  4. iobroker fehler bei installation
26 Beiträge 4 Kommentatoren 2.8k Aufrufe 3 Beobachtet
  • eule66E Offline
    eule66E Offline
    eule66
    Hallo Zusammen
    habe iobroker gerade auf einen rock64 installiert, Grundsystem ist ein Armbian 21.02.03
    bekomme bei der Installation folgenden Fehler, an was kann das liegen?
    Danke für eure Rückmeldung
    root@rock64:~# node -v
    v12.21.0
    root@rock64:~# nodejs -v
    v12.21.0
    root@rock64:~# npm -v
    6.14.11
    root@rock64:~# curl -sLf https://iobroker.net/install.sh | bash -
    library: loaded
    Library version=2021-01-23
        Welcome to the ioBroker installer!
        Installer version: 2020-12-07
        Installing prerequisites (1/4)
    Hit:1 http://security.debian.org buster/updates InRelease
    Hit:2 http://deb.debian.org/debian buster InRelease
    Hit:3 http://deb.debian.org/debian buster-updates InRelease
    Hit:4 http://deb.debian.org/debian buster-backports InRelease
    Hit:5 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:6 https://armbian.systemonachip.net/apt buster InRelease
    Reading package lists... Done
    Changing npm registry to https://registry.npmjs.org
    Installed acl
    Installed gcc-c++
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
    Installed python-dev
        Creating ioBroker user and directory (2/4)
    User iobroker created
    Directory /opt/iobroker created
        Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:56,
                     from ../src/main.cpp:3:
    /root/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
           (node::addon_register_func) (regfunc),                          \
    /root/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
       NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(diskusage, Init)
                     from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(unix_dgram, Initialize)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSe );
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGe );
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
       uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
     SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
     SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:56,
                     from ../src/./serialport.h:6,
                     from ../src/serialport.cpp:1:
    /root/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
     NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    • eule66E eule66
      Hallo Zusammen
      v12.21.0
      v12.21.0
      6.14.11
      library: loaded
      Installed acl
      Installed gcc-c++
      @eule66 sagte in iobroker fehler bei installation:
      daran, dass das keine Fehler sind -> ignorieren
      • eule66E eule66
        Hallo Zusammen
        v12.21.0
        v12.21.0
        6.14.11
        library: loaded
        Installed acl
        Installed gcc-c++
        Am root-login...
        Keine Fehler zu sehen, man installiert es trotzdem nicht als root.
          Am root-login...
          @thomas-braun sagte in iobroker fehler bei installation:
          Am root-login...
          Dabei zwingt auch Armbian inzwischen den User einen Normalo-User anzulegen und fordert auf, sich danach als dieser anzumelden 😂
            Am root-login...
            @homoran Das habe ich ganz stark vermutet, das ist ja auch durch die Bank so üblich bei allem was mit *bian zutun hat.
            Im Gegensatz zum root-Login, das ist ganz und gar unüblich und falsch.
            eule66E 1 Antwort Letzte Antwort
              eule66E Offline
              eule66E Offline
              eule66
              schrieb am zuletzt editiert von eule66
              Ok alles klar, hatte das Problem das iobroker nicht erreichbar war. bin dann die Seite durchgegangen was ist wenn iobroker nicht erreichbar ist und das Ergebnis war der admin Adapter war nicht installiert. Habe dann auf Port 8091 einen neuen angelegt, dann konnte ich iobroker über den Browser erreichen habe einen neuen admin installiert und den 8091 gelöscht.
              Sollte ich nochmal von vorne anfangen und iobroker unter den angelegten Benutzer neu installieren?
              wendy2702W Thomas BraunT HomoranH 3 Antworten Letzte Antwort
              • eule66E eule66
                wendy2702W Offline
                wendy2702W Offline
                @eule66 Vielleicht besser.
                Und spar dir die manuelle Installation von Node und NPM.
                Das wird automatisch durch den installer erledigt.
                • eule66E eule66
                  Ich würd's auch von vorneherein ordentlich machen.
                  • eule66E eule66
                    das ist aber wirklich strange!
                    der admin ist Standard
                      Vielleicht hatte das Modul noch den root als owner und kann dann vom user iobroker nicht angefasst werden. :-)
                      eule66E HomoranH 2 Antworten Letzte Antwort
                        eule66E Offline
                        eule66E Offline
                        eule66
                        Ok alles klar ich Bügel morgen nochmal armbian neu drauf und dann wechsel ich den Benutzer und lege neu los.
                        Grund warum ich das eigentlich gemacht habe, war weil ich nur Probleme mit jarvis hatte welches andauernd einen red screen brachte und erhoffe mir durch eine neuinstallation Besserung.
                          ich hab schon ewig nicht mehr iobroker als root installiert. Ganz früher war das notwendig und hält sich immer noch.
                          Wobei es auch unter root installierbar sein sollte.
                          ich habe gar nicht vor sooo langer Zeit nochmal einen Rock64 aufgesetzt, aus dem Nichts - ohne Probleme
                          @eule66
                          Einfach nur armbian - da werden die locales und Zeitzonen jetzt sogar während der Installation abgefragt - anschließend ein Userwechsel, dann sudo apt update && sudo apt upgrade und dann nur noch den Einzeiler curl -sLf https://iobroker.net/install.sh | bash -
                          Danach muss iobroker laufen
                            @eule66
                            eule66E Offline
                            eule66E Offline
                            eule66
                            @homoran hab es genauso gemacht.
                            Zeitzonen und de_de wurde auch abgefragt
                            • eule66E eule66
                              @eule66 Kann nicht sein. Dann wäre /root nicht genutzt worden.
                                eule66E Offline
                                eule66E Offline
                                eule66
                                Hab nur nicht den benutzerwechsel vollzogen
                                • eule66E eule66
                                  de_de
                                  hast du hoffentlich utf-8 genommen, nicht das seltsame, was da alternativ war
                                    de_de
                                    eule66E Offline
                                    eule66E Offline
                                    eule66
                                    @homoran nein glaube de_De hab ich genommen kam mir am besten vor
                                    Edit habe es eben neu aufgesetzt ausgewählt habe ich de_De_utf8
                                    • eule66E eule66
                                      eule66E Offline
                                      eule66E Offline
                                      eule66
                                      So alles läuft wieder danke
                                      • eule66E eule66
                                        @eule66
                                        Hast du es jetzt anders gemacht und der admin war sofort vorhanden?
                                          @eule66
                                          eule66E Offline
                                          eule66E Offline
                                          eule66
                                          @thomas-braun hab wahrscheinlich den reboot zu früh durchgeführt die Installation war noch nicht fertig denke ich.
                                          Ansonsten hätte ich noch ne Frage :ich muss jetzt zum Beispiel bei sudo reboot das passwort eingeben ist das so i.o?
