  4. Solarprognose
Solarprognose
solarprognoseadapterjavascript
158 Beiträge 28 Kommentatoren 46.0k Aufrufe 31 Beobachtet
  • Palm_ManiacP Palm_Maniac
    @wendy2702
    Das hier:
    const url = 'http://www.solarprognose.de/web/solarprediction/api/v1?_format=json&access-token=....&item=inverter&id=412&type=hourly';
    const path = '0_userdata.0.SolarGraph.';
    const idLeistung_Energie = path + 'Leistung_Energie';
    const idEnergieMaxHeute = path + 'EnergieMaxHeute';
    const idEnergieMaxMorgen = path + 'EnergieMaxMorgen';
    var Leistung_Energie = {
        "axisLabels": ["8", "9", "10", "11", "12", "13", "14", "15", "16", "17", "18", "8", "9", "10", "11", "12", "13", "14", "15", "16", "17", "18"],
        "graphs": [{
            "data": [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0],
            "type": "line",
            "legendText":"Leistung",
            "yAxis_min": 0,
            "yAxis_max": 8,
            "yAxis_step": 1,
            "yAxis_position": "left",
            "yAxis_appendix": " kW",
            "datalabel_show": false
            "type": "line",
            "line_UseFillColor": true,
            "legendText":"Energie",
            "yAxis_min": 0,
            "yAxis_max": 64,
            "yAxis_step": 8,
            "yAxis_position": "right",
            "yAxis_appendix": " kWh",
            "yAxis_color": "#91d430",
    createState(idLeistung_Energie, JSON.stringify(Leistung_Energie), {type: 'string', name: 'Leistung_Energie', role: 'table'});
    createState(idEnergieMaxHeute, 0, {type: 'number', role: 'value', name: 'EnergieMaxHeute', read: true, write: false, unit: 'kWh'});
    createState(idEnergieMaxMorgen, 0, {type: 'number', role: 'value', name: 'EnergieMaxMorgen', read: true, write: false, unit: 'kWh'});
    schedule('5 7,9,12,14,16,18 * * *', function() {
        request(url, function (error, response, result) {
            if(error) log(error, 'error');
            else {
                let obj = JSON.parse(result);
                if(obj.status) log('Fehler: ' + obj.status, 'warn');
                else {
                    let data = obj.data;
                    Leistung_Energie.axisLabels = [];
                    Leistung_Energie.graphs[0].data = [];
                    Leistung_Energie.graphs[1].data = [];
                    let i = 0;
                    for(let entry in data) {
                        let time = formatDate(parseInt(entry), 'hh');
                        Leistung_Energie.axisLabels.push(time);
                        Leistung_Energie.graphs[0].data.push(data[entry][0]);
                        Leistung_Energie.graphs[1].data.push(data[entry][1]);
                        if (time == '19')
                           if (i == 0) { setState(idEnergieMaxHeute, data[entry][1], true);  i = i+1 }
                           else         setState(idEnergieMaxMorgen, data[entry][1], true);
                    setState(idLeistung_Energie, JSON.stringify(Leistung_Energie), true);
    S
    S
    Streit187
    #87
    @palm_maniac Also ich habe gerade dein Skript genommen und bei mir gestartet. Den schedule abgewartet und alle Datenpunkte wurden wie erwartet angelegt. Damit ist ein Fehler im Skript ausgeschlossen.
    Palm_ManiacP 1 Antwort Letzte Antwort
    • S Streit187
      Palm_ManiacP
      Palm_ManiacP
      Palm_Maniac
      #88
      @streit187
      Das ist doch verrückt. Was läuft denn dann bei mir schief? Ich habe so viele Java- und Blockly Skripte laufen und keins macht Probleme, es ging immer...
      • Palm_ManiacP
        Palm_ManiacP
        Palm_Maniac
        schrieb am zuletzt editiert von Palm_Maniac
        #89
        Ich habe jetzt mal das Skript zwischengespeichert, gelöscht und neu angelegt und was soll ich sagen, jetzt läuft es. Alle Datenpunkte wurden angelegt und gefüllt. Perfekt. Jetzt gehts ans Auswerten und gleich zur nächsten Frage.
        Momentan legt das Skript ja jeden Tag extra und immer wieder neu an. Ich habe zur Zeit den kostenlosen Zugang mit den Prognosen für heute und morgen. Damit man z.b. Grafana drauf los lassen kann, wäre es besser wenn es konstante Datenpunkte gäbe, die immer aktualisiert werden, also z.b. wie heute anstatt der Anlage 03-10 und 03-11 einfach nur "Heute" und Morgen". Dann kann man versuchen es irgendwie in Grafana einzubringen und müßte nicht jeden Tag Hand anlegen. Interessant sind ja nur der aktuelle Tag und die Zukunft, nicht das was Gestern war.
        Wo und wie müßte man denn dann im Skript Hand anlegen?
        Nutz hier jemand Grafana und hat die Prognosedaten dort eingebunden? Wenn ja wie, denn über die InfluxDB wirds schwierig.
          S
          S
          Streit187
          #90
          @palm_maniac Das von dir verwendete Skript legt doch bereits Datenpunkte mit heute und morgen gefolgt von der Uhrzeit an. Hast du dann nicht was du brauchst? Sieht das bei dir nicht wie auf dem folgenden Bild aus?
          • Palm_ManiacP
            Palm_ManiacP
            Palm_Maniac
            #91
            @streit187
            Ja, aber da das Datum als Datenpunktname genutzt wird, ist in dem von mir geposteten Skript so, hatte ich erwartet, das morgen eine neue Gruppe unter 03_12 angelegt wird. Das wäre extrem Mühsam da eine Auswertung, egal mit welchem Programm, durchzuführen. Da steckt mein Problem.
              @streit187
              S
              S
              Streit187
              #92
              @palm_maniac Auch wenn sich mir der Sinn nicht erschließt weshalb ich heute die Prognosedaten von gestern behalten sollte würde deine Erwartung dich ja mit Datenpunkten "zumüllen".
              Wenn du aber die Daten von gestern usw. haben möchtest musst du die Datenpunkte aufzeichnen sprich den History Adapter, Datenbank etc. einschalten.
              • S Streit187
                Palm_ManiacP
                Palm_ManiacP
                Palm_Maniac
                #93
                @streit187
                Nein, das ist ja meine Rede, ich brauche die alten Daten nicht, aber das Skript wird sie erzeugen, deshalb meine Frage wo man das Skript abändern kann/muß, damit nur diese 2 Datenpunkte angelegt und zukünftig aktualisiert werden.
                  @streit187
                  S
                  S
                  Streit187
                  #94
                  @palm_maniac Nein, das tut das Skript nicht. Morgen ist Morgen heute und übermorgen morgen. Es bleibt bei diesen beiden Ordnern mit den dazugehörigen Datenpunkten und die Werte werden genau so aktualisiert wie du es brauchst.
                  • S Streit187
                    Palm_ManiacP
                    Palm_ManiacP
                    Palm_Maniac
                    #95
                    @streit187
                    Schau mal:
                    let time = formatDate(parseInt(entry), 'MM-DD.hh:mm');
                                        if(existsState(idLeistung + time)) setState(idLeistung + time, data[entry][0], true);
                                        else createState(idLeistung + time, data[entry][0], {
                                            type: 'number',
                                            role: 'value',
                                            name: 'Solarleistung ' + formatDate(parseInt(entry), 'DD.MM. hh:mm'),
                                            read: true,
                                            write: false,
                                            unit: 'kW'
                    Hier wird doch das Datum geparst und weiter unten in den Namen/Pfad eingebaut, was doch dazu führt, dass immer neue Ordner entstehen nach dem Schema 03-10, 03-11, 03-12 usw. Die Begriffe "Heute" und "Morgen" tauchen in diesem Skript nicht auf, so würde es mir aber reichen.
                    Oder verstehe ich das Skript da falsch?
                      @streit187
                      Schau mal:
                                              type: 'number',
                                              role: 'value',
                                              read: true,
                                              write: false,
                                              unit: 'kW'
                      S
                      S
                      Streit187
                      #96
                      @palm_maniac Wo kommt denn dieser Code her? Der ist nicht Bestandteil von deinem Ursprünglichen Skript in https://forum.iobroker.net/topic/37314/solarprognose/73.
                      • S Streit187
                        Palm_ManiacP
                        Palm_ManiacP
                        Palm_Maniac
                        #97
                        @streit187
                        Doch, hab gerade nochmal nachgeschaut.
                        • Palm_ManiacP
                          Palm_ManiacP
                          Palm_Maniac
                          #98
                          Skript läuft jetzt mit HEUTE und MORGEN. Jetzt muß ich nur noch irgendwie die Daten in meine Grafana-Darstellung bekommen, dann ist es Perfekt. :)
                          • GarganoG
                            GarganoG
                            Gargano
                            #99
                            @palm_maniac sagte in Solarprognose:
                            Würde mich auch interessieren, wie das geht, die Daten von Morgen in Grafana
                            • GarganoG Gargano
                              Palm_ManiacP
                              Palm_ManiacP
                              Palm_Maniac
                              #100
                              @gargano
                              Ja, das Hauptproblem ist der Zeitstempel, damit fällt eigentlich InfluxDB raus. Eventuell wäre es besser die Daten als JSON zubekommen, denn dafür gäbe es etwas für Grafana.
                              GarganoG 1 Antwort Letzte Antwort
                                @gargano
                                GarganoG
                                GarganoG
                                Gargano
                                #101
                                @palm_maniac Ich hab das JSON-Chart vom Scrounger verwendet. Das geht auch in die Zukunft, weil man die X-Achse mit angeben kann.
                                • GarganoG Gargano
                                  Palm_ManiacP
                                  Palm_ManiacP
                                  Palm_Maniac
                                  #102
                                  @gargano Damit haben wir die Daten aber noch nicht in Grafana. Ich habe es schon direkt versucht, das JSON-Plugin in Grafana stört sich aber an den Infos, die vor den Daten gesendet werden. Zumindest habe ich es nicht hinbekommen, ich bekam nur Fehlermeldungen beim Test.
                                    GarganoG
                                    GarganoG
                                    Gargano
                                    schrieb am zuletzt editiert von Gargano
                                    #103
                                    @palm_maniac Wie hast Du das denn gemacht mit der JSON API ? Welche Einstellung in den Datasources ?
                                    • GarganoG Gargano
                                      Palm_ManiacP
                                      Palm_ManiacP
                                      Palm_Maniac
                                      #104
                                      @gargano Mit der hab ich es auch nicht hinbekommen, mir fehlen da genauso wie dir die richtigen Einstellungen. Da meckert er schon beim Verbindungstest bei mir.
                                        @babl sagte in Solarprognose:
                                        schaut doch gut aus.
                                        Dann hier ein komplettes Script, das jede Stunde von 4:16 Uhr bis 22:16 Uhr die Daten holt:
                                        const url = 'hier die komplette URL eintragen';
                                        const path = '0_userdata.0.Solar.';
                                        const idLeistung = path + 'Leistung.';
                                        const idEnergie  = path + 'Energie.';
                                        schedule('16 4-22 * * *', function() {
                                                else {
                                                    else {
        type: 'number',
        role: 'value',
        read: true,
        write: false,
        unit: 'kW'
                                                            if(existsState(idEnergie + time)) setState(idEnergie + time, data[entry][1], true);
                                                            else createState(idEnergie + time, data[entry][1], {
        type: 'number',
        role: 'value',
        name: 'Solarenergie ' + formatDate(parseInt(entry), 'DD.MM. hh:mm'),
        read: true,
        write: false,
        unit: 'kWh'
                                        B
                                        B
                                        babl
                                        #105
                                        @paul53 sagte in Solarprognose:
                                                else {
                                                    else {
        type: 'number',
        role: 'value',
        read: true,
        write: false,
        unit: 'kW'
        type: 'number',
        role: 'value',
        read: true,
        write: false,
        unit: 'kWh'
                                        @paul53 könntest du mir vielleicht behilflich sein, da bei diesem Script nach dem update auf die neusten versionen genau der fehler kommt.
                                        Read-only state "0_userdata.0.Solar.Leistung.morgen_21:00" has been written without ack-flag with value "0"
                                        Oder wie muß ich hier das script abändern damit die einträge im log weg sind.
                                        Ansonsten läuft das Script hervorragend. Danke dir.
                                        • B babl
                                                  else {
                                                      else {
        type: 'number',
        role: 'value',
        read: true,
        write: false,
        unit: 'kW'
        type: 'number',
        role: 'value',
        read: true,
        write: false,
        unit: 'kWh'
                                          paul53P
                                          paul53P
                                          #106
                                          @babl sagte: der fehler kommt.
                                          Der Fehler dürfte nicht kommen, da der Datenpunkt mit ack = true geschrieben wird (Zeile 16).
                                          Produktiv: Asus PN42: N100 / 8 GB / 500 GB; Proxmox mit 2 VM (ioBroker / openCCU)
                                          84.2k
