  4. Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi)
    6.6k
xiaomiviomi
108 Beiträge 19 Kommentatoren 22.7k Aufrufe 26 Beobachtet
    kakacs
    @ciddi89 danke für die schnelle antwort. ich hab den link genommen und manuel installiert aber der wird mir nicht in den instanzen angezeigt woran kann das liegen ???
    • K kakacs
      da_WoodyD Offline
      da_WoodyD Offline
      @kakacs instanz angelegt, upload gemacht?
        kakacs
        @da_Woody ich mach das so
        das kommt dann dabei raus
        $ ./iobroker url "https://github.com/MeisterTR/ioBroker.mihome-vacuum" --debug
        install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee
        NPM version: 6.14.11
        npm install MeisterTR/ioBroker.mihome-vacuum#8a5a2bc9b985bb9e32147e7869f7cec87c183cee --loglevel error --prefix "/opt/iobroker" (System call)
        canvas@2.7.0 install /opt/iobroker/node_modules/canvas> node-pre-gyp install --fallback-to-build
        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird betreten
        SOLINK_MODULE(target) Release/obj.target/canvas-postbuild.node
        COPY Release/canvas-postbuild.node
        CXX(target) Release/obj.target/canvas/src/backend/Backend.o
        CXX(target) Release/obj.target/canvas/src/backend/ImageBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/PdfBackend.o
        CXX(target) Release/obj.target/canvas/src/backend/SvgBackend.o
        CXX(target) Release/obj.target/canvas/src/bmp/BMPParser.o
        ../src/bmp/BMPParser.cc: In member function ‘void BMPParser::Parser::parse(uint8_t*, int, uint8_t*)’:
        ../src/bmp/BMPParser.cc:186:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare] E(ptr - data > imgdOffset, "image data overlaps with another structure"); ~^~../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~~~../src/bmp/BMPParser.cc:201:27: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare] E(ptr - data + imgdSize > len, "not enough image data"); ~~~~~~~~~~~~~~~~^../src/bmp/BMPParser.cc:10:25: note: in definition of macro ‘E’ #define E(cond, msg) if(cond) return setErr(msg) ^~
        CXX(target) Release/obj.target/canvas/src/Backends.o
        CXX(target) Release/obj.target/canvas/src/Canvas.o
        CXX(target) Release/obj.target/canvas/src/CanvasGradient.o
        CXX(target) Release/obj.target/canvas/src/CanvasPattern.o
        CXX(target) Release/obj.target/canvas/src/CanvasRenderingContext2d.o
        CXX(target) Release/obj.target/canvas/src/closure.o
        CXX(target) Release/obj.target/canvas/src/color.o
        CXX(target) Release/obj.target/canvas/src/Image.o
        CXX(target) Release/obj.target/canvas/src/ImageData.o
        CXX(target) Release/obj.target/canvas/src/init.o
        CXX(target) Release/obj.target/canvas/src/register_font.o
        SOLINK_MODULE(target) Release/obj.target/canvas.node
        COPY Release/canvas.node
        make: Verzeichnis „/opt/iobroker/node_modules/canvas/build“ wird verlassen
        • iobroker.mihome-vacuum@3.0.2added 22 packages from 16 contributors in 73.493s
          46 packages are looking for funding run npm fund for details
          upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
          upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml
          upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png
          upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png
          upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png
          upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/root/howto.md root/howto.md text/markdown
          upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png
          upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png
          upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
          upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
          upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
          upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
          process exited with code 0
        dann steht das so da bei den adapter
        und bei instanzen steht er nicht drin
        aber wie ich bei dir sehe hast du die 2.1.1 und ich installiert habe ich die 3.0.2
        ? da_WoodyD 2 Antworten Letzte Antwort
        • K kakacs
          @kakacs ja die 3.0.2 ist richtig wenn du dein viomi Sauger damit nutzen möchtest. Dann musst du in die Adapter Übersicht und manuell eine Instanz installieren indem du auf die drei Punkte und dann auf das + klickst.
          • K kakacs
            da_WoodyD Offline
            da_WoodyD Offline
            @kakacs 1. setz dein log in quote-tags. ist unleserlich so.
            2. die version ist erstmal egal. du hast über die katze den adapter installiert, aber offensichtlich keine instanz dazu. sonst müsste das so aussehn
            die 3 punkte anklicken und dann das plus-zeichen. erst dann wird die instanz angelegt.
              kakacs
              jetzt habe ich die instanz installiert
              der wechselt immer von rot auf gelb
              ich hatte gestern den token ausgelesen wie in einer anleitung war mit ein android handy und windows pc
              und denn gebe ich da ein bei token. aber wenn ich auf geräte suche gehe kommt ein ganz anderer token raus .
                kakacs
                @da_Woody und das steht in meinem log
                  kakacs
                  @da_Woody
                  ich hab den Viomi se geht das mit dem auch ??
                  • K kakacs
                    da_WoodyD Offline
                    da_WoodyD Offline
                    @kakacs warum steht bei der suche nichts?
                    das ist dann der token.
                      kakacs
                      schrieb am zuletzt editiert von kakacs
                      @da_Woody
                      ich dachte erst das das daran lag da ich ja gestern ein anderen token ausgelesen habe über die app
                      habe ich jetzt gemacht steht auch drin und haben den auch in token eingeben.
                      instanz wecheslt von gelb auf roten ständig
                        kakacs
                        @da_Woody
                        so steht im log jetzt
                          kakacs
                          hätte einer vielleicht eine idee noch was das problem sein kann ???
                          Danke im voraus
                            kakacs
                            @Meistertr @da_Woody
                            hab es gerade noch mal versucht den adptar manuel installiert
                            das gibt er mir raus bei installieren ist dieses loglevel error normal ?
                            • iobroker.mihome-vacuum@3.0.2added 22 packages from 16 contributors in 72.94s
                            • MeistertrM Meistertr
                              Aktuelle Test Version 3.0.1-alpha
                              Veröffentlichungsdatum 22.09.2020
                              Github Link https://github.com/MeisterTR/ioBroker.mihome-vacuum
                              Hallo Leute in der letzten Zeit bring Xioami immer mehr Saugroboter auf den Markt die keine Eigenmarke sind und von der bisherigen Api vollkommen abweichen.
                              Um diese und die Zukünftigen Geräte besser und schneller integrieren zu können, war ein kompletter rework des Adapters erforderlich.
                              Was hat sich geändert:
                              • erstmal alles
                              • im alten Adapter wurden erstmal alle daten abgefragt ohne überhaupt zu wissen ob das Model überhaupt die Eigenschaften hat, jetzt wird erst das Model ermittelt und je nachdem dann die verschieden Dateien geladen. Das stabilisiert die Verbindung und führt zu keinen Verbindungsproblemen mehr
                              • jede api/Model bekommt sein eigenes File wo ggf. Funktionen wie Raumreinigung und Karte geladen werden.
                              in den ersten 3er Versionen geht es NUR im die Viomi Modelle (STYJ02YM /Mi Mop Pro und STYJ02YM)
                              wenn die soweit laufen hole ich die anderen nach und nach mit an board
                              GoodOld
                              schrieb am zuletzt editiert von GoodOld
                              @meistertr Moin, ich teste gerade den neuen (noch nicht auf dem Markt) den Dreame L10 Pro.
                              Adapter ist grün, aber leider werden nur die Üblichen Datenpunkte erzeugt wie "device Info" & "info".
                              Falls ich irgendwie helfen kann, einfach melden.
                              PS: Aktuell lässte er sich nur über den China Server einbinden.
                              mihome-vacuum.0	2021-04-02 18:57:10.832	warn	(1526) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                              mihome-vacuum.0	2021-04-02 18:57:10.832	debug	(1526) DeviceModel selected to: dreame.vacuum.p2029
                              mihome-vacuum.0	2021-04-02 18:57:10.830	debug	(1526) Get Device data from robot..
                              mihome-vacuum.0	2021-04-02 18:57:10.829	debug	(1526) Get Device data..1
                              mihome-vacuum.0	2021-04-02 18:57:10.828	debug	(1526) GETMODELFROMAPI:Data: {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_1038","ap":{"ssid":"Hust24","bssid":"xxxxxxx","rssi":-43},"netif":{"l
                              mihome-vacuum.0	2021-04-02 18:57:10.821	debug	(1526) Get Device data..0
                              mihome-vacuum.0	2021-04-02 18:57:08.812	debug	(1526) GETMODELFROMAPI: objModel: {"val":"dreame.vacuum.p2029","ack":true,"ts":1617xxxxx189,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":161xxxxx60}
                              mihome-vacuum.0	2021-04-02 18:57:08.803	debug	(1526) MAIN: Connected to device, try to get model..
                              mihome-vacuum.0	2021-04-02 18:57:08.794	debug	(1526) server started on 0.0.0.0:53421
                              mihome-vacuum.0	2021-04-02 18:57:08.779	debug	(1526) MIIO: Config: ip:192.168.178.249 token: 737xxxxxxxxxxxxxxxxx4
                              mihome-vacuum.0	2021-04-02 18:57:08.777	debug	(1526) load Map creator... true
                              mihome-vacuum.0	2021-04-02 18:57:08.656	info	(1526) check group user admin group admin: false
                              mihome-vacuum.0	2021-04-02 18:57:08.638	info	(1526) check user admin pw iobroker: false
                              mihome-vacuum.0	2021-04-02 18:57:08.340	info	(1526) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
                              mihome-vacuum.0	2021-04-02 18:57:07.541	debug	(1526) statesDB connected
                              mihome-vacuum.0	2021-04-02 18:57:07.536	debug	(1526) States connected to redis: 127.0.0.1:9010
                              mihome-vacuum.0	2021-04-02 18:57:07.489	debug	(1526) States create User PubSub Client
                              mihome-vacuum.0	2021-04-02 18:57:07.488	debug	(1526) States create System PubSub Client
                              mihome-vacuum.0	2021-04-02 18:57:07.464	debug	(1526) Redis States: Use Redis connection: 127.0.0.1:9010
                              mihome-vacuum.0	2021-04-02 18:57:07.459	debug	(1526) objectDB connected
                              mihome-vacuum.0	2021-04-02 18:57:07.436	debug	(1526) Objects connected to redis: 127.0.0.1:9011
                              mihome-vacuum.0	2021-04-02 18:57:07.386	debug	(1526) Objects client initialize lua scripts
                              mihome-vacuum.0	2021-04-02 18:57:07.385	debug	(1526) Objects create User PubSub Client
                              mihome-vacuum.0	2021-04-02 18:57:07.383	debug	(1526) Objects create System PubSub Client
                              mihome-vacuum.0	2021-04-02 18:57:07.377	debug	(1526) Objects client ready ... initialize now
                              mihome-vacuum.0	2021-04-02 18:57:06.864	debug	(1526) Redis Objects: Use Redis connection: 127.0.0.1:9011
                              mihome-vacuum.0	2021-04-02 18:57:01.857	info	(1122) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              mihome-vacuum.0	2021-04-02 18:57:01.855	info	(1122) terminating
                              mihome-vacuum.0	2021-04-02 18:57:01.853	info	(1122) Got terminate signal TERMINATE_YOURSELF
                              mihome-vacuum.0	2021-04-02 18:56:07.176	warn	(1122) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                              mihome-vacuum.0	2021-04-02 18:56:07.065	info	(1122) check group user admin group admin: false
                              mihome-vacuum.0	2021-04-02 18:56:07.056	info	(1122) check user admin pw iobroker: false
                              mihome-vacuum.0	2021-04-02 18:56:06.715	info	(1122) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
                              mihome-vacuum.0	2021-04-02 18:55:59.896	info	(632) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              mihome-vacuum.0	2021-04-02 18:55:59.894	info	(632) terminating
                              mihome-vacuum.0	2021-04-02 18:55:59.891	info	(632) Got terminate signal TERMINATE_YOURSELF
                              mihome-vacuum.0	2021-04-02 18:55:09.233	warn	(632) Model dreame.vacuum.p2029 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                              mihome-vacuum.0	2021-04-02 18:55:05.102	info	(632) check group user admin group admin: false
                              mihome-vacuum.0	2021-04-02 18:55:05.093	info	(632) check user admin pw iobroker: false
                              mihome-vacuum.0	2021-04-02 18:55:04.753	info	(632) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.23.0, js-controller: 3.2.16
                              mihome-vacuum.0	2021-04-02 18:54:57.748	info	(32156) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              mihome-vacuum.0	2021-04-02 18:54:57.746	info	(32156) terminating
                              mihome-vacuum.0	2021-04-02 18:54:57.743	info	(32156) Got terminate signal TERMINATE_YOURSEL
                              MeistertrM 1 Antwort Letzte Antwort
                              • G GoodOld
                                MeistertrM Offline
                                MeistertrM Offline
                                Meistertr
                                @goodold die Dream Modelle kommunizieren anders als die anderen nicht über miio sondern über miot das ist das neue Standartprotokoll von xiaomi mit DID (DeviceID kein Problem kommt mit über die cloud) SID (ServiceID) und PID (ParameterID) wie meine Nachforschungen ergeben haben geht diese Kommunikation auch verschlüsselt über udp wie beim miio (Schonmal gut somit kann man das alte nutzen) Ich bin gerade wieder mal an dem Adapter rewrite und baue es so, dass es Modular aufgebaut ist und schnell und einfach neue Geräte hinzugefügt werden können.
                                Jetzt Kommt aber das ABER Das Testen der Nachrichten ist sehr zeitaufwendig. Hilfe bietet jeder an (das aber auch nur, wenn es um bugreport und testen geht) für miot gibt es eine webapi wo alle komandos beschrieben sind (Reschere über git adresse ist mi.spect....) Der Adapter bieten in allen Versionen die Möglichkeit eigene Komandos zu schicken. also eigentlich nichts weltbewegendes, was auch jeder Beginner kann.
                                Ablauf:
                                1: Komandos SID und PID aus der mi.spect suchen (da gibs für jedes device einen apiurl)
                                2: config aus admin herunterladen und mit dem Texteditor öffen (unter devices müsste in einer json die DID stehen)
                                3: am besten in einen Texteditor die Messages zusammenbauen und abschicken und sehen was zurückkommt.
                                4: das ganze dokumentieren und mir zukommen lassen. dann ist der Roboter im nu eingebunden
                                da fällt mir gerade ein dass es so mit dem adapter noch nciht geht weil die Nachricht auf miio standard geprüft wird. Wenn Interesse besteht mach ich eine Version fertig in der man raw daten senden kann.
                                  kakacs
                                  @Meistertr gild das auch für den xiaomi viomi se ??? ich bekomme denn nicht verbunden mit dem adapter ??
                                  • K kakacs
                                    MeistertrM Offline
                                    MeistertrM Offline
                                    Meistertr
                                    @kakacs gibt es da etwas nähere ausführungen? debuglog? wie ist die Modellbezeichnung also viomi.vacuum.xxx
                                      kakacs
                                      #66
                                      @meistertr das model ist viomi.vacuum.v19
                                      wenn ich den andapter von dir installiere kommt das bei der installation raus .
                                      • iobroker.mihome-vacuum@3.0.2added 23 packages from 15 contributors in 68.776s
                                      52 packages are looking for funding run npm fund for details
                                      und das kommt beim log raus :
                                      mihome-vacuum.0 2021-04-04 10:59:11.969 warn (19248) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      mihome-vacuum.0 2021-04-04 10:59:11.967 info (19248) terminating
                                      mihome-vacuum.0 2021-04-04 10:59:11.942 error (19248) Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 10:59:11.941 error (19248) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                                      mihome-vacuum.0 2021-04-04 10:59:11.939 error (19248) unhandled promise rejection: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 10:59:11.937 error (19248) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      mihome-vacuum.0 2021-04-04 10:59:01.898 info (19248) check group user admin group admin: false
                                      mihome-vacuum.0 2021-04-04 10:59:01.893 info (19248) check user admin pw iobroker: true
                                      mihome-vacuum.0 2021-04-04 10:59:01.687 info (19248) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                      mihome-vacuum.0 2021-04-04 10:58:29.564 warn (19214) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      mihome-vacuum.0 2021-04-04 10:58:29.562 info (19214) terminating
                                      mihome-vacuum.0 2021-04-04 10:58:29.542 error (19214) Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 10:58:29.541 error (19214) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                                      mihome-vacuum.0 2021-04-04 10:58:29.539 error (19214) unhandled promise rejection: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 10:58:29.538 error (19214) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      mihome-vacuum.0 2021-04-04 10:58:19.440 info (19214) check group user admin group admin: false
                                      mihome-vacuum.0 2021-04-04 10:58:19.435 info (19214) check user admin pw iobroker: true
                                      mihome-vacuum.0 2021-04-04 10:58:19.235 info (19214) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                      mihome-vacuum.0 2021-04-04 10:57:47.070 warn (19187) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      mihome-vacuum.0 2021-04-04 10:57:47.068 info (19187) terminating
                                      mihome-vacuum.0 2021-04-04 10:57:47.044 error (19187) Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 10:57:47.043 error (19187) TypeError: Cannot read property 'val' of null at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                                      mihome-vacuum.0 2021-04-04 10:57:47.040 error (19187) unhandled promise rejection: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 10:57:47.039 error (19187) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      mihome-vacuum.0 2021-04-04 09:57:36.943 info (19187) check group user admin group admin: false
                                      mihome-vacuum.0 2021-04-04 09:57:36.938 info (19187) check user admin pw iobroker: true
                                      mihome-vacuum.0 2021-04-04 09:57:36.729 info (19187) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                      mihome-vacuum.0 2021-04-04 09:56:28.779 warn (19145) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      mihome-vacuum.0 2021-04-04 09:56:28.776 info (19145) terminating
                                      mihome-vacuum.0 2021-04-04 09:56:28.752 error (19145) Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:56:28.751 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                                      mihome-vacuum.0 2021-04-04 09:56:28.751 error (19145) TypeError: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:56:28.748 error (19145) unhandled promise rejection: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:56:28.747 error (19145) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      mihome-vacuum.0 2021-04-04 09:56:18.711 info (19145) check group user admin group admin: false
                                      mihome-vacuum.0 2021-04-04 09:56:18.707 info (19145) check user admin pw iobroker: true
                                      mihome-vacuum.0 2021-04-04 09:56:18.498 info (19145) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                      mihome-vacuum.0 2021-04-04 09:55:46.333 warn (19125) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      mihome-vacuum.0 2021-04-04 09:55:46.330 info (19125) terminating
                                      mihome-vacuum.0 2021-04-04 09:55:46.302 error (19125) Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:55:46.301 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                                      mihome-vacuum.0 2021-04-04 09:55:46.301 error (19125) TypeError: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:55:46.299 error (19125) unhandled promise rejection: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:55:46.297 error (19125) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      mihome-vacuum.0 2021-04-04 09:55:36.204 info (19125) check group user admin group admin: false
                                      mihome-vacuum.0 2021-04-04 09:55:36.199 info (19125) check user admin pw iobroker: true
                                      mihome-vacuum.0 2021-04-04 09:55:35.993 info (19125) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                      mihome-vacuum.0 2021-04-04 09:55:03.867 warn (19100) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      mihome-vacuum.0 2021-04-04 09:55:03.864 info (19100) terminating
                                      mihome-vacuum.0 2021-04-04 09:55:03.840 error (19100) Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:55:03.838 error at MihomeVacuum.getModel (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:102:37)
                                      mihome-vacuum.0 2021-04-04 09:55:03.838 error (19100) TypeError: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:55:03.836 error (19100) unhandled promise rejection: Cannot read property 'val' of null
                                      mihome-vacuum.0 2021-04-04 09:55:03.835 error (19100) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      mihome-vacuum.0 2021-04-04 09:54:53.734 info (19100) check group user admin group admin: false
                                      mihome-vacuum.0 2021-04-04 09:54:53.729 info (19100) check user admin pw iobroker: true
                                      mihome-vacuum.0 2021-04-04 09:54:53.507 info (19100) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                      mihome-vacuum.0 2021-04-04 09:54:48.899 info (19033) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      mihome-vacuum.0 2021-04-04 09:54:48.897 info (19033) terminating
                                      mihome-vacuum.0 2021-04-04 09:54:48.894 info (19033) Got terminate signal TERMINATE_YOURSELF
                                      mihome-vacuum.0 2021-04-04 09:52:32.454 info (19033) check group user admin group admin: false
                                      mihome-vacuum.0 2021-04-04 09:52:32.449 info (19033) check user admin pw iobroker: true
                                      mihome-vacuum.0 2021-04-04 09:52:32.235 info (19033) starting. Version 3.0.2 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                      aber was mir auffällt ist das ein ganz andere token angezeigt wird als ich von der app ausgelesen habe.
                                      • K kakacs
                                        MeistertrM Offline
                                        MeistertrM Offline
                                        Meistertr
                                        #67
                                        @kakacs sagte in Test Adapter mihome-vacuum 3.x.x (STYJ02YM / Viomi):
                                        viomi.vacuum.v19
                                        installiere mal über https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/rebuild3
                                        K A 2 Antworten Letzte Antwort
                                          viomi.vacuum.v19
                                          kakacs
                                          #68
                                          @meistertr super mit dem wird die instanz grün und unter objekten steht schon mal was Screenshot_2021-04-04 objects - ioBroker.png
                                          aber es ändert sich nichts an wenn ich den staubsauger starte im log habe ich das jetzt
                                          mihome-vacuum.0 2021-04-04 14:22:50.827 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                                          mihome-vacuum.0 2021-04-04 13:21:50.822 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220013 sec
                                          mihome-vacuum.0 2021-04-04 13:20:50.934 warn (23416) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                                          mihome-vacuum.0 2021-04-04 13:20:50.718 warn (23416) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                                          mihome-vacuum.0 2021-04-04 13:20:50.639 info (23416) check group user admin group admin: false
                                          mihome-vacuum.0 2021-04-04 13:20:50.633 info (23416) check user admin pw iobroker: true
                                          mihome-vacuum.0 2021-04-04 13:20:50.408 info (23416) starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.21.0, js-controller: 3.2.16
                                          mihome-vacuum.0 2021-04-04 13:20:45.741 info (23341) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          mihome-vacuum.0 2021-04-04 13:20:45.739 info (23341) terminating
                                          mihome-vacuum.0 2021-04-04 13:20:45.736 info (23341) Got terminate signal TERMINATE_YOURSELF
                                          mihome-vacuum.0 2021-04-04 13:20:28.689 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                                          mihome-vacuum.0 2021-04-04 13:19:28.676 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                                          mihome-vacuum.0 2021-04-04 13:18:28.669 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
                                          mihome-vacuum.0 2021-04-04 13:17:30.856 warn (23341) Model viomi.vacuum.v19 not supported! Please open issue on git: https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues
                                          mihome-vacuum.0 2021-04-04 13:17:28.662 warn (23341) Time difference between Mihome Vacuum and ioBroker: -1617220014 sec
