  4. Zigbee Adapter startet nicht
    6.6k
30 Beiträge 5 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • C Offline
    consoleman
    schrieb am zuletzt editiert von consoleman
    ich hoffe mir kann jemand helfen..... Habe heute meinen CC2531 Stick erhalten und wollte den Zigbee Adapter installieren. Das hat auch geklappt, nur leider startet der nicht mit folgendem Log:
    ioBroker läuft auf einem RPi 3
    host.raspberrypi 2021-03-09 15:50:25.285 error instance system.adapter.zigbee.0 terminated with code 1 ()
    Caught 2021-03-09 15:50:25.285 error by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:520:3)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:528:12)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module.load (internal/modules/cjs/loader.js:589:32)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:689:10)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module._compile (internal/modules/cjs/loader.js:678:30)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/@iobroker/adapter-core/build/index.js:29:54)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at require (internal/modules/cjs/helpers.js:20:18)
    Caught 2021-03-09 15:50:25.284 error by controller[0]: at Module.require (internal/modules/cjs/loader.js:626:17)
    Caught 2021-03-09 15:50:25.283 error by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:497:25)
    Caught 2021-03-09 15:50:25.283 error by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:571:15)
    Caught 2021-03-09 15:50:25.283 error by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/exitCodes'
    Caught 2021-03-09 15:50:25.283 error by controller[0]: ^
    Caught 2021-03-09 15:50:25.283 error by controller[0]: throw err;
    Caught 2021-03-09 15:50:25.281 error by controller[0]: internal/modules/cjs/loader.js:573
    Ich bin nicht wirklich der Linux Held und hilflos....
    AsgothianA arteckA 2 Antworten Letzte Antwort
    • C consoleman
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @consoleman
      • Bitte Logs immer in code Tags (</>) setzen
      • Welchen Adapter hast du installiert (version) ?
      • Welches OS ?
      • Welche NodeJS Version
      • Welche JS Controller version
      • Gab es Meldungen bei der Installation ?
      A.
      C AsgothianA 2 Antworten Letzte Antwort
      • C consoleman
        arteckA Offline
        arteckA Offline
        arteck
        @consoleman sagte in Zigbee Adapter startet nicht:
        und meine Glaskugel ist zur Zeit zur politur...
        • AsgothianA Asgothian
          @consoleman
          • Welches OS ?
          A.
          consoleman
          @asgothian said in Zigbee Adapter startet nicht:
          @consoleman
          • Welches OS ?
          A.
          Sorry, war nicht mein Plan jemanden zu ärgern.
          Adapter Version 1.4.4
          Raspberian auf RPi3
          NodeJS 10.0.0
          So wie es aussieht ist der JS Controller nicht installiert?
            @consoleman
            • Welches OS ?
            A.
            AsgothianA Offline
            AsgothianA Offline
            Asgothian
            @asgothian sagte in Zigbee Adapter startet nicht:
            Diese Beiden Fragen solltest Du noch beantworten.
            Wenn Du keinen JS Controller hast läuft dein ioBroker nicht.
            Wenn Du Node 10.0.0 hast dann stimmt da auch was nicht.
            A.
            • C consoleman
              @consoleman
              • Welches OS ?
              A.
              Raspberian auf RPi3
              NodeJS 10.0.0
              @consoleman
              iobroker -v
              which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              Bei dem Nickname dürfte die Bedienung via shell ja kein Thema sein.
              C 1 Antwort Letzte Antwort
                @consoleman
                iobroker -v
                consoleman
                nodejs:
                  Installed: 10.24.0-1nodesource1
                  Candidate: 10.24.0-1nodesource1
                  Version table:
                 *** 10.24.0-1nodesource1 500
                        500 https://deb.nodesource.com/node_10.x stretch/main armhf Packages
                     8.11.1~dfsg-2~bpo9+1 500
                        500 http://archive.raspberrypi.org/debian stretch/main armhf Packages     4.8.2~dfsg-1 500
                        500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
                Iobroker 1.5.14
                • C consoleman
                  6.4.1
                  nodejs:
                    Version table:
                  Iobroker 1.5.14
                  @consoleman das ist aber nicht der vollständige Output
                    consoleman
                    /usr/bin/nodejs
                    v10.24.0
                    /home/pi/.nvm/versions/node/v10.15.2/bin/node
                    v10.15.2
                    /home/pi/.nvm/versions/node/v10.15.2/bin/npm
                    6.4.1
                    nodejs:
                      Version table:
                    • C consoleman
                      /usr/bin/nodejs
                      v10.24.0
                      v10.15.2
                      6.4.1
                      nodejs:
                        Version table:
                      @consoleman Node-Installation ist komplett krumm.
                        consoleman
                        @thomas-braun said in Zigbee Adapter startet nicht:
                        Ok, wie behebe ich das?
                        • C consoleman
                          @consoleman
                          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                          Oder durch den Werkzeugkasten aus meiner Signatur buddeln.
                            @consoleman
                            consoleman
                            Ok.... aber was genau meinst du mit "krumm", grundsätzlich läuft ja iobroker und Homebridge Problemlos.
                            • C consoleman
                              @consoleman
                              Trotzdem krumm. Hast du das HowTo gelesen? Da steht drin wie das richtig aussehen muss.
                                @consoleman
                                consoleman
                                usr/bin/nodejs
                                v12.21.0
                                /usr/bin/node
                                v12.21.0
                                /usr/bin/npm
                                7.6.2
                                nodejs:
                                  Installed: 12.21.0-1nodesource1
                                  Candidate: 12.21.0-1nodesource1
                                  Version table:
                                 *** 12.21.0-1nodesource1 500
                                        500 https://deb.nodesource.com/node_12.x stretch/main armhf Packages
                                Besser oder?
                                Mein Problem mit dem Zigbee Adapter hat es jedoch nicht gelöst.
                                Gibt es weitere Tipps?
                                • C consoleman
                                  usr/bin/nodejs
                                  v12.21.0
                                  /usr/bin/node
                                  v12.21.0
                                  /usr/bin/npm
                                  7.6.2
                                  nodejs:
                                    Version table:
                                  Besser oder?
                                  @consoleman
                                  npm dürfte nicht 7 sein
                                  Und du hast ernsthaft einen 1er ioBroker?
                                  iobroker -v
                                    @consoleman
                                    iobroker -v
                                    consoleman
                                    pi@raspberrypi:~ $ iobroker -v
                                    1.5.14
                                    • C consoleman
                                      1.5.14
                                      @consoleman Mittlerweile sind wir bei 3.2.16
                                      Bring das System in die Jetzt-Zeit. Mit npm@6.
                                        consoleman
                                        was genau meinst du mit npm@6 ?
                                        • C consoleman
                                          @consoleman Deine Version von npm ist zu neu, die funktioniert mit ioBroker noch nicht vernünftig. Installier eine Version aus der 6er-Reihe.
                                          Reinstall von node über apt spült automatisch eine passende Version auf das System.
                                          Wenn das sauber ist installier iobroker 3.2.16
