  4. Iobroker neuinstallation startet nicht
installation iobroker
47 Beiträge 4 Kommentatoren 2.5k Aufrufe 3 Beobachtet
    @fraenki23 Schau dir das System mal mittels
    dmesg -T
    an
    @thomas-braun steht da dann auch ein eventuelles under-voltage drin?
    F Thomas BraunT 2 Antworten Letzte Antwort
      Fraenki23
      @homoran ```
      Wi-Fi is currently blocked by rfkill.
      Use raspi-config to set the country before use.
      pi@raspberrypi:~ $ dmesg -T
      [Thu Mar 11 13:36:24 2021] Booting Linux on physical CPU 0x0
      [Thu Mar 11 13:36:24 2021] Linux version 5.10.17-v7l+ (dom@buildbot) (arm-linux-        gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for U        buntu) 2.34) #1403 SMP Mon Feb 22 11:33:35 GMT 2021
      [Thu Mar 11 13:36:24 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), c        r=30c5383d
      [Thu Mar 11 13:36:24 2021] CPU: div instructions available: patching division co        de
      [Thu Mar 11 13:36:24 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruc        tion cache
      [Thu Mar 11 13:36:24 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.        1
      [Thu Mar 11 13:36:24 2021] Memory policy: Data cache writealloc
      [Thu Mar 11 13:36:24 2021] Reserved memory: created CMA memory pool at 0x0000000        01ec00000, size 256 MiB
      [Thu Mar 11 13:36:24 2021] OF: reserved mem: initialized node linux,cma, compati        ble id shared-dma-pool
      [Thu Mar 11 13:36:24 2021] Zone ranges:
      [Thu Mar 11 13:36:24 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff        ]
      [Thu Mar 11 13:36:24 2021]   Normal   empty
      [Thu Mar 11 13:36:24 2021]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff        ]
      [Thu Mar 11 13:36:24 2021] Movable zone start for each node
      [Thu Mar 11 13:36:24 2021] Early memory node ranges
      [Thu Mar 11 13:36:24 2021]   node   0: [mem 0x0000000000000000-0x000000003b3ffff        f]
      [Thu Mar 11 13:36:24 2021]   node   0: [mem 0x0000000040000000-0x00000000fbfffff        f]
      [Thu Mar 11 13:36:24 2021] Initmem setup node 0 [mem 0x0000000000000000-0x000000        00fbffffff]
      [Thu Mar 11 13:36:24 2021] On node 0 totalpages: 1012736
      [Thu Mar 11 13:36:24 2021]   DMA zone: 2304 pages used for memmap
      [Thu Mar 11 13:36:24 2021]   DMA zone: 0 pages reserved
      [Thu Mar 11 13:36:24 2021]   DMA zone: 196608 pages, LIFO batch:63
      [Thu Mar 11 13:36:24 2021]   HighMem zone: 816128 pages, LIFO batch:63
      [Thu Mar 11 13:36:24 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81        920
      [Thu Mar 11 13:36:24 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
      [Thu Mar 11 13:36:24 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
      [Thu Mar 11 13:36:24 2021] Built 1 zonelists, mobility grouping on.  Total pages        : 1010432
      [Thu Mar 11 13:36:24 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x        1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.        macaddr=DC:A6:32:3C:EA:69 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000        console=ttyS0,115200 console=tty1 root=PARTUUID=172f70ac-02 rootfstype=ext4 ele        vator=deadline fsck.repair=yes rootwait
      [Thu Mar 11 13:36:24 2021] Kernel parameter elevator= does not have any effect a        nymore.
                                 Please use sysfs to set IO scheduler for individual d        evices.
      [Thu Mar 11 13:36:24 2021] Dentry cache hash table entries: 131072 (order: 7, 52        4288 bytes, linear)
      [Thu Mar 11 13:36:24 2021] Inode-cache hash table entries: 65536 (order: 6, 2621        44 bytes, linear)
      [Thu Mar 11 13:36:24 2021] mem auto-init: stack:off, heap alloc:off, heap free:o        ff
      [Thu Mar 11 13:36:24 2021] software IO TLB: mapped [mem 0x0000000017cc0000-0x000        000001bcc0000] (64MB)
      [Thu Mar 11 13:36:24 2021] Memory: 3654936K/4050944K available (10240K kernel co        de, 1358K rwdata, 3160K rodata, 2048K init, 890K bss, 133864K reserved, 262144K        cma-reserved, 3264512K highmem)
      [Thu Mar 11 13:36:24 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, No        des=1
      [Thu Mar 11 13:36:24 2021] ftrace: allocating 33942 entries in 67 pages
      [Thu Mar 11 13:36:24 2021] ftrace: allocated 67 pages with 3 groups
      [Thu Mar 11 13:36:24 2021] rcu: Hierarchical RCU implementation.
      [Thu Mar 11 13:36:24 2021]      Rude variant of Tasks RCU enabled.
      [Thu Mar 11 13:36:24 2021]      Tracing variant of Tasks RCU enabled.
      [Thu Mar 11 13:36:24 2021] rcu: RCU calculated value of scheduler-enlistment del        ay is 10 jiffies.
      [Thu Mar 11 13:36:24 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [Thu Mar 11 13:36:24 2021] GIC: Using split EOI/Deactivate mode
      [Thu Mar 11 13:36:24 2021] random: get_random_bytes called from start_kernel+0x3        c8/0x59c with crng_init=0
      [Thu Mar 11 13:36:24 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, w        raps every 2147483647500ns
      [Thu Mar 11 13:36:24 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xff        ffffff, max_idle_ns: 1911260446275 ns
      [Thu Mar 11 13:36:24 2021] bcm2835: system timer (irq = 25)
      [Thu Mar 11 13:36:24 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
      [Thu Mar 11 13:36:24 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff        max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
      [Thu Mar 11 13:36:24 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps        every 4398046511102ns
      [Thu Mar 11 13:36:24 2021] Switching to timer-based delay loop, resolution 18ns
      [Thu Mar 11 13:36:24 2021] Console: colour dummy device 80x30
      [Thu Mar 11 13:36:24 2021] printk: console [tty1] enabled
      [Thu Mar 11 13:36:24 2021] Calibrating delay loop (skipped), value calculated us        ing timer frequency.. 108.00 BogoMIPS (lpj=540000)
      [Thu Mar 11 13:36:24 2021] pid_max: default: 32768 minimum: 301
      [Thu Mar 11 13:36:24 2021] LSM: Security Framework initializing
      [Thu Mar 11 13:36:24 2021] Mount-cache hash table entries: 2048 (order: 1, 8192        bytes, linear)
      [Thu Mar 11 13:36:24 2021] Mountpoint-cache hash table entries: 2048 (order: 1,        8192 bytes, linear)
      [Thu Mar 11 13:36:24 2021] Disabling memory control group subsystem
      [Thu Mar 11 13:36:24 2021] CPU: Testing write buffer coherency: ok
      [Thu Mar 11 13:36:24 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [Thu Mar 11 13:36:24 2021] Setting up static identity map for 0x200000 - 0x20003        c
      [Thu Mar 11 13:36:24 2021] rcu: Hierarchical SRCU implementation.
      [Thu Mar 11 13:36:24 2021] smp: Bringing up secondary CPUs ...
      [Thu Mar 11 13:36:24 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [Thu Mar 11 13:36:24 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
      [Thu Mar 11 13:36:24 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
      [Thu Mar 11 13:36:24 2021] smp: Brought up 1 node, 4 CPUs
      [Thu Mar 11 13:36:24 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS        ).
      [Thu Mar 11 13:36:24 2021] CPU: All CPU(s) started in HYP mode.
      [Thu Mar 11 13:36:24 2021] CPU: Virtualization extensions available.
      [Thu Mar 11 13:36:24 2021] devtmpfs: initialized
      [Thu Mar 11 13:36:24 2021] VFP support v0.3: implementor 41 architecture 3 part        40 variant 8 rev 0
      [Thu Mar 11 13:36:24 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0x        ffffffff, max_idle_ns: 19112604462750000 ns
      [Thu Mar 11 13:36:24 2021] futex hash table entries: 1024 (order: 4, 65536 bytes        , linear)
      [Thu Mar 11 13:36:24 2021] pinctrl core: initialized pinctrl subsystem
      [Thu Mar 11 13:36:24 2021] NET: Registered protocol family 16
      [Thu Mar 11 13:36:24 2021] DMA: preallocated 1024 KiB pool for atomic coherent a        llocations
      [Thu Mar 11 13:36:24 2021] audit: initializing netlink subsys (disabled)
      [Thu Mar 11 13:36:24 2021] audit: type=2000 audit(0.030:1): state=initialized au        dit_enabled=0 res=1
      [Thu Mar 11 13:36:24 2021] thermal_sys: Registered thermal governor 'step_wise'
      [Thu Mar 11 13:36:24 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4        watchpoint registers.
      [Thu Mar 11 13:36:24 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
      [Thu Mar 11 13:36:24 2021] Serial: AMBA PL011 UART driver
      [Thu Mar 11 13:36:24 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
      [Thu Mar 11 13:36:24 2021] raspberrypi-firmware soc:firmware: Attached to firmwa        re from 2021-02-25T12:10:40, variant start
      [Thu Mar 11 13:36:24 2021] raspberrypi-firmware soc:firmware: Firmware hash is 5        64e5f9b852b23a330b1764bcf0b2d022a20afd0
      [Thu Mar 11 13:36:24 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dma        chans=0x1
      [Thu Mar 11 13:36:24 2021] vgaarb: loaded
      [Thu Mar 11 13:36:24 2021] SCSI subsystem initialized
      [Thu Mar 11 13:36:24 2021] usbcore: registered new interface driver usbfs
      [Thu Mar 11 13:36:24 2021] usbcore: registered new interface driver hub
      [Thu Mar 11 13:36:24 2021] usbcore: registered new device driver usb
      [Thu Mar 11 13:36:24 2021] usb_phy_generic phy: supply vcc not found, using dumm        y regulator
      [Thu Mar 11 13:36:24 2021] clocksource: Switched to clocksource arch_sys_counter
      [Thu Mar 11 13:36:25 2021] VFS: Disk quotas dquot_6.6.0
      [Thu Mar 11 13:36:25 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4        096 bytes)
      [Thu Mar 11 13:36:25 2021] FS-Cache: Loaded
      [Thu Mar 11 13:36:25 2021] CacheFiles: Loaded
      [Thu Mar 11 13:36:25 2021] simple-framebuffer 3e4e0000.framebuffer: framebuffer        at 0x3e4e0000, 0x6e7000 bytes, mapped to 0x(ptrval)
      [Thu Mar 11 13:36:25 2021] simple-framebuffer 3e4e0000.framebuffer: format=a8r8g        8b8, mode=1824x984x32, linelength=7296
      [Thu Mar 11 13:36:25 2021] Console: switching to colour frame buffer device 228x        61
      [Thu Mar 11 13:36:25 2021] simple-framebuffer 3e4e0000.framebuffer: fb0: simplef        b registered!
      [Thu Mar 11 13:36:25 2021] NET: Registered protocol family 2
      [Thu Mar 11 13:36:25 2021] tcp_listen_portaddr_hash hash table entries: 512 (ord        er: 0, 6144 bytes, linear)
      [Thu Mar 11 13:36:25 2021] TCP established hash table entries: 8192 (order: 3, 3        2768 bytes, linear)
      [Thu Mar 11 13:36:25 2021] TCP bind hash table entries: 8192 (order: 4, 65536 by        tes, linear)
      [Thu Mar 11 13:36:25 2021] TCP: Hash tables configured (established 8192 bind 81        92)
      [Thu Mar 11 13:36:25 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, l        inear)
      [Thu Mar 11 13:36:25 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 byt        es, linear)
      [Thu Mar 11 13:36:25 2021] NET: Registered protocol family 1
      [Thu Mar 11 13:36:25 2021] RPC: Registered named UNIX socket transport module.
      [Thu Mar 11 13:36:25 2021] RPC: Registered udp transport module.
      [Thu Mar 11 13:36:25 2021] RPC: Registered tcp transport module.
      [Thu Mar 11 13:36:25 2021] RPC: Registered tcp NFSv4.1 backchannel transport mod        ule.
      [Thu Mar 11 13:36:25 2021] PCI: CLS 0 bytes, default 64
      [Thu Mar 11 13:36:25 2021] Initialise system trusted keyrings
      [Thu Mar 11 13:36:25 2021] workingset: timestamp_bits=14 max_order=20 bucket_ord        er=6
      [Thu Mar 11 13:36:25 2021] zbud: loaded
      [Thu Mar 11 13:36:25 2021] FS-Cache: Netfs 'nfs' registered for caching
      [Thu Mar 11 13:36:25 2021] NFS: Registering the id_resolver key type
      [Thu Mar 11 13:36:25 2021] Key type id_resolver registered
      [Thu Mar 11 13:36:25 2021] Key type id_legacy registered
      [Thu Mar 11 13:36:25 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registe        ring...
      [Thu Mar 11 13:36:25 2021] Key type asymmetric registered
      [Thu Mar 11 13:36:25 2021] Asymmetric key parser 'x509' registered
      [Thu Mar 11 13:36:25 2021] bounce: pool size: 64 pages
      [Thu Mar 11 13:36:25 2021] Block layer SCSI generic (bsg) driver version 0.4 loa        ded (major 249)
      [Thu Mar 11 13:36:25 2021] io scheduler mq-deadline registered
      [Thu Mar 11 13:36:25 2021] io scheduler kyber registered
      [Thu Mar 11 13:36:25 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d5000        00 ranges:
      [Thu Mar 11 13:36:25 2021] brcm-pcie fd500000.pcie:   No bus range found for /sc        b/pcie@7d500000, using [bus 00-ff]
      [Thu Mar 11 13:36:25 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063        fffffff -> 0x00c0000000
      [Thu Mar 11 13:36:25 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00b        fffffff -> 0x0400000000
      [Thu Mar 11 13:36:25 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (S        SC)
      [Thu Mar 11 13:36:25 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:        00
      [Thu Mar 11 13:36:25 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
      [Thu Mar 11 13:36:25 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0        x63fffffff] (bus address [0xc0000000-0xffffffff])
      [Thu Mar 11 13:36:25 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
      [Thu Mar 11 13:36:25 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
      [Thu Mar 11 13:36:25 2021] PCI: bus0: Fast back to back transfers disabled
      [Thu Mar 11 13:36:25 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
      [Thu Mar 11 13:36:25 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000ff        f 64bit]
      [Thu Mar 11 13:36:25 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
      [Thu Mar 11 13:36:25 2021] PCI: bus1: Fast back to back transfers disabled
      [Thu Mar 11 13:36:25 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x        6000fffff]
      [Thu Mar 11 13:36:25 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x        600000fff 64bit]
      [Thu Mar 11 13:36:25 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
      [Thu Mar 11 13:36:25 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x        6000fffff]
      [Thu Mar 11 13:36:25 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
      [Thu Mar 11 13:36:25 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
      [Thu Mar 11 13:36:25 2021] iproc-rng200 fe104000.rng: hwrng registered
      [Thu Mar 11 13:36:25 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_        size:0x40000000(1024 MiB)
      [Thu Mar 11 13:36:25 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Regist        ers at 0xfe200000
      [Thu Mar 11 13:36:25 2021] brd: module loaded
      [Thu Mar 11 13:36:25 2021] loop: module loaded
      [Thu Mar 11 13:36:25 2021] Loading iSCSI transport class v2.0-870.
      [Thu Mar 11 13:36:25 2021] libphy: Fixed MDIO Bus: probed
      [Thu Mar 11 13:36:25 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
      [Thu Mar 11 13:36:25 2021] libphy: bcmgenet MII bus: probed
      [Thu Mar 11 13:36:25 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
      [Thu Mar 11 13:36:25 2021] usbcore: registered new interface driver r8152
      [Thu Mar 11 13:36:25 2021] usbcore: registered new interface driver lan78xx
      [Thu Mar 11 13:36:25 2021] usbcore: registered new interface driver smsc95xx
      [Thu Mar 11 13:36:25 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
      [Thu Mar 11 13:36:25 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
      [Thu Mar 11 13:36:25 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assign        ed bus number 1
      [Thu Mar 11 13:36:25 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci vers        ion 0x100 quirks 0x0000030000000890
      [Thu Mar 11 13:36:25 2021] usb usb1: New USB device found, idVendor=1d6b, idProd        uct=0002, bcdDevice= 5.10
      [Thu Mar 11 13:36:25 2021] usb usb1: New USB device strings: Mfr=3, Product=2, S        erialNumber=1
      [Thu Mar 11 13:36:25 2021] usb usb1: Product: xHCI Host Controller
      [Thu Mar 11 13:36:25 2021] usb usb1: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
      [Thu Mar 11 13:36:25 2021] usb usb1: SerialNumber: 0000:01:00.0
      [Thu Mar 11 13:36:25 2021] hub 1-0:1.0: USB hub found
      [Thu Mar 11 13:36:25 2021] hub 1-0:1.0: 1 port detected
      [Thu Mar 11 13:36:25 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assign        ed bus number 2
      [Thu Mar 11 13:36:25 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpe        ed
      [Thu Mar 11 13:36:25 2021] usb usb2: New USB device found, idVendor=1d6b, idProd        uct=0003, bcdDevice= 5.10
      [Thu Mar 11 13:36:25 2021] usb usb2: New USB device strings: Mfr=3, Product=2, S        erialNumber=1
      [Thu Mar 11 13:36:25 2021] usb usb2: Product: xHCI Host Controller
      [Thu Mar 11 13:36:25 2021] usb usb2: Manufacturer: Linux 5.10.17-v7l+ xhci-hcd
      [Thu Mar 11 13:36:25 2021] usb usb2: SerialNumber: 0000:01:00.0
      [Thu Mar 11 13:36:25 2021] hub 2-0:1.0: USB hub found
      [Thu Mar 11 13:36:25 2021] hub 2-0:1.0: 4 ports detected
      [Thu Mar 11 13:36:25 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
      [Thu Mar 11 13:36:25 2021] dwc_otg: FIQ enabled
      [Thu Mar 11 13:36:25 2021] dwc_otg: NAK holdoff enabled
      [Thu Mar 11 13:36:25 2021] dwc_otg: FIQ split-transaction FSM enabled
      [Thu Mar 11 13:36:25 2021] Module dwc_common_port init
      [Thu Mar 11 13:36:25 2021] usbcore: registered new interface driver uas
      [Thu Mar 11 13:36:25 2021] usbcore: registered new interface driver usb-storage
      [Thu Mar 11 13:36:25 2021] mousedev: PS/2 mouse device common for all mice
      [Thu Mar 11 13:36:25 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog ti        mer
      [Thu Mar 11 13:36:25 2021] sdhci: Secure Digital Host Controller Interface drive        r
      [Thu Mar 11 13:36:25 2021] sdhci: Copyright(c) Pierre Ossman
      [Thu Mar 11 13:36:25 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferr        ing probe
      [Thu Mar 11 13:36:25 2021] sdhci-pltfm: SDHCI platform and OF driver helper
      [Thu Mar 11 13:36:25 2021] ledtrig-cpu: registered to indicate activity on CPUs
      [Thu Mar 11 13:36:25 2021] hid: raw HID events driver (C) Jiri Kosina
      [Thu Mar 11 13:36:25 2021] usbcore: registered new interface driver usbhid
      [Thu Mar 11 13:36:25 2021] usbhid: USB HID core driver
      [Thu Mar 11 13:36:25 2021] Initializing XFRM netlink socket
      [Thu Mar 11 13:36:25 2021] NET: Registered protocol family 17
      [Thu Mar 11 13:36:25 2021] Key type dns_resolver registered
      [Thu Mar 11 13:36:25 2021] Registering SWP/SWPB emulation handler
      [Thu Mar 11 13:36:25 2021] registered taskstats version 1
      [Thu Mar 11 13:36:25 2021] Loading compiled-in X.509 certificates
      [Thu Mar 11 13:36:25 2021] Key type ._fscrypt registered
      [Thu Mar 11 13:36:25 2021] Key type .fscrypt registered
      [Thu Mar 11 13:36:25 2021] Key type fscrypt-provisioning registered
      [Thu Mar 11 13:36:25 2021] uart-pl011 fe201000.serial: there is not valid maps f        or state default
      [Thu Mar 11 13:36:25 2021] uart-pl011 fe201000.serial: cts_event_workaround enab        led
      [Thu Mar 11 13:36:25 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36        , base_baud = 0) is a PL011 rev2
      [Thu Mar 11 13:36:25 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power d        omains driver
      [Thu Mar 11 13:36:25 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
      [Thu Mar 11 13:36:25 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
      [Thu Mar 11 13:36:25 2021] of_cfs_init
      [Thu Mar 11 13:36:25 2021] of_cfs_init: OK
      [Thu Mar 11 13:36:25 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
      [Thu Mar 11 13:36:25 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
      [Thu Mar 11 13:36:25 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
      [Thu Mar 11 13:36:25 2021] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.em        mc2] using ADMA
      [Thu Mar 11 13:36:25 2021] Waiting for root device PARTUUID=172f70ac-02...
      [Thu Mar 11 13:36:25 2021] random: fast init done
      [Thu Mar 11 13:36:25 2021] mmc0: new high speed SDXC card at address 2103
      [Thu Mar 11 13:36:25 2021] mmcblk0: mmc0:2103 APPSD 58.6 GiB
      [Thu Mar 11 13:36:25 2021]  mmcblk0: p1 p2
      [Thu Mar 11 13:36:25 2021] mmc1: new high speed SDIO card at address 0001
      [Thu Mar 11 13:36:25 2021] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
      [Thu Mar 11 13:36:25 2021] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
      [Thu Mar 11 13:36:25 2021] usb 1-1: new high-speed USB device number 2 using xhc        i_hcd
      [Thu Mar 11 13:36:26 2021] usb 1-1: New USB device found, idVendor=2109, idProdu        ct=3431, bcdDevice= 4.21
      [Thu Mar 11 13:36:26 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, Se        rialNumber=0
      [Thu Mar 11 13:36:26 2021] usb 1-1: Product: USB2.0 Hub
      [Thu Mar 11 13:36:26 2021] hub 1-1:1.0: USB hub found
      [Thu Mar 11 13:36:26 2021] hub 1-1:1.0: 4 ports detected
      [Thu Mar 11 13:36:45 2021] EXT4-fs (mmcblk0p2): recovery complete
      [Thu Mar 11 13:36:49 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Opts: (null)
      [Thu Mar 11 13:36:49 2021] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
      [Thu Mar 11 13:36:49 2021] devtmpfs: mounted
      [Thu Mar 11 13:36:49 2021] Freeing unused kernel memory: 2048K
      [Thu Mar 11 13:36:49 2021] Run /sbin/init as init process
      [Thu Mar 11 13:36:49 2021]   with arguments:
      [Thu Mar 11 13:36:49 2021]     /sbin/init
      [Thu Mar 11 13:36:49 2021]   with environment:
      [Thu Mar 11 13:36:49 2021]     HOME=/
      [Thu Mar 11 13:36:49 2021]     TERM=linux
      [Thu Mar 11 13:36:50 2021] systemd[1]: System time before build time, advancing        clock.
      [Thu Mar 11 13:36:50 2021] NET: Registered protocol family 10
      [Thu Mar 11 13:36:50 2021] Segment Routing with IPv6
      [Thu Mar 11 13:36:50 2021] systemd[1]: systemd 241 running in system mode. (+PAM        +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +G        NUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hi        erarchy=hybrid)
      [Thu Mar 11 13:36:50 2021] systemd[1]: Detected architecture arm.
      [Thu Mar 11 13:36:50 2021] systemd[1]: Set hostname to <raspberrypi>.
      [Thu Mar 11 13:36:51 2021] random: systemd: uninitialized urandom read (16 bytes        read)
      [Thu Mar 11 13:36:51 2021] systemd[1]: Created slice User and Session Slice.
      [Thu Mar 11 13:36:51 2021] systemd[1]: Started Forward Password Requests to Wall        Directory Watch.
      [Thu Mar 11 13:36:51 2021] systemd[1]: Listening on Journal Socket (/dev/log).
      [Thu Mar 11 13:36:51 2021] systemd[1]: Listening on fsck to fsckd communication        Socket.
      [Thu Mar 11 13:36:51 2021] systemd[1]: Listening on Journal Socket.
      [Thu Mar 11 13:36:51 2021] systemd[1]: Mounting RPC Pipe File System...
      [Thu Mar 11 13:36:51 2021] systemd[1]: Listening on Syslog Socket.
      [Thu Mar 11 13:36:56 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      [Thu Mar 11 13:36:56 2021] systemd-journald[116]: Received request to flush runt        ime journal from PID 1
      [Thu Mar 11 13:36:56 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem init        ialised: Registers at 0xfeb00000 length 0x00010000
      [Thu Mar 11 13:36:56 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem        initialised: Registers at 0xfeb10000 length 0x00001000
      [Thu Mar 11 13:36:56 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem init        ialised: Registers at 0xfeb20000 length 0x00010000
      [Thu Mar 11 13:36:56 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initia        lised: Registers at 0xfeb30000 length 0x00010000
      [Thu Mar 11 13:36:57 2021] vc_sm_cma: module is from the staging directory, the        quality is unknown, you have been warned.
      [Thu Mar 11 13:36:57 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driv        er
      [Thu Mar 11 13:36:57 2021] [vc_sm_connected_init]: start
      [Thu Mar 11 13:36:57 2021] snd_bcm2835: module is from the staging directory, th        e quality is unknown, you have been warned.
      [Thu Mar 11 13:36:57 2021] [vc_sm_connected_init]: installed successfully
      [Thu Mar 11 13:36:57 2021] mc: Linux media interface: v0.10
      [Thu Mar 11 13:36:57 2021] bcm2835_audio bcm2835_audio: card created with 4 chan        nels
      [Thu Mar 11 13:36:57 2021] videodev: Linux video capture interface: v2.00
      [Thu Mar 11 13:36:57 2021] bcm2835_mmal_vchiq: module is from the staging direct        ory, the quality is unknown, you have been warned.
      [Thu Mar 11 13:36:57 2021] bcm2835_codec: module is from the staging directory,        the quality is unknown, you have been warned.
      [Thu Mar 11 13:36:57 2021] bcm2835_isp: module is from the staging directory, th        e quality is unknown, you have been warned.
      [Thu Mar 11 13:36:57 2021] bcm2835_v4l2: module is from the staging directory, t        he quality is unknown, you have been warned.
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Device node output[0] regist        ered as /dev/video13
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Device node capture[0] regis        tered as /dev/video14
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Device node capture[1] regis        tered as /dev/video15
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registe        red as /dev/video16
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Register output node 0 with        media controller
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with        media controller
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with        media controller
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with        media controller
      [Thu Mar 11 13:36:57 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
      [Thu Mar 11 13:36:57 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d        on minor 0
      [Thu Mar 11 13:36:57 2021] bcm2835-codec bcm2835-codec: Device registered as /de        v/video10
      [Thu Mar 11 13:36:57 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
      [Thu Mar 11 13:36:57 2021] cfg80211: Loading compiled-in X.509 certificates for        regulatory database
      [Thu Mar 11 13:36:57 2021] bcm2835-codec bcm2835-codec: Device registered as /de        v/video11
      [Thu Mar 11 13:36:57 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
      [Thu Mar 11 13:36:57 2021] bcm2835-codec bcm2835-codec: Device registered as /de        v/video12
      [Thu Mar 11 13:36:57 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
      [Thu Mar 11 13:36:57 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms        _ops [vc4])
      [Thu Mar 11 13:36:57 2021] checking generic (3e4e0000 6e7000) vs hw (0 fffffffff        fffffff)
      [Thu Mar 11 13:36:57 2021] fb0: switching to vc4drmfb from simple
      [Thu Mar 11 13:36:57 2021] Console: switching to colour dummy device 80x30
      [Thu Mar 11 13:36:57 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9        cea7'
      [Thu Mar 11 13:36:57 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor        1
      [Thu Mar 11 13:36:57 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
      [Thu Mar 11 13:36:57 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac        43455-sdio for chip BCM4345/6
      [Thu Mar 11 13:36:57 2021] usbcore: registered new interface driver brcmfmac
      [Thu Mar 11 13:36:57 2021] Console: switching to colour frame buffer device 240x        67
      [Thu Mar 11 13:36:57 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/b        rcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
      [Thu Mar 11 13:36:57 2021] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
      [Thu Mar 11 13:36:58 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac        43455-sdio for chip BCM4345/6
      [Thu Mar 11 13:36:58 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6        wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
      [Thu Mar 11 13:37:15 2021] uart-pl011 fe201000.serial: no DMA platform data
      [Thu Mar 11 13:37:15 2021] random: crng init done
      [Thu Mar 11 13:37:15 2021] random: 7 urandom warning(s) missed due to ratelimiti        ng
      [Thu Mar 11 13:37:15 2021] 8021q: 802.1Q VLAN Support v1.8
      [Thu Mar 11 13:37:15 2021] Adding 102396k swap on /var/swap.  Priority:-2 extent        s:1 across:102396k SSFS
      [Thu Mar 11 13:37:16 2021] bcmgenet fd580000.ethernet: configuring instance for        external RGMII (RX delay)
      [Thu Mar 11 13:37:16 2021] bcmgenet fd580000.ethernet eth0: Link is Down
      [Thu Mar 11 13:37:19 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/F        ull - flow control off
      [Thu Mar 11 13:37:19 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes rea        dy
      [Thu Mar 11 13:38:13 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (        syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time        _ms instead
      pi@raspberrypi:~ $
      muss gleich weg sieht man da was
      Ist original raspi 4 Netzteil
        Ja, auch under voltage würde da drin stehen. Deswegen schau ich da ganz gerne in Gänze rein, alles was dem System wirklich weh tut landet im dmesg.
        @Fraenki23
        Da läuft eine graphische Oberfläche mit, würde ich behaupten. Stell den Server auf RunLevel 3 (Nur Kommandozeile) ein.
        Das Dateisystem wurde auch vor dem boot von 13:36 nicht sauber heruntergefahren/ausgehängt. Das braucht wegen des dann zwangsweise durchgeführten filesystemcheck auch noch mal mehr Zeit als üblich.
        F 1 Antwort Letzte Antwort
          @Fraenki23
          Fraenki23
          @thomas-braun Hallo
          Vielen Dank für die Hilfe die ich bekommen habe.
          Ich habe in den letzten Tagen einiges gelernt.
          Nachdem ich nun zig mal eine neue Karte beschrieben habe und es immer wieder hing habe ich die Karte nicht im Raspi4 sondern im alten Raspi 3 eingelegt.
          Dort läuft alles rasend schnell die Installation ca 30 Minuten.
          Inkl Update Upgrade usw.
          Nun denke ich der Raspi 4 hat nen Fehler und ich weiß nicht was ich mit dem tun kann .
          Gruß und dank Frank
          P.s. Wie sieht das unten aus ?
          login as: pi
          pi@192.168.178.66's password:
          Linux raspberrypi 5.10.17-v7+ #1403 SMP Mon Feb 22 11:29:51 GMT 2021 armv7l
          permitted by applicable law.
          Last login: Thu Mar 11 18:53:23 2021 from 192.168.178.46
          SSH is enabled and the default password for the 'pi' user has not been changed.
          This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
          [Thu Mar 11 18:57:20 2021] Booting Linux on physical CPU 0x0
          [Thu Mar 11 18:57:20 2021] Linux version 5.10.17-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1403 SMP Mon Feb 22 11:29:51 GMT 2021
          [Thu Mar 11 18:57:20 2021] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
          [Thu Mar 11 18:57:20 2021] CPU: div instructions available: patching division code
          [Thu Mar 11 18:57:20 2021] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
          [Thu Mar 11 18:57:20 2021] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
          [Thu Mar 11 18:57:20 2021] Memory policy: Data cache writealloc
          [Thu Mar 11 18:57:20 2021] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
          [Thu Mar 11 18:57:20 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
          [Thu Mar 11 18:57:20 2021] Zone ranges:
          [Thu Mar 11 18:57:20 2021]   DMA      [mem 0x0000000000000000-0x000000003b3fffff]
          [Thu Mar 11 18:57:20 2021]   Normal   empty
          [Thu Mar 11 18:57:20 2021] Movable zone start for each node
          [Thu Mar 11 18:57:20 2021] Early memory node ranges
          [Thu Mar 11 18:57:20 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
          [Thu Mar 11 18:57:20 2021] Initmem setup node 0 [mem 0x0000000000000000-0x000000003b3fffff]
          [Thu Mar 11 18:57:20 2021] On node 0 totalpages: 242688
          [Thu Mar 11 18:57:20 2021]   DMA zone: 2133 pages used for memmap
          [Thu Mar 11 18:57:20 2021]   DMA zone: 0 pages reserved
          [Thu Mar 11 18:57:20 2021]   DMA zone: 242688 pages, LIFO batch:63
          [Thu Mar 11 18:57:20 2021] percpu: Embedded 20 pages/cpu s50700 r8192 d23028 u81920
          [Thu Mar 11 18:57:20 2021] pcpu-alloc: s50700 r8192 d23028 u81920 alloc=20*4096
          [Thu Mar 11 18:57:20 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
          [Thu Mar 11 18:57:20 2021] Built 1 zonelists, mobility grouping on.  Total pages: 240555
          [Thu Mar 11 18:57:20 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9cfaa631-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
          [Thu Mar 11 18:57:20 2021] Kernel parameter elevator= does not have any effect anymore.
                                     Please use sysfs to set IO scheduler for individual devices.
          [Thu Mar 11 18:57:20 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
          [Thu Mar 11 18:57:20 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
          [Thu Mar 11 18:57:20 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
          [Thu Mar 11 18:57:20 2021] Memory: 879832K/970752K available (9216K kernel code, 1311K rwdata, 2940K rodata, 1024K init, 860K bss, 25384K reserved, 65536K cma-reserved)
          [Thu Mar 11 18:57:20 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
          [Thu Mar 11 18:57:20 2021] ftrace: allocating 31910 entries in 63 pages
          [Thu Mar 11 18:57:20 2021] ftrace: allocated 63 pages with 6 groups
          [Thu Mar 11 18:57:20 2021] rcu: Hierarchical RCU implementation.
          [Thu Mar 11 18:57:20 2021]      Rude variant of Tasks RCU enabled.
          [Thu Mar 11 18:57:20 2021]      Tracing variant of Tasks RCU enabled.
          [Thu Mar 11 18:57:20 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
          [Thu Mar 11 18:57:20 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
          [Thu Mar 11 18:57:20 2021] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=0
          [Thu Mar 11 18:57:20 2021] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
          [Thu Mar 11 18:57:20 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
          [Thu Mar 11 18:57:20 2021] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
          [Thu Mar 11 18:57:20 2021] Switching to timer-based delay loop, resolution 52ns
          [Thu Mar 11 18:57:20 2021] Console: colour dummy device 80x30
          [Thu Mar 11 18:57:20 2021] printk: console [tty1] enabled
          [Thu Mar 11 18:57:20 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
          [Thu Mar 11 18:57:20 2021] pid_max: default: 32768 minimum: 301
          [Thu Mar 11 18:57:20 2021] LSM: Security Framework initializing
          [Thu Mar 11 18:57:20 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Thu Mar 11 18:57:20 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
          [Thu Mar 11 18:57:20 2021] Disabling memory control group subsystem
          [Thu Mar 11 18:57:20 2021] CPU: Testing write buffer coherency: ok
          [Thu Mar 11 18:57:20 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [Thu Mar 11 18:57:20 2021] Setting up static identity map for 0x100000 - 0x10003c
          [Thu Mar 11 18:57:20 2021] rcu: Hierarchical SRCU implementation.
          [Thu Mar 11 18:57:20 2021] smp: Bringing up secondary CPUs ...
          [Thu Mar 11 18:57:20 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [Thu Mar 11 18:57:20 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
          [Thu Mar 11 18:57:20 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
          [Thu Mar 11 18:57:20 2021] smp: Brought up 1 node, 4 CPUs
          [Thu Mar 11 18:57:20 2021] SMP: Total of 4 processors activated (153.60 BogoMIPS).
          [Thu Mar 11 18:57:20 2021] CPU: All CPU(s) started in HYP mode.
          [Thu Mar 11 18:57:20 2021] CPU: Virtualization extensions available.
          [Thu Mar 11 18:57:20 2021] devtmpfs: initialized
          [Thu Mar 11 18:57:20 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
          [Thu Mar 11 18:57:20 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [Thu Mar 11 18:57:20 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
          [Thu Mar 11 18:57:20 2021] pinctrl core: initialized pinctrl subsystem
          [Thu Mar 11 18:57:20 2021] NET: Registered protocol family 16
          [Thu Mar 11 18:57:20 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
          [Thu Mar 11 18:57:20 2021] audit: initializing netlink subsys (disabled)
          [Thu Mar 11 18:57:20 2021] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
          [Thu Mar 11 18:57:20 2021] thermal_sys: Registered thermal governor 'step_wise'
          [Thu Mar 11 18:57:20 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
          [Thu Mar 11 18:57:20 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
          [Thu Mar 11 18:57:20 2021] Serial: AMBA PL011 UART driver
          [Thu Mar 11 18:57:20 2021] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
          [Thu Mar 11 18:57:20 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-02-25T12:12:09, variant start
          [Thu Mar 11 18:57:20 2021] raspberrypi-firmware soc:firmware: Firmware hash is 564e5f9b852b23a330b1764bcf0b2d022a20afd0
          [Thu Mar 11 18:57:20 2021] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
          [Thu Mar 11 18:57:20 2021] SCSI subsystem initialized
          [Thu Mar 11 18:57:20 2021] usbcore: registered new interface driver usbfs
          [Thu Mar 11 18:57:20 2021] usbcore: registered new interface driver hub
          [Thu Mar 11 18:57:20 2021] usbcore: registered new device driver usb
          [Thu Mar 11 18:57:20 2021] clocksource: Switched to clocksource arch_sys_counter
          [Thu Mar 11 18:57:21 2021] VFS: Disk quotas dquot_6.6.0
          [Thu Mar 11 18:57:21 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
          [Thu Mar 11 18:57:21 2021] FS-Cache: Loaded
          [Thu Mar 11 18:57:21 2021] CacheFiles: Loaded
          [Thu Mar 11 18:57:21 2021] NET: Registered protocol family 2
          [Thu Mar 11 18:57:21 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
          [Thu Mar 11 18:57:21 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
          [Thu Mar 11 18:57:21 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
          [Thu Mar 11 18:57:21 2021] TCP: Hash tables configured (established 8192 bind 8192)
          [Thu Mar 11 18:57:21 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Thu Mar 11 18:57:21 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
          [Thu Mar 11 18:57:21 2021] NET: Registered protocol family 1
          [Thu Mar 11 18:57:21 2021] RPC: Registered named UNIX socket transport module.
          [Thu Mar 11 18:57:21 2021] RPC: Registered udp transport module.
          [Thu Mar 11 18:57:21 2021] RPC: Registered tcp transport module.
          [Thu Mar 11 18:57:21 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
          [Thu Mar 11 18:57:21 2021] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
          [Thu Mar 11 18:57:21 2021] Initialise system trusted keyrings
          [Thu Mar 11 18:57:21 2021] workingset: timestamp_bits=14 max_order=18 bucket_order=4
          [Thu Mar 11 18:57:21 2021] zbud: loaded
          [Thu Mar 11 18:57:21 2021] FS-Cache: Netfs 'nfs' registered for caching
          [Thu Mar 11 18:57:21 2021] NFS: Registering the id_resolver key type
          [Thu Mar 11 18:57:21 2021] Key type id_resolver registered
          [Thu Mar 11 18:57:21 2021] Key type id_legacy registered
          [Thu Mar 11 18:57:21 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [Thu Mar 11 18:57:21 2021] Key type asymmetric registered
          [Thu Mar 11 18:57:21 2021] Asymmetric key parser 'x509' registered
          [Thu Mar 11 18:57:21 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
          [Thu Mar 11 18:57:21 2021] io scheduler mq-deadline registered
          [Thu Mar 11 18:57:21 2021] io scheduler kyber registered
          [Thu Mar 11 18:57:21 2021] bcm2708_fb soc:fb: FB found 1 display(s)
          [Thu Mar 11 18:57:21 2021] Console: switching to colour frame buffer device 82x26
          [Thu Mar 11 18:57:21 2021] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
          [Thu Mar 11 18:57:21 2021] bcm2835-rng 3f104000.rng: hwrng registered
          [Thu Mar 11 18:57:21 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
          [Thu Mar 11 18:57:21 2021] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
          [Thu Mar 11 18:57:22 2021] brd: module loaded
          [Thu Mar 11 18:57:22 2021] loop: module loaded
          [Thu Mar 11 18:57:22 2021] Loading iSCSI transport class v2.0-870.
          [Thu Mar 11 18:57:22 2021] libphy: Fixed MDIO Bus: probed
          [Thu Mar 11 18:57:22 2021] usbcore: registered new interface driver lan78xx
          [Thu Mar 11 18:57:22 2021] usbcore: registered new interface driver smsc95xx
          [Thu Mar 11 18:57:22 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
          [Thu Mar 11 18:57:22 2021] Core Release: 2.80a
          [Thu Mar 11 18:57:22 2021] Setting default values for core params
          [Thu Mar 11 18:57:22 2021] Finished setting default values for core params
          [Thu Mar 11 18:57:22 2021] Using Buffer DMA mode
          [Thu Mar 11 18:57:22 2021] Periodic Transfer Interrupt Enhancement - disabled
          [Thu Mar 11 18:57:22 2021] Multiprocessor Interrupt Enhancement - disabled
          [Thu Mar 11 18:57:22 2021] OTG VER PARAM: 0, OTG VER FLAG: 0
          [Thu Mar 11 18:57:22 2021] Dedicated Tx FIFOs mode
          [Thu Mar 11 18:57:22 2021] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b7504000 dma = 0xf7504000 len=9024
          [Thu Mar 11 18:57:23 2021] FIQ FSM acceleration enabled for :
                                     Non-periodic Split Transactions
                                     Periodic Split Transactions
                                     High-Speed Isochronous Endpoints
                                     Interrupt/Control Split Transaction hack enabled
          [Thu Mar 11 18:57:23 2021] dwc_otg: Microframe scheduler enabled
          [Thu Mar 11 18:57:23 2021] WARN::hcd_init_fiq:457: FIQ on core 1
          [Thu Mar 11 18:57:23 2021] WARN::hcd_init_fiq:458: FIQ ASM at 807be568 length 36
          [Thu Mar 11 18:57:23 2021] WARN::hcd_init_fiq:497: MPHI regs_base at bb810000
          [Thu Mar 11 18:57:23 2021] dwc_otg 3f980000.usb: DWC OTG Controller
          [Thu Mar 11 18:57:23 2021] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
          [Thu Mar 11 18:57:23 2021] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
          [Thu Mar 11 18:57:23 2021] Init: Port Power? op_state=1
          [Thu Mar 11 18:57:23 2021] Init: Power Port (0)
          [Thu Mar 11 18:57:23 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
          [Thu Mar 11 18:57:23 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
          [Thu Mar 11 18:57:23 2021] usb usb1: Product: DWC OTG Controller
          [Thu Mar 11 18:57:23 2021] usb usb1: Manufacturer: Linux 5.10.17-v7+ dwc_otg_hcd
          [Thu Mar 11 18:57:23 2021] usb usb1: SerialNumber: 3f980000.usb
          [Thu Mar 11 18:57:23 2021] hub 1-0:1.0: USB hub found
          [Thu Mar 11 18:57:23 2021] hub 1-0:1.0: 1 port detected
          [Thu Mar 11 18:57:23 2021] dwc_otg: FIQ enabled
          [Thu Mar 11 18:57:23 2021] dwc_otg: NAK holdoff enabled
          [Thu Mar 11 18:57:23 2021] dwc_otg: FIQ split-transaction FSM enabled
          [Thu Mar 11 18:57:23 2021] Module dwc_common_port init
          [Thu Mar 11 18:57:23 2021] usbcore: registered new interface driver usb-storage
          [Thu Mar 11 18:57:23 2021] mousedev: PS/2 mouse device common for all mice
          [Thu Mar 11 18:57:23 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
          [Thu Mar 11 18:57:23 2021] sdhci: Secure Digital Host Controller Interface driver
          [Thu Mar 11 18:57:23 2021] sdhci: Copyright(c) Pierre Ossman
          [Thu Mar 11 18:57:23 2021] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
          [Thu Mar 11 18:57:23 2021] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
          [Thu Mar 11 18:57:23 2021] sdhci-pltfm: SDHCI platform and OF driver helper
          [Thu Mar 11 18:57:23 2021] ledtrig-cpu: registered to indicate activity on CPUs
          [Thu Mar 11 18:57:23 2021] hid: raw HID events driver (C) Jiri Kosina
          [Thu Mar 11 18:57:23 2021] usbcore: registered new interface driver usbhid
          [Thu Mar 11 18:57:23 2021] usbhid: USB HID core driver
          [Thu Mar 11 18:57:23 2021] Initializing XFRM netlink socket
          [Thu Mar 11 18:57:23 2021] NET: Registered protocol family 17
          [Thu Mar 11 18:57:23 2021] Key type dns_resolver registered
          [Thu Mar 11 18:57:23 2021] Registering SWP/SWPB emulation handler
          [Thu Mar 11 18:57:23 2021] registered taskstats version 1
          [Thu Mar 11 18:57:23 2021] Loading compiled-in X.509 certificates
          [Thu Mar 11 18:57:23 2021] Key type ._fscrypt registered
          [Thu Mar 11 18:57:23 2021] Key type .fscrypt registered
          [Thu Mar 11 18:57:23 2021] Key type fscrypt-provisioning registered
          [Thu Mar 11 18:57:23 2021] uart-pl011 3f201000.serial: cts_event_workaround enabled
          [Thu Mar 11 18:57:23 2021] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
          [Thu Mar 11 18:57:23 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
          [Thu Mar 11 18:57:23 2021] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
          [Thu Mar 11 18:57:23 2021] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
          [Thu Mar 11 18:57:23 2021] sdhost: log_buf @ (ptrval) (f7507000)
          [Thu Mar 11 18:57:23 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
          [Thu Mar 11 18:57:23 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
          [Thu Mar 11 18:57:23 2021] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
          [Thu Mar 11 18:57:23 2021] of_cfs_init
          [Thu Mar 11 18:57:23 2021] of_cfs_init: OK
          [Thu Mar 11 18:57:23 2021] Waiting for root device PARTUUID=9cfaa631-02...
          [Thu Mar 11 18:57:23 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
          [Thu Mar 11 18:57:23 2021] Indeed it is in host mode hprt0 = 00021501
          [Thu Mar 11 18:57:23 2021] random: fast init done
          [Thu Mar 11 18:57:23 2021] mmc0: host does not support reading read-only switch, assuming write-enable
          [Thu Mar 11 18:57:23 2021] mmc0: new high speed SDXC card at address aaaa
          [Thu Mar 11 18:57:23 2021] mmcblk0: mmc0:aaaa SE64G 59.5 GiB
          [Thu Mar 11 18:57:23 2021]  mmcblk0: p1 p2
          [Thu Mar 11 18:57:23 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Mar 11 18:57:23 2021] mmc1: new high speed SDIO card at address 0001
          [Thu Mar 11 18:57:23 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Mar 11 18:57:23 2021] devtmpfs: mounted
          [Thu Mar 11 18:57:23 2021] Freeing unused kernel memory: 1024K
          [Thu Mar 11 18:57:23 2021] usb 1-1: new high-speed USB device number 2 using dwc_otg
          [Thu Mar 11 18:57:23 2021] Indeed it is in host mode hprt0 = 00001101
          [Thu Mar 11 18:57:23 2021] Run /sbin/init as init process
          [Thu Mar 11 18:57:23 2021]   with arguments:
          [Thu Mar 11 18:57:23 2021]     /sbin/init
          [Thu Mar 11 18:57:23 2021]   with environment:
          [Thu Mar 11 18:57:23 2021]     HOME=/
          [Thu Mar 11 18:57:23 2021]     TERM=linux
          [Thu Mar 11 18:57:23 2021] usb 1-1: New USB device found, idVendor=0424, idProduct=9514, bcdDevice= 2.00
          [Thu Mar 11 18:57:23 2021] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
          [Thu Mar 11 18:57:23 2021] hub 1-1:1.0: USB hub found
          [Thu Mar 11 18:57:23 2021] hub 1-1:1.0: 5 ports detected
          [Thu Mar 11 18:57:24 2021] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
          [Thu Mar 11 18:57:24 2021] systemd[1]: System time before build time, advancing clock.
          [Thu Mar 11 18:57:24 2021] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
          [Thu Mar 11 18:57:24 2021] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
          [Thu Mar 11 18:57:24 2021] smsc95xx v2.0.0
          [Thu Mar 11 18:57:24 2021] NET: Registered protocol family 10
          [Thu Mar 11 18:57:24 2021] libphy: smsc95xx-mdiobus: probed
          [Thu Mar 11 18:57:24 2021] Segment Routing with IPv6
          [Thu Mar 11 18:57:24 2021] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:77:4f:95
          [Thu Mar 11 18:57:24 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
          [Thu Mar 11 18:57:24 2021] systemd[1]: Detected architecture arm.
          [Thu Mar 11 18:57:24 2021] systemd[1]: Set hostname to <raspberrypi>.
          [Thu Mar 11 18:57:25 2021] random: systemd: uninitialized urandom read (16 bytes read)
          [Thu Mar 11 18:57:25 2021] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
          [Thu Mar 11 18:57:25 2021] systemd[1]: Created slice User and Session Slice.
          [Thu Mar 11 18:57:25 2021] systemd[1]: Listening on Journal Socket (/dev/log).
          [Thu Mar 11 18:57:25 2021] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
          [Thu Mar 11 18:57:25 2021] systemd[1]: Reached target Slices.
          [Thu Mar 11 18:57:25 2021] systemd[1]: Listening on Journal Socket.
          [Thu Mar 11 18:57:25 2021] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
          [Thu Mar 11 18:57:26 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          [Thu Mar 11 18:57:26 2021] systemd-journald[120]: Received request to flush runtime journal from PID 1
          [Thu Mar 11 18:57:26 2021] mc: Linux media interface: v0.10
          [Thu Mar 11 18:57:26 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu Mar 11 18:57:26 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
          [Thu Mar 11 18:57:26 2021] [vc_sm_connected_init]: start
          [Thu Mar 11 18:57:26 2021] [vc_sm_connected_init]: installed successfully
          [Thu Mar 11 18:57:26 2021] videodev: Linux video capture interface: v2.00
          [Thu Mar 11 18:57:26 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu Mar 11 18:57:26 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
          [Thu Mar 11 18:57:27 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu Mar 11 18:57:27 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu Mar 11 18:57:27 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu Mar 11 18:57:27 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
          [Thu Mar 11 18:57:27 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
          [Thu Mar 11 18:57:27 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
          [Thu Mar 11 18:57:27 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
          [Thu Mar 11 18:57:27 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
          [Thu Mar 11 18:57:27 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
          [Thu Mar 11 18:57:27 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
          [Thu Mar 11 18:57:27 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
          [Thu Mar 11 18:57:27 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
          [Thu Mar 11 18:57:27 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
          [Thu Mar 11 18:57:27 2021] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
          [Thu Mar 11 18:57:27 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
          [Thu Mar 11 18:57:27 2021] usbcore: registered new interface driver brcmfmac
          [Thu Mar 11 18:57:27 2021] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430-sdio.raspberrypi,3-model-b.txt failed with error -2
          [Thu Mar 11 18:57:27 2021] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
          [Thu Mar 11 18:57:27 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Oct 22 2019 01:59:28 version 7.45.98.94 (r723000 CY) FWID 01-3b33decd
          [Thu Mar 11 18:57:29 2021] Under-voltage detected! (0x00050005)
          [Thu Mar 11 18:57:30 2021] uart-pl011 3f201000.serial: no DMA platform data
          [Thu Mar 11 18:57:30 2021] 8021q: 802.1Q VLAN Support v1.8
          [Thu Mar 11 18:57:30 2021] random: crng init done
          [Thu Mar 11 18:57:30 2021] random: 7 urandom warning(s) missed due to ratelimiting
          [Thu Mar 11 18:57:30 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
          [Thu Mar 11 18:57:31 2021] SMSC LAN8700 usb-001:003:01: attached PHY driver [SMSC LAN8700] (mii_bus:phy_addr=usb-001:003:01, irq=POLL)
          [Thu Mar 11 18:57:31 2021] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
          [Thu Mar 11 18:57:31 2021] smsc95xx 1-1.1:1.0 eth0: Link is Down
          [Thu Mar 11 18:57:33 2021] smsc95xx 1-1.1:1.0 eth0: Link is Up - 100Mbps/Full - flow control off
          [Thu Mar 11 18:57:33 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
          [Thu Mar 11 18:57:34 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
          [Thu Mar 11 18:57:34 2021] Bluetooth: Core ver 2.22
          [Thu Mar 11 18:57:34 2021] NET: Registered protocol family 31
          [Thu Mar 11 18:57:34 2021] Bluetooth: HCI device and connection manager initialized
          [Thu Mar 11 18:57:34 2021] Bluetooth: HCI socket layer initialized
          [Thu Mar 11 18:57:34 2021] Bluetooth: L2CAP socket layer initialized
          [Thu Mar 11 18:57:34 2021] Bluetooth: SCO socket layer initialized
          [Thu Mar 11 18:57:34 2021] Bluetooth: HCI UART driver ver 2.3
          [Thu Mar 11 18:57:34 2021] Bluetooth: HCI UART protocol H4 registered
          [Thu Mar 11 18:57:34 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
          [Thu Mar 11 18:57:34 2021] Bluetooth: HCI UART protocol Broadcom registered
          [Thu Mar 11 18:57:35 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
          [Thu Mar 11 18:57:35 2021] Bluetooth: BNEP filters: protocol multicast
          [Thu Mar 11 18:57:35 2021] Bluetooth: BNEP socket layer initialized
          pi@raspberrypi:~ $ iobroker repo list
          default     : http://download.iobroker.net/sources-dist.json
          latest      : http://download.iobroker.net/sources-dist-latest.json
          Active repo: default
          pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          /usr/bin/nodejs
          v12.21.0
          /usr/bin/node
          v12.21.0
          /usr/bin/npm
          6.14.11
          nodejs:
            Installed: 12.21.0-1nodesource1
            Candidate: 12.21.0-1nodesource1
            Version table:
           *** 12.21.0-1nodesource1 500
                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
               10.24.0~dfsg-1~deb10u1 500
          pi@raspberrypi:~ $
          • F Fraenki23
            @thomas-braun Hallo
            Gruß und dank Frank
            login as: pi
            /usr/bin/nodejs
            v12.21.0
            /usr/bin/node
            v12.21.0
            /usr/bin/npm
            6.14.11
            nodejs:
              Version table:
            pi@raspberrypi:~ $
            @fraenki23
            Das Netzteil ist zu schwach auf der Brust.
              @fraenki23
              Fraenki23
              Ja danke das ist ein normales .
              Kann ich auch sehen wieviel Volt das liefert.
              • F Fraenki23
                @fraenki23 was ist ein 'normales' Netzteil?
                  Fraenki23
                  @thomas-braun ein Anker usb Netzteil 5 Volt.
                  möchte es im Magic Mirror direkt mit einem Huschinen Netzteil betreiben.
                  • F Fraenki23
                    wendy2702W Offline
                    wendy2702W Offline
                    @fraenki23 sagte in Iobroker neuinstallation startet nicht:
                    Bestimmt ein Ladegerät und kein richtiges Netzteil.
                    Für den PI ist neben der Spannung auch der Strom wichtig der geliefert werden kann und wie Stabil das Netzteil unter Belastung die 5V halten kann.
                    • wendy2702W wendy2702
                      Fraenki23
                      @wendy2702 Hast recht. Ein Ladegerät
                      Bin mir noch nicht sicher welches HutschinenNetzteil das richtige ist. Nachdem der Raspi 3 funktioniert würde ich alles in den Spiegel packen und dann vom Schaltschrank aus mit Strom versorgen.
                      Hat mir jemand eine Link für ein Netzteil?
                      Danke Frank
                      • F Fraenki23
                        Danke Frank
                        wendy2702W Offline
                        wendy2702W Offline
                        @fraenki23 Ich habe die im Einsatz:
                        https://de.elv.com/search?p=1&ffFollowSearch=9183&ffFilter[attributes-elv-ExtendedSearch]=Regular&q=hutschinen netzteil&o=7&n=24&ffFilter[Ausgangsspannung]=5 V DC
                          Fraenki23
                          @wendy2702 Danke
                          Reicht das 12 Watt Netzteil für den Rasp 3 ?
                          • F Fraenki23
                            @wendy2702 Danke
                            wendy2702W Offline
                            wendy2702W Offline
                            @fraenki23
                            Ich habe zweimal das DR15-5 verbaut.
                            Denke aber das 12 Watt reicht auch.
                              @fraenki23
                              Fraenki23
                              @wendy2702 Danke
                              würde den 15-5 nehemen.
                              Gruß und Dank Frank
