  4. Zigbee Adapter startet nicht
    6.6k
30 Beiträge 5 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • C consoleman
    ich hoffe mir kann jemand helfen..... Habe heute meinen CC2531 Stick erhalten und wollte den Zigbee Adapter installieren. Das hat auch geklappt, nur leider startet der nicht mit folgendem Log:
    ioBroker läuft auf einem RPi 3
    host.raspberrypi 2021-03-09 15:50:25.285 error instance system.adapter.zigbee.0 terminated with code 1 ()
    Caught 2021-03-09 15:50:25.285 error by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:520:3)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:528:12)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module.load (internal/modules/cjs/loader.js:589:32)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:689:10)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module._compile (internal/modules/cjs/loader.js:678:30)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js:29:54)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at require (internal/modules/cjs/helpers.js:20:18)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module.require (internal/modules/cjs/loader.js:626:17)
    Caught 2021-03-09 15:50:25.283 error by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:497:25)
    Caught 2021-03-09 15:50:25.283 error by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:571:15)
    Caught 2021-03-09 15:50:25.283 error by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/exitCodes'
    Caught 2021-03-09 15:50:25.283 error by controller[0]: ^
    Caught 2021-03-09 15:50:25.283 error by controller[0]: throw err;
    Caught 2021-03-09 15:50:25.281 error by controller[0]: internal/modules/cjs/loader.js:573
    Ich bin nicht wirklich der Linux Held und hilflos....
    arteckA Offline
    arteckA Offline
    arteck
    @consoleman sagte in Zigbee Adapter startet nicht:
    und meine Glaskugel ist zur Zeit zur politur...
    • AsgothianA Asgothian
      @consoleman
      • Bitte Logs immer in code Tags (</>) setzen
      • Welchen Adapter hast du installiert (version) ?
      • Welches OS ?
      • Welche NodeJS Version
      • Welche JS Controller version
      • Gab es Meldungen bei der Installation ?
      A.
      consoleman
      @asgothian said in Zigbee Adapter startet nicht:
      @consoleman
      • Welches OS ?
      A.
      Sorry, war nicht mein Plan jemanden zu ärgern.
      Adapter Version 1.4.4
      Raspberian auf RPi3
      NodeJS 10.0.0
      So wie es aussieht ist der JS Controller nicht installiert?
        @consoleman
        • Welches OS ?
        A.
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        @asgothian sagte in Zigbee Adapter startet nicht:
        Diese Beiden Fragen solltest Du noch beantworten.
        Wenn Du keinen JS Controller hast läuft dein ioBroker nicht.
        Wenn Du Node 10.0.0 hast dann stimmt da auch was nicht.
        A.
        • C consoleman
          @consoleman
          • Welches OS ?
          A.
          Raspberian auf RPi3
          NodeJS 10.0.0
          @consoleman
          iobroker -v
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          Bei dem Nickname dürfte die Bedienung via shell ja kein Thema sein.
          C 1 Antwort Letzte Antwort
            @consoleman
            iobroker -v
            consoleman
            schrieb am zuletzt editiert von consoleman
            nodejs:
              Installed: 10.24.0-1nodesource1
              Candidate: 10.24.0-1nodesource1
              Version table:
             *** 10.24.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x stretch/main armhf Packages
                 8.11.1~dfsg-2~bpo9+1 500
                    500 http://archive.raspberrypi.org/debian stretch/main armhf Packages     4.8.2~dfsg-1 500
                    500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
            Iobroker 1.5.14
            • C consoleman
              6.4.1
              nodejs:
                Version table:
              Iobroker 1.5.14
              @consoleman das ist aber nicht der vollständige Output
                consoleman
                /usr/bin/nodejs
                v10.24.0
                /home/pi/.nvm/versions/node/v10.15.2/bin/node
                v10.15.2
                /home/pi/.nvm/versions/node/v10.15.2/bin/npm
                6.4.1
                nodejs:
                  Version table:
                • C consoleman
                  /usr/bin/nodejs
                  v10.24.0
                  v10.15.2
                  6.4.1
                  nodejs:
                    Version table:
                  @consoleman Node-Installation ist komplett krumm.
                    consoleman
                    @thomas-braun said in Zigbee Adapter startet nicht:
                    Ok, wie behebe ich das?
                    • C consoleman
                      @consoleman
                      https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                      Oder durch den Werkzeugkasten aus meiner Signatur buddeln.
                        @consoleman
                        consoleman
                        Ok.... aber was genau meinst du mit "krumm", grundsätzlich läuft ja iobroker und Homebridge Problemlos.
                        • C consoleman
                          @consoleman
                          Trotzdem krumm. Hast du das HowTo gelesen? Da steht drin wie das richtig aussehen muss.
                            @consoleman
                            consoleman
                            usr/bin/nodejs
                            v12.21.0
                            /usr/bin/node
                            v12.21.0
                            /usr/bin/npm
                            7.6.2
                            nodejs:
                              Installed: 12.21.0-1nodesource1
                              Candidate: 12.21.0-1nodesource1
                              Version table:
                             *** 12.21.0-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                            Besser oder?
                            Mein Problem mit dem Zigbee Adapter hat es jedoch nicht gelöst.
                            Gibt es weitere Tipps?
                            • C consoleman
                              usr/bin/nodejs
                              v12.21.0
                              /usr/bin/node
                              v12.21.0
                              /usr/bin/npm
                              7.6.2
                              nodejs:
                                Version table:
                              Besser oder?
                              @consoleman
                              npm dürfte nicht 7 sein
                              Und du hast ernsthaft einen 1er ioBroker?
                              iobroker -v
                                @consoleman
                                iobroker -v
                                consoleman
                                pi@raspberrypi:~ $ iobroker -v
                                1.5.14
                                • C consoleman
                                  1.5.14
                                  @consoleman Mittlerweile sind wir bei 3.2.16
                                  Bring das System in die Jetzt-Zeit. Mit npm@6.
                                    consoleman
                                    was genau meinst du mit npm@6 ?
                                    • C consoleman
                                      @consoleman Deine Version von npm ist zu neu, die funktioniert mit ioBroker noch nicht vernünftig. Installier eine Version aus der 6er-Reihe.
                                      Reinstall von node über apt spült automatisch eine passende Version auf das System.
                                      Wenn das sauber ist installier iobroker 3.2.16
                                        consoleman
                                        Das iobroker Update läuft nicht durch.... 1000 Fehler. Kein Bock mehr
                                        arteckA HomoranH 2 Antworten Letzte Antwort
                                        • C consoleman
                                          arteckA Offline
                                          arteckA Offline
                                          arteck
                                          @consoleman ach komm. ist halt ein lebends system.. das braucht zeit :-)
                                          also was sagt das LOG.. dass das Update fehler schmeisst ist normal.. ist ja nicht NUR für dein System geschrieben
