Time        nsMNT   = MNT namespace
    * S       = Process Statu   SWAP    = Swapped Size    nsNET   = NET namespace
    * %CPU    = CPU Usage       CODE    = Code Size (Ki   nsPID   = PID namespace
    * %MEM    = Memory Usage    DATA    = Data+Stack (K   nsUSER  = USER namespac
    * TIME+   = CPU Time, hun   nMaj    = Major Page Fa   nsUTS   = UTS namespace
    * COMMAND = Command Name/   nMin    = Minor Page Fa   LXC     = LXC container
      PPID    = Parent Proces   nDRT    = Dirty Pages C   RSan    = RES Anonymous
      UID     = Effective Use   WCHAN   = Sleeping in F   RSfd    = RES File-base
      RUID    = Real User Id    Flags   = Task Flags <s   RSlk    = RES Locked (K
      RUSER   = Real User Nam   CGROUPS = Control Group   RSsh    = RES Shared (K
      SUID    = Saved User Id   SUPGIDS = Supp Groups I   CGNAME  = Control Group
      SUSER   = Saved User Na   SUPGRPS = Supp Groups N   NU      = Last Used NUM
      GID     = Group Id        TGID    = Thread Group
      GROUP   = Group Name      OOMa    = OOMEM Adjustm
    pi@raspberrypi:/opt/iobroker $ free -m
    Mem:           3906         711        2424          40         770        3146
    Swap:            99           0          99
    pi@raspberrypi:/opt/iobroker $ who -r
             Runlevel 5   2021-03-18 21:45
    • Ronny GerndtR Ronny Gerndt
      Objects type: file
      States  type: file
      + instance is alive
      Swap:            99           0          99
      @ronny-gerndt
      Eigentlich relativ unauffällig.
      Aber wenn (die im Moment eh nicht aktive) vis nicht auf einem an den Pi angeschlossenen Display läuft: Mach den Desktop-Kram aus.
      Schau im 'Linux-Werkzeugkasten' aus meiner Signatur wie das auf dem Pi geht.
      Das Log sagt zu früheren Zeitpunkten was?
      Vermutlich ist
      cleaned everything up...
      nicht der Anfang.
      Ronny GerndtR 1 Antwort Letzte Antwort
        @ronny-gerndt
        Vermutlich ist
        nicht der Anfang.
        Ronny Gerndt
        @thomas-braun Ja das ist der Plan irgendwann, wenn ich alles soweit hab da ne Vis zu machen und einen Touchbildschirm an den Raspi anzuschließen, wobei es eventuell auch ein Tablet wird da bin ich noch nicht 100% sicher.
        deconz.0	2021-03-21 14:47:04.567	info	(9233) cleaned everything up...
        admin.0	2021-03-21 14:47:04.560	info	(9102) terminating http server on port 8081
        info.0	2021-03-21 14:47:04.550	info	(9121) cleaned everything up...
        simple-api.0	2021-03-21 14:47:04.560	info	(9658) terminating http server on port 8087
        javascript.0	2021-03-21 14:47:04.560	info	(9598) Stop script script.js.common.Aufwecken
        simple-api.0	2021-03-21 14:47:04.556	error	(9658) States database error: read ECONNRESET
        backitup.0	2021-03-21 14:47:04.544	info	(9673) cleaned everything up...
        web.0	2021-03-21 14:47:04.549	info	(9613) terminated http server on port 8082
        alexa2.0	2021-03-21 13:37:34.067	info	(8545) Subscribing to states...
        Ich hatte die ganze Zeit den Log offen, da aktuell nicht viel passiert war der letzte Eintrag von 13:37, dann hab extra um Punkt 14:47 auf F5 gedrückt und dann war wieder alles tot.
          @ronny-gerndt sagte in Seite neu Laden lässt ioBroker neustarten:
          ich fürchte her, dass bereits ab 13:37 alles tot war und erst um 14:47 iobroker neustartete
          1:10 keinerlei logeinträge ist schon sehr seltsam.
          Wo hast du das log her?
          auch aus der grafischen Oberfläche kopiert?
          dann ist die da vielleicht erste mal wieder refreshed worden.
          Lad mal das heutige log runter und sieh nach was da alles in dieser Zeit wirklich drin steht
          Ronny GerndtR Thomas BraunT 2 Antworten Letzte Antwort
            Ronny Gerndt
            @homoran Ja aus der Weboberfläche. Also bewusst habe ich die letzte Stunde auch nichts gemacht, also keine Lichter an/aus oder sonstiges.
            Wenn ich über die Weboberfläche Log Herunterlade reicht? Oder gibts doch noch ein anderes das hilfreich sein könnte? Denn in dem heruntergeladenen sieht es genauso aus.
              @ronny-gerndt
              Das log file von heute kann man sich mit
              less /opt/iobroker/log/iobroker.current.log
              anschauen.
                @homoran sagte in Seite neu Laden lässt ioBroker neustarten:
                In meiner Installation ist das aber die Regel. An ruhigen Tagen (also wenn ich da nix dran rumfummel) habe ich da insgesamt nur ein oder zwei Zeilen drin.
                  @thomas-braun sagte in Seite neu Laden lässt ioBroker neustarten:
                  hast du alles nur auf WARN stehen?
                  bei mir rattert es nur so
                  Thomas BraunT F 2 Antworten Letzte Antwort
                    @homoran Nö, alles auf INFO. Hab halt nur brave Adapter und Geräte im Einsatz. :-)
                      frankyboy73
                      schrieb am zuletzt editiert von frankyboy73
                      @homoran Hi, das kaum Meldungungen im Log stehen, kann ich bestätigen.
                      Mein Log steht auch auf Info, und ich hab nur Morgens ein paar Zeilen drin, wenn die Internetverbindung getrennt wird und wenn ich meinen Ical Adapter starte. Den Rest des Tages kommt eigentlich nichts mehr.
                      Edit: Nur der fritz dect ist bei mir auf Warn, der gibt ja sonst bei jeder Änderung ne Ausgabe.
                      Schöne Grüße Frank
                        @ronny-gerndt
                        anschauen.
                        Ronny Gerndt
                        @thomas-braun said in Seite neu Laden lässt ioBroker neustarten:
                        @ronny-gerndt
                        anschauen.
                        Da sieht der Log genauso aus.
                        @Thomas-Braun ich bin grad mal deinen Linux Werkzeugkasten durchgegangen und habe damit das Problem gerade wie es aussieht eliminiert. Von NodeJs war nur Version 10.irgendwas installiert und von Node 14.16.0. Ich habe Nodejs nun mal auf die gleiche Version gezogen, also 14.16.0 und seitdem scheint es zu laufen. :) Zumindest habe ich in den letzten 10 Minuten keinen Neustart mehr gesehen.
                        Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                          @ronny-gerndt
                          anschauen.
                          Das freut mich wirklich ganz besonders, wenn dir der Werkzeugkasten etwas helfen konnte. Dafür schreibt man sowas. :-)
                            @ronny-gerndt
                            anschauen.
                            in Wirklichkeit hattest du 2 node-Installationen parallel.
                            Das führt zu Problemen
                            Wenn beide die gleiche Version gehabt hätten wärte es nur nicht so leicht zu finden gewesen.
                              @ronny-gerndt
                              anschauen.
                              @ronny-gerndt
                              Was sagt denn
                              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                              jetzt genau?
                                @ronny-gerndt
                                Was sagt denn
                                jetzt genau?
                                Ronny Gerndt
                                Was mir da gerade noch auffällt bei mir liegt Node un NPM im Local Ordner was nach deinem Guide eigentlich nicht sein sollte?
                                pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                /usr/bin/nodejs
                                v14.16.0
                                /usr/local/bin/node
                                v14.16.0
                                /usr/local/bin/npm
                                6.14.11
                                nodejs:
                                  Installiert:           14.16.0-1nodesource1
                                  Installationskandidat: 14.16.0-1nodesource1
                                  Versionstabelle:
                                 *** 14.16.0-1nodesource1 100
                                     12.21.0-1nodesource1 500
                                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                                     10.24.0~dfsg-1~deb10u1 500
                                @Homoran Ja das hört sich nicht wirklich gut an wenn das so war.
                                  /usr/bin/nodejs
                                  v14.16.0
                                  /usr/local/bin/node
                                  v14.16.0
                                  /usr/local/bin/npm
                                  6.14.11
                                  nodejs:
                                    Versionstabelle:
                                  @ronny-gerndt
                                  Ja, du hast immer noch zwei Installationen, jetzt allerdings (für den Moment) mit den gleichen Versionsnummern. Das driftet dir aber mit dem nächsten Update im jetzigen Setup wieder auseinander.
                                  Kurz: Der Kram in
                                  /usr/local
                                  muss da weg. Und deine nodesource.list ist offenbar auch nicht richtig und 'schwimmt' nicht mit den Updates mit.
                                    @ronny-gerndt
                                    Kurz: Der Kram in
                                    /usr/local
                                    Ronny Gerndt
                                    @thomas-braun Okay, wie auch immer das passiert ist. Hab da eigentlich nicht bewusst was gemacht.
                                    Das heißt Node und Npm im Local Ordner deinstallieren? Oder was wäre die einfachste Lösung?
                                      @ronny-gerndt Schau dir das zweite HowTo aus meiner Signatur an, da steht alles zu nodeJS drin.
                                        @ronny-gerndt
                                        Jetzt würde mich mal interessieren, wie und wo du die node14 her hast.
                                        Aus dem Paketmanager kannst du die nicht haben. Die muss 'freihändig' installiert worden sein.
                                          @ronny-gerndt
                                          Ronny Gerndt
                                          @thomas-braun Ich hab den Raspi 4 am Freitag bekommen und den ioBroker Ordner des alten auf den neuen geschoben. Und versucht da wieder zum laufen zu bekommen, da hat dann Node gefehlt und ich habe es installiert.
                                          Passt das nun oder ist noch was krum?
                                          pi@raspberrypi:/usr $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                                          /usr/bin/nodejs
                                          v14.16.0
                                          /usr/bin/node
                                          v14.16.0
                                          /usr/bin/npm
                                          6.14.11
                                          nodejs:
                                            Versionstabelle:
                                          Das passiert dann wohl wenn man Windows User auf Linux los lässt :D
